Aktualizacja GUI Generic
lukasz06
Has thanked: 45 times
Been thanked: 21 times
Wybacz. Jakoś nie znalazłem instrukcji.
Been thanked: 5 times
lukasz06 wrote: Mon Mar 18, 2024 9:32 pm Proszę 😉
Błąd generowania
In file included from GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/SuplaDeviceGUI.h:61,
                 from GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/control/ThermostatGUI.h:31,
                 from GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/control/ThermostatGUI.cpp:18:
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:35:35: error: 'ThermostatGUI' is not a member of 'Supla::Control::GUI'
   std::array thermostat;
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:35:66: error: template argument 1 is invalid
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:35:66: error: template argument 2 is invalid
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:43:73: error: 'ThermostatGUI' is not a member of 'Supla::Control::GUI'
   OledButtonController(SuplaOled *oled, std::array &thermostat);
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:43:104: error: template argument 1 is invalid
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:43:104: error: template argument 2 is invalid
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:43:46: error: 'std::array' is not a type
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:43:51: error: expected ',' or '...' before '<' token
                 from GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/SuplaOled.h:20,
                 from GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/SuplaOled.cpp:18:
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:33:3: error: 'SuplaOled' does not name a type; did you mean 'SuplaOled_H'?
   SuplaOled *oled;
   SuplaOled_H
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:43:33: error: expected ')' before '*' token
GUI-Generic_bv6.0_gv7.14.16_pl_677c7403bee8609cae96cf3284561f9a/src/display/OledButtonController.h:46:33: error: expected ')' before '*' token
   OledButtonController(SuplaOled *oled);
xxxxxxxxxxxxxxxxxx
BOARD esp32:esp32:d32:PartitionScheme=min_spiffs
BOARD_NAME ESP32_Relay_X4
TEMPLATE_JSON ESP32_RELAY_X4
JSON_DEFINITION NAME:ESP32_Relay_X4 GPIO:[1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 544 0 226 227 1 0 0 0 0 224 225 1 1 1 0 0 1]
OPTIONS
-DTEMPLATE_JSON=\"{\\\"NAME\\\":\\\"ESP32_Relay_X4\\\",\\\"GPIO\\\":[1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,1,1,544,0,226,227,1,0,0,0,0,224,225,1,1,1,0,0,1]}\"
-DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL -DNDEBUG -DSUPLA_ACTION_TRIGGER -DSUPLA_BH1750_KPOP -DSUPLA_BME280 -DSUPLA_BUTTON -DSUPLA_CONDITIONS -DSUPLA_CONFIG
-DSUPLA_DHT22 -DSUPLA_DIRECT_LINKS -DSUPLA_DIRECT_LINKS_MULTI_SENSOR -DSUPLA_DISABLE_LOGS -DSUPLA_DS18B20 -DSUPLA_ENABLE_GUI -DSUPLA_EXCLUDE_LITTLEFS_CONFIG
-DSUPLA_LED -DSUPLA_LIMIT_SWITCH -DSUPLA_OLED -DSUPLA_OTA -DSUPLA_PUSHOVER -DSUPLA_RELAY -DSUPLA_RGBW -DSUPLA_THERMOSTAT -DTEMPLATE_BOARD_JSON
Możesz wesprzeć autorów w dalszym rozwoju projektu.
