Supla 3 Way switch esp8266
elmaya
Supla 3 Way Switch works as a direct replacement for the last switch in a 3-way circuit.
Allows control from the App, existing switches and the button connected to the device (toggle).
status memory in case of power failure.
Sensor Gpio 5 -- D1
Relay Gpio 4 -- D2
Button Gpio 0 -- D3
stsLed Gpio 2 -- D4
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>// V.1.6.1
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESPEFC.h>  // modification of ESP8266HTTPUpdateServer that includes erases flash and wifi credentials
#include <Ticker.h>      //for LED status
Ticker ticker;
extern "C"
#include "user_interface.h"
WiFiEventHandler gotIpEventHandler, disconnectedEventHandler;
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
int relay_1 = 4;   //D2------------------- set relay1 Gpio -----
int button_1 = 0;  //D3------------------- set button1 Gpio ----
int fb_1_pin = 5;  //D1------------------- set fb1 Gpio
#define BTN_COUNT 1
#define status_led 2   //      ----------------------- status Led -----------------------
bool wifi_ok = false;
bool start = true;
bool eep = LOW;
int epr = 0;
int s;
int an;
int buttonValue = 0;
unsigned long eep_milis = 5000;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 5000;               // config delay 5 seconds           ----------        opóźnienie konfiguracji 5 sekund
bool tikOn = false;
WiFiClient client;
ESP8266WebServer httpServer(81);
ESPEFC httpUpdater;
const char* update_path = "/update";
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
char up_host[21];
char update_username[21];
char update_password[21];
byte mac[6];
bool initialConfig = false;
int timeout = 180;          // seconds to run the wifi config
void tick(){
  //toggle Led state
  int state = digitalRead(status_led);
  digitalWrite(status_led, !state);
void saveConfigCallback () {                 //callback notifying us of the need to save config
  shouldSaveConfig = true;
 ticker.attach(1.5, tick);
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
  WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
  WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
  WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
  WiFiManager wifiManager;
  wifiManager.setBreakAfterConfig(true);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.addParameter(&custom_Supla_name);
  wifiManager.addParameter(&custom_update_username);
  wifiManager.addParameter(&custom_update_password);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  wifiManager.setMinimumSignalQuality(8);
  wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla_3_Way")) {
      Serial.println("Not connected to WiFi but continuing anyway.");
    } else {
      Serial.println("connected...yeey :)");    //if you get here you have connected to the WiFi
    //read updated parameters
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    strcpy(update_username, custom_update_username.getValue());
    strcpy(update_password, custom_update_password.getValue());
  WiFi.softAPdisconnect(true);   //  close AP
typedef struct {  //------------------------------------------- BTN ----------------------------------------------------
  int pin;
  int relay_pin;
  int fb_pin;
  int channel;
  char last_val;
  int ms;
  unsigned long last_time;
  bool FB;
  bool fb;
} _btn_t;
_btn_t btn[BTN_COUNT];
void supla_btn_init() {
  for(int a=0;a<BTN_COUNT;a++)
    if (btn[a].pin > 0) {
        pinMode(btn[a].pin-1, INPUT_PULLUP);
        btn[a].last_val = digitalRead(btn[a].pin-1);
        btn[a].last_time = millis();
        pinMode(btn[a].relay_pin-1,OUTPUT);
        pinMode(btn[a].fb_pin, INPUT_PULLUP);
        btn[a].fb = !(digitalRead(btn[a].fb_pin));
void togle_relay(int canal){
             if (digitalRead(btn[canal].relay_pin-1) == LOW){
                digitalWrite(btn[canal].relay_pin-1, HIGH);
              }else{
                digitalWrite(btn[canal].relay_pin-1, LOW);
void supla_timer() {
    for(int z=0;z<BTN_COUNT;z++){
      btn[z].FB = digitalRead(btn[z].fb_pin);
      if (btn[z].FB !=  btn[z].fb){
        SuplaDevice.channelValueChanged(z,!btn[z].FB);
        Serial.print("FB: ");
        Serial.println(btn[z].FB);
        btn[z].fb = btn[z].FB;
void iti_bot(){
  char v;
  unsigned long now = millis(); {
        v = digitalRead(btn[a].pin-1);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           delay(75);
           if (v==0){
              togle_relay(a);
              Serial.println("Boton");
int supla_DigitalRead(int channelNumber, uint8_t pin) {
     return !(btn[channelNumber].fb) ;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
   if (val != btn[channelNumber].fb) return;
   if (val == btn[channelNumber].fb) {togle_relay(channelNumber);}
  return;
void Eeprom_save() {                  //----------EEPROM write  ---------------------- EEprom
        if (start){
          return;
      for(int e=0;e<BTN_COUNT;e++) {  //  ---check relay except it have delay (staircase)
         if ( btn[e].ms > 0 ) {
                     continue;
         } else {
        eep = (btn[e].fb);                    //  --- read relay state
        if (eep != EEPROM.read(e)){            //  --- compare relay state with memorized state
         EEPROM.write(e,eep);                  //  --- if different write memory
         Serial.print("EEPROM.");
         Serial.print(e);
         Serial.print(" write.");
         Serial.println((eep));
         EEPROM.commit();
void Eepron_read() {                  //----------EEPROM read  ---------------------- EEprom
       if ( btn[epr].ms > 0 ) {
                     return;
         } else {
         eep = EEPROM.read(epr);               //  ---read relay state
         Serial.print(epr);
         Serial.print(" read.");
         Serial.print((eep));
         Serial.print(" channel ");
         Serial.println((btn[epr].channel));
         SuplaDevice.channelValueChanged(epr,!(digitalRead(btn[epr].fb_pin)));
        if (eep != digitalRead(btn[epr].fb_pin)){ togle_relay(epr); }
