Terminal log file
Date: 18.04.2025 - 10:43:31
10:43:33.716, =========== After Setup Start ============INTERNAL Memory Info:------------------------------------------ Total Size : 394204 B ( 385.0 KB) Free Bytes : 275932 B ( 269.5 KB) Allocated Bytes : 107816 B ( 105.3 KB) Minimum Free Bytes: 271408 B ( 265.0 KB) Largest Free Block: 245748 B ( 240.0 KB)------------------------------------------GPIO Info:------------------------------------------ GPIO : BUS_TYPE[bus/unit][chan] -------------------------------------- 9 : GPIO 12 : USB_DM 13 : USB_DP 16 : UART_TX[0] 17 : UART_RX[0]============ After Setup End =============Resetting Zigbee to factory settings, reboot.[ 25525][V][ZigbeeCore.cpp:417] factoryReset(): Factory resetting Zigbee stack, device will reboot
10:43:33.716, ESP-ROM:esp32c6-20220919
10:43:33.716, Build:Sep 19 2022
10:43:33.716, rst:0xc (SW_CPU),boot:0xc (SPI_FAST_FLASH_BOOT)
10:43:33.716, Saved PC:0x4001975a
10:43:33.716, SPIWP:0xee
10:43:33.716, mode:DIO, clock div:2
10:43:33.716, load:0x40875720,len:0x1228
10:43:33.716, load:0x4086c110,len:0xd9c
10:43:33.716, load:0x4086e610,len:0x2f74
10:43:33.716, entry 0x4086c110
10:43:34.371, [ 1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012a44
10:43:34.371, [ 12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012a08
10:43:34.371, [ 23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x420129cc
10:43:34.371, [ 35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012990
10:43:34.371, [ 46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012a44
10:43:34.371, [ 57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012a08
10:43:34.480, [ 69][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x420129cc
10:43:34.480, [ 80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012990
10:43:34.480, [ 91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DM (38) successfully set to 0x4200e576
10:43:34.480, [ 103][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DP (39) successfully set to 0x4200e576
10:43:34.480, [ 114][V][ZigbeeEP.cpp:21] ZigbeeEP(): Endpoint: 1
10:43:34.480, [ 131][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type UART_RX (2) with bus 0x4081444c
10:43:34.480, [ 142][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type UART_TX (3) with bus 0x4081444c
10:43:34.480, [ 152][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 12 successfully set to type USB_DM (38) with bus 0x40818b68
10:43:34.480, [ 163][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type USB_DP (39) with bus 0x40818b68
10:43:34.696, =========== Before Setup Start ===========Chip Info:------------------------------------------ Model : ESP32-C6 Package : 0 Revision : 0.01 Cores : 1 CPU Frequency : 160 MHz XTAL Frequency : 40 MHz Features Bitfield : 0x00000052 Embedded Flash : No Embedded PSRAM : No 2.4GHz WiFi : Yes Classic BT : No BT Low Energy : Yes IEEE 802.15.4 : Yes------------------------------------------INTERNAL Memory Info:------------------------------------------ Total Size : 394204 B ( 385.0 KB) Free Bytes : 345204 B ( 337.1 KB) Allocated Bytes : 37344 B ( 36.5 KB) Minimum Free Bytes: 345204 B ( 337.1 KB) Largest Free Block: 319476 B ( 312.0 KB)------------------------------------------Flash Info:------------------------------------------ Chip Size : 16777216 B (16 MB) Block Size : 65536 B ( 64.0 KB) Sector Size : 4096 B ( 4.0 KB) Page Size : 256 B ( 0.2 KB) Bus Speed : 40 MHz Bus Mode : QIO------------------------------------------Partitions Info:------------------------------------------ nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA app0 : addr: 0x00010000, size: 2560.0 KB, type: APP, subtype: OTA_0 spiffs : addr: 0x00290000, size: 1384.0 KB, type: DATA, subtype: SPIFFS zb_storage : addr: 0x003EA000, size: 16.0 KB, type: DATA, subtype: FAT zb_fct : addr: 0x003EE000, size: 4.0 KB, type: DATA, subtype: FAT rcp_fw : addr: 0x003EF000, size: 4.0 KB, type: DATA, subtype: SPIFFS coredump : addr: 0x003F0000, size: 64.0 KB, type: DATA, subtype: COREDUMP------------------------------------------Software Info:------------------------------------------ Compile Date/Time : Mar 10 2025 09:32:48 Compile Host OS : linux ESP-IDF Version : v5.3.2-584-g489d7a2b3a-dirty Arduino Version : 3.1.3------------------------------------------Board Info:------------------------------------------ Arduino Board : ESP32C6_DEV Arduino Variant : esp32c6 Arduino FQBN : esp32:esp32:esp32c6:PartitionScheme=custom,ZigbeeMode=zczr,DebugLevel=verbose,CDCOnBoot=cdc============ Before Setup End ============[ 286][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x4201023a
10:43:34.696, [ 286][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set to type GPIO (1) with bus 0xa
10:43:34.696, [ 287][D][ZigbeeCore.cpp:85] addEndpoint(): Endpoint: 1, Device ID: 0x0050
10:43:36.375, [ 528][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x156e) closed, devices joining not allowed.
10:43:36.375, [ 529][I][ZigbeeCore.cpp:316] esp_zb_app_signal_handler(): Formed network successfully (Extended PAN ID: 40:4c:ca:ff:fe:5f:a0:34, PAN ID: 0x156e, Channel:11, Short Address: 0x0000)
10:43:36.375, [ 997][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x156e) is open for 180 seconds
10:43:36.375, [ 998][I][ZigbeeCore.cpp:331] esp_zb_app_signal_handler(): Network steering started
10:43:34.696, beeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x156e) is open for 180 seconds
10:43:34.696, [ 998][I][ZigbeeCore.cpp:331] esp_zb_app_signal_handler(): Network steering started
10:43:38.775, [ 4383][V][ZigbeeCore.cpp:254] openNetwork(): Opening network for joining for 180 seconds
10:43:39.218, [ 4850][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x156e) is open for 180 seconds
10:43:43.418, Resetting Zigbee to factory settings, reboot.[ 9043][V][ZigbeeCore.cpp:417] factoryReset(): Factory resetting Zigbee stack, device will reboot
10:43:43.418, ESP-ROM:esp32c6-20220919
10:43:43.418, Build:Sep 19 2022
10:43:43.418, rst:0xc (SW_CPU),boot:0xc (SPI_FAST_FLASH_BOOT)
10:43:43.418, Saved PC:0x4001975a
10:43:43.418, SPIWP:0xee
10:43:43.418, mode:DIO, clock div:2
10:43:43.418, load:0x40875720,len:0x1228
10:43:43.418, load:0x4086c110,len:0xd9c
10:43:43.529, load:0x4086e610,len:0x2f74
10:43:43.529, entry 0x4086c110
10:43:44.082, [ 1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012a44
10:43:44.082, [ 12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012a08
10:43:44.082, [ 23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x420129cc
10:43:44.082, [ 35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012990
10:43:44.082, [ 46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012a44
10:43:44.191, [ 57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012a08
10:43:44.191, [ 69][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x420129cc
10:43:44.191, [ 80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012990
10:43:44.191, [ 91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DM (38) successfully set to 0x4200e576
10:43:44.191, [ 103][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DP (39) successfully set to 0x4200e576
10:43:44.191, [ 114][V][ZigbeeEP.cpp:21] ZigbeeEP(): Endpoint: 1
