https://github.com/SUPLA/supla-device/b ... 2023-05-25
Zapraszam na
Błąd generowania
lib/SuplaDeviceExtensions/src/supla/control/ButtonAnalog.cpp: In member function 'virtual void Supla::Control::ButtonAnalog::onTimer()':
lib/SuplaDeviceExtensions/src/supla/control/ButtonAnalog.cpp:40:38: error: 'bistable' was not declared in this scope; did you mean 'isBistable'?
40 | if (stateResult == TO_PRESSED || bistable) {
| isBistable
lib/SuplaDeviceExtensions/src/supla/control/ButtonAnalog.cpp:46:10: error: 'bistable' was not declared in this scope; did you mean 'isBistable'?
46 | if (!bistable && stateResult == PRESSED) {
| isBistable
lib/SuplaDeviceExtensions/src/supla/control/RFBridgeReceive.cpp: In member function 'virtual void Supla::Control::RFBridgeReceive::onTimer()':
lib/SuplaDeviceExtensions/src/supla/control/RFBridgeReceive.cpp:114:38: error: 'bistable' was not declared in this scope; did you mean 'isBistable'?
114 | if (stateResult == TO_PRESSED || bistable) {
| isBistable
lib/SuplaDeviceExtensions/src/supla/control/RFBridgeReceive.cpp:120:10: error: 'bistable' was not declared in this scope; did you mean 'isBistable'?
120 | if (!bistable && stateResult == PRESSED) {
| isBistable
Multiple libraries were found for "SoftwareSerial.h"
Used: .arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/SoftwareSerial
Not used: /var/www/html/github/GUI-Generic/lib/espsoftwareserial
xxxxxxxxxxxxxxxxxx
BOARD esp8266:esp8266:generic:eesz=1M64,xtal=160
BOARD_NAME Gosund SP111 v1.1
TEMPLATE_JSON GOSUND_SP111_V1_1
JSON_DEFINITION NAME:Gosund SP111 v1.1 GPIO:[56 0 158 0 132 134 0 0 131 17 0 21 0]
OPTIONS -DTEMPLATE_JSON=\"{\\\"NAME\\\":\\\"Gosund SP111 v1.1\\\",\\\"GPIO\\\":[56,0,158,0,132,134,0,0,131,17,0,21,0]}\" -DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL
-DBEARSSL_SSL_BASIC -DSUPLA_BUTTON -DSUPLA_CONFIG -DSUPLA_ENABLE_GUI -DSUPLA_HLW8012 -DSUPLA_LED -DSUPLA_OTA -DSUPLA_RELAY -DTEMPLATE_BOARD_JSON
Możesz wesprzeć autorów w dalszym rozwoju projektu.
Postaw nam kawę na buycoffee.to Przekaż darowiznę za pomocą przycisku PayPal
SPI Flash Config:
Crystal Freq: 26MHz
SPI Speed: 40MHz
SPI Mode: DOUT
Flash size ESP82xx: 8Mbit
Flash size ESP32: 32Mbit
(8Mbit = 1MB)
GUI-Generic Builder
GUI-Generic: v6.1.0; Builder: v4.22.1
Board ESP8266: v3.0.2; Board ESP32: v2.0.4
Wideo poradnikWideo poradnik
Przewodnik online 📖https://forum.supla.orghttps://forum.supla.org
Uploader dwuetapowyUploader dwuetapowy (bin.gz)
Ustawienia kompilacji
Płytka
Gosund SP111 v1.1
Procesor
ESP8266
Częstotliwość procesora 160 MHz dla ESP82xx
Pamięć FLASH
1MB (FS:64KB OTA:~470KB)
Dostępne opcje dla modułu
Podstawowe
Konfiguracja (LED, Config)
Aktualizacja przez WWW
Dostępne GUI podczas pracy modułu
Szyfrowane połączenie z serwerem (SSL)
Tryb głębokiego uśpienia (Deep Sleep)
Wake on LAN
Sterowanie
Przekaźniki
Przyciski
Wyzwalacze akcji
Rolety
Krańcówki
Warunkowanie
LED załączenia przekaźnika
Pushover
Linki bezpośrednie
Bramka RF 315/433MHz
Ekspandery
MCP23017
PCF8575
PCF8574/A
1Wire
Sensor DS18B20
Sensor DHT11
Sensor DHT22
Sensor Si7021 Sonoff
I2C
Sensor BME280
Sensor BMP280
Sensor SHT3x
Sensor SHTxx
Sensor Si7021
Sensor VL53L0X
Sensor HDC1080
Wyświetlacz OLED SSD1306, SH1106
Wyświetlacz LCD HD44780
Sensor BH1750
Sensor MAX4400Ok, na szybko spojrzałem i wygląda dobrze tylko nie możesz zmieniać długości KEY_ACTIVE_SENSOR bo rozjadą się stare konfigurację tam już się osiągnęło maxa sensorów. Tutaj niestety należało by powołać nowy klucz KEY_ACTIVE_SENSOR_2 lub KEY_SENSOR_I2C i tam przechowywać nowe sensory.
