vajera wrote: Thu Aug 07, 2025 10:02 am
Hmm...a mam prośbę - czy możesz wgrać na C6 takie narzędzie jak skaner i odczytać logi z parowania? Najlepiej wgrywać go z uprzednim wyczyszczeniem FLASHu, więc jak masz więcej tych C6, to chwilowo poświęć jedno na skaner.
============ After Setup End =============
[ 90351][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 90354][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 91197][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd9fa)
[ 91198][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[ 91199][D][ZigbeeGateway.cpp:545] zbDeviceAnnce(): zbDeviceAnnce short address (0xd9fa), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[ 91199][D][ZigbeeGateway.cpp:548] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xd9fa), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[ 91200][I][ZigbeeGateway.cpp:572] zbDeviceAnnce(): Tuya magic last hope
[ 91761][I][ZigbeeGateway.cpp:615] printJoinedDevices(): joined devices:
[ 91761][I][ZigbeeGateway.cpp:618] printJoinedDevices(): Device on endpoint 1, short address: 0xd9fa
[ 91962][I][ZigbeeGateway.cpp:1803] sendCustomClusterCmd(): _custom_cmd_last_tsn = 1
[ 92162][I][ZigbeeGateway.cpp:1811] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[ 92162][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 93163][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 96163][I][ZigbeeGateway.cpp:380] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 98163][E][ZigbeeGateway.cpp:383] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 98163][I][Z2S_Device_Scanner.ino:139] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
Scheduling soft restart in 0 ms
Current status: [41] Software reset
[ 98165][I][ZigbeeGateway.cpp:1385] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 98366][I][ZigbeeGateway.cpp:322] zbPrintDeviceDiscovery(): short_addr_req 55802
[ 98856][I][ZigbeeGateway.cpp:256] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 55802, endpoints count 3
[ 98856][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 98857][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 2, id 35
[ 98858][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 3, id 38
[ 98968][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 55802, endpoint # 1
[ 98969][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[ 98970][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 3
[ 98970][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 5
[ 98971][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[ 99081][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 55802, endpoint # 35
[ 99082][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 2
[ 99083][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 99083][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[ 99084][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[ 99084][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 4, id 15
[ 99085][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 5, id 32
[ 99085][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 6, id 1280
[ 99086][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
[ 99087][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[ 99191][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 55802, endpoint # 38
[ 99192][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 1
[ 99193][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 99194][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[ 99194][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 1026
[ 99195][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
[ 99645][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 99646][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x0), attribute id (0x0), data type (0x20)
[ 99647][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x0), attribute id (0x4), data type (0x42)
[ 99648][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x0), attribute id (0x5), data type (0x42)
[ 99649][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x0), attribute id (0x6), data type (0x42)
[ 99650][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x0), attribute id (0x7), data type (0x30)
[ 99758][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 99758][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 99759][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x1), attribute id (0x31), data type (0x30)
[ 99760][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x1), attribute id (0x33), data type (0x20)
[ 99762][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x1), attribute id (0x34), data type (0x20)
[ 99763][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x1), attribute id (0x36), data type (0x20)
[ 99764][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x1), attribute id (0x3e), data type (0x1b)
[ 99866][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 99867][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x3), attribute id (0x0), data type (0x21)
[ 99981][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 99981][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0xf), attribute id (0x1c), data type (0x42)
[ 99982][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0xf), attribute id (0x51), data type (0x10)
[ 99983][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0xf), attribute id (0x55), data type (0x10)
[ 99984][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0xf), attribute id (0x67), data type (0x30)
[ 99985][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0xf), attribute id (0x6f), data type (0x18)
[100092][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[100093][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x20), attribute id (0x0), data type (0x23)
[100094][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x20), attribute id (0x1), data type (0x23)
[100095][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x20), attribute id (0x2), data type (0x21)
[100096][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x20), attribute id (0x3), data type (0x21)
[100205][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[100206][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x500), attribute id (0x0), data type (0x30)
[100207][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x500), attribute id (0x1), data type (0x31)
[100208][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x500), attribute id (0x2), data type (0x19)
[100209][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x500), attribute id (0x10), data type (0xf0)
[100210][I][ZigbeeGateway.cpp:1007] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xd9fa), source endpoint (0x23), source cluster (0x500), attribute id (0x11), data type (0x20)
[100311][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[100423][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[100534][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[100644][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[100756][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[100868][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[102874][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[102874][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0xd9fa) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[102875][I][ZigbeeGateway.cpp:983] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[104417][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[104418][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xd9fa), src_endpoint(35) to dst_endpoint(1), cluster(0x500) for command (0x0) with status 0x0
