error during compile esp32 c3 core 2.0.6 with new 25.8.1 arduino library release
micdj
Hello! I've thi compile error: 'mbedtls_pkcs5_pbkdf2_hmac_ext' was not declared in this scope, with core 2.0.6, from what core version can I compile? I use some other library not compatible with core 3.3.3 as asynchttprequest
- Has thanked: 289 times
- Been thanked: 161 times
You should switch to Arduino Core 3.x.x at least.micdj wrote: Mon Nov 10, 2025 9:08 am Hello! I've thi compile error: 'mbedtls_pkcs5_pbkdf2_hmac_ext' was not declared in this scope, with core 2.0.6, from what core version can I compile? I use some other library not compatible with core 3.3.3 as asynchttprequest
BTW Which library is not compatibile with AC 3.3.3?
micdj
I use asynchttprrequest library to update firmware from http
https://github.com/khoih-prog/AsyncHTTPRequest_Generic
If you are working in PlatformIO, there is no core 3.3.3 yetmicdj wrote: Mon Nov 10, 2025 9:08 am Hello! I've thi compile error: 'mbedtls_pkcs5_pbkdf2_hmac_ext' was not declared in this scope, with core 2.0.6, from what core version can I compile? I use some other library not compatible with core 3.3.3 as asynchttprequest
viewtopic.php?p=214066#p214066
klew wrote: Sat Oct 04, 2025 4:29 pm ... Ogólnie możesz też z pliku crypto.cpp w SD wyrzucić od linii 36 do 54 oraz 63.
;use in platformio.ini
platform = https://github.com/pioarduino/platform-espressif32/releases/download/54.03.20/platform-espressif32.zip
framework = arduino
-- SuplaDevice @ 25.8.1+sha.a3360e1
- framework-arduinoespressif32 @ 3.2.0
- framework-arduinoespressif32-libs @ 5.4.0+sha.2f7dcd862a
- tool-esptoolpy @ 4.8.9
- tool-mklittlefs @ 3.2.0
- tool-riscv32-esp-elf-gdb @ 14.2.0+20240403
- tool-xtensa-esp-elf-gdb @ 14.2.0+20240403
- toolchain-riscv32-esp @ 14.2.0+20241119