void status_func(int status, const char *msg) {     //    ------------------------ Status --------------------------
 s=status;                                          //    -- to check if we are registered and ready before restore from memory
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200);
  delay(100);
  Serial.println("");
  pinMode(status_led,OUTPUT);
  digitalWrite(status_led, LOW);
  EEPROM.begin(512);
  gotIpEventHandler = WiFi.onStationModeGotIP([](const WiFiEventStationModeGotIP& event){
     Serial.println("");
     Serial.println("CONNECTED");
     Serial.print("local IP: "); Serial.println(WiFi.localIP());
     Serial.print("subnetMask: "); Serial.println(WiFi.subnetMask());
     Serial.print("gatewayIP: "); Serial.println(WiFi.gatewayIP());
     long rssi = WiFi.RSSI(); Serial.print("Signal Strength (RSSI): "); Serial.print(rssi); Serial.println(" dBm");
     wifi_ok = true;
     httpUpdater.setup(&httpServer, update_path, update_username, update_password);
     httpServer.begin();
  disconnectedEventHandler = WiFi.onStationModeDisconnected([](const WiFiEventStationModeDisconnected& event){
    Serial.println("Station disconnected");
    wifi_ok = false;
  if (WiFi.SSID()==""){
    initialConfig = true;
  WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
   uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
  SuplaDevice.addRelay(101, false);
  memset(btn, 0, sizeof(btn));
  btn[0].pin =button_1 +1;          // pin gpio buton  +1
  btn[0].relay_pin =relay_1 +1;  // pin gpio Relay   +1
  btn[0].fb_pin =fb_1_pin;
  btn[0].channel =0;      // channel
  btn[0].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[0].FB =0;
  btn[0].fb =0;
  supla_btn_init();
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        DynamicJsonBuffer jsonBuffer;
        json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(Location_id, json["Location_id"]);
          strcpy(Location_Pass, json["Location_Pass"]);
          strcpy(Supla_name, json["Supla_name"]);
          strcpy(update_username, json["update_username"]);
          strcpy(update_password, json["update_password"]);
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  wifi_station_set_hostname(Supla_name);
  SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead);
  SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);
  SuplaDevice.setTimerFuncImpl(&supla_timer);
  SuplaDevice.setStatusFuncImpl(&status_func);
  SuplaDevice.setName(Supla_name);
  int LocationID = atoi(Location_id);
  SuplaDevice.begin(GUID,
                    mac,
                    Supla_server,
                    LocationID,
                    Location_Pass);
  // read_initial_relay_state
    for(int i=0;i<BTN_COUNT;i++){
     if ( (btn[i].ms) > 0 ) {
                     continue;
         } else {
        eep = EEPROM.read(i);
       if (eep >= 2 ){
         EEPROM.write(i,0);
         Serial.println("epp correct");
         EEPROM.commit();
         Serial.print("Recover.");
         Serial.print(i);
         if (eep != digitalRead(btn[i].fb_pin)){
          togle_relay(i);
           Serial.println("restore output");
    start = false;
void loop() {
  iti_bot();
  if (initialConfig){
        EEPROM.write(i, 1);
      EEPROM.commit();
    ondemandwifiCallback () ;
  if (shouldSaveConfig) {
    Serial.println("saving config");
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    json["Supla_name"] = Supla_name;
    json["update_username"] = update_username;
    json["update_password"] = update_password;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {Serial.println("failed to open config file for writing");}
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    ticker.detach();
    digitalWrite(status_led, HIGH);
    ESP.restart();
    delay(5000);
  if (millis() > eep_milis){
     Eeprom_save() ;   //        ------------------------------Eepron save callback -----------------------------
     eep_milis = millis() + 5000 ;
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
  case 17:      // -----     STATUS_REGISTERED_AND_READY
    if (epr<BTN_COUNT){
   Eepron_read() ;                // ------------------------------- Eeprom read callback -------------------------------
   epr = epr+1;// -------- 1 loop for each output  ----------
    break;
   case 10:      // --------------------- REGISTER_IN_PROGRESS  ----------------------
    epr = 0 ;
    break;
  int C_W_read = digitalRead(btn[0].pin-1);{
   if (C_W_read != last_C_W_state) {
     time_last_C_W_change = millis();
   if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       Serial.println("Triger sate changed");
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
   last_C_W_state = C_W_read;
  if (wifi_ok){
     SuplaDevice.iterate();
      delay(50);
      httpServer.handleClient();
// Supla.org ethernet layer
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
          SuplaDeviceCallbacks cb;
          cb.get_temperature = NULL;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
AC line detector:https://learn.edwinrobotics.com/230v110 ... 266-thing/
supla_3_way_DOUT_16Mbit.rar
Luca.supla
good evening everyone
interesting project i am trying to download the file without success
Can anyone help me?
elmaya
Luca.supla wrote: Mon Dec 23, 2019 5:49 pm good evening everyone
Can anyone help me?
Download is fine.
surely you have an old version of rar, update.
Luca.supla
Thanks so much!
Luca.supla
Since there are also possible to have the file for arduino ide
elmaya
in the future.
I am compiling the codes with the new supla library and until it is completely due to constant changes there will be no code otherwise I will be correcting for someone every day
xmichal88x
Hi.
Is it possible to modify the program for 4 channels?
elmaya
There are not enough free Gpio for 4.
You can do 2 or even 3 with some limitation.
xmichal88x
Could you modify the program for 2 channels?
Can the stsLED only light up during setup?
elmaya
xmichal88x wrote: Sat Jan 11, 2020 10:38 pm Could you modify the program for 2 channels?
I guess you understand the meaning of this that appears in the upper right
