You need to add appropriate entries to configuration.yml.
You should consider what kind of device this valve should be visible in the HA and what functions it should have.
Supla with Home assistant error
moravec.frantisek
Yes i know that theori but i hope that may U will have any pies of code for valves…
moravec.frantisek
mqtt:
- switch:
unique_id: Valve_switch
name: "Water Valve switc"
state_topic: "**********************************************"
command_topic: "**********************************************"
availability:
- topic: "*************************"
payload_on: "ON"
payload_off: "OFF"
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 0
retain: true
- switch:
availability:
payload_on: "ON"
payload_off: "OFF"
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 0
retain: true
moravec.frantisek
i do not know what to set here:
availability:
availability:
- Been thanked: 59 times
state_topic: "supla/988d8c3e919ea6b60c5ea0e8c2b865d6/devices/4277/channels/8463/state/closed"
command_topic: "supla/988d8c3e919ea6b60c5ea0e8c2b865d6/devices/4277/channels/8463/execute_action"
payload_on: "CLOSE"
payload_off: "OPEN"
state_on: "true"
state_off: "false"
retain: false
availability:
- topic: supla/988d8c3e919ea6b60c5ea0e8c2b865d6/devices/4277/channels/8463/state/connected
- payload_available: "true"
- payload_not_available: "false"
More or less. I may have made a mistake in copying the IDs from your screenshot.
payload_on: "CLOSE"
payload_off: "OPEN"
state_on: "true"
state_off: "false"
retain: false
availability:
moravec.frantisek
So like that:
mqtt:
switch:
unique_id: Water Valve switch
payload_on: "CLOSE"
payload_off: "OPEN"
state_on: "true"
state_off: "false"
retain: false
availability:
mqtt:
switch:
payload_on: "CLOSE"
payload_off: "OPEN"
state_on: "true"
state_off: "false"
retain: false
availability:
moravec.frantisek
Something is wrong...any idea?
moravec.frantisek
Now its aviable but open and close do not work.
Mybey comman line change execute_action to set?
