how to in new supla device, with old rolleshutters functions
micdj
Hello! I hope you someone can help me to transfer in new library all the functions i used before.
For example, if I want know the rolleshutter is in movement, before was:
if (SuplaDevice.rollerShutterMotorIsOn(0))
and now?
I tr to understand class definiitons and i think is
if (Supla::Control::RollerShutter::inMove())
but doensn't work
thank you to someone can help me
Has thanked: 136 times
micdj wrote: Sun Jan 22, 2023 1:44 pm and now?
inMove is a protected method, so it can be called only by class methods.
You can use getCurrentDirection() method which is public. It returns:
0 - STOP
1 - DOWN
2 - UP
This method can be called only on an instance of a RollerShutter class (or on a pointer pointing on that instance).
You can store pointer to a roller shutter instance and then use it, i.e.:
// global definition
Supla::Control::RollerShutter *rs1;
// in setup
rs1 = new Supla::Control::RollerShutter(....);
// in setup or in loop methods:
if (rs1->getCurrentDirection() != 0) {
  // in move
} else {
  // stop
micdj
thank you for aswer, and how to implement thif old funcitons?
SuplaDevice.setStatusFuncImpl(&status_func);
  SuplaDevice.setRollerShutterFuncImpl(&supla_rs_SavePosition, &supla_rs_LoadPosition, &supla_rs_SaveSettings, &supla_rs_LoadSettings);
  SuplaDevice.setName(nomechar);
micdj wrote: Tue Feb 21, 2023 5:47 pm thank you for aswer, and how to implement thif old funcitons?
setStatusFuncImpl was left as it was in older version.
setName also.
Saving and restoring roller shutter position is handled in Supla::Storage classes. You can check RollerShutter example in SuplaDevice, here is relevant part of code:
// Choose where Supla should store roller shutter data in persistant memory
// We recommend to use external FRAM memory
#define STORAGE_OFFSET 100
#include <supla/storage/eeprom.h>
Supla::Eeprom eeprom(STORAGE_OFFSET);
// #include <supla/storage/fram_spi.h>
// Supla::FramSpi fram(STORAGE_OFFSET);
You can adjust storage offset to other value if you use "eeprom" class in your sketch.
micdj
yes I know that now rollershutters uses storage class, but for obviously reason, in old library i used setStatusFuncImpl to save in FS position and close/open time.
I see in public class this functions that I see are for position and open/close time
void onLoadState() override;
  void onSaveState() override;
Can I use them? How? Can you explain me please?
micdj wrote: Thu Feb 23, 2023 4:50 pm yes I know that now rollershutters uses storage class, but for obviously reason, in old library i used setStatusFuncImpl to save in FS position and close/open time.
"setStatusFuncImpl" is a callback executed when device status changes, i.e. to "registered" or "disconnected" state. I'm not sure how and why you would like to use it for storing roller shutter open/close time.
RollerShutter use "onLoadState" and "onSaveState" methods to load and save their state, like: position, close/open time. They are called automatically, when Storage class instance is configured. However I don't recommend to use them for any custom storage, because they are part of procedures used in Supla::Storage class. I.e. during startup onSaveState is called before onLoadState - it is called "dry run" without actual write to storage, but it is used to calculate storage section size.
It will be easier to help if you share some more details on what and how you want to do, or if you share your "old code".
micdj
In my old code, I share some info as position, close/open time and some others, with my mqtt server, ios and android app, so commands are always specular, if I give supla command, I see in real time, for example, the position of rollershutter on my app and vice-versa, To do this in old code I used "setStatusFuncImpl" to take supla status connection and send the info to mqtt server
void status_func(int status, const char *msg) {
  s = status;
To take variables of position, and config close/open time, I used "setStatusFuncImpl" as:
.......... supla declarations.....
