Obydwie centrale zachowują się tak samo czyli TIMEOUT ......
256 łączona po lokalnym wifi lub przez zewn IP, brak jakiejkolwiek integracji
128 tylko po lokalnym (brak zew. IP), port zmieniony na 7095 w Satelu i w kodzie, HA wyłączony
Co ciekawe przy obydwu coś się zadziało (był jednocześnie włączony dloadx i SateIntegrator): coś się wysypało, zerwał połączenie a na telefonie wyskoczył komunikat, coś w stylu "Możliwa nieciągłość komunikatów"
Connected to Supla Server
22:13:44.278 -> Send: [53 55 50 4C 41 14 28 00 00 00 45 00 00 00 42 03 00 00 6C 69 6D 2E 6A 61 63 65 6B 40 67 6D 61 69 6C 2E 63 6F 6D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C4 91 37 41 3E 9A 26 2C 0A 54 59 D2 53 B3 5B 8B 51 C9 32 01 06 A7 34 0F 55 1F 98 AF 43 96 8D 75 53 55 50 4C 41 2D 45 53 50 38 32 36 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
22:13:44.559 -> Send: [53 55 50 4C 41 ]
22:13:44.605 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:13:55.207 -> Recv: [53 55 50 4C 41 14 01 00 00 00 46 00 00 00 07 00 00 00 03 00 00 00 78 14 01 53 55 50 4C 41 ]
22:13:55.207 -> Device registered (activity timeout 120 s, server version: 20, server min version: 1)
22:13:55.253 -> Changing activity timeout to 30
22:13:55.253 -> Send: [53 55 50 4C 41 14 29 00 00 00 D2 00 00 00 01 00 00 00 1E ]
22:13:55.347 -> Send: [53 55 50 4C 41 ]
22:13:55.394 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:14:06.013 -> Recv: [53 55 50 4C 41 14 02 00 00 00 DC 00 00 00 03 00 00 00 1E 0A F0 53 55 50 4C 41 ]
22:14:06.013 -> Activity timeout set to 30 s
22:14:06.013 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:14:16.608 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:14:27.201 -> Send: [53 55 50 4C 41 14 2A 00 00 00 28 00 00 00 10 00 00 00 71 02 00 00 00 00 00 00 F5 14 0A 00 00 00 00 00 ]
22:14:27.295 -> Send: [53 55 50 4C 41 ]
22:14:27.387 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:14:37.961 -> Connecting without certificate validation (INSECURE)
22:14:38.008 -> Establishing encrypted connection with: svrXX.supla.org (port: 2016)
22:14:39.028 -> Connected to Supla Server
22:14:39.028 -> Send: [53 55 50 4C 41 14 2B 00 00 00 45 00 00 00 42 03 00 00 6C 69 6D 2E 6A 61 63 65 6B 40 67 6D 61 69 6C 2E 63 6F 6D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C4 91 37 41 3E 9A 26 2C 0A 54 59 D2 53 B3 5B 8B 51 C9 32 01 06 A7 34 0F 55 1F 98 AF 43 96 8D 75 53 55 50 4C 41 2D 45 53 50 38 32 36 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
22:14:39.259 -> Send: [53 55 50 4C 41 ]
22:14:39.307 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:14:49.943 -> Recv: [53 55 50 4C 41 14 01 00 00 00 46 00 00 00 07 00 00 00 03 00 00 00 78 14 01 53 55 50 4C 41 ]
22:14:49.943 -> Device registered (activity timeout 120 s, server version: 20, server min version: 1)
22:14:49.943 -> Changing activity timeout to 30
22:14:49.943 -> Send: [53 55 50 4C 41 14 2C 00 00 00 D2 00 00 00 01 00 00 00 1E ]
22:14:50.081 -> Send: [53 55 50 4C 41 ]
22:14:50.127 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:15:00.729 -> Recv: [53 55 50 4C 41 14 02 00 00 00 DC 00 00 00 03 00 00 00 1E 0A F0 53 55 50 4C 41 ]
22:15:00.775 -> Activity timeout set to 30 s
22:15:00.775 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:15:11.365 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:15:21.950 -> Send: [53 55 50 4C 41 14 2D 00 00 00 28 00 00 00 10 00 00 00 A8 02 00 00 00 00 00 00 C9 64 06 00 00 00 00 00 ]
22:15:22.042 -> Send: [53 55 50 4C 41 ]
22:15:22.042 -> Tx: FE FE 7E FF 50 8C FE 0D TIMEOUT
22:15:32.646 -> Connecting without certificate validation (INSECURE)
22:15:32.646 -> Establishing encrypted connection with: svrXX.supla.org (port: 2016)
22:15:33.662 -> Connected to Supla Server
22:15:33.662 -> Send: [53 55 50 4C 41 14 2E 00 00 00 45 00 00 00 42 03 00 00 6C 69 6D 2E 6A 61 63 65 6B 40 67 6D 61 69 6C 2E 63 6F 6D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C4 91 37 41 3E 9A 26 2C 0A 54 59 D2 53 B3 5B 8B 51 C9 32 01 06 A7 34 0F 55 1F 98 AF 43 96 8D 75 53 55 50 4C 41 2D 45 53 50 38 32 36 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
22:15:33.940 -> Send: [53 55 50 4C 41 ]
22:15:33.986 -> Tx: FE FE 7E FF 50 8C FE 0D
