I dalej nic
pi@raspberrypi:~ $ sudo apt update
Get:1 file:/var/cache/openmediavault/archives InRelease
Ign:1 file:/var/cache/openmediavault/archives InRelease
Get:2 file:/var/cache/openmediavault/archives Release
Ign:2 file:/var/cache/openmediavault/archives Release
Get:3 file:/var/cache/openmediavault/archives Packages
Ign:3 file:/var/cache/openmediavault/archives Packages
Get:4 file:/var/cache/openmediavault/archives Translation-en
Ign:4 file:/var/cache/openmediavault/archives Translation-en
Hit:5 http://security.debian.org/debian-security buster/updates InRelease
Hit:6 http://httpredir.debian.org/debian buster-backports InRelease
Hit:7 http://packages.openmediavault.org/public usul InRelease
Hit:8 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:9 https://download.docker.com/linux/raspbian buster InRelease
Hit:10 https://download.docker.com/linux/debian buster InRelease
Ign:11 https://dl.bintray.com/openmediavault-p ... opers/usul buster InRelease
Hit:12 https://openmediavault.github.io/packages usul InRelease
Get:13 https://dl.bintray.com/openmediavault-p ... opers/usul buster Release [4363 B]
Hit:14 http://archive.raspberrypi.org/debian buster InRelease
Fetched 4363 B in 4s (1074 B/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
37 packages can be upgraded. Run 'apt list --upgradable' to see them.
pi@raspberrypi:~ $ sudo apt install -y python3-pip
python3-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 37 not upgraded.
pi@raspberrypi:~ $ sudo pip3 install docker-compose
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting docker-compose
Using cached https://files.pythonhosted.org/packages ... ne-any.whl
Collecting docker[ssh]<5,>=4.3.1 (from docker-compose)
Requirement already satisfied: requests<3,>=2.20.0 in /usr/lib/python3/dist-packages (from docker-compose) (2.21.0)
Collecting websocket-client<1,>=0.32.0 (from docker-compose)
Collecting texttable<2,>=0.9.0 (from docker-compose)
Collecting dockerpty<1,>=0.4.1 (from docker-compose)
Using cached https://www.piwheels.org/simple/dockerp ... ne-any.whl
Requirement already satisfied: cached-property<2,>=1.2.0 in /usr/lib/python3/dist-packages (from docker-compose) (1.5.1)
Collecting docopt<1,>=0.6.1 (from docker-compose)
Using cached https://www.piwheels.org/simple/docopt/ ... ne-any.whl
Collecting distro<2,>=1.5.0 (from docker-compose)
Requirement already satisfied: PyYAML<6,>=3.10 in /usr/lib/python3/dist-packages (from docker-compose) (3.13)
Collecting jsonschema<4,>=2.5.1 (from docker-compose)
Collecting python-dotenv<1,>=0.13.0 (from docker-compose)
Requirement already satisfied: six>=1.4.0 in /usr/lib/python3/dist-packages (from docker[ssh]<5,>=4.3.1->docker-compose) (1.12.0)
Collecting paramiko>=2.4.2; extra == "ssh" (from docker[ssh]<5,>=4.3.1->docker-compose)
Collecting pyrsistent>=0.14.0 (from jsonschema<4,>=2.5.1->docker-compose)
Using cached https://files.pythonhosted.org/packages ... 7.3.tar.gz
Complete output from command python setup.py egg_info:
Traceback (most recent call last):
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'setuptools'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-2hrkai_c/pyrsistent/
pi@raspberrypi:~ $
Własny serwer supla - od czego zacząć
sudo apt install python3-setuptools
sudo pip3 install docker-composeSOP 2023
SOP 2024
cz->b
+ila
SOP 2024
Simono
- Been thanked: 6 times
Panowie chciałem zaktualizować dockera na malinie i wywala mi takie coś:
Pomoże ktoś?
