Dimmer Dziwny problem
veeroos
Been thanked: 9 times
Cześć pytanko. Pacjent dimmer. Program prosty
#define STATUS_LED_GPIO 8
#define BUTTON_CFG_GPIO 9
#define DIMMER_PIN 10
#define przycisk 7
#define DEFAULT_BUTTON_STEP 1
#define DEFAULT_FADE_EFFECT 500
#define DEFAULT_ITERATION_DELAY 750
#include <SuplaDevice.h>
#include <supla/control/action_trigger.h>
#include <supla/device/status_led.h>
#include <supla/storage/littlefs_config.h>
#include <supla/network/esp_web_server.h>
#include <supla/network/html/device_info.h>
#include <supla/network/html/protocol_parameters.h>
#include <supla/network/html/status_led_parameters.h>
#include <supla/network/html/wifi_parameters.h>
#include <supla/device/supla_ca_cert.h>
#include <supla/events.h>
#include <supla/network/html/custom_text_parameter.h>
#include <supla/network/html/custom_parameter.h>
#include <supla/control/dimmer_leds.h>
#include <supla/network/html/div.h>
#include <supla/network/html/h3_tag.h>
const char DEV_NAME[] = "dev_name";
char devName[30] = {};
const char BUTTON_STEP[] = "button_step";
int32_t btnStep = DEFAULT_BUTTON_STEP;
const char FADE_EFFECT[] = "fade_effect";
int32_t fadeEffect_ = DEFAULT_FADE_EFFECT;
const char ITERATION_DELAY[] = "iteration_delay";
int32_t iterationDelay = DEFAULT_ITERATION_DELAY;
#include <supla/storage/eeprom.h>
Supla::Eeprom eeprom;
Supla::ESPWifi wifi;
Supla::LittleFsConfig configSupla;
Supla::Device::StatusLed statusLed(STATUS_LED_GPIO, true); // inverted state
Supla::EspWebServer suplaServer;
void setup() {
  Serial.begin(115200);
  //******************własna nazwa*****************************
  Supla::Storage::Init();
  if (Supla::Storage::ConfigInstance()->getString(DEV_NAME, devName, 30)) {
    SUPLA_LOG_DEBUG("# Param[%s]: %s", DEV_NAME, devName);
  } else {
    Supla::Storage::ConfigInstance()->setString(DEV_NAME, "Supla-DIMMER_1CH");
  if (Supla::Storage::ConfigInstance()->getInt32(BUTTON_STEP, &btnStep)) {
    if (btnStep <= 0 || btnStep > 20) {
      Supla::Storage::ConfigInstance()->setInt32(BUTTON_STEP, btnStep);
    SUPLA_LOG_DEBUG("# Param[%s]: %d", BUTTON_STEP, btnStep);
  } else {
    SUPLA_LOG_DEBUG("# Param[%s] is not set", BUTTON_STEP);
  if (Supla::Storage::ConfigInstance()->getInt32(FADE_EFFECT, &fadeEffect_)) {
    if (fadeEffect_ <= 0 || fadeEffect_ > 3000) {
      Supla::Storage::ConfigInstance()->setInt32(FADE_EFFECT, fadeEffect_);
    SUPLA_LOG_DEBUG("# Param[%s]: %d", FADE_EFFECT, fadeEffect_);
  } else {
    SUPLA_LOG_DEBUG("# Param[%s] is not set", FADE_EFFECT);
  if (Supla::Storage::ConfigInstance()->getInt32(ITERATION_DELAY,
                                                            &iterationDelay)) {
    if (iterationDelay <= 0 || iterationDelay > 5000) {
      Supla::Storage::ConfigInstance()->setInt32(ITERATION_DELAY,
                                                               iterationDelay);
