Pomóżcie proszę początkującemu
Moderator: vajera
potem bramka się resetuje. Potem na jakiś czas łączy z Suplą (pojawiły się kanały). I takie logi lecą.
[  4485][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x2123) is open for 180 seconds
[  4807][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[  4807][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
LittleFsConfig: writing to file "/supla-dev.cfg"
LittleFsConfig: writing to file "/supla-dev.cfg.bak"
PowerCycle: timeout, counter reset to 0
[ 26082][D][AsyncTCP.cpp:1106] _poll(): rx timeout 4
[ 26083][D][AsyncTCP.cpp:1106] _poll(): rx timeout 4
Send: [53 55 50 4C 41 17 11 00 00 00 28 00 00 00 10 00 00 00 7D 17 95 68 00 00 00 00 9D 20 0F 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 17 11 00 00 00 32 00 00 00 10 00 00 00 5E FB 94 68 00 00 00 00 84 08 0C 00 00 00 00 00 53 55 50 4C 41 ]
[ 34472][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 34475][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 35338][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x9b30)
[ 35339][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[ 35339][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x9b30), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[ 35340][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x9b30), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[ 35341][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 35846][I][ZigbeeGateway.cpp:617] printJoinedDevices(): joined devices:
[ 35847][I][ZigbeeGateway.cpp:620] printJoinedDevices(): Device on endpoint 35, short address: 0x9b30
[ 35848][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 35849][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[ 35850][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 36851][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x0
[ 39851][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x0
[ 39885][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 39886][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x9b30) src endpoint(35) to dst endpoint(1) cluster(0x0)
[ 39886][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(20)
[ 39887][I][ZigbeeGateway.cpp:411] zbReadBasicCluster(): Peer Manufacturer is "Develco Products A/S"
[ 39888][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 39889][I][ZigbeeGateway.cpp:431] zbReadBasicCluster(): ZCL version id is "1"
[ 39889][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0x1), type(0x0), value(0)
[ 39890][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(9)
[ 39891][I][ZigbeeGateway.cpp:418] zbReadBasicCluster(): Peer Model is "WISZB-120"
[ 39891][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 39892][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): ZCL power source id is "3"
[ 39893][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[ 39894][I][ZigbeeGateway.cpp:447] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x0
[ 39895][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 40135][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40136][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x9b30), src_endpoint(35) to dst_endpoint(1), cluster(0x0) for command (0x10) with status 0x82
[ 40137][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (0), is common (1)
[ 40137][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 0, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 40138][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 40139][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -25
[ 40219][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40219][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x9b30), src_endpoint(35) to dst_endpoint(1), cluster(0x0) for command (0x10) with status 0x82
[ 40220][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (0), is common (1)
[ 40221][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 0, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 40222][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 40222][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -25
[ 40325][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 40325][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x9b30), src_endpoint(35) to dst_endpoint(1), cluster(0x0) for command (0x10) with status 0x82
[ 40326][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (0), is common (1)
[ 40327][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 0, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 40328][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 40329][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -25
[ 40895][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x0
[ 43896][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x0
[ 45894][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 45895][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x9b30), src_endpoint(35) to dst_endpoint(1), cluster(0x0) for command (0x10) with status 0x82
[ 45896][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (0), is common (1)
[ 45896][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 0, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 45897][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 45898][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -25
[ 45899][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x5
[ 45900][I][Z2S_Gateway.ino:1637] loop(): LIST matched Develco Products A/S::WISZB-120, entry # 93, endpoints # 1, endpoints 0x0::0x0,0x0::0x0,0x0::0x0,0x0::0x0
[ 45901][I][Z2S_Gateway.ino:1657] loop(): DESC matched 0x2002, 2, 0x1, 0x500, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x1
[ 45902][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x9b30), endpoint (0x1), cluster_id (0x1) to bind ZC
[ 46006][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 46007][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 48897][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 48897][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 49031][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 49032][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 49476][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 50019][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[ 50019][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0x9b30) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[ 50021][I][ZigbeeGateway.cpp:986] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[ 51553][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 51553][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 51633][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x9b30), rejoin (NO)
[ 56555][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 56556][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
NLME Status Indication, status: 0x6
[ 61557][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 61558][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 61559][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x9b30), endpoint (0x1), cluster_id (0x1)
[ 61563][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x9b30), endpoint (0x1) cluster (0x1)
[ 61563][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 61759][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x9b30), endpoint (0x1), cluster_id (0x500) to bind ZC
[ 66761][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 66762][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
NLME Status Indication, status: 0x0
[ 71763][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 71764][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 73131][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 73134][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 73999][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x9b30)
[ 74000][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[ 74000][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x9b30), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[ 74001][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x9b30), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[ 74002][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 75537][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 75537][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x9b30) src endpoint(35) to dst endpoint(1) cluster(0x0)
[ 75538][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(20)