Edyta:
Nieaktualne brakowało mi:
po aktualizacji maliny do bustera.
pi@raspberrypi:~/supla-docker $ ./supla.sh upgrade Making database backup
Database backup saved to ./var/backups/supla09232021175527.sql.gz
Stopping SUPLA containers
File "/usr/local/bin/docker-compose", line 7, in <module>
from compose.cli.main import main
File "/usr/local/lib/python2.7/dist-packages/compose/cli/main.py", line 17, in <module>
import docker
File "/usr/local/lib/python2.7/dist-packages/docker/__init__.py", line 2, in <module>
from .api import APIClient
File "/usr/local/lib/python2.7/dist-packages/docker/api/__init__.py", line 2, in <module>
from .client import APIClient
File "/usr/local/lib/python2.7/dist-packages/docker/api/client.py", line 10, in <module>
from .build import BuildApiMixin
File "/usr/local/lib/python2.7/dist-packages/docker/api/build.py", line 6, in <module>
from .. import auth
File "/usr/local/lib/python2.7/dist-packages/docker/auth.py", line 9, in <module>
from .utils import config
File "/usr/local/lib/python2.7/dist-packages/docker/utils/__init__.py", line 3, in <module>
from .decorators import check_resource, minimum_version, update_headers
File "/usr/local/lib/python2.7/dist-packages/docker/utils/decorators.py", line 4, in <module>
from . import utils
File "/usr/local/lib/python2.7/dist-packages/docker/utils/utils.py", line 12, in <module>
from .. import tls
File "/usr/local/lib/python2.7/dist-packages/docker/tls.py", line 5, in <module>
from .transport import SSLAdapter
File "/usr/local/lib/python2.7/dist-packages/docker/transport/__init__.py", line 3, in <module>
from .ssladapter import SSLAdapter
File "/usr/local/lib/python2.7/dist-packages/docker/transport/ssladapter.py", line 21, in <module>
from backports.ssl_match_hostname import match_hostname
ImportError: No module named ssl_match_hostname
Edyta:
sudo pip3 install docker-compose-
MrBaKTaMo
Witam powiem szczerze jestem kompletnym laikiem poleglem na samym poczateczku ogolnie zaczne od poczatku mam w planach kupic takie cos jak hp t630 thin client z tego co mi sie wydaje powinna na tym supla isc i to z zapasem w kazdym badz razie chcialem sprobowac postawic serwer na swoim lapku zeby sie podszkolic zatrzymalem sie na etapie instalacji dochuba i zalaczenia tego wsl chociaz nawet nwm co to jest w kazdym badz razie po wpisaniu komendy w terminalu
git clone https://github.com/SUPLA/supla-docker.git
wyskakuje mi to
S C:\Users\PC> git clone https://github.com/SUPLA/supla-docker.git
git : The term 'git' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify th
at the path is correct and try again.
At line:1 char:1
+ git clone https://github.com/SUPLA/supla-docker.git
+ CategoryInfo : ObjectNotFound: (git:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
i wtym momencie zostalem pokonany szczerze moja znajomosc ang jest na poziomie podstawowym rozumiem z tego wszystkiego tyle ze dochub nie kmini komenty git gdyby ktos chcial mi pomoc bylbym cholernie wdzieczny nie wiem co zrobilem zle czego nie zrobilem prosze o pomoc
wyskakuje mi to
At line:1 char:1
[email protected]
- Has thanked: 18 times
- Been thanked: 26 times
Domyślnie w Windowsie nie jest zainstalowany git i musisz go najpierw zainstalować
- Has thanked: 290 times
- Been thanked: 161 times
Instalacja własnego serwera ma sens jeżeli w miarę ogarniasz środowisko, w którym instalujesz serwer. Inaczej istnieje duże ryzyko, że będziesz miał wiecznie problemy albo ktoś włamie Ci się na serwer z zewnątrz.MrBaKTaMo wrote: Sat Dec 14, 2024 10:44 pm Witam powiem szczerze jestem kompletnym laikiem poleglem na samym poczateczku ogolnie zaczne od poczatku mam w planach kupic takie cos jak hp t630 thin client z tego co mi sie wydaje powinna na tym supla isc i to z zapasem w kazdym badz razie chcialem sprobowac postawic serwer na swoim lapku zeby sie podszkolic zatrzymalem sie na etapie instalacji dochuba i zalaczenia tego wsl chociaz nawet nwm co to jest w kazdym badz razie po wpisaniu komendy w terminalu
wyskakuje mi to
At line:1 char:1
Zapewniam Cię, że jest na tym forum sporo osób, które znają się bardzo dobrze np. na Linuksie a mimo to korzystają z serwerów publicznych...bo wygodnie, tanio (póki co
Zasada jest prosta - jeżeli nie masz jasno zdefiniowanego powodu dla posiadania prywatnego serwera to lepiej odpuść bo inaczej Twoi domownicy dojdą do wniosku, że ta Supla to jest...
