Dzięki już sprawdzam.
GUI Generic - Błąd generowania
@krycha88 dalej błąd, coś takiego.
Błąd generowania
In file included from GUI-Generic_bv5.2_gv7.5.16_pl_85d54313ab3969e152ed42255e39f9d7/src/sensor/DirectLinks.h:24,
from GUI-Generic_bv5.2_gv7.5.16_pl_85d54313ab3969e152ed42255e39f9d7/GUI-Generic_bv5.2_gv7.5.16_pl_85d54313ab3969e152ed42255e39f9d7.ino:38:
GUI-Generic_bv5.2_gv7.5.16_pl_85d54313ab3969e152ed42255e39f9d7/src/sensor/pressure.h:24: warning: "PRESSURE_NOT_AVAILABLE" redefined
24 | #define PRESSURE_NOT_AVAILABLE -1
In file included from lib/SuplaDevice/src/supla/sensor/BME280.h:25,
from GUI-Generic_bv5.2_gv7.5.16_pl_85d54313ab3969e152ed42255e39f9d7/SuplaDeviceGUI.h:88,
from GUI-Generic_bv5.2_gv7.5.16_pl_85d54313ab3969e152ed42255e39f9d7/GUI-Generic_bv5.2_gv7.5.16_pl_85d54313ab3969e152ed42255e39f9d7.ino:16:
lib/SuplaDevice/src/supla/sensor/therm_hygro_press_meter.h:24: note: this is the location of the previous definition
24 | #define PRESSURE_NOT_AVAILABLE -1.0
GUI-Generic_bv5.2_gv7.5.16_pl_85d54313ab3969e152ed42255e39f9d7/src/display/SuplaOled.cpp: In function 'void displayThermostat(OLEDDisplay*, OLEDDisplayUiState*, int16_t, int16_t)':
GUI-Generic_bv5.2_gv7.5.16_pl_85d54313ab3969e152ed42255e39f9d7/src/display/SuplaOled.cpp:382:48: error: 'relay' is not a member of 'Supla::GUI'
382 | if (getCountActiveThermostat() < Supla::GUI::relay.size()) {
Multiple libraries were found for "SoftwareSerial.h"
Used: /var/www/html/github/GUI-Generic/lib/EspSoftwareSerial
Not used: /var/www/html/github/GUI-Generic/lib/EspSoftwareSerial
Not used: .arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/SoftwareSerial
xxxxxxxxxxxxxxxxxx
BOARD esp8266:esp8266:generic:eesz=4M1M,xtal=160
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL -DSUPLA_ACTION_TRIGGER -DSUPLA_BME280 -DSUPLA_BUTTON -DSUPLA_CONFIG -DSUPLA_DIRECT_LINKS_MULTI_SENSOR
-DSUPLA_DS18B20 -DSUPLA_ENABLE_GUI -DSUPLA_LCD_HD44780 -DSUPLA_OLED -DSUPLA_OTA
Błąd generowania
xxxxxxxxxxxxxxxxxx
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
Przed chwilą poszło wygląda że już jest ok.
No raczej do końca nie jest ok. Nadal błędy generowania. Zmieniłem płytkę na ESP32 Dev Module i jest to samo.
Zauważyłem ,że jak jest zaznaczona funkcja Warunkowanie to wyrzucają błędy generowania , czy to dla ESP8266 czy dla ESP32. Jak nie zaznaczę funkcji Warunkowania to plik generuje się prawidłowo. Sprawdzałem wielokrotnie.
- Has thanked: 5 times
- Been thanked: 14 times
Jak już pokazuje ci się błąd, to dobrze jest go tu wkleić, dla @krycha88 bedzie prościej.
GUI-Generic_bv5.2_gv7.5.17_pl_6ea3cbe672e1d1ba1269c301f71d9261/SuplaDeviceGUI.cpp: In function 'void Supla::GUI::addHLW8012(int8_t, int8_t, int8_t)':
GUI-Generic_bv5.2_gv7.5.17_pl_6ea3cbe672e1d1ba1269c301f71d9261/SuplaDeviceGUI.cpp:769:3: error: 'eeprom' was not declared in this scope; did you mean 'Eeprom'?
