Hello everyone,
I'm encountering an issue when starting Supla on a VirtualBox virtual machine. Here's the error I'm receiving: "Oh no! Something has gone wrong. A problem has occurred and the system can't recover. Please contact a system administrator."
I've already tried restarting the VM and reconfiguring the settings without success. Does anyone have any suggestions on how to resolve this issue?
Thank you in advance for your help!
Supla Startup Problem on VirtualBox - System Failure Error
spider_iot
- Been thanked: 59 times
spider_iot
Hi, thank you for your suggestion, Mr. PZYGMUNT.
I installed Supla-docker and was able to run the Supla-server and Supla-cloud.
However, I apologize for not clarifying my previous question.
My issue was related to the virtual machine used to generate the customized firmware using "SUPLA-IoT_SDK_x86/x64".
I am still receiving the same error message.
This VM uses an outdated library that we no longer support. Take a look at this https://github.com/SUPLA/supla-device
You may also be interested in https://gui-generic-builder.supla.io/