Postaw nam kawę na buycoffee.to Przekaż darowiznę za pomocą przycisku PayPal
GUI-Generic Builder
GUI-Generic: v7.14.16; Builder: v6.0.1
Board ESP8266: v3.1.2; Board ESP32: v2.0.9
Wideo poradnikWideo poradnik
Przewodnik online 📖https://forum.supla.orghttps://forum.supla.org
Uploader dwuetapowyUploader dwuetapowy (bin.gz)
Ustawienia kompilacji
Płytka
ESP32_Relay_X4
Procesor
ESP32
Pamięć FLASH
Minimal SPIFFS (Large APPS with OTA)
Dostępne opcje dla modułu
Podstawowe
Konfiguracja (LED, Config)
Aktualizacja przez WWW
Dostępne GUI podczas pracy modułu
Szyfrowane połączenie z serwerem (SSL)
Tryb głębokiego uśpienia (Deep Sleep)
Wake on LAN
WT32-ETH01
Sterowanie
Przekaźniki
Przyciski
Wyzwalacze akcji
Termostat
Rolety
Krańcówki
Warunkowanie
LED załączenia przekaźnika
Pushover
Linki bezpośrednie
Bramka RF 315/433MHz
Ekspandery
MCP23017
PCF8575
PCF8574/A
1Wire
Sensor DS18B20
Sensor DHT11
Sensor DHT22
Sensor Si7021 Sonoff
I2C
Sensor BME280
Sensor BMP280
Sensor SHT3x
Sensor SHTxx
Sensor Si7021
Sensor VL53L0X
Sensor HDC1080
Wyświetlacz OLED SSD1306, SH1106
Wyświetlacz LCD HD44780
Sensor BH1750
Sensor MS5611
Sensor MAX44009
Sensor AHT10/20
SPI
Termopara MAX6675
Termopara MAX31855
Analogowe
Pomiar analogowy (ADC Pin)
Termistor NTC 10K
Czujnik ciśnienia MPX5xxx
Licznik Energii Elektrycznej
Licznik energii HLW8012, BL0937
Licznik energii PZEM V3
Licznik energii CSE7766
Licznik energii ADE7953
Licznik energii SDM Modbus 1F
Licznik energii SDM Modbus 3F
Inne
RGBW, RGB, Dimmer
Czujnik odległości HC-SR04
Licznik impulsów
Linki bezpośrednie - odczyt temperatury (stare)
Linki bezpośrednie - odczyt wartości kanału
Czujnik czystości powietrza
IKEA VINDRIKTNING
PMSx003
boneIO
boneIO 32x10A
boneIO 24x16A
Debug
Wyłączenie LittleFS
Wyłączenie wszystkich logów
Testowe
SUPLA_ETH01_LAN8720
Wrzuciłem poprawkę.
lukasz06
krycha88 wrote: Tue Mar 19, 2024 3:44 pm
Błąd generowania
   SuplaOled *oled;
   SuplaOled_H
xxxxxxxxxxxxxxxxxx
OPTIONS
GUI-Generic Builder
Płytka
ESP32_Relay_X4
Procesor
ESP32
Pamięć FLASH
Podstawowe
Wake on LAN
WT32-ETH01
Sterowanie
Przekaźniki
Przyciski
Wyzwalacze akcji
Termostat
Rolety
Krańcówki
Warunkowanie
Pushover
Linki bezpośrednie
Ekspandery
MCP23017
PCF8575
PCF8574/A
1Wire
Sensor DS18B20
Sensor DHT11
Sensor DHT22
I2C
Sensor BME280
Sensor BMP280
Sensor SHT3x
Sensor SHTxx
Sensor Si7021
Sensor VL53L0X
Sensor HDC1080
Sensor BH1750
Sensor MS5611
Sensor MAX44009
Sensor AHT10/20
SPI
Termopara MAX6675
Termopara MAX31855
Analogowe
Termistor NTC 10K
Inne
RGBW, RGB, Dimmer
Licznik impulsów
IKEA VINDRIKTNING
PMSx003
boneIO
boneIO 32x10A
boneIO 24x16A
Debug
Wyłączenie LittleFS
Testowe
SUPLA_ETH01_LAN8720
Wrzuciłem poprawkę.