void supla_rs_SavePosition(int channelNumber, int position) {
  intlivello = position;
  if ((!digitalRead(relay_1)) && (!digitalRead(relay_2))) {
    inttmp0 = position;
    savers0 = true;
  if (position <= 100 || position >= 10100) {
    inttmp0 = position;
    SuplaDevice.rollerShutterStop(0);
    savers0 = true;
  void supla_rs_LoadPosition(int channelNumber, int *position) {
  //SuplaDevice.StopTimer();
  readPosFile();
   position = intlivello;
  //EEPROM.get(2, *position);
  Serial.print("read position R1: ");
  Serial.println(*position);
  //intlivello = *position;
  //Serial.println(intlivello);
  motoron = true;
  //SuplaDevice.StartTimer();
  void supla_rs_SaveSettings(int channelNumber, unsigned int full_opening_time, unsigned int full_closing_time) {
  full_opening_time = full_opening_time / 1000;
  full_closing_time = full_closing_time / 1000;
  String(full_opening_time).toCharArray(tempochar, 4);
  String(full_closing_time).toCharArray(tempochar2, 4);
  Serial.println(tempochar);
  Serial.println(tempochar2);
  if (writeConfigFile()) {
    publishTime1 = true;
    publishTime2 = true;
    EEPROM.put(50, full_opening_time);
    EEPROM.put(55, full_closing_time);
    EEPROM.commit();
  void supla_rs_LoadSettings(int channelNumber, unsigned int *full_opening_time, unsigned int *full_closing_time) {
  //EEPROM.get(50, *full_opening_time);
  //EEPROM.get(55, *full_closing_time);
  readConfigFile();
  Serial.println("sono nel ciclo supla");
   full_opening_time = tempo * 1000;
   full_closing_time = tempo2 * 1000;
  Serial.print("read R1--channel: "); Serial.print((channelNumber)); Serial.print(" opening_time "); Serial.print((*full_opening_time)); Serial.print(" closing_time "); Serial.println((*full_closing_time));
so I can share variables with mqtt server topics.
micdj wrote: Sun Feb 26, 2023 1:42 pm In my old code, I share some info as position, close/open time and some others, with my mqtt server, ios and android app, so commands are always specular, if I give supla command, I see in real time, for example, the position of rollershutter on my app and vice-versa, To do this in old code I used "setStatusFuncImpl" to take supla status connection and send the info to mqtt server
I just added to library getters for closing and opening time. I think that easiest way to get data from roller shutter instance is to read those values from object.
I.e.
Supla::Control::RollerShutter *rs1 = nullptr;
// in setup
rs1 = new RollerShutter(....);
// in loop
uint32_t closingTime = rs1->getClosingTimeMs();
uint32_t openingTime = rs1->getOpeningTimeMs();
// do_something_with(closingTime, openingTime);
auto pos = rs1->getCurrentPosition();
For "status" I already wrote that this method was left as it was in older library, so you can use it in the same way.
micdj
Great!!! Thank you for your fast mod!!
I Will try next days to upgrade my code.
radzik_r
Been thanked: 2 times
klew wrote: Mon Jan 23, 2023 11:00 am
0 - STOP
1 - DOWN
2 - UP
// in setup
  // in move
} else {
  // stop
I use for 12 blinds with my TFT like this
int aktualny_ruch_rolety_[12] = { -2, -2, -2, -2, -2, -2, -2, -2, -2, -2, -2, -2};
for (int i = 0; i < 12; i++) {
  if (aktualny_ruch_rolety_[i] != ROLLER_SHUTTER_[i]->getCurrentDirection()) {
    aktualny_ruch_rolety_[i] = ROLLER_SHUTTER_[i]->getCurrentDirection();
    tft.setCursor(kolumna2, wiersz_[i]);
    tft.setTextColor(ST7735_ORANGE, ST7735_BLACK);
    switch (ROLLER_SHUTTER_[i]->getCurrentDirection()) {
      case 0: tft.print("STOP     "); break;
      case 1: tft.print("DOWN     "); break;
      case 2: tft.print(" UP      "); break;
Return to “Help”
