hello
i have successfully uploaded the roller shutter code using gui generic builder
but i am stuck in settings of roller shutting in cfg mode using 192.168.4.1
i want the functionality like SRW-01 module but for DC motor project
Relay settings are working fine but iam stuck in button settings
using two buttons one for up and other for down but button settings not working like srw-01.
steps i followed:
once the page visible i mentioned 1 in roller shutter quantity then save
then go to device settings
in Relay - Quantity 2 and selected the desired gpios
in button - quantity 2
Button 1.setting button nr 1.
a . internal pull check
b. reverse logic check
c. On Press
d. open or close
Button 2. setting for button stop (which shown by automatically in cfg mode i.e. for stop)
a. internal up check
b. reverse logic
c. on Press
(i dont want extra button to stop the roller)
Button 3 setting button nr 2
a. internal pull up check
I have attached the screenshots please look at it.
Doubt.
1. do i need to use resistor in button .
2. what is the correct setting for 2 buttons one for going up another one for going down in cfg settings
Reply would be highly appreciated
Best Regards to all
stuck on roller shutter esp8266 setting in cfg mode
- Has thanked: 134 times
I'm not very familiar with how it is done in Gui Generic.
If I remember correcly, you should select there 2 buttons. On first button configure it as "move up or move down" and second button automatically be configured.
Stop button may be left as not used.
workatforce
klew wrote: Thu Aug 31, 2023 8:19 pmI'm not very familiar with how it is done in Gui Generic.
But it is working with 1 button only that is going up and there is no way to bring the roller down.
Please let me know the other way around
Thankyou for the reply
You have to set button count to 2. Then configure first button on GPIOx with action "move up or move down". Then button "stop" set as "disabled", and for button 2 configure its GPIO.workatforce wrote: Fri Sep 01, 2023 1:41 amklew wrote: Thu Aug 31, 2023 8:19 pmI'm not very familiar with how it is done in Gui Generic.
With those settings it should work properly.
workatforce
button 2 not working at all and there is no option to disable the stop button .klew wrote: Fri Sep 01, 2023 7:40 amYou have to set button count to 2. Then configure first button on GPIOx with action "move up or move down". Then button "stop" set as "disabled", and for button 2 configure its GPIO.workatforce wrote: Fri Sep 01, 2023 1:41 amklew wrote: Thu Aug 31, 2023 8:19 pm
workatforce
workatforce wrote: Sat Sep 02, 2023 12:09 pmbutton 2 not working at all and there is no option to disable the stop button .klew wrote: Fri Sep 01, 2023 7:40 amYou have to set button count to 2. Then configure first button on GPIOx with action "move up or move down". Then button "stop" set as "disabled", and for button 2 configure its GPIO.workatforce wrote: Fri Sep 01, 2023 1:41 am
Thankyou Problem solved gui builder working perfectly but there is a glitch while using gui builder i had selected only roller shutter so few setting not working internally then i had selected all the options in control section of gui builder and flash memory 4 mb VOILA.... worked perfectly
Thankyou for your time. Best Wishes