    SUPLA_LOG_DEBUG("# Param[%s]: %d", ITERATION_DELAY, iterationDelay);
  } else {
    SUPLA_LOG_DEBUG("# Param[%s] is not set", ITERATION_DELAY);
  auto button = new Supla::Control::Button(przycisk, true, true);
  auto buttonCfgRelay = new Supla::Control::Button(BUTTON_CFG_GPIO, true, true);
  buttonCfgRelay->configureAsConfigButton(&SuplaDevice);
  auto sciemniacz = new Supla::Control::DimmerLeds(DIMMER_PIN);
  sciemniacz->setStep(btnStep);
  sciemniacz->setFadeEffectTime(fadeEffect_);
  sciemniacz->setMinMaxIterationDelay(iterationDelay);
  sciemniacz->setDefaultStateRestore();
  //auto button = new Supla::Control::Button(przycisk, true, true);
  button->setMulticlickTime(200);
  button->setHoldTime(400);
  button->repeatOnHoldEvery(35);
  button->addAction(Supla::ITERATE_DIM_ALL, sciemniacz, Supla::ON_HOLD);
  button->addAction(Supla::TOGGLE, sciemniacz, Supla::ON_CLICK_1);
  new Supla::Html::DeviceInfo(&SuplaDevice);
  new Supla::Html::WifiParameters;
  new Supla::Html::ProtocolParameters;
  new Supla::Html::StatusLedParameters;
  new Supla::Html::CustomTextParameter(DEV_NAME, "Nazwa urządzenia", 30);
  new Supla::Html::DivEnd();
  new Supla::Html::DivBegin("box");
  new Supla::Html::H3Tag("Regulacja Parametrów");
  new Supla::Html::CustomParameter(BUTTON_STEP, "Krok regulacji jasności",
                                                          DEFAULT_BUTTON_STEP);
  new Supla::Html::CustomParameter(FADE_EFFECT, "Efekt wygaszania (ms) (1-3000)",
                                                          DEFAULT_FADE_EFFECT);
  new Supla::Html::CustomParameter(ITERATION_DELAY, "Opóźnienie powtarzania (ms) (1-5000)",
                                                      DEFAULT_ITERATION_DELAY);
  // configure defualt Supla CA certificate
  httpUpdater.setup(suplaServer.getServerPtr(), "/update");
  new Supla::Html::UpdateParameter;
  SuplaDevice.setName(devName);
  SuplaDevice.setSuplaCACert(suplaCACert);
  SuplaDevice.setSupla3rdPartyCACert(supla3rdCACert);
  SuplaDevice.begin();
void loop() {
  SuplaDevice.iterate();
Najprostszy Dimmer pod ESP32 C3, jednakże jego zachowanie jest dosyć dziwne. Jeżeli Dimmer jest zalogowany do Clouda, jeżeli nie jest dodany do Clouda (lub tryb konfiguracji), oraz jeżeli nie jest w zasięgu sieci do której zastał dodany to działa poprawnie. Jednakże jeżeli Dimmer widzi sieć do której został dodany, jednakże sieć nie pozwala mu się połączyć (przekroczona maksymalna liczba użytkowników w sieci) to działa jak chce, przeważnie nie reaguje na przycisk do regulacji (lub włączania). Czy ktoś spotkał się z takim problemem?
https://github.com/v33r005
Zbierz logi i opisz dokładniej co się dzieje.
Może procek cały czas próbuje się połączyć z wifi, a ten wątek ma wyższy priorytet niż np obsługa przycisku czy dimmera i stąd takie efekty
veeroos
klew wrote: Thu May 08, 2025 8:03 pm Zbierz logi i opisz dokładniej co się dzieje.
