Wgrywam do niego skaner: https://github.com/lsroka76/Z2S_Library ... merged.bin
i mam taki log :
ESP-ROM:esp32c6-20220919
Build:Sep 19 2022
rst:0x15 (USB_UART_HPSYS),boot:0x6f (SPI_FAST_FLASH_BOOT)
Saved PC:0x408054de
SPIWP:0xee
mode:DIO, clock div:2
load:0x40875730,len:0x12e0
load:0x4086b910,len:0xdc8
load:0x4086e610,len:0x3180
entry 0x4086b910
[ 1][V][ZigbeeEP.cpp:22] ZigbeeEP(): Endpoint: 1
[ 14][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DM (38) successfully set to 0x4201446e
[ 26][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 12 successfully set to type USB_DM (38) with bus 0x4081abfc
[ 36][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DP (39) successfully set to 0x4201446e
[ 48][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type USB_DP (39) with bus 0x4081abfc
=========== Before Setup Start ===========
Chip Info:
Model : ESP32-C6
Package : 1
Revision : 0.02
Cores : 1
CPU Frequency : 160 MHz
XTAL Frequency : 40 MHz
Features Bitfield : 0x00000052
Embedded Flash : No
Embedded PSRAM : No
2.4GHz WiFi : Yes
Classic BT : No
BT Low Energy : Yes
IEEE 802.15.4 : Yes
INTERNAL Memory Info:
Total Size : 383212 B ( 374.2 KB)
Free Bytes : 326028 B ( 318.4 KB)
Allocated Bytes : 44296 B ( 43.3 KB)
Minimum Free Bytes: 326028 B ( 318.4 KB)
Largest Free Block: 311284 B ( 304.0 KB)
Flash Info:
Chip Size : 4194304 B (4 MB)
Block Size : 65536 B ( 64.0 KB)
Sector Size : 4096 B ( 4.0 KB)
Page Size : 256 B ( 0.2 KB)
Bus Speed : 80 MHz
Flash Frequency : 80 MHz (source: 80 MHz, divider: 1)
Bus Mode : QIO
Partitions Info:
nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS
otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA
app0 : addr: 0x00010000, size: 2560.0 KB, type: APP, subtype: OTA_0
spiffs : addr: 0x00290000, size: 1384.0 KB, type: DATA, subtype: SPIFFS
zb_storage : addr: 0x003EA000, size: 16.0 KB, type: DATA, subtype: FAT
zb_fct : addr: 0x003EE000, size: 4.0 KB, type: DATA, subtype: FAT
rcp_fw : addr: 0x003EF000, size: 4.0 KB, type: DATA, subtype: SPIFFS
coredump : addr: 0x003F0000, size: 64.0 KB, type: DATA, subtype: COREDUMP
Software Info:
Compile Date/Time : Mar 12 2026 18:37:37
Compile Host OS : linux
ESP-IDF Version : v5.5.2-249-gf56bea3d1f
Arduino Version : 3.3.6
Board Info:
Arduino Board : ESP32C6_DEV
Arduino Variant : esp32c6
Arduino FQBN : esp32:esp32:esp32c6:PartitionScheme=custom,ZigbeeMode=zczr,DebugLevel=verbose,CDCOnBoot=cdc
============ Before Setup End ============
[ 170][V][esp32-hal-periman.c:251] perimanClearBusDeinit(): Deinit function for type UART_RX (2) cleared
[ 170][V][esp32-hal-periman.c:251] perimanClearBusDeinit(): Deinit function for type UART_TX (3) cleared
[ 171][V][esp32-hal-periman.c:251] perimanClearBusDeinit(): Deinit function for type UART_CTS (4) cleared
[ 171][V][esp32-hal-periman.c:251] perimanClearBusDeinit(): Deinit function for type UART_RTS (5) cleared
[ 172][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type UART_RX (2) with bus 0x408167c8
[ 172][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4201911a
[ 173][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type UART_TX (3) with bus 0x408167c8
[ 174][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42018fe0
[ 174][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x420163b2
[ 175][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set to type GPIO (1) with bus 0xa
[ 176][D][ZigbeeCore.cpp:99] addEndpoint(): Endpoint: 1, Device ID: 0x0050
[ 176][D][ZigbeeCore.cpp:182] zigbeeInit(): Initialize Zigbee stack
[ 218][D][ZigbeeCore.cpp:189] zigbeeInit(): Register all Zigbee EPs in list
[ 225][I][ZigbeeCore.cpp:197] zigbeeInit(): List of registered Zigbee EPs:
[ 225][I][ZigbeeCore.cpp:201] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
[ 232][V][ZigbeeCore.cpp:503] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
[ 233][I][ZigbeeCore.cpp:306] esp_zb_app_signal_handler(): Zigbee stack initialized
[ 237][I][ZigbeeCore.cpp:453] esp_zb_app_signal_handler(): Network(0xee0e) closed, devices joining not allowed.
[ 238][I][ZigbeeCore.cpp:312] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
[ 238][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): Device rebooted
[ 239][I][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
[ 239][D][ZigbeeCore.cpp:678] searchBindings(): Requesting binding table for address 0x0000
[ 240][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 241][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 22, cluster_id: 0x0033, asdu_length: 2
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x0000
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 0, rx_time: 0
[ 243][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[ 243][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x8033, asdu_length: 5
[ 245][D][ZigbeeCore.cpp:607] bindingTableCb(): Binding table callback for address 0x0000 with status 0
[ 246][D][ZigbeeCore.cpp:610] bindingTableCb(): Binding table info: total 0, index 0, count 0
[ 246][D][ZigbeeCore.cpp:616] bindingTableCb(): No binding table entries found
=========== After Setup Start ============
Free Bytes : 279424 B ( 272.9 KB)
Allocated Bytes : 92460 B ( 90.3 KB)
Minimum Free Bytes: 277080 B ( 270.6 KB)
Largest Free Block: 262132 B ( 256.0 KB)
GPIO Info:
GPIO : BUS_TYPE[bus/unit][chan]
9 : GPIO
12 : USB_DM
13 : USB_DP
16 : UART_TX[0]
17 : UART_RX[0]
============ After Setup End =============
[ 707][I][ZigbeeCore.cpp:447] esp_zb_app_signal_handler(): Network(0xee0e) is open for 180 seconds
[ 708][I][ZigbeeCore.cpp:450] esp_zb_app_signal_handler(): channel 20
[180707][I][ZigbeeCore.cpp:453] esp_zb_app_signal_handler(): Network(0xee0e) closed, devices joining not allowed.mam tylko tyle:
Build:Sep 19 2022
Saved PC:0x4080086c
SPIWP:0xee
entry 0x4086b910
E (554) esp_littlefs: ./managed_components/joltwallet__littlefs/src/littlefs/lfs.c:1382:error: Corrupted dir pair at {0x0, 0x1}
E (554) esp_littlefs: mount failed, (-84)
E (558) esp_littlefs: Failed to initialize LittleFS
Build:Sep 19 2022
Saved PC:0x40030cde
SPIWP:0xee
entry 0x4086b910