769 | eeprom.setStateSavePeriod(TIME_SAVE_PERIOD_IMPULSE_COUNTER_SEK * 1000);
| Eeprom
xxxxxxxxxxxxxxxxxx
BOARD esp8266:esp8266:generic:eesz=1M64,xtal=160
BOARD_NAME Gosund SP111 v1.1
TEMPLATE_JSON GOSUND_SP111_V1_1
JSON_DEFINITION NAME:Gosund SP111 v1.1 GPIO:[56 0 158 0 132 134 0 0 131 17 0 21 0]
OPTIONS -DTEMPLATE_JSON=\"{\\\"NAME\\\":\\\"Gosund SP111 v1.1\\\",\\\"GPIO\\\":[56,0,158,0,132,134,0,0,131,17,0,21,0]}\" -DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL
-DBEARSSL_SSL_BASIC -DSUPLA_ACTION_TRIGGER -DSUPLA_BUTTON -DSUPLA_CONFIG -DSUPLA_ENABLE_GUI -DSUPLA_HLW8012 -DSUPLA_LED -DSUPLA_OTA -DSUPLA_RELAY
-DTEMPLATE_BOARD_JSON
Czy jest szansa aby funkcjonalność Warunkowania można było znowu wgrywać? Bez tego to słabo widzę kolejny projekt.
GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd/GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd.ino: In function 'void setup()':
GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd/GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd.ino:149:90: error: no matching function for call to 'addConditionsSensor(sensorList, const char [12], Supla::Sensor::Binary*&, uint8_t&)'
149 | Supla::GUI::Conditions::addConditionsSensor(SENSOR_BINARY, S_LIMIT_SWITCH, binary, nr);
In file included from GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd/SuplaDeviceGUI.h:60,
from GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd/GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd.ino:16:
GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd/SuplaConditions.h:143:6: note: candidate: 'void Supla::GUI::Conditions::addConditionsSensor(int, const char*, Supla::ChannelElement*, uint8_t)'
143 | void addConditionsSensor(int functionSensor, const char* nameSensor, Supla::ChannelElement* sensor, uint8_t nrSensor = 0);
GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd/SuplaConditions.h:143:93: note: no known conversion for argument 3 from 'Supla::Sensor::Binary*' to 'Supla::ChannelElement*'
GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd/SuplaConditions.h:144:6: note: candidate: 'void Supla::GUI::Conditions::addConditionsSensor(int, const char*, Supla::Sensor::ElectricityMeter*, uint8_t)'
144 | void addConditionsSensor(int functionSensor, const char* nameSensor, Supla::Sensor::ElectricityMeter* electricityMete, uint8_t nrSensor = 0);
GUI-Generic_bv5.2_gv7.5.17_pl_75638aee9ae8b98fe30495cf746fd9fd/SuplaConditions.h:144:103: note: no known conversion for argument 3 from 'Supla::Sensor::Binary*' to 'Supla::Sensor::ElectricityMeter*'
xxxxxxxxxxxxxxxxxx
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL -DBEARSSL_SSL_BASIC -DSUPLA_ACTION_TRIGGER -DSUPLA_BUTTON -DSUPLA_CONDITIONS -DSUPLA_CONFIG -DSUPLA_DHT11
-DSUPLA_DHT22 -DSUPLA_DS18B20 -DSUPLA_ENABLE_GUI -DSUPLA_LIMIT_SWITCH -DSUPLA_OTA -DSUPLA_PUSHOVER -DSUPLA_RELAY
jeszcze jeden błąd Wemos D1 Mini - licznik impulsów
Błąd generowania
GUI-Generic_bv5.2_gv7.5.17_pl_f4919912bcba37fb686655d2b1cd4f06/SuplaDeviceGUI.cpp: In function 'void Supla::GUI::addImpulseCounter(uint8_t)':
GUI-Generic_bv5.2_gv7.5.17_pl_f4919912bcba37fb686655d2b1cd4f06/SuplaDeviceGUI.cpp:636:3: error: 'eeprom' was not declared in this scope; did you mean 'Eeprom'?
636 | eeprom.setStateSavePeriod(TIME_SAVE_PERIOD_IMPULSE_COUNTER_SEK * 1000);
| Eeprom
xxxxxxxxxxxxxxxxxx
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL -DBEARSSL_SSL_BASIC -DSUPLA_CONFIG -DSUPLA_ENABLE_GUI -DSUPLA_IMPULSE_COUNTER -DSUPLA_OTA
Błąd generowania
| Eeprom
xxxxxxxxxxxxxxxxxx
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