[104419][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[104420][I][ZigbeeGateway.cpp:1753] zbCmdDefaultResponse(): tsn = 20, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[104420][I][ZigbeeGateway.cpp:1767] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 20, _custom_cmd_last_tsn_flag = 2
[104421][I][ZigbeeGateway.cpp:1769] zbCmdDefaultResponse(): custom cmd rssi -43
[104432][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[104432][V][ZigbeeHandlers.cpp:322] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xd9fa) src endpoint(35) to dst endpoint(1) cluster(0x500), zone status (0x35), extended status (0x0), zone id (0x1), delay (0x40)
[105355][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[106005][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0xd9fa), rejoin (NO)
[109026][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[109028][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[109873][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x24f9)
[109874][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[109874][D][ZigbeeGateway.cpp:545] zbDeviceAnnce(): zbDeviceAnnce short address (0x24f9), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[109875][D][ZigbeeGateway.cpp:548] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x24f9), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[109876][I][ZigbeeGateway.cpp:572] zbDeviceAnnce(): Tuya magic last hope
[110399][I][ZigbeeGateway.cpp:615] printJoinedDevices(): joined devices:
[110399][I][ZigbeeGateway.cpp:618] printJoinedDevices(): Device on endpoint 1, short address: 0x24f9
[110600][I][ZigbeeGateway.cpp:1803] sendCustomClusterCmd(): _custom_cmd_last_tsn = 22
[110800][I][ZigbeeGateway.cpp:1811] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[110800][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[111801][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x17
[114801][I][ZigbeeGateway.cpp:380] zbQueryDeviceBasicCluster(): basic tsn 0x18
[116801][E][ZigbeeGateway.cpp:383] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[116801][I][Z2S_Device_Scanner.ino:139] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
[116802][I][ZigbeeGateway.cpp:1385] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[117004][I][ZigbeeGateway.cpp:322] zbPrintDeviceDiscovery(): short_addr_req 9465
[117531][I][ZigbeeGateway.cpp:256] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 9465, endpoints count 3
[117532][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[117532][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 2, id 35
[117533][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 3, id 38
[117643][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 9465, endpoint # 1
[117644][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[117644][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 3
[117645][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 5
[117645][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[117754][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 9465, endpoint # 35
[117754][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 2
[117755][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[117756][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[117756][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[117757][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 4, id 15
[117757][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 5, id 32
[117758][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 6, id 1280
[117758][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
[117759][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[117864][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 9465, endpoint # 38
[117865][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 1
[117865][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[117866][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[117867][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 1026
[117867][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
[118309][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[118422][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[118535][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[118645][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[118755][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[118869][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[118981][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[119092][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[119203][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[119314][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[119425][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[119536][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[121547][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[121548][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0x24f9) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[121549][I][ZigbeeGateway.cpp:983] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[123088][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[123089][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x24f9), src_endpoint(35) to dst_endpoint(1), cluster(0x500) for command (0x0) with status 0x0
[123090][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[123091][I][ZigbeeGateway.cpp:1753] zbCmdDefaultResponse(): tsn = 41, _custom_cmd_last_tsn = 22, _custom_cmd_last_tsn_flag = 2
[123091][I][ZigbeeGateway.cpp:1767] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 41, _custom_cmd_last_tsn_flag = 2
[123092][I][ZigbeeGateway.cpp:1769] zbCmdDefaultResponse(): custom cmd rssi -35
[123105][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[123105][V][ZigbeeHandlers.cpp:322] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x24f9) src endpoint(35) to dst endpoint(1) cluster(0x500), zone status (0x35), extended status (0x0), zone id (0x1), delay (0x40)
[124029][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[124678][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x24f9), rejoin (NO)
[127697][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[127700][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[128546][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x064b)
[128547][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[128547][D][ZigbeeGateway.cpp:545] zbDeviceAnnce(): zbDeviceAnnce short address (0x64b), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[128548][D][ZigbeeGateway.cpp:548] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x64b), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[128549][I][ZigbeeGateway.cpp:572] zbDeviceAnnce(): Tuya magic last hope
[129141][I][ZigbeeGateway.cpp:615] printJoinedDevices(): joined devices:
[129141][I][ZigbeeGateway.cpp:618] printJoinedDevices(): Device on endpoint 1, short address: 0x64b
[129342][I][ZigbeeGateway.cpp:1803] sendCustomClusterCmd(): _custom_cmd_last_tsn = 43
[129542][I][ZigbeeGateway.cpp:1811] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[129542][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[130543][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x2c
[133543][I][ZigbeeGateway.cpp:380] zbQueryDeviceBasicCluster(): basic tsn 0x2d