[ 75539][I][ZigbeeGateway.cpp:411] zbReadBasicCluster(): Peer Manufacturer is "Develco Products A/S"
[ 75540][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[ 75541][I][ZigbeeGateway.cpp:431] zbReadBasicCluster(): ZCL version id is "1"
[ 75541][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0x1), type(0x0), value(0)
[ 75542][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(9)
[ 75543][I][ZigbeeGateway.cpp:418] zbReadBasicCluster(): Peer Model is "WISZB-120"
[ 75543][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 75544][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): ZCL power source id is "3"
[ 75544][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[ 75545][I][ZigbeeGateway.cpp:447] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x0
[ 76765][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 76766][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 78652][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 78653][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x9b30), src_endpoint(35) to dst_endpoint(1), cluster(0x500) for command (0x0) with status 0x94
[ 78654][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 78654][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 5, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 78655][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 5, _custom_cmd_last_tsn_flag = 255
[ 78656][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -25
[ 78765][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 78765][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 79109][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 79110][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 81560][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 81561][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 81562][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x9b30), endpoint (0x1), cluster_id (0x500)
[ 81566][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x9b30), endpoint (0x1) cluster (0x500)
[ 81566][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 81664][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 81665][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 81766][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x9b30), endpoint (0x1) cluster (0x500)
[ 81767][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 81962][I][z2s_devices_table.cpp:505] Z2S_addZBDeviceTableSlot(): ZB device already in ZB devices table
[ 81964][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x1, channel type 0xffffffff
[ 81965][I][z2s_devices_table.cpp:2474] Z2S_addZ2SDevice(): Device (0x9b30), endpoint (0x1) already in z2s_channels_table (index 0x0)
[ 81966][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x1, channel type 0xffffffff
[ 81967][I][z2s_devices_table.cpp:2474] Z2S_addZ2SDevice(): Device (0x9b30), endpoint (0x1) already in z2s_channels_table (index 0x1)
[ 81968][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x1, channel type 0xffffffff
[ 81969][I][z2s_devices_table.cpp:2474] Z2S_addZ2SDevice(): Device (0x9b30), endpoint (0x1) already in z2s_channels_table (index 0x2)
[ 81970][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x0)
[ 82170][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x7c)
Scheduling soft restart in 5000 ms
LAST STATE ADDED: Software reset (35)
Current status: [41] Software reset
[ 82373][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 82374][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[ 82375][I][Z2S_Gateway.ino:1637] loop(): LIST matched Develco Products A/S::WISZB-120, entry # 93, endpoints # 1, endpoints 0x0::0x0,0x0::0x0,0x0::0x0,0x0::0x0
[ 82377][I][Z2S_Gateway.ino:1657] loop(): DESC matched 0x2002, 2, 0x1, 0x500, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x1
[ 82378][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x9b30), endpoint (0x1), cluster_id (0x1) to bind ZC
[ 85037][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 85038][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 85145][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 85146][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 87571][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 87571][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 87802][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 87802][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 87922][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 87923][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 88135][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 88573][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[ 88574][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0x9b30) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[ 88575][I][ZigbeeGateway.cpp:986] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[ 90107][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[ 90107][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 90108][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x9b30), endpoint (0x1), cluster_id (0x1)
[ 90112][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x9b30), endpoint (0x1) cluster (0x1)
[ 90113][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 90187][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x9b30), rejoin (NO)
[ 90313][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x9b30), endpoint (0x1), cluster_id (0x500) to bind ZC
[ 93230][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 93232][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 94098][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x9b30)
[ 94099][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[ 94099][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x9b30), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[ 94100][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x9b30), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[ 94101][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 95315][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 95316][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 95629][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 95630][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x9b30), src_endpoint(35) to dst_endpoint(1), cluster(0x0) for command (0xb0) with status 0x82
[ 95631][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (0), is common (1)
[ 95632][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 0, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 95632][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 0, _custom_cmd_last_tsn_flag = 255
[ 95633][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -25
[ 95856][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 95856][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 96091][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 96091][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 96200][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 96201][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 98648][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 98648][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 98756][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[ 98757][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 98849][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x9b30), endpoint (0x1), cluster_id (0x500)
[ 98853][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x9b30), endpoint (0x1) cluster (0x500)
[ 98854][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 99054][I][z2s_devices_table.cpp:505] Z2S_addZBDeviceTableSlot(): ZB device already in ZB devices table
[ 99055][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x1, channel type 0xffffffff
[ 99056][I][z2s_devices_table.cpp:2474] Z2S_addZ2SDevice(): Device (0x9b30), endpoint (0x1) already in z2s_channels_table (index 0x0)
[ 99057][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x1, channel type 0xffffffff
[ 99058][I][z2s_devices_table.cpp:2474] Z2S_addZ2SDevice(): Device (0x9b30), endpoint (0x1) already in z2s_channels_table (index 0x1)
[ 99059][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x1, channel type 0xffffffff
[ 99060][I][z2s_devices_table.cpp:2474] Z2S_addZ2SDevice(): Device (0x9b30), endpoint (0x1) already in z2s_channels_table (index 0x2)
