Jul 16 21:27:15 rpi04 supla-server[5676]: error:14076102:SSL routines:SSL23_GET_CLIENT_HELLO:unsupported protocol
ldd /usr/sbin/supla-server
linux-vdso.so.1 (0x7ee75000)
/usr/lib/arm-linux-gnueabihf/libarmmem.so (0x76faa000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0x76f8c000)
libssl.so.1.0.0 => /usr/lib/arm-linux-gnueabihf/libssl.so.1.0.0 (0x76f32000)
libcrypto.so.1.0.0 => /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0 (0x76dc4000)
libmysqlclient.so.18 => /usr/lib/arm-linux-gnueabihf/libmysqlclient.so.18 (0x76ab6000)
libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x769da000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0x7695e000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0x76931000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0x76909000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x767c8000)
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x767b5000)
/lib/ld-linux-armhf.so.3 (0x54b91000)
libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0x7678d000)Code: Select all
epoll_create1(0) = 4
eventfd2(0, O_NONBLOCK) = 5
epoll_ctl(4, EPOLL_CTL_ADD, 5, {EPOLLIN|EPOLLET, {u32=5, u64=5}}) = 0
rt_sigaction(SIGHUP, {0x1f18c, [HUP], SA_RESTORER|SA_RESTART, 0x76ad8180}, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGINT, {0x1f18c, [INT], SA_RESTORER|SA_RESTART, 0x76ad8180}, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGTERM, {0x1f18c, [TERM], SA_RESTORER|SA_RESTART, 0x76ad8180}, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGQUIT, {0x1f18c, [QUIT], SA_RESTORER|SA_RESTART, 0x76ad8180}, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x76ad8180}, {SIG_DFL, [], 0}, 8) = 0
socket(PF_LOCAL, SOCK_STREAM, 0) = 6
access("/tmp/supla-dev-ctrl.sock", R_OK) = -1 ENOENT (No such file or directory)
bind(6, {sa_family=AF_LOCAL, sun_path="/tmp/supla-dev-ctrl.sock"}, 110) = 0
listen(6, 5) = 0
chmod("/tmp/supla-dev-ctrl.sock", 0777) = 0
mmap2(NULL, 8388608, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x76296000
mprotect(0x76296000, 4096, PROT_NONE) = 0
clone(child_stack=0x76a94f88, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SELS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x76a954b8, tls=0x76a95910, child_tidptr=0x76a954b8) = 60
mmap2(NULL, 8388608, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x75a96000
mprotect(0x75a96000, 4096, PROT_NONE) = 0
clone(child_stack=0x76294f88, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SELS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x762954b8, tls=0x76295910, child_tidptr=0x762954b8) = 61
mmap2(NULL, 8388608, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x75296000
mprotect(0x75296000, 4096, PROT_NONE) = 0
clone(child_stack=0x75a94f88, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SELS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x75a954b8, tls=0x75a95910, child_tidptr=0x75a954b8) = 62
mmap2(NULL, 8388608, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x74900000
mprotect(0x74900000, 4096, PROT_NONE) = 0
clone(child_stack=0x750fef88, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SELS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x750ff4b8, tls=0x750ff910, child_tidptr=0x750ff4b8) = 63
epoll_wait(4, DEBUG[1468698048.449801] Connecting...
{}, 10, 1000) = 0
epoll_wait(4, {}, 10, 1000) = 0
epoll_wait(4, DEBUG[1468698053.467495] Connecting...
{}, 10, 1000) = 0
epoll_wait(4, DEBUG[1468698058.478107] Connecting...
