Natywne wsparcie dla MQTT
daw34
U mnie działa musiałem na nowo uruchomić Mosquitto broker a następnie wczytać ponownie integracje mqtt. (albo zatrzymać całkowicie i następnie uruchomić) mi pomogło
krzakx
No nie dobrze ... u mnie nie działa.
W logach mosquito tylko timeout:
2023-04-13 12:59:13: Connecting bridge bridge-bxxxxxxxxxx (mqtt80.supla.org:8883)
2023-04-13 12:59:13: mosquitto version 2.0.15 running
2023-04-13 12:59:15: New connection from 127.0.0.1:59742 on port 1883.
2023-04-13 12:59:15: Expiring client local.core-mosquitto.bridge-bmZfy83DfDY7bDzE due to timeout
Co może oznaczać ten timeout?
A czy macie podobne ostrzeżenie w Logach systemu HA?
Logger: homeassistant.components.sensor
Source: components/sensor/__init__.py:497
Integration: Sensor (documentation, issues)
First occurred: April 13, 2023 at 2:42:35 PM (4 occurrences)
Last logged: 10:08:18 AM
Entity sensor.electricity_meter_total_cost_balanced (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) is using state class 'measurement' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
Entity sensor.electricity_meter_total_cost (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) is using state class 'measurement' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
Podłącz się MQTT Explorerem do Twojego brokera i sprawdź czy widać tam topiki pochodzące z cloud-a.
tomkowski
Has thanked: 2 times
daw34 wrote: Thu Apr 13, 2023 1:05 pm U mnie działa musiałem na nowo uruchomić Mosquitto broker a następnie wczytać ponownie integracje mqtt. (albo zatrzymać całkowicie i następnie uruchomić) mi pomogło
Jest jakiś problem z ostatnią aktualizacja add-ona.
Działa tak mniej więcej co drugi restart;).
Dla tych, których dotyka problem - spróbujcie zmienić nazwę pliku bridge.conf na mosquito.conf.
jaku2k
@pzygmunt Czy moglibyście zmienić udostępniane opcje kanału otwierania drzwi do Home Assistanta?
Obecnie w Home Assistancie mogę sterować nim jak roletą (otwórz/zatrzymaj/zamknij). W przypadku suplowych kanałów otwierania drzwi/furtki takie opcje nie mają sensu - impuls jest wysyłany jeden raz - nie da się go "zatrzymać".
Może wystarczyłoby udostępniać ten typ kanału jako Button?
Wiem, że obecna konfiguracja pokazuje otwieranie drzwi jako otwieranie drzwi. Dostępne w HA opcje sterowania drzwiami sugerują jednak, że rozwiązanie różni się od suplowego.
Jakub
Nie możemy tego zmienić z uwagi na już istniejące integracje.
Drzwi są w Supli udostępniane do HA?
jaku2k
klew wrote: Fri Apr 28, 2023 8:38 am Drzwi są w Supli udostępniane do HA?
Tak. Chodzi o kanał Otwieranie drzwi
Jakub
Nie mogę tego zmienić na tym etapie.
Tak
Return to “MQTT”
