#include <FS.h> // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <math.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESPEFC.h> // modification of ESP8266HTTPUpdateServer that includes erases flash and wifi credentials
extern "C"
#include "user_interface.h"
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
#define CD4051_a 14 // D5 CD4051 Pin 11 Data A
#define CD4051_b 12 // D6 CD4051 Pin 10 Data B
#define CD4051_c 13 // D7 CD4051 Pin 9 Data C
#define config_pin 0 // D3 wifi config
#define status_led 2 // D4 status Led
bool pr_wifi = true;
bool start = true;
int s;
unsigned long wifi_checkDelay = 20000;
unsigned long wifimilis;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // config delay 10 seconds ---------- opóźnienie konfiguracji 10 sekund
WiFiClient client;
ESP8266WebServer httpServer(81);
ESPEFC httpUpdater;
const char* update_path = "/";
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
char update_username[21];
char update_password[21];
byte mac[6];
bool initialConfig = false;
int timeout = 180; // seconds to run the wifi config
unsigned long voltage_lasttime;
int voltage_mtbs = 1000; // mean time between get_voltage
int epr = 0;
int val = 0;
double Voltage_0_Send = -1;
double Voltage_1_Send = -1;
double Voltage_2_Send = -1;
double Voltage_3_Send = -1;
double Voltage_4_Send = -1;
double Voltage_5_Send = -1;
double Voltage_6_Send = -1;
double Voltage_7_Send = -1;
double Voltage_Value = 0;
void saveConfigCallback () { //callback notifying us of the need to save config
shouldSaveConfig = true;
digitalWrite(status_led, LOW);
httpServer.stop();
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
WiFiManager wifiManager;
wifiManager.setBreakAfterConfig(true);
wifiManager.addParameter(&custom_Location_id);
wifiManager.addParameter(&custom_Location_Pass);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_update_username);
wifiManager.addParameter(&custom_update_password);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality(8);
wifiManager.setConfigPortalTimeout(timeout);
if (!wifiManager.startConfigPortal("Supla_8_X_V")) {
Serial.println("Not connected to WiFi but continuing anyway.");
} else {
Serial.println("connected...yeey :)"); //if you get here you have connected to the WiFi
//read updated parameters
strcpy(Location_id, custom_Location_id.getValue());
strcpy(Location_Pass, custom_Location_Pass.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
strcpy(update_username, custom_update_username.getValue());
strcpy(update_password, custom_update_password.getValue());
WiFi.softAPdisconnect(true); // close AP
void get_voltage(int cvs) {
if (cvs == 0){
digitalWrite(CD4051_c, LOW);digitalWrite(CD4051_b, LOW);digitalWrite(CD4051_a, LOW);
delay(2);
val = 0;
for(int i = 0; i < 5; i++) {
val += analogRead(A0);
delay(1);
val = val / 5;
Voltage_Value = val * (5.0 / 1023.0);
Voltage_Value = round(Voltage_Value * 100.0) / 100.0;
if (Voltage_Value != Voltage_0_Send){
Voltage_0_Send = Voltage_Value;
Serial.print("send voltage 0 = ");
Serial.println(Voltage_0_Send,2);
SuplaDevice.channelDoubleValueChanged(0, Voltage_0_Send);
}yield();}
if (cvs == 1){
digitalWrite(CD4051_c, LOW);digitalWrite(CD4051_b, LOW);digitalWrite(CD4051_a, HIGH);
delay(2);
val = 0;
delay(1);
val = val / 5;
if (Voltage_Value != Voltage_1_Send){
Voltage_1_Send = Voltage_Value;
Serial.print("send voltage 1 = ");
Serial.println(Voltage_1_Send,2);
SuplaDevice.channelDoubleValueChanged(1, Voltage_1_Send);
}yield();}
if (cvs == 2){
digitalWrite(CD4051_c, LOW);digitalWrite(CD4051_b, HIGH);digitalWrite(CD4051_a, LOW);
delay(2);
val = 0;
delay(1);
val = val / 5;
if (Voltage_Value != Voltage_2_Send){
Voltage_2_Send = Voltage_Value;
Serial.print("send voltage 2 = ");
Serial.println(Voltage_2_Send,2);
SuplaDevice.channelDoubleValueChanged(2, Voltage_2_Send);
}yield();}
if (cvs == 3){
digitalWrite(CD4051_c, LOW);digitalWrite(CD4051_b, HIGH);digitalWrite(CD4051_a, HIGH);
delay(2);
val = 0;
delay(1);
val = val / 5;
if (Voltage_Value != Voltage_3_Send){
Voltage_3_Send = Voltage_Value;
Serial.print("send voltage 3 = ");
Serial.println(Voltage_3_Send,2);
SuplaDevice.channelDoubleValueChanged(3, Voltage_3_Send);
}yield();}
if (cvs == 4){
digitalWrite(CD4051_c, HIGH);digitalWrite(CD4051_b, LOW);digitalWrite(CD4051_a, LOW);
delay(2);
val = 0;
delay(1);
val = val / 5;
if (Voltage_Value != Voltage_4_Send){
Voltage_4_Send = Voltage_Value;
Serial.print("send voltage 4 = ");
Serial.println(Voltage_4_Send,2);