Jak widać, nie wystarczy tylko podmienić bibliotekiYepestis wrote: Thu Jun 08, 2023 7:28 pm Wybrałem SP111 v1.1 bez żadnych dodatkowych opcji
Błąd generowania lib/SuplaDeviceExtensions/src/supla/control/ButtonAnalog.cpp: In member function 'virtual void Supla::Control::ButtonAnalog::onTimer()': lib/SuplaDeviceExtensions/src/supla/control/ButtonAnalog.cpp:40:38: error: 'bistable' was not declared in this scope; did you mean 'isBistable'? 40 | if (stateResult == TO_PRESSED || bistable) { | ^~~~~~~~ | isBistable lib/SuplaDeviceExtensions/src/supla/control/ButtonAnalog.cpp:46:10: error: 'bistable' was not declared in this scope; did you mean 'isBistable'? 46 | if (!bistable && stateResult == PRESSED) { | ^~~~~~~~ | isBistable lib/SuplaDeviceExtensions/src/supla/control/RFBridgeReceive.cpp: In member function 'virtual void Supla::Control::RFBridgeReceive::onTimer()': lib/SuplaDeviceExtensions/src/supla/control/RFBridgeReceive.cpp:114:38: error: 'bistable' was not declared in this scope; did you mean 'isBistable'? 114 | if (stateResult == TO_PRESSED || bistable) { | ^~~~~~~~ | isBistable lib/SuplaDeviceExtensions/src/supla/control/RFBridgeReceive.cpp:120:10: error: 'bistable' was not declared in this scope; did you mean 'isBistable'? 120 | if (!bistable && stateResult == PRESSED) { | ^~~~~~~~ | isBistable Multiple libraries were found for "SoftwareSerial.h" Used: .arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/SoftwareSerial Not used: /var/www/html/github/GUI-Generic/lib/espsoftwareserial Error during build: exit status 1 xxxxxxxxxxxxxxxxxx BOARD esp8266:esp8266:generic:eesz=1M64,xtal=160 BOARD_NAME Gosund SP111 v1.1 TEMPLATE_JSON GOSUND_SP111_V1_1 JSON_DEFINITION NAME:Gosund SP111 v1.1 GPIO:[56 0 158 0 132 134 0 0 131 17 0 21 0] OPTIONS -DTEMPLATE_JSON=\"{\\\"NAME\\\":\\\"Gosund SP111 v1.1\\\",\\\"GPIO\\\":[56,0,158,0,132,134,0,0,131,17,0,21,0]}\" -DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL -DBEARSSL_SSL_BASIC -DSUPLA_BUTTON -DSUPLA_CONFIG -DSUPLA_ENABLE_GUI -DSUPLA_HLW8012 -DSUPLA_LED -DSUPLA_OTA -DSUPLA_RELAY -DTEMPLATE_BOARD_JSON Możesz wesprzeć autorów w dalszym rozwoju projektu. Postaw nam kawę na buycoffee.to Przekaż darowiznę za pomocą przycisku PayPal SPI Flash Config: Crystal Freq: 26MHz SPI Speed: 40MHz SPI Mode: DOUT Flash size ESP82xx: 8Mbit Flash size ESP32: 32Mbit (8Mbit = 1MB) GUI-Generic Builder GUI-Generic: v6.1.0; Builder: v4.22.1 Board ESP8266: v3.0.2; Board ESP32: v2.0.4 Wideo poradnikWideo poradnik Przewodnik online 📖https://forum.supla.orghttps://forum.supla.org Uploader dwuetapowyUploader dwuetapowy (bin.gz) Ustawienia kompilacji Płytka Gosund SP111 v1.1 Procesor ESP8266 Częstotliwość procesora 160 MHz dla ESP82xx Pamięć FLASH 1MB (FS:64KB OTA:~470KB) Dostępne opcje dla modułu Podstawowe Konfiguracja (LED, Config) Aktualizacja przez WWW Dostępne GUI podczas pracy modułu Szyfrowane połączenie z serwerem (SSL) Tryb głębokiego uśpienia (Deep Sleep) Wake on LAN Sterowanie Przekaźniki Przyciski Wyzwalacze akcji Rolety Krańcówki Warunkowanie LED załączenia przekaźnika Pushover Linki bezpośrednie Bramka RF 315/433MHz Ekspandery MCP23017 PCF8575 PCF8574/A 1Wire Sensor DS18B20 Sensor DHT11 Sensor DHT22 Sensor Si7021 Sonoff I2C Sensor BME280 Sensor BMP280 Sensor SHT3x Sensor SHTxx Sensor Si7021 Sensor VL53L0X Sensor HDC1080 Wyświetlacz OLED SSD1306, SH1106 Wyświetlacz LCD HD44780 Sensor BH1750 Sensor MAX4400
Nie ma problemu poczekamy, każdy ma swoje prywatne życiekrycha88 wrote: Thu Jun 08, 2023 7:45 pm Jak widać, nie wystarczy tylko podmienić bibliotekibęde musiał wycofać zmiany bo nie mam czasu na naprawę.
Błąd generowania
| isBistable
| isBistable
| isBistable
| isBistable
xxxxxxxxxxxxxxxxxx
BOARD_NAME Sonoff Basic
TEMPLATE_JSON SONOFF_BASIC
JSON_DEFINITION NAME:Sonoff Basic GPIO:[17 255 255 255 255 0 0 0 21 56 255 0 0]
OPTIONS -DTEMPLATE_JSON=\"{\\\"NAME\\\":\\\"Sonoff Basic\\\",\\\"GPIO\\\":[17,255,255,255,255,0,0,0,21,56,255,0,0]}\" -DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL
-DBEARSSL_SSL_BASIC -DSUPLA_BUTTON -DSUPLA_CONFIG -DSUPLA_ENABLE_GUI -DSUPLA_LED -DSUPLA_OTA -DSUPLA_RELAY -DTEMPLATE_BOARD_JSON
