Hello
I wanted to deploy Supla using Linux on VPS,wanted to know the suggestion on system requirements for the same.Thanks
Suggestion on System requirements for Supla
- Been thanked: 59 times
https://www.ovh.co.uk/order/vps/#/legacy/vps/options?vps=~(category~'ssd~product~'vps_ssd_model1_2017v3~os~'linux~datacenter~'uk1)SUPLA.... Nareszcie w domu.
aruneshdutta
Thanks,so is this the ideal requirements as shown in ? was planning to use in Ubuntu 16.04
fracz
- Has thanked: 4 times
- Been thanked: 6 times
If you plan to use Docker installation: viewtopic.php?f=12&p=16088 I would suggest Debian rather than Ubuntu.
aruneshdutta
Thanks I'll go in with debian&docker.What's the minimum hw requirements of the server or any estimates that will help me know same for deployment
LyleSo
Does it not work at all on Ubuntu or does it simply work better on Debian? I'm also considering Linux.aruneshdutta wrote: Fri Jan 26, 2018 6:35 am Thanks I'll go in with debian&docker.What's the minimum hw requirements of the server or any estimates that will help me know same for deployment
