default duration impulse doesn't work on CONTROLLINGTHEDOORLOCK
micdj
Hello, I'm trying to set default value to relay1 with no success
g_relay1 = new Supla::Control::Relay(RELAY1_PIN, true);
        g_relay1->setDefaultFunction(SUPLA_CHANNELFNC_CONTROLLINGTHEDOORLOCK);
		g_relay1->setDefaultImpulseDurationMs(500);
        g_relay1->getChannel()->setInitialCaption("START");
Can you help me?
micdj wrote: Sat Apr 25, 2026 9:05 pm
What is actually not working?
This default impulse will be used by device when there is no other duration stored in flash or right after changing it's function to i.e. "controlling the door lock".
However this value is used only internally by the device. Currently config exchange with server is not implemented for this function, so on Cloud you may see different value.
micdj
Hello, thank you for answer, after reset to factory, time for CONTROLLINGTHELOCKDOOR is not 0,5 seconds as I set in firmware, but 6 seconds, the same I see on cloud setting
micdj wrote: Sun Apr 26, 2026 2:58 pm Hello, thank you for answer, after reset to factory, time for CONTROLLINGTHELOCKDOOR is not 0,5 seconds as I set in firmware, but 6 seconds, the same I see on cloud setting
Yes, config exchange is not implemented for this channel function, so cloud will use it's own default value instead
Return to “Help”