[ 99061][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x0)
[ 99261][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x7c)
[ 99464][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 99464][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[ 99466][I][Z2S_Gateway.ino:1637] loop(): LIST matched Develco Products A/S::WISZB-120, entry # 93, endpoints # 1, endpoints 0x0::0x0,0x0::0x0,0x0::0x0,0x0::0x0
[ 99467][I][Z2S_Gateway.ino:1657] loop(): DESC matched 0x2002, 2, 0x1, 0x500, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x1
[ 99468][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x9b30), endpoint (0x1), cluster_id (0x1) to bind ZC
[102001][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[102001][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[102127][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[102127][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[104660][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[104661][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[104773][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[104774][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[105771][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[105772][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0x9b30) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[105773][I][ZigbeeGateway.cpp:986] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[107303][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[107303][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[107536][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[107537][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x9b30), src_endpoint(35) to dst_endpoint(1), cluster(0x500) for command (0x0) with status 0x0
[107538][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[107538][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 13, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[107539][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 13, _custom_cmd_last_tsn_flag = 255
[107540][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -54
[107552][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[107552][V][ZigbeeHandlers.cpp:323] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x9b30) src endpoint(35) to dst endpoint(1) cluster(0x500), zone status (0x35), extended status (0x0), zone id (0x1), delay (0x40)
[107654][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[107655][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[107656][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x9b30), endpoint (0x1), cluster_id (0x1)
[107660][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x9b30), endpoint (0x1) cluster (0x1)
[107661][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[107856][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x9b30), endpoint (0x1), cluster_id (0x500) to bind ZC
[108234][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[109271][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[109272][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[109352][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x9b30), rejoin (NO)
[112396][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[112398][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[113265][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x9b30)
[113266][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[113267][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x9b30), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[113268][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x9b30), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[113269][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[114273][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[114274][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[114802][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[114803][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x9b30) src endpoint(35) to dst endpoint(1) cluster(0x0)
[114804][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(20)
[114805][I][ZigbeeGateway.cpp:411] zbReadBasicCluster(): Peer Manufacturer is "Develco Products A/S"
[114805][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[114806][I][ZigbeeGateway.cpp:431] zbReadBasicCluster(): ZCL version id is "1"
[114807][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0x1), type(0x0), value(0)
[114807][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(9)
[114808][I][ZigbeeGateway.cpp:418] zbReadBasicCluster(): Peer Model is "WISZB-120"
[114809][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[114810][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): ZCL power source id is "3"
[114810][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[114811][I][ZigbeeGateway.cpp:447] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x0
[115025][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[115025][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[115135][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[115136][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[115495][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[115496][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[115608][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x500)
[115609][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[115696][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x9b30), endpoint (0x1), cluster_id (0x500)
[115700][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x9b30), endpoint (0x1) cluster (0x500)
[115701][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[115720][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4082), endpoint (0x40), cluster (0xb914)
[115720][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[115905][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x9b30), endpoint (0x1) cluster (0x500)
[115905][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[116101][I][z2s_devices_table.cpp:505] Z2S_addZBDeviceTableSlot(): ZB device already in ZB devices table
[116102][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x1, channel type 0xffffffff
[116103][I][z2s_devices_table.cpp:2474] Z2S_addZ2SDevice(): Device (0x9b30), endpoint (0x1) already in z2s_channels_table (index 0x0)
[116104][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x1, channel type 0xffffffff
[116105][I][z2s_devices_table.cpp:2474] Z2S_addZ2SDevice(): Device (0x9b30), endpoint (0x1) already in z2s_channels_table (index 0x1)
[116106][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x1, channel type 0xffffffff
[116107][I][z2s_devices_table.cpp:2474] Z2S_addZ2SDevice(): Device (0x9b30), endpoint (0x1) already in z2s_channels_table (index 0x2)
[116108][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x0)
[116308][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x7c)
[116511][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[116512][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[116513][I][Z2S_Gateway.ino:1637] loop(): LIST matched Develco Products A/S::WISZB-120, entry # 93, endpoints # 1, endpoints 0x0::0x0,0x0::0x0,0x0::0x0,0x0::0x0
[116514][I][Z2S_Gateway.ino:1657] loop(): DESC matched 0x2002, 2, 0x1, 0x500, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x1
[116515][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x9b30), endpoint (0x1), cluster_id (0x1) to bind ZC
[118170][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[118171][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[118297][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[118298][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[120823][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x9b30), endpoint (0x1), cluster (0x1)
[120824][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[120937][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0
Ogólnie to kręci się w kółko ;)
Jest zielona dioda, potem krócej niebieska, potem czerwona i reset.
Has thanked: 291 times
Been thanked: 161 times
Wrzuciłem "5" ;)
@klew Wrzucisz jeszcze w wolnej chwili tę "5" testowo? Czy już odpuściłeś ten czujnik? 😉
vajera wrote: Sat Aug 09, 2025 7:05 am @klew Wrzucisz jeszcze w wolnej chwili tę "5" testowo? Czy już odpuściłeś ten czujnik? 😉
W poniedziałek wracam do tematu. Teraz chwilowo na wyjeździe
klew wrote: Sat Aug 09, 2025 7:29 am
To udanego weekendu!