10:43:44.191, [ 131][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type UART_RX (2) with bus 0x4081444c
10:43:44.191, [ 142][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type UART_TX (3) with bus 0x4081444c
10:43:44.191, [ 152][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 12 successfully set to type USB_DM (38) with bus 0x40818b68
10:43:44.300, [ 163][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type USB_DP (39) with bus 0x40818b68
10:43:44.409, =========== Before Setup Start ===========Chip Info:------------------------------------------ Model : ESP32-C6 Package : 0 Revision : 0.01 Cores : 1 CPU Frequency : 160 MHz XTAL Frequency : 40 MHz Features Bitfield : 0x00000052 Embedded Flash : No Embedded PSRAM : No 2.4GHz WiFi : Yes Classic BT : No BT Low Energy : Yes IEEE 802.15.4 : Yes------------------------------------------INTERNAL Memory Info:------------------------------------------ Total Size : 394204 B ( 385.0 KB) Free Bytes : 345204 B ( 337.1 KB) Allocated Bytes : 37344 B ( 36.5 KB) Minimum Free Bytes: 345204 B ( 337.1 KB) Largest Free Block: 319476 B ( 312.0 KB)------------------------------------------Flash Info:------------------------------------------ Chip Size : 16777216 B (16 MB) Block Size : 65536 B ( 64.0 KB) Sector Size : 4096 B ( 4.0 KB) Page Size : 256 B ( 0.2 KB) Bus Speed : 40 MHz Bus Mode : QIO------------------------------------------Partitions Info:------------------------------------------ nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA app0 : addr: 0x00010000, size: 2560.0 KB, type: APP, subtype: OTA_0 spiffs : addr: 0x00290000, size: 1384.0 KB, type: DATA, subtype: SPIFFS zb_storage : addr: 0x003EA000, size: 16.0 KB, type: DATA, subtype: FAT zb_fct : addr: 0x003EE000, size: 4.0 KB, type: DATA, subtype: FAT rcp_fw : addr: 0x003EF000, size: 4.0 KB, type: DATA, subtype: SPIFFS coredump : addr: 0x003F0000, size: 64.0 KB, type: DATA, subtype: COREDUMP------------------------------------------Software Info:------------------------------------------ Compile Date/Time : Mar 10 2025 09:32:48 Compile Host OS : linux ESP-IDF Version : v5.3.2-584-g489d7a2b3a-dirty Arduino Version : 3.1.3------------------------------------------Board Info:------------------------------------------ Arduino Board : ESP32C6_DEV Arduino Variant : esp32c6 Arduino FQBN : esp32:esp32:esp32c6:PartitionScheme=custom,ZigbeeMode=zczr,DebugLevel=verbose,CDCOnBoot=cdc============ Before Setup End ============[ 286][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x4201023a
10:43:44.409, [ 286][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set to type GPIO (1) with bus 0xa
10:43:44.409, [ 287][D][ZigbeeCore.cpp:85] addEndpoint(): Endpoint: 1, Device ID: 0x0050
10:43:44.409, [ 287][D][ZigbeeCore.cpp:166] zigbeeInit(): Initialize Zigbee stack
10:43:44.409, [ 372][D][ZigbeeCore.cpp:173] zigbeeInit(): Register all Zigbee EPs in list
10:43:44.409, [ 377][I][ZigbeeCore.cpp:181] zigbeeInit(): List of registered Zigbee EPs:
10:43:44.409, [ 377][I][ZigbeeCore.cpp:183] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
10:43:44.520, [ 381][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
10:43:44.520, [ 381][I][ZigbeeCore.cpp:275] esp_zb_app_signal_handler(): Zigbee stack initialized
10:43:44.520, [ 383][I][ZigbeeCore.cpp:281] esp_zb_app_signal_handler(): Device started up in factory-reset mode
10:43:44.520, [ 384][I][ZigbeeCore.cpp:285] esp_zb_app_signal_handler(): Start network formation
10:43:44.631, [ 528][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0xbafa) closed, devices joining not allowed.