SuplaDevice.channelDoubleValueChanged(4, Voltage_4_Send);
}yield();}
if (cvs == 5){
digitalWrite(CD4051_c, HIGH);digitalWrite(CD4051_b, LOW);digitalWrite(CD4051_a, HIGH);
delay(2);
val = 0;
delay(1);
val = val / 5;
if (Voltage_Value != Voltage_5_Send){
Voltage_5_Send = Voltage_Value;
Serial.print("send voltage 5 = ");
Serial.println(Voltage_5_Send,2);
SuplaDevice.channelDoubleValueChanged(5, Voltage_5_Send);
}yield();}
if (cvs == 6){
digitalWrite(CD4051_c, HIGH);digitalWrite(CD4051_b, HIGH);digitalWrite(CD4051_a, LOW);
delay(2);
val = 0;
delay(1);
val = val / 5;
if (Voltage_Value != Voltage_6_Send){
Voltage_6_Send = Voltage_Value;
Serial.print("send voltage 6 = ");
Serial.println(Voltage_6_Send,2);
SuplaDevice.channelDoubleValueChanged(6, Voltage_6_Send);
}yield();}
if (cvs == 7){
digitalWrite(CD4051_c, HIGH);digitalWrite(CD4051_b, HIGH);digitalWrite(CD4051_a, HIGH);
delay(2);
val = 0;
delay(1);
val = val / 5;
if (Voltage_Value != Voltage_7_Send){
Voltage_7_Send = Voltage_Value;
Serial.print("send voltage 7 = ");
Serial.println(Voltage_7_Send,2);
SuplaDevice.channelDoubleValueChanged(7, Voltage_7_Send);
}yield();}
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
s=status; // -- to check if we are registered and ready before restore from memory
void setup() { //------------------------------------------------ Setup ----------------------------------------------
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin(115200);
delay(200);
pinMode(status_led,OUTPUT);
pinMode(CD4051_a,OUTPUT);
pinMode(CD4051_b,OUTPUT);
pinMode(CD4051_c,OUTPUT);
digitalWrite(status_led, HIGH);
if (WiFi.SSID()==""){
initialConfig = true;
WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.macAddress(mac);
char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
DynamicJsonBuffer jsonBuffer;
json.printTo(Serial); //print config data to serial on startup
if (json.success()) {
Serial.println("\nparsed json");
strcpy(Location_id, json["Location_id"]);
strcpy(Location_Pass, json["Location_Pass"]);
strcpy(Supla_name, json["Supla_name"]);
strcpy(update_username, json["update_username"]);
strcpy(update_password, json["update_password"]);
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
wifi_station_set_hostname(Supla_name); //nazwa w sieci lokalnej @cino111
SuplaDevice.setStatusFuncImpl(&status_func); // ----------------------------- Status -----------------------------
SuplaDevice.setName(Supla_name);
int LocationID = atoi(Location_id);
mac, // Ethernet MAC address
Supla_server, // SUPLA server address
LocationID, // Location ID
Location_Pass); // Location Password
void loop() {
if (initialConfig){
ondemandwifiCallback () ;
if (shouldSaveConfig) {
Serial.println("saving config");
json["Location_id"] = Location_id;
json["Location_Pass"] = Location_Pass;
json["Supla_name"] = Supla_name;
json["update_username"] = update_username;
json["update_password"] = update_password;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
ESP.restart();
delay(5000);
int C_W_read = digitalRead(config_pin);{
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
Serial.println("Triger sate changed");
C_W_state = C_W_read;
if (C_W_state == LOW) {
last_C_W_state = C_W_read;
SuplaDevice.iterate();
if (pr_wifi == true){
Serial.println("");
Serial.println("CONNECTED");
Serial.print("local IP: ");
Serial.print("subnetMask: ");
Serial.print("gatewayIP: ");
long rssi = WiFi.RSSI();
Serial.print("Signal Strength (RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
pr_wifi = false;
httpUpdater.setup(&httpServer, update_path, update_username, update_password);
httpServer.begin();
delay(50);
if (pr_wifi == false){
httpServer.handleClient();
yield();
if (s == 17){
if (millis() > voltage_lasttime + voltage_mtbs) { //--------------Voltage callback--------------------
if (epr>7){epr = 0;}
get_voltage(epr);
epr = epr+1;
voltage_lasttime = millis();
}else {
Voltage_0_Send = -1;Voltage_1_Send = -1;Voltage_2_Send = -1;Voltage_3_Send = -1;Voltage_4_Send = -1;Voltage_5_Send = -1;Voltage_6_Send = -1;Voltage_7_Send = -1;
}else{
WiFi_up();
// Supla.org ethernet layer
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
SuplaDeviceCallbacks cb;
cb.get_temperature = NULL;
cb.get_rgbw_value = NULL;
cb.set_rgbw_value = NULL;
return cb;
void WiFi_up(){ // conect to wifi
if (millis() > wifimilis) {
WiFi.begin();
delay(500);
pr_wifi = true;
Serial.println("CONNECTING WIFI");
wifimilis = (millis() + wifi_checkDelay) ;