vajera wrote: Sat Aug 09, 2025 8:01 am
Wersja 5:
Channel[110] ConfigType 0 applied
ConfigTypesBitmap: Set config type 0 to 1
Channel[110] Sending SetChannelConfigResult OK (1)
Send: [53 55 50 4C 41 17 0B 00 00 00 B4 02 00 00 03 00 00 00 01 00 6E ]
[ 25639][D][AsyncTCP.cpp:1106] _poll(): rx timeout 4
[ 25640][D][AsyncTCP.cpp:1106] _poll(): rx timeout 4
[ 27140][D][AsyncTCP.cpp:1106] _poll(): rx timeout 4
[ 27640][D][AsyncTCP.cpp:1106] _poll(): rx timeout 4
[ 27641][D][AsyncTCP.cpp:1106] _poll(): rx timeout 4
NLME Status Indication, status: 0x12
[ 33141][D][AsyncTCP.cpp:1106] _poll(): rx timeout 4
Send: [53 55 50 4C 41 17 0C 00 00 00 28 00 00 00 10 00 00 00 5D CF 99 68 00 00 00 00 1F 87 09 00 00 00 00 00 ]
[ 35058][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 35059][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
Recv: [53 55 50 4C 41 17 0C 00 00 00 32 00 00 00 10 00 00 00 40 B3 99 68 00 00 00 00 84 FD 03 00 00 00 00 00 53 55 50 4C 41 ]
[ 42042][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 42042][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 49046][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 49047][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 56426][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 56426][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
Send: [53 55 50 4C 41 17 0D 00 00 00 28 00 00 00 10 00 00 00 76 CF 99 68 00 00 00 00 A2 92 09 00 00 00 00 00 ]
[ 60001][I][Z2S_Gateway.ino:1498] loop(): New UTC time 808225783, new local time 808225783
[ 60003][I][Z2S_Gateway.ino:1512] loop(): Local Time Cluster UTC time attribute 808225783, local time attribute 808225783
[ 60006][I][z2s_web_gui.cpp:470] fillMemoryUptimeInformation(): Memory & uptime information <b><i>Flash chip real size:</b></i> 8388608 B <b>| <i>Free Sketch Space:</b></i> 3407872 B<br><b><i>Free Heap:</b></i> 90536 B <b>| <i>Minimal Free Heap:</b></i> 49100 B <b>| <i>HeapSize:</b></i> 359484 B <b>| <i>MaxAllocHeap:</b></i> 50164 B<br><br><b><i>Local time:</i></b> Mon Aug 11 11:09:43 2025
<b><i>Supla uptime:</i></b> 60 s
Recv: [53 55 50 4C 41 17 0D 00 00 00 32 00 00 00 10 00 00 00 59 B3 99 68 00 00 00 00 DE C5 03 00 00 00 00 00 53 55 50 4C 41 ]
[ 63399][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 63399][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
CB: id(26) Type(0) '' = Zigbee settings
[ 70775][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 70775][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 74642][D][AsyncTCP.cpp:1097] _poll(): ack timeout 4
[ 77922][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 77923][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
Send: [53 55 50 4C 41 17 0E 00 00 00 28 00 00 00 10 00 00 00 8F CF 99 68 00 00 00 00 6B 9E 09 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0E 00 00 00 32 00 00 00 10 00 00 00 72 B3 99 68 00 00 00 00 1B C1 03 00 00 00 00 00 53 55 50 4C 41 ]
[ 85295][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 85296][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
Send: [53 55 50 4C 41 17 0F 00 00 00 28 00 00 00 10 00 00 00 A8 CF 99 68 00 00 00 00 9C AA 09 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0F 00 00 00 32 00 00 00 10 00 00 00 8B B3 99 68 00 00 00 00 37 64 03 00 00 00 00 00 53 55 50 4C 41 ]
[120009][I][Z2S_Gateway.ino:1498] loop(): New UTC time 808225843, new local time 808225843
[120010][I][Z2S_Gateway.ino:1512] loop(): Local Time Cluster UTC time attribute 808225843, local time attribute 808225843
[120012][I][z2s_web_gui.cpp:470] fillMemoryUptimeInformation(): Memory & uptime information <b><i>Flash chip real size:</b></i> 8388608 B <b>| <i>Free Sketch Space:</b></i> 3407872 B<br><b><i>Free Heap:</b></i> 93536 B <b>| <i>Minimal Free Heap:</b></i> 49100 B <b>| <i>HeapSize:</b></i> 359484 B <b>| <i>MaxAllocHeap:</b></i> 50164 B<br><br><b><i>Local time:</i></b> Mon Aug 11 11:10:43 2025
<b><i>Supla uptime:</i></b> 120 s
[133560][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[133563][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
Send: [53 55 50 4C 41 17 10 00 00 00 28 00 00 00 10 00 00 00 C1 CF 99 68 00 00 00 00 48 BA 09 00 00 00 00 00 ]
[134874][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x4f5f)
[134875][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[134875][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x4f5f), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[134876][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x4f5f), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[134877][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
Recv: [53 55 50 4C 41 17 10 00 00 00 32 00 00 00 10 00 00 00 A4 B3 99 68 00 00 00 00 11 39 03 00 00 00 00 00 53 55 50 4C 41 ]
[135064][V][ZigbeeCore.cpp:255] openNetwork(): Opening network for joining for 180 seconds
[135065][I][z2s_web_gui.cpp:2170] generalZigbeeCallback(): get tx power 20
[135066][I][z2s_web_gui.cpp:2170] generalZigbeeCallback(): get tx power 20
[135067][I][z2s_web_gui.cpp:2170] generalZigbeeCallback(): get tx power 20
[135381][I][ZigbeeGateway.cpp:617] printJoinedDevices(): joined devices:
[135382][I][ZigbeeGateway.cpp:620] printJoinedDevices(): Device on endpoint 35, short address: 0x4f5f
[135383][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[135383][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[135385][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[135845][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0xc0bb) is open for 180 seconds
[136385][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x1
[136411][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[136411][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x4f5f) src endpoint(35) to dst endpoint(1) cluster(0x0)
[136412][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(20)
[136413][I][ZigbeeGateway.cpp:411] zbReadBasicCluster(): Peer Manufacturer is "Develco Products A/S"
