Sterowanie roletami / przekaźnikami - Arduino Mega
furia
Mam jeszcze pytanie.
Jakie linie kodu trzeba wkleić aby sterować innymi rzeczami?
np. RGB, oświetleniem itp.
jest gdzieś na forum to opisane?
nowy1
próbowałem dodac dwa kody rgb i sterowanie rolet ale mi nie rozpoznaje urządzenia wtedy
#include <SPI.h>
#include <Ethernet.h>
#include <SuplaDevice.h>
* SUPLA DEVICE - ARDUINO - ETHERNET SHIELD & RGBW
* Author: Przemyslaw Zygmunt <[email protected]>
* Youtube: https://youtu.be/FE9tqzTjmA4
 #define RED_PIN    44
 #define GREEN_PIN  45
 #define BLUE_PIN   46
 #define BRIGHTNESS_PIN        7
 #define COLOR_BRIGHTNESS_PIN  8
 unsigned char _red = 0;
 unsigned char _green = 255;
 unsigned char _blue = 0;
 unsigned char _color_brightness = 0;
 unsigned char _brightness = 0;
void get_rgbw_value(int channelNumber, unsigned char *red, unsigned char *green, unsigned char *blue, unsigned char *color_brightness, unsigned char *brightness) {
  *brightness = _brightness;
  *color_brightness= _color_brightness;
  *red = _red;
  *green = _green;
  *blue = _blue;
void set_rgbw() {
    analogWrite(BRIGHTNESS_PIN, (_brightness * 255) / 100);
    analogWrite(COLOR_BRIGHTNESS_PIN, (_color_brightness * 255) / 100);
    analogWrite(RED_PIN, _red);
    analogWrite(GREEN_PIN, _green);
    analogWrite(BLUE_PIN, _blue);
void set_rgbw_value(int channelNumber, unsigned char red, unsigned char green, unsigned char blue, unsigned char color_brightness, unsigned char brightness) {
    _brightness = brightness;
    _color_brightness= color_brightness;
    _red = red;
    _green = green;
    _blue = blue;
    set_rgbw();
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
digitalWrite(pin, val);
if ( pin == 3 )
digitalWrite(5, val);
void setup() {
  SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);
  Serial.begin(9600);
  set_rgbw();
  // Set RGBW callbacks
  SuplaDevice.setRGBWCallbacks(&get_rgbw_value, &set_rgbw_value);
  // Replace the falowing GUID
  char GUID[SUPLA_GUID_SIZE] = {0000000};
  // Ethernet MAC address
  uint8_t mac[6] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05};
    // CHANNEL3 - TWO RELAYS (Roller shutter operation)
  //SuplaDevice.addRollerShutterRelays(3,     // 46 - Pin number where the 1st relay is connected
                            10);    // 47 - Pin number where the 2nd relay is connected
   CHANNEL0 - RGB controller and dimmer (RGBW)
  SuplaDevice.addRgbControllerAndDimmer();
  // SuplaDevice.addRgbController();
  // SuplaDevice.addDimmer();
   * SuplaDevice Initialization.
                    "svr1.supla.org",  // SUPLA server address
                    0,                 // Location ID
                    "02");               // Location Password
void loop() {
  SuplaDevice.iterate();
Co znaczy nie rozpoznaje ? Jaki komunikat w konsoli ?
nowy1
pzygmunt wrote:Co znaczy nie rozpoznaje ? Jaki komunikat w konsoli ?
kompiluje sie normalnie ,ale na Supla Cloud widzi jaku wyłączone urządzenie ,
furia
Zmień GIUD, ID i Hasło i sprobuj tego...
mi się kompiluje - nie sprawdzałem czy widzi na SUPLI
#include <SPI.h>
 #define RED_PIN    44
 #define BLUE_PIN   46
  *red = _red;
  *green = _green;
  *blue = _blue;
void set_rgbw() {
    _red = red;
    _green = green;
    _blue = blue;
    set_rgbw();
void setup() {
  Serial.begin(9600);
  set_rgbw();
  char GUID[SUPLA_GUID_SIZE] = {0000000000000000000000000000000000000000000000000000000000000};
  // CHANNEL0 - RELAY
 SuplaDevice.addRollerShutterRelays(23, 25, true);
  SuplaDevice.addRollerShutterRelays(27, 29, true);
   SuplaDevice.addRollerShutterRelays(31, 33, true);
    SuplaDevice.addRollerShutterRelays(35, 37, true);
     SuplaDevice.addRollerShutterRelays(39, 41, true);
                    xxxx,                // Location ID - TU WKLEJASZ SWÓJ ID
                    "xxxx");           // Location Password - W NAWIASIE WKLEJASZ HASŁO
void loop() {
nowy1
furia wrote:Zmień GIUD, ID i Hasło i sprobuj tego...
#include <SPI.h>
 #define RED_PIN    44
 #define BLUE_PIN   46
  *red = _red;
  *green = _green;
  *blue = _blue;
void set_rgbw() {
    _red = red;
    _green = green;
    _blue = blue;
    set_rgbw();
void setup() {
  Serial.begin(9600);
  set_rgbw();
  // CHANNEL0 - RELAY
void loop() {
Mi też nawet twój kod sie kompiluje ,po wgrani nie łaczy sie z Suplą cloud
furia
Faktycznie... coś jest nie tak.
Wygenerowałem nowy GUID i zadziałało.
Oto dowód, że działa:
nowy1
furia wrote:Faktycznie... coś jest nie tak.
Dziękuje
wygenerowałem nowy GUID i też mi już działa .