[135543][E][ZigbeeGateway.cpp:383] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[135543][I][Z2S_Device_Scanner.ino:139] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
[135544][I][ZigbeeGateway.cpp:1385] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[135747][I][ZigbeeGateway.cpp:322] zbPrintDeviceDiscovery(): short_addr_req 1611
[136204][I][ZigbeeGateway.cpp:256] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 1611, endpoints count 3
[136205][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[136205][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 2, id 35
[136206][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 3, id 38
[136316][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 1611, endpoint # 1
[136317][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[136317][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 3
[136318][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 5
[136318][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[136426][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 1611, endpoint # 35
[136427][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 2
[136428][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[136428][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[136429][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[136429][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 4, id 15
[136430][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 5, id 32
[136430][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 6, id 1280
[136431][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
[136431][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[136538][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 1611, endpoint # 38
[136539][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 1
[136539][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[136540][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[136541][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 1026
[136541][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
[136985][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[137097][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[137210][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[137322][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[137433][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[137544][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[137657][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[137766][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[137879][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[137990][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[138104][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[138215][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[140224][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[140224][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0x64b) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[140226][I][ZigbeeGateway.cpp:983] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[141766][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[141766][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x64b), src_endpoint(35) to dst_endpoint(1), cluster(0x500) for command (0x0) with status 0x0
[141767][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[141768][I][ZigbeeGateway.cpp:1753] zbCmdDefaultResponse(): tsn = 62, _custom_cmd_last_tsn = 43, _custom_cmd_last_tsn_flag = 2
[141769][I][ZigbeeGateway.cpp:1767] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 62, _custom_cmd_last_tsn_flag = 2
[141770][I][ZigbeeGateway.cpp:1769] zbCmdDefaultResponse(): custom cmd rssi -33
[141780][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[141781][V][ZigbeeHandlers.cpp:322] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x64b) src endpoint(35) to dst endpoint(1) cluster(0x500), zone status (0x35), extended status (0x0), zone id (0x1), delay (0x40)
[142701][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[143356][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x064b), rejoin (NO)
[146377][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[146379][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[147227][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x26a4)
[147228][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[147228][D][ZigbeeGateway.cpp:545] zbDeviceAnnce(): zbDeviceAnnce short address (0x26a4), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[147229][D][ZigbeeGateway.cpp:548] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x26a4), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[147230][I][ZigbeeGateway.cpp:572] zbDeviceAnnce(): Tuya magic last hope
[147781][I][ZigbeeGateway.cpp:615] printJoinedDevices(): joined devices:
[147781][I][ZigbeeGateway.cpp:618] printJoinedDevices(): Device on endpoint 1, short address: 0x26a4
[147982][I][ZigbeeGateway.cpp:1803] sendCustomClusterCmd(): _custom_cmd_last_tsn = 64
[148182][I][ZigbeeGateway.cpp:1811] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[148182][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[149183][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x41
[152183][I][ZigbeeGateway.cpp:380] zbQueryDeviceBasicCluster(): basic tsn 0x42
[154183][E][ZigbeeGateway.cpp:383] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[154183][I][Z2S_Device_Scanner.ino:139] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
[154185][I][ZigbeeGateway.cpp:1385] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[154386][I][ZigbeeGateway.cpp:322] zbPrintDeviceDiscovery(): short_addr_req 9892
[154886][I][ZigbeeGateway.cpp:256] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 9892, endpoints count 3
[154887][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[154887][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 2, id 35
[154888][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 3, id 38
[155000][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 9892, endpoint # 1
[155001][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[155001][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 3
[155002][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 5
[155003][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[155113][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 9892, endpoint # 35
[155114][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 2
[155115][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[155115][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[155116][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[155116][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 4, id 15
[155117][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 5, id 32
[155117][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 6, id 1280
[155118][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
[155119][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[155226][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 9892, endpoint # 38
[155227][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 1
[155227][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[155228][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[155229][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 1026
[155229][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
