Udało się
* Supla.org NodeMCU WiFi minimal example
* Author: Programistyk - Kamil Kaminski <[email protected]>
* This example shows how to configure SuplaDevice for building for NodeMCU within Arduino IDE
int button1 = 0; //set value in button 1
#include <srpc.h>
#include <log.h>
#include <eh.h>
#include <proto.h>
#include <IEEE754tools.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <lck.h>
#include <DHT.h>
#include <WiFiClient.h>
#include <ESP8266WiFiType.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiScan.h>
#include <ESP8266WiFiMulti.h>
#include <WiFiServer.h>
#include <ESP8266WiFiGeneric.h>
#include <WiFiClientSecure.h>
#include <ESP8266WiFiAP.h>
#include <ESP8266WiFiSTA.h>
#include <WiFiUdp.h>
WiFiClient client;
const char* ssid = "MyWiFiNetwork";
const char* password = "MyWiFiPassword";
void setup() {
Serial.begin(115200);
pinMode(16,INPUT_PULLUP);
char GUID[SUPLA_GUID_SIZE] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uint8_t mac[6] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
// Przekaźniki
SuplaDevice.addRelay(5);
SuplaDevice.addRelay(4);
mac, // Ethernet MAC address
"svr1.supla.org", // SUPLA server address
0, // Location ID
""); // Location Password
void loop() {
SuplaDevice.iterate();
TSD_SuplaChannelNewValue value1; //Set value name
value1.SenderID = 0; // Notify other users that your smartphone opens a blind. In case of actuators is to be 0
value1.ChannelNumber = 3; // Need enter the relay channel number
value1.DurationMS = 0; //turn on time
button1 = digitalRead(16);
if(digitalRead(16)==LOW){
value1.value[0] = !value1.value[0];
SuplaDevice.channelSetValue(&value1);
while(digitalRead(16)==LOW);
delay(20);
if ( size > 0 ) {
return client.read((uint8_t *)buf, size);}
return -1;}
return client.write((const uint8_t *)buf, count);}
return client.connect(server, 2015);}
return client.connected();}
client.stop();}
WiFi.begin(ssid, password);
delay(500);}}
SuplaDeviceCallbacks cb;
cb.get_temperature = NULL;
cb.get_rgbw_value = NULL;
cb.set_rgbw_value = NULL;
return cb;
