is possible to change serial log level? for exmaple I don't want see this:
Send: [53 55 50 4C 41 ]
20:33:25.549 -> Recv: [53 55 50 4C 41 10 96 00 00 00 32 00 00 00 10 00 00 00 86 BF F7 63 00 00 00 00 58 20 02 00 00 00 00 00 53 55 50 4C 41 ]
20:33:50.448 -> Send: [53 55 50 4C 41 10 71 01 00 00 28 00 00 00 10 00 00 00 4C 0D 00 00 00 00 00 00 10 BB 01 00 00 00 00 00 ]
20:33:50.448 -> Send: [53 55 50 4C 41 ]
Is it possible?
serial log level
- Has thanked: 134 times
On linux based compilation you can change log level in config (see: https://github.com/SUPLA/supla-device/t ... -log_level ).micdj wrote: Thu Feb 23, 2023 7:36 pm is possible to change serial log level? for exmaple I don't want see this:
Is it possible?
Those logs are currently printed with "debug" level, however I will change it to "verbose" log level. Commit is on the main branch already, but not released officially yet. So if you use github you can pull latest version. If you use i.e. Arduino library manager, you'll have to wait for new version official release to get this log at "verbose" level.
On any other target, you have to change code to disable this log level. Please check this file: https://github.com/SUPLA/supla-device/b ... pper.h#L50
If you'll move this line above "if def", it will cut off all verbose logs.
You can also disable this particular log, by commenting it out from source code:
https://github.com/SUPLA/supla-device/b ... k.cpp#L170