10:43:44.631, [ 529][I][ZigbeeCore.cpp:316] esp_zb_app_signal_handler(): Formed network successfully (Extended PAN ID: 40:4c:ca:ff:fe:5f:a0:34, PAN ID: 0xbafa, Channel:11, Short Address: 0x0000)
10:43:45.068, [ 997][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0xbafa) is open for 180 seconds
10:43:45.068, [ 998][I][ZigbeeCore.cpp:331] esp_zb_app_signal_handler(): Network steering started
10:44:06.400, Resetting Zigbee to factory settings, reboot.[ 22328][V][ZigbeeCore.cpp:417] factoryReset(): Factory resetting Zigbee stack, device will reboot
10:44:06.511, ESP-ROM:esp32c6-20220919
10:44:06.511, Build:Sep 19 2022
10:44:06.511, rst:0xc (SW_CPU),boot:0xc (SPI_FAST_FLASH_BOOT)
10:44:06.511, Saved PC:0x4001975a
10:44:06.511, SPIWP:0xee
10:44:06.511, mode:DIO, clock div:2
10:44:06.511, load:0x40875720,len:0x1228
10:44:06.511, load:0x4086c110,len:0xd9c
10:44:06.511, load:0x4086e610,len:0x2f74
10:44:06.511, entry 0x4086c110
10:44:07.063, [ 1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012a44
10:44:07.063, [ 12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012a08
10:44:07.063, [ 23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x420129cc
10:44:07.176, [ 35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012990
10:44:07.176, [ 46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012a44
10:44:07.176, [ 57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012a08
10:44:07.176, [ 69][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x420129cc
10:44:07.176, [ 80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012990
10:44:07.176, [ 91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DM (38) successfully set to 0x4200e576
10:44:07.176, [ 103][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DP (39) successfully set to 0x4200e576
10:44:07.176, [ 114][V][ZigbeeEP.cpp:21] ZigbeeEP(): Endpoint: 1
10:44:07.176, [ 131][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type UART_RX (2) with bus 0x4081444c
10:44:07.286, [ 142][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type UART_TX (3) with bus 0x4081444c
10:44:07.286, [ 152][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 12 successfully set to type USB_DM (38) with bus 0x40818b68
10:44:07.286, [ 163][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type USB_DP (39) with bus 0x40818b68
10:44:07.395, =========== Before Setup Start ===========Chip Info:------------------------------------------ Model : ESP32-C6 Package : 0 Revision : 0.01 Cores : 1 CPU Frequency : 160 MHz XTAL Frequency : 40 MHz Features Bitfield : 0x00000052 Embedded Flash : No Embedded PSRAM : No 2.4GHz WiFi : Yes Classic BT : No BT Low Energy : Yes IEEE 802.15.4 : Yes------------------------------------------INTERNAL Memory Info:------------------------------------------ Total Size : 394204 B ( 385.0 KB) Free Bytes : 345204 B ( 337.1 KB) Allocated Bytes : 37344 B ( 36.5 KB) Minimum Free Bytes: 345204 B ( 337.1 KB) Largest Free Block: 319476 B ( 312.0 KB)------------------------------------------Flash