SENSORS GOOGLE HOME COMPATIBLE
Scintilla
Hi, I managed to get an esp8266 to work with Supla but the examples I see don't even seem to have a sensor compatible with Google Home. If I wanted to connect a temperature sensor to Google Home it's not possible, if I wanted to send a generic value of an ADC reading I haven't even found a useful sensor that can send values other than on or off to Google Home. How come ? Thank you
Scintilla
so a thermometer or anything else that reads a value cannot be connected to google home? Only relays and state open / close ?
Thanks ..
Thanks ..
Scintilla
With alexa it works.. I can see thermometer configuration for alexa so supla send values to alexa..
Scintilla
Thank you for your kindness . ok then I give up. With incomplete implementations of the supla server towards google home I cannot try to implement anything on my end. unfortunately it is a serious shortcoming not to be able to read even a simple temperature sensor from google home