[155672][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[155783][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[155893][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[156005][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[156117][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[156228][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[156341][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[156453][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[156568][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[156679][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[156788][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[156901][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[158905][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[158906][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0x26a4) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[158907][I][ZigbeeGateway.cpp:983] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[160446][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[160446][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x26a4), src_endpoint(35) to dst_endpoint(1), cluster(0x500) for command (0x0) with status 0x0
[160448][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[160448][I][ZigbeeGateway.cpp:1753] zbCmdDefaultResponse(): tsn = 83, _custom_cmd_last_tsn = 64, _custom_cmd_last_tsn_flag = 2
[160449][I][ZigbeeGateway.cpp:1767] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 83, _custom_cmd_last_tsn_flag = 2
[160450][I][ZigbeeGateway.cpp:1769] zbCmdDefaultResponse(): custom cmd rssi -34
[160461][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[160461][V][ZigbeeHandlers.cpp:322] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x26a4) src endpoint(35) to dst endpoint(1) cluster(0x500), zone status (0x35), extended status (0x0), zone id (0x1), delay (0x40)
[161381][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[162038][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x26a4), rejoin (NO)
[165063][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[165066][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[165912][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x7b90)
[165912][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[165913][D][ZigbeeGateway.cpp:545] zbDeviceAnnce(): zbDeviceAnnce short address (0x7b90), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[165914][D][ZigbeeGateway.cpp:548] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x7b90), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[165915][I][ZigbeeGateway.cpp:572] zbDeviceAnnce(): Tuya magic last hope
[166417][I][ZigbeeGateway.cpp:615] printJoinedDevices(): joined devices:
[166418][I][ZigbeeGateway.cpp:618] printJoinedDevices(): Device on endpoint 1, short address: 0x7b90
[166619][I][ZigbeeGateway.cpp:1803] sendCustomClusterCmd(): _custom_cmd_last_tsn = 85
[166819][I][ZigbeeGateway.cpp:1811] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[166819][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[167820][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x56
[170820][I][ZigbeeGateway.cpp:380] zbQueryDeviceBasicCluster(): basic tsn 0x57
[172820][E][ZigbeeGateway.cpp:383] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[172820][I][Z2S_Device_Scanner.ino:139] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
[172822][I][ZigbeeGateway.cpp:1385] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[173023][I][ZigbeeGateway.cpp:322] zbPrintDeviceDiscovery(): short_addr_req 31632
[173569][I][ZigbeeGateway.cpp:256] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 31632, endpoints count 3
[173569][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[173570][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 2, id 35
[173571][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 3, id 38
[173681][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 31632, endpoint # 1
[173681][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[173682][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 3
[173683][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 5
[173683][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[173796][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 31632, endpoint # 35
[173797][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 2
[173797][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[173798][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[173799][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[173799][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 4, id 15
[173800][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 5, id 32
[173800][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 6, id 1280
[173801][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
[173801][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[173907][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 31632, endpoint # 38
[173907][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 1
[173908][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[173909][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[173909][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 1026
[173910][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
[174354][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[174467][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[174576][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[174690][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[174803][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[174916][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[175027][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[175140][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[175250][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[175362][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[175475][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[175588][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1004) callback
[177494][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[177495][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0x7b90) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[177496][I][ZigbeeGateway.cpp:983] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[179035][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[179036][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x7b90), src_endpoint(35) to dst_endpoint(1), cluster(0x500) for command (0x0) with status 0x0
[179037][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[179037][I][ZigbeeGateway.cpp:1753] zbCmdDefaultResponse(): tsn = 104, _custom_cmd_last_tsn = 85, _custom_cmd_last_tsn_flag = 2
[179038][I][ZigbeeGateway.cpp:1767] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 104, _custom_cmd_last_tsn_flag = 2
[179039][I][ZigbeeGateway.cpp:1769] zbCmdDefaultResponse(): custom cmd rssi -34
[179050][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[179050][V][ZigbeeHandlers.cpp:322] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x7b90) src endpoint(35) to dst endpoint(1) cluster(0x500), zone status (0x35), extended status (0x0), zone id (0x1), delay (0x40)
[180067][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[180628][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x7b90), rejoin (NO)
[181409][I][ZigbeeCore.cpp:391] esp_zb_app_signal_handler(): Network(0x1c59) closed, devices joining not allowed.