Info:------------------------------------------ Chip Size : 16777216 B (16 MB) Block Size : 65536 B ( 64.0 KB) Sector Size : 4096 B ( 4.0 KB) Page Size : 256 B ( 0.2 KB) Bus Speed : 40 MHz Bus Mode : QIO------------------------------------------Partitions Info:------------------------------------------ nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA app0 : addr: 0x00010000, size: 2560.0 KB, type: APP, subtype: OTA_0 spiffs : addr: 0x00290000, size: 1384.0 KB, type: DATA, subtype: SPIFFS zb_storage : addr: 0x003EA000, size: 16.0 KB, type: DATA, subtype: FAT zb_fct : addr: 0x003EE000, size: 4.0 KB, type: DATA, subtype: FAT rcp_fw : addr: 0x003EF000, size: 4.0 KB, type: DATA, subtype: SPIFFS coredump : addr: 0x003F0000, size: 64.0 KB, type: DATA, subtype: COREDUMP------------------------------------------Software Info:------------------------------------------ Compile Date/Time : Mar 10 2025 09:32:48 Compile Host OS : linux ESP-IDF Version : v5.3.2-584-g489d7a2b3a-dirty Arduino Version : 3.1.3------------------------------------------Board Info:------------------------------------------ Arduino Board : ESP32C6_DEV Arduino Variant : esp32c6 Arduino FQBN : esp32:esp32:esp32c6:PartitionScheme=custom,ZigbeeMode=zczr,DebugLevel=verbose,CDCOnBoot=cdc============ Before Setup End ============[ 286][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x4201023a
10:44:07.395, [ 286][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set to type GPIO (1) with bus 0xa
10:44:07.395, [ 287][D][ZigbeeCore.cpp:85] addEndpoint(): Endpoint: 1, Device ID: 0x0050
10:44:07.395, [ 287][D][ZigbeeCore.cpp:166] zigbeeInit(): Initialize Zigbee stack
10:44:07.505, [ 370][D][ZigbeeCore.cpp:173] zigbeeInit(): Register all Zigbee EPs in list
10:44:07.505, [ 375][I][ZigbeeCore.cpp:181] zigbeeInit(): List of registered Zigbee EPs:
10:44:07.505, [ 375][I][ZigbeeCore.cpp:183] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
10:44:07.505, [ 380][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
10:44:07.505, [ 380][I][ZigbeeCore.cpp:275] esp_zb_app_signal_handler(): Zigbee stack initialized
10:44:07.505, [ 382][I][ZigbeeCore.cpp:281] esp_zb_app_signal_handler(): Device started up in factory-reset mode
10:44:07.505, [ 383][I][ZigbeeCore.cpp:285] esp_zb_app_signal_handler(): Start network formation
10:44:07.614, [ 527][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x0ec9) closed, devices joining not allowed.
10:44:07.614, [ 528][I][ZigbeeCore.cpp:316] esp_zb_app_signal_handler(): Formed network successfully (Extended PAN ID: 40:4c:ca:ff:fe:5f:a0:34, PAN ID: 0x0ec9, Channel:11, Short Address: 0x0000)
10:44:08.054, [ 996][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x0ec9) is open for 180 seconds
10:44:08.054, [ 997][I][ZigbeeCore.cpp:331] esp_zb_app_signal_handler(): Network steering started