Niestety to nie pomogło, nadal wywala błąd aktualizacji
lukasz06 wrote: Tue Mar 19, 2024 5:38 pm Niestety to nie pomogło, nadal wywala błąd aktualizacji
Zobacz wersję 7.14.18
lukasz06
Teraz śmiga, dziękuję :)
kurus
krycha88 wrote: Tue Mar 19, 2024 6:35 pm
Wygenerowałem sobie dziś soft dla esp32s2 i jest jakiś problem bo chciałem z samym aht10/20 i dimerem i metodą prób i błędów ustawiając dimmer po zapisaniu ustawień moduł nie wstaje, udało mi się to zaczytać bo terminal też się zawiesza:
Na esp32 jest tak samo, ustawie wyzwalacz i czujnik na i2c to ładnie się rejestruje w cloud, dodam dimmer to wywala się moduł, miga na nim ikonka wtedy jednostajnie
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:13220
ho 0 tail 12 room 4
load:0x40080400,len:3028
entry 0x400805e4
Config read
Key: 0 Value: �#��^N��J�S*�,
Key: 1 Value: �ha#�e��ޞg\��
Key: 2 Value: sss
Key: 3 Value: sss
Key: 4 Value: admin
Key: 5 Value: admin
Key: 6 Value: GUI Generic
Key: 7 Value: sss
Key: 8 Value: sss
Key: 9 Value:
Key: 10 Value: 1
Key: 11 Value:
Key: 12 Value:
Key: 13 Value:
Key: 14 Value:
Key: 15 Value:
Key: 16 Value:
Key: 17 Value:
Key: 18 Value:
Key: 19 Value:
Key: 20 Value:
Key: 21 Value:
Key: 22 Value:
Key: 23 Value:
Key: 24 Value: ,,,,,,,1,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Key: 25 Value:
Key: 26 Value: ,,0,,,,,,,,,,,,,,,1,,,,,,,,,,,,,,,,,
Key: 27 Value:
Key: 28 Value:
Key: 29 Value: 1,2,,1,,2,0,,,,,,,,,,1,,,,,,,,,,,,,,
Key: 30 Value:
Key: 31 Value: 1,25,,,2,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Key: 32 Value:
Key: 33 Value: 2,25,,,2,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Key: 34 Value:
Key: 35 Value: 3,25,,,2,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Key: 36 Value:
Key: 37 Value:
Key: 38 Value:
Key: 39 Value:
Key: 40 Value:
Key: 41 Value:
Key: 42 Value:
Key: 43 Value:
Key: 44 Value:
Key: 45 Value:
Key: 46 Value:
Key: 47 Value:
Key: 48 Value:
Key: 49 Value:
Key: 50 Value:
Key: 51 Value:
Key: 52 Value:
Key: 53 Value:
Key: 54 Value:
Key: 55 Value:
Key: 56 Value:
Key: 57 Value:
Key: 58 Value:
Key: 59 Value:
Key: 60 Value:
Key: 61 Value:
Key: 62 Value:
Key: 63 Value:
Key: 64 Value:
Key: 65 Value:
Key: 66 Value:
Key: 67 Value: 3
Key: 68 Value:
Key: 69 Value:
Key: 70 Value:
Key: 71 Value:
Key: 72 Value:
Key: 73 Value:
Key: 74 Value:
Key: 75 Value:
Key: 76 Value:
Key: 77 Value:
Key: 78 Value:
Key: 79 Value:
Key: 80 Value: 1
Key: 81 Value: 1
Key: 82 Value:
Key: 83 Value:
Key: 84 Value:
Key: 85 Value:
Key: 86 Value:
Key: 87 Value:
Key: 88 Value:
Key: 89 Value:
Key: 90 Value:
Key: 91 Value:
Key: 92 Value:
Key: 93 Value:
Key: 94 Value:
Key: 95 Value:
Key: 96 Value: 0.25
Key: 97 Value: 0.4
Key: 98 Value: 0,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Key: 99 Value:
Key: 100 Value:
Key: 101 Value:
Key: 102 Value: 0
