Problem z reejestracją urządzenia w prywatnej supli
Mac
Zaktualizowałem firmware loratap do nowszego.
Urządzenie nie chce się podpiąć do prywatnej instancji inicjuje po czym wywala komunikat Serwer jest rozłączony.
Dodatkowo co około 40sek router odnawia ip tego sterownika, jakby był w pętli.
logi z supla serwer
ERR[14:08:16.207256] Could not get any token for any remote gateway from AD server.
INFO[14:08:21.157865] Connection accepted: 10.0.6.22:65436 ClientSD: 41 Secure: 1
INFO[14:08:22.156282] Connection accepted: 10.0.6.22:64524 ClientSD: 110 Secure: 1
INFO[14:08:32.157250] Connection accepted: 10.0.6.22:60508 ClientSD: 41 Secure: 1
INFO[14:08:42.157379] Connection accepted: 10.0.6.22:59112 ClientSD: 96 Secure: 1
INFO[14:08:52.157543] Connection accepted: 10.0.6.22:63109 ClientSD: 41 Secure: 1
INFO[14:09:02.157362] Connection accepted: 10.0.6.22:62588 ClientSD: 96 Secure: 1
INFO[14:09:12.159516] Connection accepted: 10.0.6.22:61161 ClientSD: 41 Secure: 1
INFO[14:09:13.156097] Connection accepted: 10.0.6.22:63307 ClientSD: 96 Secure: 1
ERR[14:09:16.399293] Could not get any token for any remote gateway from AD server.
INFO[14:09:23.157243] Connection accepted: 10.0.6.22:55593 ClientSD: 41 Secure: 1
INFO[14:09:33.157685] Connection accepted: 10.0.6.22:65250 ClientSD: 96 Secure: 1
INFO[14:09:43.157229] Connection accepted: 10.0.6.22:60263 ClientSD: 41 Secure: 1
INFO[14:09:50.182665] Connection accepted: 10.0.6.36:61042 ClientSD: 96 Secure: 1
INFO[14:09:50.399674] Cipher: AES128-SHA256, SSL Version: TLSv1.2, ClientSD: 96
INFO[14:09:50.477741] Device registration started. ClientSD: 96 Protocol Version: 16 ThreadID: 30168 GUID: DB09A75A
INFO[14:09:50.560531] Device registered. ID: 47, ClientSD: 96 Protocol Version: 16 ThreadID: 30168 GUID: DB09A75A ResultCode: 3
INFO[14:09:53.157540] Connection accepted: 10.0.6.22:55116 ClientSD: 41 Secure: 1
INFO[14:10:03.158755] Connection accepted: 10.0.6.22:60697 ClientSD: 110 Secure: 1
INFO[14:10:04.158218] Connection accepted: 10.0.6.22:64589 ClientSD: 41 Secure: 1
INFO[14:10:14.158668] Connection accepted: 10.0.6.22:61475 ClientSD: 44 Secure: 1
ERR[14:10:16.590200] Could not get any token for any remote gateway from AD server.
INFO[14:10:24.158580] Connection accepted: 10.0.6.22:55773 ClientSD: 41 Secure: 1
INFO[14:10:34.158961] Connection accepted: 10.0.6.22:55376 ClientSD: 44 Secure: 1
10.0.6.22 to własnie ten sterownik
W supli SVR poprawnie inicjuje i poprawnie działa.
Wersja SUPLA Cloud 24.06.01
Gdy wróce do poprzedniego firmware to działa normalnie.
Jaki masz sterownik? Może jest włączone sprawdzanie certyfikatu serwera, co na prywatnych serwerach nie działa?
Mac
Ja mam certyfikat także tu nie problem.
Tak na prywtnym nie działa po aktualizacji softu , jak wróće na poprzedni to jest ok.
Sc500w v2 soft działajacy 2.4 /1.35@lukfud soft nie działający :WERSJA (23.12.14 @lukfud)
Znalazłem takie coś i chyba to będzie winowajcą ale za cienki jestem by to ogarnąć.
viewtopic.php?t=12494&start=10
W v24.06.01 wróciliśmy w dockerach do OpenSSL.
Jest jednak problem ponieważ urządzenia łączące się z użyciem algorytmów uważanych za mało bezpieczne są odrzucane.