10:44:12.218, =========== After Setup Start ============INTERNAL Memory Info:------------------------------------------ Total Size : 394204 B ( 385.0 KB) Free Bytes : 275932 B ( 269.5 KB) Allocated Bytes : 107816 B ( 105.3 KB) Minimum Free Bytes: 271408 B ( 265.0 KB) Largest Free Block: 245748 B ( 240.0 KB)------------------------------------------GPIO Info:------------------------------------------ GPIO : BUS_TYPE[bus/unit][chan] -------------------------------------- 9 : GPIO 12 : USB_DM 13 : USB_DP 16 : UART_TX[0] 17 : UART_RX[0]============ After Setup End =============[ 5082][V][ZigbeeCore.cpp:254] openNetwork(): Opening network for joining for 180 seconds
10:44:12.549,
10:44:12.549, assert failed: vPortExitCritical port.c:632 (port_uxCriticalNesting[0] > 0)
10:44:12.549, Core 0 register dump:
10:44:12.549, MEPC : 0x408015c2 RA : 0x40808764 SP : 0x40825430 GP : 0x40814a64
10:44:12.549, TP : 0x408256b0 T0 : 0x37363534 T1 : 0x7271706f T2 : 0x33323130
10:44:12.549, S0/FP : 0x00000001 S1 : 0x408255ab A0 : 0x40825494 A1 : 0x40817df5
10:44:12.549, A2 : 0x00000001 A3 : 0x00000029 A4 : 0x00000001 A5 : 0x40823000
10:44:12.549, A6 : 0x00000000 A7 : 0x76757473 S2 : 0x0000007c S3 : 0x40825488
10:44:12.549, S4 : 0x40825488 S5 : 0x42130895 S6 : 0x00000000 S7 : 0x004d8c88
10:44:12.549, S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000007
10:44:12.549, T3 : 0x6e6d6c6b T4 : 0x6a696867 T5 : 0x66656463 T6 : 0x62613938
10:44:12.549, MSTATUS : 0x00001881 MTVEC : 0x40800001 MCAUSE : 0x00000007 MTVAL : 0x00000000
10:44:12.549, MHARTID : 0x00000000
10:44:12.549,
10:44:12.549, Stack memory:
10:44:12.549, 40825430: 0x0000001b 0x00000000 0x42140684 0x4080f10a 0x00000000 0x4205209e 0x7fffffff 0x40817df4
10:44:12.549, 40825450: 0x40809b62 0x40022498 0x408254d0 0x00323336 0x40809b62 0x40817f14 0x42140684 0x40817f24
10:44:12.549, 40825470: 0x42130895 0x40817f28 0x4082545c 0x40817f2c 0x4213089c 0x40817df4 0x00000000 0x00000000
10:44:12.549, 40825490: 0x40000000 0x65737361 0x66207472 0x656c6961 0x76203a64 0x74726f50 0x74697845 0x74697243
10:44:12.549, 408254b0: 0x6c616369 0x726f7020 0x3a632e74 0x20323336 0x726f7028 0x78755f74 0x74697243 0x6c616369
10:44:12.549, 408254d0: 0x7473654e 0x5b676e69 0x3e205d30 0x00293020 0x408256b0 0x40022494 0x40000624 0x4080928a
10:44:12.549, 408254f0: 0x4083f638 0x00000004 0x00000001 0xffffffff 0x00000004 0x00000000 0x7fffffff 0x408255a8
10:44:12.549, 40825510: 0x00000004 0x00000000 0x7fffffff 0x408255b8 0x00000004 0x00000000 0x4083e25c 0x408087aa
10:44:12.549, 40825530: 0x00000000 0x00000000 0x4083e25c 0x40808cec 0x40826538 0xffffffff 0x4083e25c 0x00000000
10:44:12.549, 40825550: 0x00000000 0x000464da 0x7fffffff 0xd7cf59e5 0x00000000 0x000464da 0x7fffffff 0x000000ff
10:44:12.549, 40825570: 0x4081b3f0 0xfffffffd 0x40823000 0x40809bc2 0x00000000 0x40823000 0x00000000 0x4206fbb6
10:44:12.549, 40825590: 0x0000000f 0x408255d0 0x4081b410 0x4202a8d4 0x0000000f 0x40823000 0x00000001 0x4206f906
10:44:12.549, 408255b0: 0x0000000f 0x408255d0 0x00000005 0x00000000 0x0000000f 0x40823000 0x00000001 0x4206faf0
10:44:12.658, fe 0xfefefefe 0xfefefefe
10:44:12.658,
10:44:12.658,
10:44:12.658,
10:44:12.658, ELF file SHA256: 82cf1e36e
10:44:12.658,
10:44:12.658, Rebooting...
