const extend = {
enableDisplay: m.binary({
valueOn: [true, 0],
valueOff: [false, 1],
cluster: "hvacUserInterfaceCfg",
attribute: {ID: 0x0106, type: Zcl.DataType.ENUM8},
description: "Whether to enable the device display.",
temperatureDisplayMode: m.enumLookup({
lookup: {celsius: 0, fahrenheit: 1},
attribute: "tempDisplayMode",
description: "The unit of the temperature displayed on the device screen.",
comfortSmiley: m.binary({
valueOn: [true, 0],
attribute: {ID: 0x0002, type: Zcl.DataType.ENUM8},
description: "Whether to show a comfort indicator on the device screen.",
comfortTemperatureMin: m.numeric({
attribute: {ID: 0x0102, type: Zcl.DataType.INT16},
description: "Minimum temperature that is considered comfortable (default 20.00°C).",
unit: "°C",
valueMin: -50.0,
valueMax: 120.0,
valueStep: 0.01,
scale: 100,
comfortTemperatureMax: m.numeric({
attribute: {ID: 0x0103, type: Zcl.DataType.INT16},
description: "Maximum temperature that is considered comfortable (default 25.00°C).",
unit: "°C",
valueMin: -50.0,
valueMax: 120.0,
valueStep: 0.01,
scale: 100,
comfortHumidityMin: m.numeric({
attribute: {ID: 0x0104, type: Zcl.DataType.UINT16},
description: "Minimum relative humidity that is considered comfortable (default 40.00%)",
unit: "%",
valueMin: 0,
valueMax: 100,
scale: 100,
comfortHumidityMax: m.numeric({
attribute: {ID: 0x0105, type: Zcl.DataType.UINT16},
description: "Maximum relative humidity that is considered comfortable (default 60.00%).",
unit: "%",
valueMin: 0,
valueMax: 100,
scale: 100,
temperatureCalibration: m.numeric({
attribute: {ID: 0x0100, type: Zcl.DataType.INT16},
description: "Offset to add/subtract to the reported temperature (default 0°C).",
unit: "°C",
valueMin: -50.0,
valueMax: 50.0,
valueStep: 0.01,
scale: 100,
humidityCalibration: m.numeric({
attribute: {ID: 0x0101, type: Zcl.DataType.INT16},
description: "Offset to add/subtract to the reported relative humidity (default 0%).",
unit: "%",
valueMin: -50.0,
valueMax: 50.0,
valueStep: 0.01,
scale: 100,
measurementInterval: m.numeric({
attribute: {ID: 0x0107, type: Zcl.DataType.UINT8},
description: "Configure sensor measurement interval (default 10 seconds).",
unit: "s",
valueMin: 3,
valueMax: 30,
