Problem z dodaniem Auraton Box do lokalnej Supli
michalf
Cześć,
Postawiłem suplę lokalnie i chcę dodać do niej Auraton Boxa.
Ustawiłem przez 192.168.4.1 adres IP mojego servera + custom CA certificate.
Dodaję przez aplikację, ale urządzenie nie jest widoczne w lokalnej supla cloud + dioda na Auraton ciągle miga. Czy ktoś wie co może być przyczyną? Box wcześniej działał prawidłowo w supla cloud w chmurze.
W logach supla-server mam:
INFO[22:03:23.707525] Cipher: TLS_AES_256_GCM_SHA384, SSL Version: TLSv1.3, ClientSD: 17
INFO[22:03:23.743655] Client registered. ClientSD: 17 ID: 1 Protocol Version: 27
INFO[22:03:28.668626] Connection accepted: 192.168.33.9:64563 ClientSD: 16 Secure: 1
INFO[22:03:38.687648] Connection accepted: 192.168.33.9:64564 ClientSD: 21 Secure: 1
INFO[22:03:48.683546] Connection accepted: 192.168.33.9:64565 ClientSD: 20 Secure: 1
INFO[22:03:58.755681] Connection accepted: 192.168.33.9:64566 ClientSD: 21 Secure: 1
INFO[22:03:59.706118] Connection accepted: 192.168.33.9:64567 ClientSD: 20 Secure: 1
ERR[22:04:03.461521] An attempt to obtain remote gateway token from the AD server failed. Result code: 403
INFO[22:04:09.715148] Connection accepted: 192.168.33.9:64568 ClientSD: 21 Secure: 1
INFO[22:04:19.725399] Connection accepted: 192.168.33.9:64569 ClientSD: 20 Secure: 1
INFO[22:04:39.771658] Connection accepted: 192.168.33.7:53802 ClientSD: 21 Secure: 1
INFO[22:04:39.787268] Cipher: TLS_AES_256_GCM_SHA384, SSL Version: TLSv1.3, ClientSD: 21
INFO[22:04:39.822247] Client registered. ClientSD: 21 ID: 1 Protocol Version: 27
INFO[22:04:46.574455] Connection accepted: 192.168.33.9:62896 ClientSD: 16 Secure: 1
INFO[22:04:47.503765] Connection accepted: 192.168.33.9:62897 ClientSD: 20 Secure: 1
lukfud
Has thanked: 13 times
Been thanked: 11 times
Jaki masz "last state" na bramce?
https://smartnerzeczy.pl
michalf
LAST STATE: Config mode (484), Wi-Fi: disconnecting from AP (46), Not connected to Supla server
michalf wrote: Wed Oct 29, 2025 8:08 am LAST STATE: Config mode (484), Wi-Fi: disconnecting from AP (46), Not connected to Supla server
Nic ciekawego tu nie widać. W jaki sposób miga dioda Supli?
Spróbuj na razie wyłączyć weryfikację certyfikatu i zobacz, czy wtedy się połączy.
michalf
Ok dzięki, poszło bez certyfikatu.
Wziąłem ten z supla-docker/ssl/server/cert.crt i nie działał
michalf wrote: Wed Oct 29, 2025 3:17 pm Ok dzięki, poszło bez certyfikatu.
Nie wiem do czego jest ten co podałeś, ale tam są co najmniej dwa certyfikaty:
Jeden do https dla cloud.
Drugi do połączeń z serwerem na porcie 2016.
michalf
Tak są dwa, testowałem z tym serwerowym tylko. Coś nie bardzo mi ten box chce z nim wystartować, ale jeszcze pogeneruję nowe i zobaczymy
Return to “AURATON Box”