Key: 103 Value:
Key: 104 Value:
Key: 105 Value:
Key: 106 Value:
Key: 107 Value:
Key: 108 Value:
Key: 109 Value:
Key: 110 Value:
Key: 111 Value:
Key: 112 Value: ,,,,,,,0,0,0,,,,,,,,,,,,,,,,,,,,,,,,
Key: 113 Value:
Key: 114 Value:
Key: 115 Value:
Key: 116 Value:
Key: 117 Value:
Key: 118 Value:
Key: 119 Value:
Key: 120 Value:
Key: 121 Value:
Key: 122 Value:
Key: 123 Value:
CORRUPT HEAP: Bad tail at 0x3ffb8d75. Expected 0xbaad5678 got 0xbaad0101
assert failed: multi_heap_free multi_heap_poisoning.c:253 (head != NULL)
Backtrace: 0x40083c1d:0x3ffb2050 0x4008da99:0x3ffb2070 0x40093701:0x3ffb2090 0x40093373:0x3ffb21c0 0x400840e1:0x3ffb21e0 0x40093731:0x3ffb2200 0x40184701:0x3ffb2220 0x400d30c1:0x3ffb2240 0x4010204e:0x3ffb2290
Wygląda jakby stos się przepełniał, albo coś innego pisze po pamięci
kurus
Dodam że, po tej akcji nawet modułu w tryb konfiguracji nie idzie wprowadzić.
kurus wrote: Sun Apr 07, 2024 5:03 pm
Rebooting...
ho 0 tail 12 room 4
entry 0x400805e4
Config read
Key: 2 Value: sss
Key: 3 Value: sss
Key: 4 Value: admin
Key: 5 Value: admin
Key: 7 Value: sss
Key: 8 Value: sss
Key: 9 Value:
Key: 10 Value: 1
Key: 11 Value:
Key: 12 Value:
Key: 13 Value:
Key: 14 Value:
Key: 15 Value:
Key: 16 Value:
Key: 17 Value:
Key: 18 Value:
Key: 19 Value:
Key: 20 Value:
Key: 21 Value:
Key: 22 Value:
Key: 23 Value:
Key: 25 Value:
Key: 27 Value:
Key: 28 Value:
Key: 30 Value:
Key: 32 Value:
Key: 34 Value:
Key: 36 Value:
Key: 37 Value:
Key: 38 Value:
Key: 39 Value:
Key: 40 Value:
Key: 41 Value:
Key: 42 Value:
Key: 43 Value:
Key: 44 Value:
Key: 45 Value:
Key: 46 Value:
Key: 47 Value:
Key: 48 Value:
Key: 49 Value:
Key: 50 Value:
Key: 51 Value:
Key: 52 Value:
Key: 53 Value:
Key: 54 Value:
Key: 55 Value:
Key: 56 Value:
Key: 57 Value:
Key: 58 Value:
Key: 59 Value:
Key: 60 Value:
Key: 61 Value:
Key: 62 Value:
Key: 63 Value:
Key: 64 Value:
Key: 65 Value:
Key: 66 Value:
Key: 67 Value: 3
Key: 68 Value:
Key: 69 Value:
Key: 70 Value:
Key: 71 Value:
Key: 72 Value:
Key: 73 Value:
Key: 74 Value:
Key: 75 Value:
Key: 76 Value:
Key: 77 Value:
Key: 78 Value:
Key: 79 Value:
Key: 80 Value: 1
Key: 81 Value: 1
Key: 82 Value:
Key: 83 Value:
Key: 84 Value:
Key: 85 Value:
Key: 86 Value:
Key: 87 Value:
Key: 88 Value:
Key: 89 Value:
Key: 90 Value:
Key: 91 Value:
Key: 92 Value:
Key: 93 Value:
Key: 94 Value:
Key: 95 Value:
Key: 96 Value: 0.25
Key: 97 Value: 0.4
Key: 99 Value:
Key: 100 Value:
Key: 101 Value:
Key: 102 Value: 0
Key: 103 Value:
Key: 104 Value:
Key: 105 Value:
Key: 106 Value:
Key: 107 Value:
Key: 108 Value:
Key: 109 Value:
Key: 110 Value:
Key: 111 Value:
Key: 113 Value:
Key: 114 Value:
Key: 115 Value:
Key: 116 Value:
Key: 117 Value:
Key: 118 Value:
Key: 119 Value:
Key: 120 Value:
Key: 121 Value:
Key: 122 Value:
Key: 123 Value:
A jak dodasz sam dimmera to co się dzieje?
