kod błędu
Arduino:1.8.9 (Windows 10), Płytka:"NodeMCU 0.9 (ESP-12 Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
UWAGA: biblioteka SuplaDevice działa na architekturze(/architekturach) (avr) i może nie być kompatybilna z obecną płytką która działa na architekturze(/architekturach) (esp8266).
In file included from C:\Users\USERNAMEXXX\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecure.h:41:0,
from C:\Users\USERNAMEXXX\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiServerSecure.h:20,
from C:\Users\USERNAMEXXX\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/ESP8266WiFi.h:41,
from C:\Users\USERNAMEXXX\Documents\Arduino\ESP-NODEMCUV3-wifi\ESP-NODEMCUV3-wifi.ino:10:
C:\Users\USERNAMEXXX\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:38:5: error: 'BearSSL::WiFiClientSecure::~WiFiClientSecure()' marked override, but does not override
~WiFiClientSecure() override;
C:\Users\USERNAMEXXX\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:41:9: error: 'int BearSSL::WiFiClientSecure::connect(const String&, uint16_t)' marked override, but does not override
int connect(const String& host, uint16_t port) override;
C:\Users\USERNAMEXXX\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:46:12: error: 'size_t BearSSL::WiFiClientSecure::write_P(const char*, size_t)' marked override, but does not override
size_t write_P(PGM_P buf, size_t size) override;
C:\Users\USERNAMEXXX\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:58:12: error: 'size_t BearSSL::WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override
size_t peekBytes(uint8_t *buffer, size_t length) override;
Znaleziono wiele bibliotek w "WiFiClient.h"
Wykorzystane: C:\Program Files (x86)\Arduino\libraries\WiFi
Niewykorzystane: C:\Users\USERNAMEXXX\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi
exit status 1
Błąd kompilacji dla płytki NodeMCU 0.9 (ESP-12 Module).
Ten raport powinien zawierać więcej informacji jeśli w
File -> Preferencje zostanie włączona opcja "Pokaż
szczegółowe informacje podczas kompilacji"
#include "DHT.h"
#define DHTPIN 4 // what digital pin the DHT22 is conected to
#define DHTTYPE DHT22 // there are multiple kinds of DHT sensors
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <WiFiClient.h>
#include <ESP8266WiFiType.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiScan.h>
#include <ESP8266WiFiMulti.h>
#include <WiFiServer.h>
#include <ESP8266WiFiGeneric.h>
#include <WiFiClientSecure.h>
#include <ESP8266WiFiAP.h>
#include <ESP8266WiFiSTA.h>
#include <WiFiUdp.h>
WiFiClient client;
// Setup Supla connection
const char* ssid = "XXX-X" ;
const char* password = "XXXXXX";
DHT dht(DHTPIN, DHTTYPE);
void get_temperature_and_humidity(int channelNumber, double *temp, double *humidity) {
*temp = dht.readTemperature();
*humidity = dht.readHumidity();
if ( isnan(*temp) || isnan(*humidity) ) {
*temp = -275;
*humidity = -1;
void setup() {
Serial.begin(9600);
Serial.setTimeout(2000);
while(!Serial) { }
Serial.println("Device Started");
Serial.println("-------------------------------------");
Serial.println("Running DHT!");
// Replace the falowing GUID
char GUID[SUPLA_GUID_SIZE] = {0xDD,0x1E,0x14,0xA9,0x31,0x04,0x15,0x1C,0xF5,0x45,0x08,0xC2,0xAD,0x9E,0x5E,0x55};
// Ethernet MAC address
uint8_t mac[6] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05};
SuplaDevice.addDHT22();
mac, // Ethernet MAC address
"XXX.supla.org", // SUPLA server address
XXXX, // Location ID
"XXXX"); // Location Password
int timeSinceLastRead = 0;
void loop() {
SuplaDevice.iterate();
// Report every 2 seconds.
if(timeSinceLastRead > 2000) {
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.println(" *C");
delay(100);
timeSinceLastRead += 100;
// Supla.org ethernet layer
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
// Serial.println("WiFi init");
WiFi.begin(ssid, password);
delay(500);
// Serial.print(".");
//Serial.print("\nlocalIP: ");
//Serial.println(WiFi.localIP());
//Serial.print("subnetMask: ");
//Serial.println(WiFi.subnetMask());
//Serial.print("gatewayIP: ");
//Serial.println(WiFi.gatewayIP());
SuplaDeviceCallbacks cb;
cb.get_temperature = NULL;
cb.get_temperature_and_humidity = get_temperature_and_humidity;
cb.get_rgbw_value = NULL;
cb.set_rgbw_value = NULL;
return cb;
Szkic robił początkowo tylko serial print i było ok
Problemy pojawiły się po dodaniu bibliotek WiFiClientSecure
Główny problem obstawiam własnie z tą biblioteką i ten błąd
Z góry dziękuję za pomoc.