Aby umożliwić akceptowanie takich połączeń dodaliśmy odpowiedni kod do źródeł serwera. Wymaga to jednak przebudowy dockerów co niebawem nastąpi. Jeśli sprawa jest pilna to możesz samodzielnie przebudować kontener supla-server z użyciem tego pliku
https://github.com/SUPLA/supla-docker/b ... Dockerfile
Mac
Odpaliłem instancje z 23.09 z backupa i to samo
INFO[16:43:38.280358] Connection accepted: 10.0.6.22:53046 ClientSD: 112 Secure: 1
INFO[16:43:39.279519] Connection accepted: 10.0.6.22:54764 ClientSD: 104 Secure: 1
INFO[16:43:49.282226] Connection accepted: 10.0.6.22:49712 ClientSD: 112 Secure: 1
INFO[16:43:59.281531] Connection accepted: 10.0.6.22:64468 ClientSD: 113 Secure: 1
INFO[16:44:09.281869] Connection accepted: 10.0.6.22:56709 ClientSD: 104 Secure: 1
INFO[16:44:19.281743] Connection accepted: 10.0.6.22:53414 ClientSD: 113 Secure: 1
Zamlowska Mewa 01 2.8.58 i SBW 01 2.8.58 wszystko ok
Mac wrote: Sat Jul 06, 2024 3:14 pm Ja mam certyfikat także tu nie problem.
Ja miałem na myśli certyfikat używany przy połączeniu urządzeń na port 2016 serwera. To nie są certyfikaty SSL używane do https.
Te certyfikaty są sprawdzane względem Root CA Supli. Nie pamiętam czy i kiedy lukfud tą opcję wprowadził do softu, ale mógł to zrobić. Także sprwadź ustawienia urządzenia w trybie cfg.
W logach urządzenia powinno też to być widoczne (lub więcej informacji o innym błędzie), tylko pamiętaj, aby nie podłaczać urządzenia zasilanego 230 V pod programator na USB.
Mac
pzygmunt wrote: Sat Jul 06, 2024 3:40 pm W v24.06.01 wróciliśmy w dockerach do OpenSSL.
Przy 4 kroku takie coś mi wywala
Step 4/10 : RUN git clone https://github.com/SUPLA/supla-core.git --branch ${SERVER_VERSION} /src && cd / src && git cherry-pick 1fb8cc00fc13580375527c8d1c60290f8e1ad7c6 && cd /src/supla-scheduler/Release && make all && cd /src/supla-server/Release && make all && cp /src/supla-scheduler/Release/supla-sc heduler /src/supla-server/Release/supla-server /usr/local/bin && rm -fr /src && mkdir -p /etc/supla-s erver
---> Running in 7acd315e7b07
Cloning into '/src'...
Note: switching to '198d7c0eeb16fb3635822f97588d6c29c945361d'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c <new-branch-name>
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
Updating files: 100% (2270/2270), done.
Committer identity unknown
*** Please tell me who you are.
Run
git config --global user.email "[email protected]"
git config --global user.name "Your Name"
to set your account's default identity.
Omit --global to set the identity only in this repository.
fatal: unable to auto-detect email address (got 'root@7acd315e7b07.(none)')
The command '/bin/sh -c git clone https://github.com/SUPLA/supla-core.git --branch ${SERVER_VERSION} /src && cd /src && git cherry-pick 1fb8cc00fc13580375527c8d1c60290f8e1ad7c6 && cd /src/supla-scheduler/Re lease && make all && cd /src/supla-server/Release && make all && cp /src/supla-scheduler/Release/ supla-scheduler /src/supla-server/Release/supla-server /usr/local/bin && rm -fr /src && mkdir -p /etc /supla-server' returned a non-zero code: 128
Nie mam programatora a w konfigu niestety nie ma takich rzeczy
Poprawiłem Dockerfile.
Spróbuj jeszcze raz.
lukfud
Has thanked: 13 times
Been thanked: 11 times
W poprzedniej wersji urządzenie nie sprawdzało certyfikatu serwera
23:45:28.679 -> Establishing Secured connection without certificate matching with: moja_domena (port: 2016)
W grudniowej wersji urządzenie certyfikat już sprawdza.
3:49:53.956 -> Establishing encrypted connection with: moja_domena (port: 2016)
W szkicu dodane są linie:
SuplaDevice.setSuplaCACert(suplaCACert);
SuplaDevice.setSupla3rdPartyCACert(supla3rdCACert);
W tym poście Krzysiek ładnie wszystko wyjaśnił ;)
viewtopic.php?p=168075#p168075
(opcja nr 3)
https://smartnerzeczy.pl