kurus
krycha88 wrote: Sun Apr 07, 2024 7:18 pm
Rebooting...
ho 0 tail 12 room 4
entry 0x400805e4
Config read
Key: 2 Value: sss
Key: 3 Value: sss
Key: 4 Value: admin
Key: 5 Value: admin
Key: 7 Value: sss
Key: 8 Value: sss
Key: 9 Value:
Key: 10 Value: 1
Key: 11 Value:
Key: 12 Value:
Key: 13 Value:
Key: 14 Value:
Key: 15 Value:
Key: 16 Value:
Key: 17 Value:
Key: 18 Value:
Key: 19 Value:
Key: 20 Value:
Key: 21 Value:
Key: 22 Value:
Key: 23 Value:
Key: 25 Value:
Key: 27 Value:
Key: 28 Value:
Key: 30 Value:
Key: 32 Value:
Key: 34 Value:
Key: 36 Value:
Key: 37 Value:
Key: 38 Value:
Key: 39 Value:
Key: 40 Value:
Key: 41 Value:
Key: 42 Value:
Key: 43 Value:
Key: 44 Value:
Key: 45 Value:
Key: 46 Value:
Key: 47 Value:
Key: 48 Value:
Key: 49 Value:
Key: 50 Value:
Key: 51 Value:
Key: 52 Value:
Key: 53 Value:
Key: 54 Value:
Key: 55 Value:
Key: 56 Value:
Key: 57 Value:
Key: 58 Value:
Key: 59 Value:
Key: 60 Value:
Key: 61 Value:
Key: 62 Value:
Key: 63 Value:
Key: 64 Value:
Key: 65 Value:
Key: 66 Value:
Key: 67 Value: 3
Key: 68 Value:
Key: 69 Value:
Key: 70 Value:
Key: 71 Value:
Key: 72 Value:
Key: 73 Value:
Key: 74 Value:
Key: 75 Value:
Key: 76 Value:
Key: 77 Value:
Key: 78 Value:
Key: 79 Value:
Key: 80 Value: 1
Key: 81 Value: 1
Key: 82 Value:
Key: 83 Value:
Key: 84 Value:
Key: 85 Value:
Key: 86 Value:
Key: 87 Value:
Key: 88 Value:
Key: 89 Value:
Key: 90 Value:
Key: 91 Value:
Key: 92 Value:
Key: 93 Value:
Key: 94 Value:
Key: 95 Value:
Key: 96 Value: 0.25
Key: 97 Value: 0.4
Key: 99 Value:
Key: 100 Value:
Key: 101 Value:
Key: 102 Value: 0
Key: 103 Value:
Key: 104 Value:
Key: 105 Value:
Key: 106 Value:
Key: 107 Value:
Key: 108 Value:
Key: 109 Value:
Key: 110 Value:
Key: 111 Value:
Key: 113 Value:
Key: 114 Value:
Key: 115 Value:
Key: 116 Value:
Key: 117 Value:
Key: 118 Value:
Key: 119 Value:
Key: 120 Value:
Key: 121 Value:
Key: 122 Value:
Key: 123 Value:
Wygenerowałem soft na nowo z samym dimmerem, automatycznie dodają się przyciski jak zaznaczysz dimmera, skonfigurowałem sam przycisk, restart i jest ok moduł się rejestruje, dodaje dimmera, klikam restart i koniec moduł leży efekt ten sam co wcześniej
Return to “GUI Generic”