[136414][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[136415][I][ZigbeeGateway.cpp:431] zbReadBasicCluster(): ZCL version id is "1"
[136415][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0x1), type(0x0), value(0)
[136416][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(9)
[136417][I][ZigbeeGateway.cpp:418] zbReadBasicCluster(): Peer Model is "WISZB-120"
[136417][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[136418][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): ZCL power source id is "3"
[136419][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[136419][I][ZigbeeGateway.cpp:447] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x0
[136420][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[137420][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x2
[139416][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[139417][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x4f5f) src endpoint(35) to dst endpoint(1) cluster(0x0)
[139417][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(20)
[139418][I][ZigbeeGateway.cpp:411] zbReadBasicCluster(): Peer Manufacturer is "Develco Products A/S"
[139420][I][Z2S_Gateway.ino:1656] loop(): LIST matched Develco Products A/S::WISZB-120, entry # 93, endpoints # 2, endpoints 0x23::0x2002,0x26::0x1000,0x0::0x0,0x0::0x0
[139422][I][Z2S_Gateway.ino:1676] loop(): DESC matched 0x2002, 2, 0x1, 0x500, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x23
[139423][I][Z2S_Gateway.ino:1696] loop(): Develco test
[139423][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x0)
[139626][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x7c)
[139789][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1001) callback
[139790][V][ZigbeeHandlers.cpp:192] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x4f5f) src endpoint(35) to dst endpoint(1) cluster(0x500)
[139791][V][ZigbeeHandlers.cpp:199] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x500), attribute(0xffff)
[139792][I][ZigbeeGateway.cpp:954] zbWriteAttrResponse(): tsn = 3, _write_attr_last_tsn = 4, _write_attr_last_tsn_flag = 2
[139792][I][ZigbeeGateway.cpp:968] zbWriteAttrResponse(): zbWriteAttrResponse async, tsn = 3, _set_config_last_tsn_flag = 2
[139827][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x4f5f), endpoint (0x23), cluster_id (0x1) to bind ZC
[139908][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1001) callback
[139908][V][ZigbeeHandlers.cpp:192] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x4f5f) src endpoint(35) to dst endpoint(1) cluster(0x500)
[139909][V][ZigbeeHandlers.cpp:199] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x500), attribute(0xffff)
[139910][I][ZigbeeGateway.cpp:954] zbWriteAttrResponse(): tsn = 4, _write_attr_last_tsn = 4, _write_attr_last_tsn_flag = 2
[139911][I][ZigbeeGateway.cpp:968] zbWriteAttrResponse(): zbWriteAttrResponse async, tsn = 4, _set_config_last_tsn_flag = 2
[142454][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1001) callback
[142455][V][ZigbeeHandlers.cpp:192] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x4f5f) src endpoint(35) to dst endpoint(1) cluster(0x500)
[142456][V][ZigbeeHandlers.cpp:199] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x500), attribute(0xffff)
[142457][I][ZigbeeGateway.cpp:954] zbWriteAttrResponse(): tsn = 4, _write_attr_last_tsn = 4, _write_attr_last_tsn_flag = 2
[142457][I][ZigbeeGateway.cpp:968] zbWriteAttrResponse(): zbWriteAttrResponse async, tsn = 4, _set_config_last_tsn_flag = 2
[142611][I][ZigbeeGateway.cpp:214] bindCb(): ZED (0x4f5f), endpoint (0x23) cluster (0x1) has bounded to ZC
[142612][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[142613][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x4f5f), endpoint (0x23), cluster_id (0x1)
[142617][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x4f5f), endpoint (0x23) cluster (0x1)
[142617][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[142631][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x2000) callback
[142632][V][ZigbeeHandlers.cpp:133] zb_attribute_reporting_handler(): Received report from address(0x4f5f) src endpoint(35) to dst endpoint(1) cluster(0x1)
[142633][I][ZigbeeGateway.cpp:845] zbAttributeReporting(): power config battery voltage 30
[142633][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x2000) callback
[142634][V][ZigbeeHandlers.cpp:133] zb_attribute_reporting_handler(): Received report from address(0x4f5f) src endpoint(35) to dst endpoint(1) cluster(0x1)
[142635][I][ZigbeeGateway.cpp:849] zbAttributeReporting(): power config cluster (0x1), attribute id (0x3e), attribute data type (0x1b)
[142813][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x4f5f), endpoint (0x23), cluster_id (0x500) to bind ZC
[143276][I][ZigbeeGateway.cpp:214] bindCb(): ZED (0x4f5f), endpoint (0x23) cluster (0x500) has bounded to ZC
[143277][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[143278][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x4f5f), endpoint (0x23), cluster_id (0x500)
[143282][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x4f5f), endpoint (0x23) cluster (0x500)
[143282][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[143284][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[143285][E][ZigbeeHandlers.cpp:320] zb_cmd_ias_zone_status_change_handler(): Received message: error status(1)
[143479][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x23, channel type 0xffffffff
[143480][I][z2s_devices_table.cpp:1958] Z2S_addZ2SDevice(): No channel found for address  for 0:15:bc:0:1e:0:4a:dc, adding new one!
[143480][I][z2s_devices_table.cpp:1966] Z2S_addZ2SDevice(): model id 8194, first free slot 0
[143481][I][z2s_devices_table.cpp:459] Z2S_updateZBDeviceTableSlot(): update failed - device not found
LittleFS: writing file Z2S_devs_table
[143673][I][z2s_devices_table.cpp:370] Z2S_saveChannelsTable(): Channels table new size(15360) write success!
