Supla with Home assistant error
moravec.frantisek
I am using mqtt just for Victron as integration from HACS nothing more. So i could use both methots.
So i chouse integration to supla broker
Really i just need one working methot.
Thank U!!!
I don't know what Victron is but I assume it connects to the local MQTT broker to which the HA is connected. Is it correct ?
moravec.frantisek
Victron is solar system and it is not using mqtt broker. It is integration. So i could use both methots for supla.
Then I suggest using the simplest method.
https://en-forum.supla.org/viewtopic.ph ... 22#p161922
moravec.frantisek
Ok. But how? Because it is not working. Where is problem?
I unninstall mosquito broker and now i am trying integration but it is not working
What do you see when you connect with MQTT Explorer? What devices do you have connected to the Supla cloud? What do you see in the Home Assistant logs?
moravec.frantisek
Here is a MQTT Exploler
Support for HA discovery does not include valves. This means that HA will not automatically create the appropriate entities. You need to add them manually.
moravec.frantisek
Do you know how?
moravec.frantisek
ok. I connect another devices ROW-02 and it is working perfect. Thank U. I do not know that Valves is not supported. four days i spent on it...:-D
One more qustion... How can i add Valve? I do not know how to do it.
Thank U
Return to “Help”
