#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
//********************************************************PARAMETRY KONFIGURACYJNE****************************************************************
const char* ssid = "xxxx";
const char* password = "xxxx";
const char* WiFi_hostname = "Supla_BUTTON_JEDNA_SCENA";
byte Adres_z_DHCP = 0; //1 = DHCP, 0 = Statyczne_IP
IPAddress staticIP(192,168,1,100);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
const char* host = "xxxxx.noip.pl";
String url = "/direct/4/xxxxxxxx/toggle"; //Adres PUBLICZNY SCENY 1
const int httpsPort = 443; //Port serwera
byte button = 0;
#define GPIO 0 //Na którym porcie jest przycisk
#define Moc_nadawcza 20.5 //Możliwość ustawienia w zakresie od 0 do 20.5
void setup()
Serial.begin(115200);
Serial.println();
Serial.println();
Serial.println();
void loop()
if (WiFi.status() != WL_CONNECTED) {
Serial.println("Brak polaczenia z WIFI");
WiFi_up();
button = digitalRead(GPIO);
if (button == 0 ){
button = 1;
WiFiClientSecure client;
if (client.connect(host, httpsPort)) {
Serial.print("Poloczono z ");
Serial.println(host);
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: SuplaButtonESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("Koniec polaczenia");
void WiFi_up(){
WiFi.setOutputPower(Moc_nadawcza);
WiFi.disconnect();
delay(200);
Serial.print("Moc nadawcza: ");
Serial.println(Moc_nadawcza);
Serial.print("SSID: ");
Serial.println(ssid);
Serial.print("PASSWORD: ");
Serial.println(password);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
if (Adres_z_DHCP == 0){
Serial.print("");
Serial.println("Uruchamiam statycze IP");
WiFi.config(staticIP, gateway, subnet);
if (Adres_z_DHCP == 1){
Serial.print("");
Serial.println("Uruchamiam DHCP");
Serial.print("Laczenie z WIFI");
delay(500);
Serial.print(".");
Serial.println(" ");
Serial.print("localIP: ");
Serial.print("subnetMask: ");
Serial.print("gatewayIP: ");
}P. S czy komuś kto ma własny serwer na malinie to działa? Ja nie mogę podołać ani tym ani z softami kolegi elyama, a wcześniej jak używałem publicznych serwerów nie miałem problemu.