Channel[0] initial caption set to 'CONTACT'
[143773][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x23, channel type 0xffffffff
[143774][I][z2s_devices_table.cpp:1958] Z2S_addZ2SDevice(): No channel found for address  for 0:15:bc:0:1e:0:4a:dc, adding new one!
[143775][I][z2s_devices_table.cpp:1966] Z2S_addZ2SDevice(): model id 8194, first free slot 1
[143776][I][z2s_devices_table.cpp:459] Z2S_updateZBDeviceTableSlot(): update failed - device not found
[143942][I][z2s_devices_table.cpp:370] Z2S_saveChannelsTable(): Channels table new size(15360) write success!
Channel[1] initial caption set to 'TAMPER'
[143978][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x23, channel type 0xffffffff
[143979][I][z2s_devices_table.cpp:1958] Z2S_addZ2SDevice(): No channel found for address  for 0:15:bc:0:1e:0:4a:dc, adding new one!
[143979][I][z2s_devices_table.cpp:1966] Z2S_addZ2SDevice(): model id 8194, first free slot 2
[143980][I][z2s_devices_table.cpp:459] Z2S_updateZBDeviceTableSlot(): update failed - device not found
[144163][I][z2s_devices_table.cpp:370] Z2S_saveChannelsTable(): Channels table new size(15360) write success!
Channel[2] initial caption set to 'LOW BATTERY'
[144207][I][Z2S_Gateway.ino:1676] loop(): DESC matched 0x1000, 3, 0x1, 0x402, 0x405, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x26
[144208][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x4f5f), endpoint (0x26), cluster_id (0x1) to bind ZC
[144921][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[144922][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[145034][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[145034][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[146568][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[146569][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[146680][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[146681][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[148564][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[149570][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[149571][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[149651][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x4f5f), rejoin (NO)
[152695][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[152697][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[154009][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x4f5f)
[154010][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[154010][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x4f5f), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[154011][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x4f5f), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[154012][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[154572][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[154573][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[154574][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x4f5f), endpoint (0x26), cluster_id (0x1)
[154578][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x4f5f), endpoint (0x26) cluster (0x1)
[154579][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[154775][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x4f5f), endpoint (0x26), cluster_id (0x402) to bind ZC
[158549][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[158549][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x4f5f), src_endpoint(35) to dst_endpoint(1), cluster(0x0) for command (0xb0) with status 0x82
[158550][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (0), is common (1)
[158551][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 0, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[158552][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 0, _custom_cmd_last_tsn_flag = 255
[158552][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -32
[158835][I][ZigbeeGateway.cpp:214] bindCb(): ZED (0x4f5f), endpoint (0x26) cluster (0x402) has bounded to ZC
[158836][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[158837][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x4f5f), endpoint (0x26), cluster_id (0x402)
[158841][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x4f5f), endpoint (0x26) cluster (0x402)
[158841][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[158895][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x2000) callback
[158895][V][ZigbeeHandlers.cpp:133] zb_attribute_reporting_handler(): Received report from address(0x4f5f) src endpoint(38) to dst endpoint(1) cluster(0x402)
[158896][I][ZigbeeGateway.cpp:681] zbAttributeReporting(): temperature measurement 28.870001
[159038][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x4f5f), endpoint (0x26), cluster_id (0x405) to bind ZC
[159214][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x405)
[159215][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[160748][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x405)
[160749][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[160866][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x405)
[160867][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[165407][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x405)
[165408][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[165520][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x405)
[165521][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[167699][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[168431][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x1)! Device (0x4f5f), endpoint (0x26), cluster (0x405)
[168431][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[168433][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x4f5f), endpoint (0x26), cluster_id (0x405)
[168436][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x4f5f), endpoint (0x26) cluster (0x405)
[168437][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[168491][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x4f5f), rejoin (NO)
[168638][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x26, channel type 0xffffffff
[168639][I][z2s_devices_table.cpp:1958] Z2S_addZ2SDevice(): No channel found for address  for 0:15:bc:0:1e:0:4a:dc, adding new one!
[168639][I][z2s_devices_table.cpp:1966] Z2S_addZ2SDevice(): model id 4096, first free slot 3
[168640][I][z2s_devices_table.cpp:459] Z2S_updateZBDeviceTableSlot(): update failed - device not found
[168840][I][z2s_devices_table.cpp:370] Z2S_saveChannelsTable(): Channels table new size(15360) write success!