Też właśnie mi się zdaje, jutro postaram się zebrać logi
veeroos
No to logi, zanim dodam układ do Clouda:
ESP-ROM:esp32c3-api1-20210207
rent status: [5] SuplaDevice initialized
Wi-Fi SSID missing
WiFi: enter config mode with SSID: "SUPLA-DIMMER-1CH-F0F5BDFBEF2C"
Starting local web server
LAST STATE ADDED: Config mode
Current status: [40] Config mode
 *** Supla - Initialization done
Button[0] pressed
Button[0] released
RGBWBase[0]: 0,0,0,0,100
Wi-Fi SSID missing
Channel(0) value changed to RGB(0, 0, 0), colBr(0), bright(100)
Wrote 1 bytes to storage at 15
Wrote 7 bytes to storage at 8
Commit
Button[0] pressed
Button[0] released
RGBWBase[0]: 0,0,0,0,0
Wi-Fi SSID missing
Channel(0) value changed to RGB(0, 0, 0), colBr(0), bright(0)
Button[0] pressed
Button[0] released
Wi-Fi SSID missing
Button[0] pressed
Button[0] released
Wi-Fi SSID missing
Commit
ja widać ładnie się załącza za każdym razem, tak samo jest jak sieć wifi nie nadaje, oraz jak jesteśmy zalogowani, jednakże jak sieć nie wpuszcza urządzenia:
WiFi Station disconnected
Deinitializing SRPC
Supla server connection lost. Trying to reconnect
nnecting, return error
E (97869) wifi:sta is connecting, return error
E (97948) wifi:sta is connecting, return error
E (98071) wifi:sta is connecting, return error
E (98146) wifi:sta is connecting, return error
E (98221) wifi:sta is connecting, return error
E (98302) wifi:sta is connecting, return error
E (98372) wifi:sta is connecting, return error
E (98423) wifi:sta is connecting, return error
E (98465) wifi:sta is connecting, return error
E (98513) wifi:sta is connecting, return error
E (98554) wifi:sta is connecting, return error
E (98592) wifi:sta is connecting, return error
E (98685) wifi:sta is connecting, return error
E (98860) wifi:sta is connecting, return error
E (98938) wifi:sta is connecting, return error
E (99033) wifi:sta is connecting, return error
E (99106) wifi:sta is connecting, return error
E (99214) wifi:sta is connecting, return error
E (99295) wifi:sta is connecting, return error
E (99368) wifi:sta is connecting, return error
E (99443) wifi:sta is connecting, return error
E (99484) wifi:sta is connecting, return error
E (99626) wifi:sta is connecting, return error
E (99658) wifi:sta is connecting, return error
E (99728) wifi:sta is connecting, return error
eturn error
E (99929) wifi:sta is connecting, return error
E (100028) wifi:sta is connecting, return error
100172) wifi:sta is connecting, return error
E (100482) wifi:sta is connecting, return error
E (100543) wifi:sta is connecting, return error
E (100608) wifi:sta is connecting, return error
E (100817) wifi:sta is connecting, return error
r
E (101087) wifi:sta is connecting, return error
101153) wifi:sta is connecting, return error
E (101192) wifi:sta is connecting, return error
E (101266) wifi:sta is connecting, return error
E (101335) wifi:sta is connecting, return error
E (101379) wifi:sta is connecting, return error
E (101462) wifi:sta is connecting, return error
E (101597) wifi:sta is connecting, return error
E (101713) wifi:sta is connecting, return error
E (101978) wifi:sta is connecting, return error
E (102053) wifi:sta is connecting, return error
E (102093) wifi:sta is connecting, return error
E (102180) wifi:sta is connecting, return error
E (102272) wifi:sta is connecting, return error
E (102373) wifi:sta is connecting, return error
E (102500) wifi:sta is connecting, return error
E (102609) wifi:sta is connecting, return error
E (102682) wifi:sta is connecting, return error
E (102725) wifi:sta is connecting, return error
E (102865) wifi:sta is connecting, return error
E (102905) wifi:sta is connecting, return error
E (103056) wifi:sta is connecting, return error
Button[0] pressed
or
Button[0] released
E (103260) wifi:sta is connecting, return error
E (103336) wifi:sta is connecting, return error
E (103427) wifi:sta is connecting, return error
E (103493) wifi:sta is connecting, return error
E (103529) wifi:sta is connecting, return error
E (103599) wifi:sta is connecting, return error
E (103675) wifi:sta is connecting, return error
E (103723) wifi:sta is connecting, return error
E (103798) wifi:sta is connecting, return error
E (103957) wifi:sta is connecting, return error
