Automatyczny reset - da się?
Dawid84
To co Elmaya radzil str 15 post nr5 od gory
Dawid
Dawid
elmaya
it's true, it's fixed for now.kindziol wrote: Sun Dec 01, 2019 8:55 pmTeraz według mnie jest okey. Tylko jak zmieniam pin w cofig i zapisuje to go nie zmienia.elmaya wrote: Sun Dec 01, 2019 8:30 pm I am seeing that there is a problem with a certain Flash model.
flash vendor 85h
precisely the one you have.
This has the time set at 5 minutes.
It will work for you until I see exactly what the problem is with that model.
reset_router_v3_stc15f_v5_DOUT_4Mbit.rar
I have to find a solution to save data for this Flash manufacturer
elmaya
thanksDawid84 wrote: Sun Dec 01, 2019 9:06 pm Witajcie
Zrobilem tak jak na str.15 radzil Elmaya wgralem ustawilem, zamiast przekaznika wstawilem led i czekalem 5min 15min nic zadnego resetu
It disconnects continuously from WiFi.
I review it thoroughly and answer you
@elmaya
I am always at your service.
I really appreciate your contribution to SUPLA.
Dawid84
Przeoczyłem mój błąd sorry za zamieszanie jutro sprawdze.
Dawid
Dawid
@elmaya
PUYA Flash problem.
PUYA Flash problem.
kindziol
@elmaya
Chcę Ci podziękować za pomoc w programowaniu i za napisanie programu. Pamiętaj jednak o mnie w sprawie diody, która ma informować o awarii.
pozdrawiam i jeszcze raz dziękuję.
elmaya
@kindziol
With the help of @Patryk, the problem with the Flash of your module has been solved.
With this soft you can change Google to whatever you want and select the restart time in wificonfig.
You have to connect the Led between Gpio2 and Vcc through a resistor.
The builtin LED is connected to Gpio 1 which is the one that controls the relay.
kindziol
Tak więc dziękuje również @Patryk za udział w rozwiązaniu problemu.elmaya wrote: Mon Dec 02, 2019 7:18 pm @kindziol
reset_router_v3_stc15f_delaySel_DOUT_4Mbit_PUYA_Fix.rar
Dziękuje bardzo.