LAST STATE ADDED: Software reset (135)
[168956][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[168957][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[168959][I][Z2S_Gateway.ino:1656] loop(): LIST matched Develco Products A/S::WISZB-120, entry # 93, endpoints # 2, endpoints 0x23::0x2002,0x26::0x1000,0x0::0x0,0x0::0x0
[168960][I][Z2S_Gateway.ino:1676] loop(): DESC matched 0x2002, 2, 0x1, 0x500, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x23
[168961][I][Z2S_Gateway.ino:1696] loop(): Develco test
[168961][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x0)
[169161][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0x10), type (0xf0), size (0x8), value (0x7c)
[169362][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x4f5f), endpoint (0x23), cluster_id (0x1) to bind ZC
[171537][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[171540][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[172542][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x688c)
[172543][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[172544][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x688c), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[172544][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x688c), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[172545][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[174209][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[174210][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x688c) src endpoint(35) to dst endpoint(1) cluster(0x0)
[174210][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(20)
[174211][I][ZigbeeGateway.cpp:411] zbReadBasicCluster(): Peer Manufacturer is "Develco Products A/S"
[174212][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[174213][I][ZigbeeGateway.cpp:431] zbReadBasicCluster(): ZCL version id is "1"
[174213][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0x1), type(0x0), value(0)
[174214][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(9)
[174215][I][ZigbeeGateway.cpp:418] zbReadBasicCluster(): Peer Model is "WISZB-120"
[174215][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[174216][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): ZCL power source id is "3"
[174217][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[174218][I][ZigbeeGateway.cpp:447] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x0
[174364][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x1)
[174365][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[179219][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x1)
[179220][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[179419][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x1)
[179420][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[184221][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x1)
[184222][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[184343][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[184344][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0x688c) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[184345][I][ZigbeeGateway.cpp:986] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[184422][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x1)
[184422][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[185885][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[185885][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x688c), src_endpoint(35) to dst_endpoint(1), cluster(0x500) for command (0x0) with status 0x0
[185886][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[185887][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 9, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[185888][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 9, _custom_cmd_last_tsn_flag = 255
[185889][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -34
[185901][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[185902][V][ZigbeeHandlers.cpp:323] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x688c) src endpoint(35) to dst endpoint(1) cluster(0x500), zone status (0x35), extended status (0x0), zone id (0x1), delay (0x40)
[186541][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[187477][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x688c), rejoin (NO)
[189223][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x1)
[189224][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[189225][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x4f5f), endpoint (0x23), cluster_id (0x1)
[189229][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x4f5f), endpoint (0x23) cluster (0x1)
[189229][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[189423][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x1)
[189424][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[189429][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x4f5f), endpoint (0x23) cluster (0x1)
[189429][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[189625][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x4f5f), endpoint (0x23), cluster_id (0x500) to bind ZC
[194627][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x500)
[194628][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[199629][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x500)
[199630][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[204631][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x500)
[204632][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[208501][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[208504][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[209633][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x500)
[209634][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[209814][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x40b0)
[209815][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x00
[209816][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x40b0), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[209816][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x40b0), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x1e):(0x0):(0x4a):(0xdc)
[209817][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[211481][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[211481][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x40b0) src endpoint(35) to dst endpoint(1) cluster(0x0)
[211482][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(20)
[211483][I][ZigbeeGateway.cpp:411] zbReadBasicCluster(): Peer Manufacturer is "Develco Products A/S"
[211484][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(1)
[211484][I][ZigbeeGateway.cpp:431] zbReadBasicCluster(): ZCL version id is "1"
[211485][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0x1), type(0x0), value(0)
[211486][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(9)
[211487][I][ZigbeeGateway.cpp:418] zbReadBasicCluster(): Peer Model is "WISZB-120"
[211487][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[211488][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): ZCL power source id is "3"
[211488][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[211489][I][ZigbeeGateway.cpp:447] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x0
[214369][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[214635][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x500)
[214636][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[216491][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x23), cluster (0x500)
[216492][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[216493][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x4f5f), endpoint (0x23), cluster_id (0x500)
[216497][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x4f5f), endpoint (0x23) cluster (0x500)
[216497][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[216694][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x23, channel type 0xffffffff
[216695][I][z2s_devices_table.cpp:2492] Z2S_addZ2SDevice(): Device (0x4f5f), endpoint (0x23) already in z2s_channels_table (index 0x0)
[216696][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x23, channel type 0xffffffff
[216696][I][z2s_devices_table.cpp:2492] Z2S_addZ2SDevice(): Device (0x4f5f), endpoint (0x23) already in z2s_channels_table (index 0x1)
[216697][I][z2s_devices_table.cpp:123] Z2S_findChannelNumberSlot(): 0:15:bc:0:1e:0:4a:dc, endpoint 0x23, channel type 0xffffffff
[216698][I][z2s_devices_table.cpp:2492] Z2S_addZ2SDevice(): Device (0x4f5f), endpoint (0x23) already in z2s_channels_table (index 0x2)
[216699][I][Z2S_Gateway.ino:1676] loop(): DESC matched 0x1000, 3, 0x1, 0x402, 0x405, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x26
[216700][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x4f5f), endpoint (0x26), cluster_id (0x1) to bind ZC
[219637][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[219638][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[221621][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1030) callback
[221622][V][ZigbeeHandlers.cpp:299] zb_cmd_ias_zone_enroll_request_handler(): IAS Zone Enroll Request: from address(0x40b0) src endpoint(35) to dst endpoint(1) cluster(0x500), zone type (0x15), manufacturer code (0x1015)
[221623][I][ZigbeeGateway.cpp:986] zbIASZoneEnrollRequest(): Sending 'ias zone enroll resp' command
[221701][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[221702][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[223164][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[223165][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x40b0), src_endpoint(35) to dst_endpoint(1), cluster(0x500) for command (0x0) with status 0x0
[223166][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[223166][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 11, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255
[223167][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 11, _custom_cmd_last_tsn_flag = 255
[223168][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -33
[223180][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1031) callback
[223181][V][ZigbeeHandlers.cpp:323] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x40b0) src endpoint(35) to dst endpoint(1) cluster(0x500), zone status (0x35), extended status (0x0), zone id (0x1), delay (0x8c)
[223505][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[224639][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[224640][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[224752][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x40b0), rejoin (NO)
[226703][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[226704][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[228971][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[229641][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[229642][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[231705][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[231706][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[231707][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x4f5f), endpoint (0x26), cluster_id (0x1)
[234226][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[234644][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x85)! Device (0x4f5f), endpoint (0x26), cluster (0x1)
[234645][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[234649][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x4f5f), endpoint (0x26) cluster (0x1)
[234650][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[234845][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x4f5f), endpoint (0x26), cluster_id (0x402) to bind ZC
NLME Status Indication, status: 0x0
W logach widać temperaturę, ale coś chyba nie dogaduje się, bo w sumie w kółko to samo leci w logach.