E (104034) wifi:sta is connecting, return error
E (104083) wifi:sta is connecting, return error
E (104328) wifi:sta is connecting, return error
E (104481) wifi:sta is connecting, return error
E (104521) wifi:sta is connecting, return error
E (104594) wifi:sta is connecting, return error
E (104666) wifi:sta is connecting, return error
04793) wifi:sta is connecting, return error
E (104868) wifi:sta is connecting, return error
E (104943) wifi:sta is connecting, return error
E (105022) wifi:sta is connecting, return error
E (105068) wifi:sta is connecting, return error
Button[0] pressed
error
E (105214) wifi:sta is connecting, return error
Button[0] released
E (105294) wifi:sta is connecting, return error
E (105342) wifi:sta is connecting, return error
E (105413) wifi:sta is connecting, return error
ror
 (105561) wifi:sta is connecting, return error
E (105611) wifi:sta is connecting, return error
E (105681) wifi:sta is connecting, return error
E (105741) wifi:sta is connecting, return error
E (105866) wifi:sta is connecting, return error
E (105945) wifi:sta is connecting, return error
E (106011) wifi:sta is connecting, return error
E (106054) wifi:sta is connecting, return error
E (106127) wifi:sta is connecting, return error
E (106215) wifi:sta is connecting, return error
cting, return error
E (106334) wifi:sta is connecting, return error
E (106405) wifi:sta is connecting, return error
E (106491) wifi:sta is connecting, return error
E (106566) wifi:sta is connecting, return error
E (106606) wifi:sta is connecting, return error
E (106673) wifi:sta is connecting, return error
E (106733) wifi:sta is connecting, return error
E (106778) wifi:sta is connecting, return error
E (106851) wifi:sta is connecting, return error
E (107000) wifi:sta is connecting, return error
E (107044) wifi:sta is connecting, return error
E (107112) wifi:sta is connecting, return error
E (107181) wifi:sta is connecting, return error
E (107229) wifi:sta is connecting, return error
E (107300) wifi:sta is connecting, return error
E (107382) wifi:sta is connecting, return error
E (107450) wifi:sta is connecting, return error
E (107495) wifi:sta is connecting, return error
E (107564) wifi:sta is connecting, return error
E (107632) wifi:sta is connecting, return error
E (107671) wifi:sta is connecting, return error
Warning: network is not ready (10 s)
E (107756) wifi:sta is connecting, return error
E (107834) wifi:sta is connecting, return error
E (107993) wifi:sta is connecting, return error
E (108032) wifi:sta is connecting, return error
E (108109) wifi:sta is connecting, return error
E (108182) wifi:sta is connecting, return error
E (108213) wifi:sta is connecting, return error
 return error
ng, return error
E (108732) wifi:sta is connecting, return error
E (108932) wifi:sta is connecting, return error
E (109007) wifi:sta is connecting, return error
E (109086) wifi:sta is connecting, return error
E (109161) wifi:sta is connecting, return error
E (109189) wifi:sta is connecting, return error
E (109263) wifi:sta is connecting, return error
E (109307) wifi:sta is connecting, return error
E (109384) wifi:sta is connecting, return error
E (109543) wifi:sta is connecting, return error
E (109615) wifi:sta is connecting, return error
E (109658) wifi:sta is connecting, return error
E (109735) wifi:sta is connecting, return error
E (109803) wifi:sta is connecting, return error
turn error
E (110096) wifi:sta is connecting, return error
E (110177) wifi:sta is connecting, return error
E (110279) wifi:sta is connecting, return error
Oczywiście urywek tego co się dzieje. Co któryś tam raz udaje się załączyć, ale o regulacji można zapomnieć, nie pokazuje nawet wciśniętego guzika w logach. Da się coś z tym zrobić? Znaczy ja nie mam problemu, bo wiem, że sieć jest przeciążona i nie wpuszcza nowych użytkowników, trzeba wymienić router itp, ale może na przykład da się ustawić w bibliotece priorytet że automatyka ma się wykonywać z wyższym priorytetem niż połączenie z siecią. Tutaj to jest tylko przykład z dimmerem, który tak na prawdę jak nie będzie działał to trudno, można sobie w ciemności posiedzieć, ale załóżmy, że takim urządzeniem jest termostat i nie zareaguje odpowienio jak sieć zgłupieje.
