Server setup step by step
TMSer
Anyone that can help out. I got a server on scaleway. Would like to use it. Its a ubuntu server.
Hi. Unfortunately there is no installation manual available yet.
May be help you bash_history of supla server installation. Please check attachment.
TMSer
I have no idea on what to do with that. All those commands.
There is a guy that has a fork on github. Is this correct for the install?
https://github.com/IoTAqua/supla-cloud
If you give me access to your device, I can install everything remotely for you.
TMSer
Sent you a pm
Now you have to provide email credentials
cd /var/www/html
nano app/config/parameters.yml
./clear_cache.sh
mailer_from:
admin_email:
mailer_host:
mailer_user:
mailer_password:
supla_server: raspberrypi
"raspverrypi" change to your server ip
TMSer
Only problem now is that app will not connect.
You have to open
TCP 2015
TCP 2016
TMSer
both are open. Tried the online port lookup. It says they are open.
TMSer
When i tried the raspberry pi image and virtualbox one. I also had this problem. The app would not connect even if the ports are open.
Return to “Help”