Po kilku minutach zrobiłem reset bramce i zarejestrowała kanały w Cloud, ale są offline. i w logach kręci się j/w.
Dodam jeszcze, że kanał czujnika otwarcia zaczął działać. Wczoraj tego nie zauważyłem, ale dziś sprawdziłem i stan w apce się poprawnie zmienia.
Temperatura nie działa - są "---" (na kanale temp+wilgotność - nie wiem czy to urządzenie raportuje wilgotność, jeśli nie, to inny kanał trzeba tam ustawić)
klew wrote: Tue Aug 12, 2025 8:28 am
Najbardziej uparty czujnik w całej mojej dziewięciomiesięcznej 😉 przygodzie z Zigbee.
Niemniej, jeżeli jeszcze nie odpuściłeś, to będę walczył dalej.
BTW. Możesz sparować to gniazdko z tą testową bramką? Chciłabym zobaczyć last binding result.
vajera wrote: Tue Aug 12, 2025 2:32 pm BTW. Możesz sparować to gniazdko z tą testową bramką? Chciłabym zobaczyć last binding result.
Gniazdko:
[114131][V][ZigbeeCore.cpp:255] openNetwork(): Opening network for joining for 180 seconds
[114602][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0xc0bb) is open for 180 seconds
[118343][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[118346][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[118387][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x8652)
[118387][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[118388][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x8652), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[118389][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x8652), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[118390][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[118896][I][ZigbeeGateway.cpp:617] printJoinedDevices(): joined devices:
[118896][I][ZigbeeGateway.cpp:620] printJoinedDevices(): Device on endpoint 35, short address: 0x8652
[118897][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[118898][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[118901][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[118999][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[119000][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[119000][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[119001][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[119001][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 19 size: 12
[119002][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[119002][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[119003][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[119003][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[119004][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[119004][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[119005][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[119005][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[119006][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[119006][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[119006][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x8652, 0x8652, 0x0, 0x0
[119007][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[119092][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0xc0bb) is open for 180 seconds
[119901][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x1
[122901][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x2
[124901][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[124902][I][Z2S_Gateway.ino:1640] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
Scheduling soft restart in 0 ms
LAST STATE ADDED: Software reset (118)
Current status: [41] Software reset
[124905][D][Z2S_Gateway.ino:2237] loop(): Unknown model ::, no binding is possible
[124908][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[124908][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[125911][E][AsyncTCP.cpp:1516] begin(): bind error: -8
Reset requested. Reset device
LittleFsConfig: writing to file "/supla-dev.cfg"
LittleFsConfig: writing to file "/supla-dev.cfg.bak"
[125962][V][AP.cpp:108] _onApEvent(): AP Started
[125963][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 130 - AP_START
[125963][V][AP.cpp:88] _onApArduinoEvent(): Arduino AP Event: 130 - AP_START
[125968][V][AP.cpp:112] _onApEvent(): AP Stopped
[125969][V][AP.cpp:108] _onApEvent(): AP Started
[125969][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 131 - AP_STOP
[125970][V][AP.cpp:88] _onApArduinoEvent(): Arduino AP Event: 131 - AP_STOP
[125970][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 130 - AP_START
[125970][V][AP.cpp:88] _onApArduinoEvent(): Arduino AP Event: 130 - AP_START
[125972][V][AP.cpp:112] _onApEvent(): AP Stopped
[125972][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 131 - AP_STOP
[125973][V][AP.cpp:88] _onApArduinoEvent(): Arduino AP Event: 131 - AP_STOP
[125979][V][STA.cpp:216] _onStaEvent(): STA Disconnected: SSID: truskawka_IoT, BSSID: 24:5a:4c:1c:5b:a9, Reason: 8
[125979][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 113 - STA_DISCONNECTED
[125980][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 113 - STA_DISCONNECTED
[125980][W][STA.cpp:137] _onStaArduinoEvent(): Reason: 8 - ASSOC_LEAVE
WiFi Station disconnected
[125984][V][STA.cpp:190] _onStaEvent(): STA Stopped
[125984][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 111 - STA_STOP
[125985][V][STA.cpp:110] _onStaArduinoEvent(): Arduino STA Event: 111 - STA_STOP
[125990][V][NetworkEvents.cpp:117] _checkForEvent(): Network Event: 100 - WIFI_OFF
[125991][V][NetworkInterface.cpp:262] destroyNetif(): Unregistered event handler
Resetting in 0.5s...
See you soon!
klew wrote: Wed Aug 13, 2025 8:44 am
Gniazdko:
To jeszcze skaner (x2):
ten: https://github.com/lsroka76/Z2S_Library ... merged.bin
i ten
Gdybyś przypadkiem się znudził, to ja bardzo chętnie wypożyczę od Ciebie te urządzenia ;)
Return to “Bramka ZigBee”