Może da się coś z tym zrobić?
veeroos wrote: Fri May 09, 2025 12:22 pm wyższym priorytetem niż połączenie z siecią. Tutaj to jest tylko przykład z dimmerem, który tak na prawdę jak nie będzie działał to trudno, można sobie w ciemności posiedzieć, ale załóżmy, że takim urządzeniem jest termostat i nie zareaguje odpowienio jak sieć zgłupieje.
Wydaje mi się, że coś podobnego kiedyś z lukfudem omawiałem. Tam w implementacji "wifi esp" jest robiony "reconnect" a chyba niektóre boardy dodatkowo wysyłają jakiś event "disconnect" i tam się jakaś pętla robi, która bez przerwy włącza/wyłącza Wi-Fi.
Problem jest związany tylko z kompilacjami na bazie "Arduino IDE" oraz tylko na niektórych boardach.
Dobrze by było, gdyby ktoś usiadł nad tym tematem i sprawdził: esp32, esp32-c3 i kilka innych boardów jak to się zachowuje i jakie eventy są generowane.
Problem prawdopodobnie jest w tej linijce:
https://github.com/SUPLA/supla-device/b ... wifi.h#L98
Możesz spróbować ją usunąć i sprawdzić czy to pomoże i czy urządzenie łączy się samodzielnie do Wi-Fi, gdy miało połączenie i je utraci. Wtedy będziemy wiedzieli, że to dobry trop. Następnie trzeba sprawdzić kilka różnych boardów ESP32, tak aby naprawiając jeden board, nie zepsuć innych.
Ewentualnie możesz issue dodać, choć z mojej strony jest kiepsko z czasem i osobiście nie używam Arduino IDE już wcale. Przez to jeszcze trudniej mi znaleźć jest czas na rzeczy, których osobiście do niczego nie potrzebuję :P
veeroos
No więc tak. Po usunięciu tej linii w ogóle moduł nie łączy się z siecią ustawioną.
veeroos wrote: Fri May 09, 2025 5:18 pm No więc tak. Po usunięciu tej linii w ogóle moduł nie łączy się z siecią ustawioną.
To dziwne. Pierwsze połączenie powinno pójść.
veeroos
klew wrote: Fri May 09, 2025 5:28 pm
Sprawdzę jeszcze raz bo teraz to po cofnięciu zmian nie chce mi się moduł połączyć, wezmę kolejnego procka, bo może zamordowałeś go teraz kombinowaniem 😁
veeroos wrote: Fri May 09, 2025 6:38 pm
Nie znam sposobu na zepsucie ESP poprzez soft. Nigdy też nie udało mi się czegoś takiego zrobić, a wgrywam czasem po kilkadziesiąt razy dziennie ;)
Zibi_007
Has thanked: 10 times
Been thanked: 31 times
Przepraszam, że się wtrącam ale to może ten C3 z serii tych "felernych". U mnie albo nie pracują od początku, albo po pewnym czasie łapią takie lagi, że nawet połączenie ze stroną konfiguracyjną trwa wieki. W ciągu ostatnich kilku dni znowu dwa poszły na złom. Kupowane po 5 zł, więc pieniędzy nie szkoda, ale denerwuje mnie stracony czas na dochodzenie co jest nie tak...
Return to “supla-dev”