10:44:12.658, ESP-ROM:esp32c6-20220919
10:44:12.658, Build:Sep 19 2022
10:44:12.658, rst:0xc (SW_CPU),boot:0xc (SPI_FAST_FLASH_BOOT)
10:44:12.658, Saved PC:0x4001975a
10:44:12.658, SPIWP:0xee
10:44:12.658, mode:DIO, clock div:2
10:44:12.658, load:0x40875720,len:0x1228
10:44:12.658, load:0x4086c110,len:0xd9c
10:44:12.658, load:0x4086e610,len:0x2f74
10:44:12.658, entry 0x4086c110
10:44:12.549, 408255d0: 0x00000000 0x00000000 0x00000000 0x004d8c88 0x00000000 0x000464da 0x7fffffff 0x000000ff
10:44:12.549, 408255f0: 0x0000000f 0xfffffffd 0x40819190 0x420298a0 0x0000000f 0x00000000 0x40819190 0x42029b92
10:44:12.549, 40825610: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x4083e470 0x00000000
10:44:12.549, 40825630: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
10:44:12.549, 40825650: 0x00000000 0x00000000 0x00000000 0x42017984 0x00000000 0x00000000 0x00000000 0x4201799a
10:44:12.549, 40825670: 0x00000000 0x00000000 0x00000000 0x40809a28 0x00000000 0x00000000 0x00000000 0x00000000
10:44:12.549, 40825690: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
10:44:12.549, 408256b0: 0xa5a5a5a5 0xbaad5678 0x00000cb1 0x40823174 0x40823174 0xfefefefe 0xfefefefe 0x03f00010
10:44:12.549, 408256d0: 0x0000ffff 0x05000000 0x40825704 0xfefefefe 0xfefefefe 0xfefefefe 0xfefefefe 0xffffffff
10:44:12.549, 408256f0: 0xffffffff 0xfefefefe 0xfefefefe 0xfefefefe 0xfefefefe 0x01200011 0x0000ffff 0x05000000
10:44:12.549, 40825710: 0x40825738 0xfefefefe 0xfefefefe 0xfefefefe 0xfefefefe 0xad5678ff 0xfefefefe 0xfefefefe
10:44:12.549, 40825730: 0xfefefefe 0xfefefefe 0x400ceffe 0x0000ffff 0x05000000 0x40825774 0xfefefefe 0xfefefefe
10:44:12.549, 40825750: 0xfefefefe 0xfefefefe 0x00000000 0x00000000 0x00000000 0xfefefefe 0xfefefefe 0xfefefefe
10:44:12.549, 40825770: 0xfefefefe 0x4001e000 0x0000ffff 0x05000000 0x408257a8 0xfefefefe 0xfefefefe 0xfefefefe
10:44:12.549, 40825790: 0xfefefefe 0xad567800 0xfefefefe 0xfefefefe 0xfefefefe 0xfefefefe 0x4001e001 0x0000ffff
10:44:12.549, 408257b0: 0x05000000 0x408257dc 0xfefefefe 0xfefefefe 0xfefefefe 0xfefefefe 0xad567800 0xfefefefe
10:44:12.549, 408257d0: 0xfefefefe 0xfefefefe 0xfefefefe 0x4002e002 0x0000ffff 0x05000000 0x4083f35c 0xfefefefe
10:44:12.549, 408257f0: 0xfefefefe 0xfefefefe 0xfefefefe 0x56780000 0xfefefefe 0xfefefefe 0xfefefefe 0xfefefefe
10:44:13.205, 40825810: 0x00000500 0x408255dc 0xee000002 0xeb420190 0x40825924 0xfefefe[ 1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012a44
10:44:13.205, [ 12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012a08
10:44:13.205, [ 23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x420129cc
10:44:13.998, [ 35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012990
10:44:13.998, [ 46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012a44
10:44:13.998, [ 57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012a08
10:44:13.998, [ 69][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x420129cc
10:44:13.998, [ 80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012990
10:44:13.998, [ 91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DM (38) successfully set to 0x4200e576
10:44:13.998, [ 103][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DP (39) successfully set to 0x4200e576
10:44:13.998, [ 114][V][ZigbeeEP.cpp:21] ZigbeeEP(): Endpoint: 1
10:44:13.998, [ 131][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type UART_RX (2) with bus 0x4081444c
10:44:13.998, [ 142][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type UART_TX (3) with bus 0x4081444c
10:44:13.998, [ 152][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 12 successfully set to type USB_DM (38) with bus 0x40818b68
10:44:13.998, [ 163][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type USB_DP (39) with bus 0x40818b68
10:44:13.998, =========== Before Setup Start ===========Chip Info:------------------------------------------ Model : ESP32-C6 Package : 0 Revision : 0.01 Cores : 1 CPU Frequency : 160 MHz XTAL Frequency : 40 MHz Features Bitfield : 0x00000052 Embedded Flash : No Embedded PSRAM : No 2.4GHz WiFi : Yes Classic BT : No BT Low Energy : Yes IEEE 802.15.4 : Yes------------------------------------------INTERNAL Memory Info:------------------------------------------ Total Size : 394204 B ( 385.0 KB) Free Bytes : 345204 B ( 337.1 KB) Allocated Bytes : 37344 B ( 36.5 KB) Minimum Free Bytes: 345204 B ( 337.1 KB) Largest Free Block: 319476 B ( 312.0 KB)------------------------------------------Flash Info:------------------------------------------ Chip Size : 16777216 B (16 MB) Block Size : 65536 B ( 64.0 KB) Sector Size : 4096 B ( 4.0 KB) Page Size : 256 B ( 0.2 KB) Bus Speed : 40 MHz Bus Mode : QIO------------------------------------------Partitions Info:------------------------------------------ nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA app0 : addr: 0x00010000, size: 2560.0 KB, type: APP, subtype: OTA_0 spiffs : addr: 0x00290000, size: 1384.0 KB, type: DATA, subtype: SPIFFS zb_storage : addr: 0x003EA000, size: 16.0 KB, type: DATA, subtype: FAT zb_fct : addr: 0x003EE000, size: 4.0 KB, type: DATA, subtype: FAT rcp_fw : addr: 0x003EF000, size: 4.0 KB, type: DATA, subtype: SPIFFS coredump : addr: 0x003F0000, size: 64.0 KB, type: DATA, subtype: COREDUMP------------------------------------------Software Info:------------------------------------------ Compile Date/Time : Mar 10 2025 09:32:48 Compile Host OS : linux ESP-IDF Version : v5.3.2-584-g489d7a2b3a-dirty Arduino Version : 3.1.3------------------------------------------Board Info:------------------------------------------ Arduino Board : ESP32C6_DEV Arduino Variant : esp32c6 Arduino FQBN : esp32:esp32:esp32c6:PartitionScheme=custom,ZigbeeMode=zczr,DebugLevel=verbose,CDCOnBoot=cdc============ Before Setup End ============[ 286][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x4201023a
10:44:13.998, [ 286][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set to type GPIO (1) with bus 0xa
10:44:13.998, [ 287][D][ZigbeeCore.cpp:85] addEndpoint(): Endpoint: 1, Device ID: 0x0050
10:44:13.998, [ 287][D][ZigbeeCore.cpp:166] zigbeeInit(): Initialize Zigbee stack
10:44:13.998, [ 369][D][ZigbeeCore.cpp:173] zigbeeInit(): Register all Zigbee EPs in list
10:44:13.998, [ 374][I][ZigbeeCore.cpp:181] zigbeeInit(): List of registered Zigbee EPs:
10:44:14.077, [ 855][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x0ec9) is open for 180 seconds
10:44:13.998, [ 374][I][ZigbeeCore.cpp:183] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
10:44:13.998, [ 378][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
10:44:13.998, [ 379][I][ZigbeeCore.cpp:275] esp_zb_app_signal_handler(): Zigbee stack initialized
10:44:13.998, [ 384][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x0ec9) closed, devices joining not allowed.
10:44:13.998, [ 386][I][ZigbeeCore.cpp:281] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
10:44:13.998, [ 386][I][ZigbeeCore.cpp:294] esp_zb_app_signal_handler(): Device rebooted
10:44:13.998, [ 387][I][ZigbeeCore.cpp:298] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
10:44:13.998, [ 387][D][ZigbeeCore.cpp:539] searchBindings(): Requesting binding table for address 0x0000
10:44:13.998, [ 389][D][ZigbeeCore.cpp:479] bindingTableCb(): Binding table callback for address 0x0000 with status 0
10:44:13.998, [ 389][D][ZigbeeCore.cpp:482] bindingTableCb(): Binding table info: total 0, index 0, count 0
10:44:13.998, [ 390][D][ZigbeeCore.cpp:485] bindingTableCb(): No binding table entries found
Date: 18.04.2025 - 10:44:26
End log file
