Na QNAPie:
../src/supla-client-lib/supla-socket.c:42:10: fatal error: openssl/err.h: No such file or directory
#include <openssl/err.h>
compilation terminated.
make: *** [src/supla-client-lib/subdir.mk:60: src/supla-client-lib/supla-socket.o] Error 1
Na malinie to już w ogóle wszystko się sypie (ale tutaj raczej problem z systemem, który trochę "kuleje"):
../src/yaml/yaml.cpp:1864:36: error: expected ‘;’ before ‘it’
for (auto it = node.Begin(); it != node.End(); it++) {
../src/yaml/yaml.cpp:1864:36: error: ‘it’ was not declared in this scope
../src/yaml/yaml.cpp:1952:12: warning: ‘auto’ changes meaning in C++11; please remove it [-Wc++0x-compat]
for (auto it = lines.begin(); it != lines.end(); it++) {
../src/yaml/yaml.cpp:1952:17: error: ‘it’ does not name a type
../src/yaml/yaml.cpp:1952:37: error: expected ‘;’ before ‘it’
../src/yaml/yaml.cpp:1952:37: error: ‘it’ was not declared in this scope
../src/yaml/yaml.cpp: In function ‘std::string Yaml::ExceptionMessage(const string&, Yaml::ReaderLine&)’:
../src/yaml/yaml.cpp:1980:44: error: ‘to_string’ is not a member of ‘std’
return message + std::string(" Line ") + std::to_string(line.No) +
../src/yaml/yaml.cpp: In function ‘std::string Yaml::ExceptionMessage(const string&, Yaml::ReaderLine&, size_t)’:
../src/yaml/yaml.cpp:1986:44: error: ‘to_string’ is not a member of ‘std’
../src/yaml/yaml.cpp:1987:36: error: ‘to_string’ is not a member of ‘std’
std::string(" column ") + std::to_string(errorPos + 1) +
../src/yaml/yaml.cpp: In function ‘std::string Yaml::ExceptionMessage(const string&, size_t, size_t)’:
../src/yaml/yaml.cpp:1993:44: error: ‘to_string’ is not a member of ‘std’
return message + std::string(" Line ") + std::to_string(errorLine) +
../src/yaml/yaml.cpp:1994:36: error: ‘to_string’ is not a member of ‘std’
std::string(" column ") + std::to_string(errorPos);
../src/yaml/yaml.cpp: In function ‘std::string Yaml::ExceptionMessage(const string&, size_t, const string&)’:
../src/yaml/yaml.cpp:1999:44: error: ‘to_string’ is not a member of ‘std’
../src/yaml/yaml.cpp: In function ‘size_t Yaml::FindNotCited(const string&, char, size_t&)’:
../src/yaml/yaml.cpp:2049:39: error: ‘>>’ should be ‘> >’ within a nested template argument list
std::vector<std::pair<size_t, size_t>> quotes;
../src/yaml/yaml.cpp:2054:22: warning: extended initializer lists only available with -std=c++11 or -std=gnu++11
quotes.push_back({quoteStart, quoteEnd});
../src/yaml/yaml.cpp:2054:44: warning: extended initializer lists only available with -std=c++11 or -std=gnu++11
../src/yaml/yaml.cpp:2067:49: error: in C++98 ‘currentQuote’ must be initialized by constructor, not by ‘{...}’
std::pair<size_t, size_t> currentQuote = {0, 0};
../src/yaml/yaml.cpp: In function ‘void Yaml::CopyNode(const Yaml::Node&, Yaml::Node&)’:
../src/yaml/yaml.cpp:2157:12: warning: ‘auto’ changes meaning in C++11; please remove it [-Wc++0x-compat]
for (auto it = from.Begin(); it != from.End(); it++) {
../src/yaml/yaml.cpp:2157:17: error: ‘it’ does not name a type
../src/yaml/yaml.cpp:2157:36: error: expected ‘;’ before ‘it’
../src/yaml/yaml.cpp:2157:36: error: ‘it’ was not declared in this scope
../src/yaml/yaml.cpp:2164:12: warning: ‘auto’ changes meaning in C++11; please remove it [-Wc++0x-compat]
../src/yaml/yaml.cpp:2164:17: error: ‘it’ does not name a type
../src/yaml/yaml.cpp:2164:36: error: expected ‘;’ before ‘it’
../src/yaml/yaml.cpp:2164:36: error: ‘it’ was not declared in this scope
../src/yaml/yaml.cpp: In function ‘void Yaml::AddEscapeTokens(std::string&, const string&)’:
../src/yaml/yaml.cpp:2183:8: warning: ‘auto’ changes meaning in C++11; please remove it [-Wc++0x-compat]
for (auto it = tokens.begin(); it != tokens.end(); it++) {
../src/yaml/yaml.cpp:2183:13: error: ‘it’ does not name a type
../src/yaml/yaml.cpp:2183:34: error: expected ‘;’ before ‘it’
../src/yaml/yaml.cpp:2183:34: error: ‘it’ was not declared in this scope
../src/yaml/yaml.cpp: In member function ‘const char* Yaml::Exception::Message() const’:
../src/yaml/yaml.cpp:96:57: warning: control reaches end of non-void function [-Wreturn-type]
const char *Exception::Message() const { return what(); }
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::ScalarImp::Insert(size_t)’:
../src/yaml/yaml.cpp:276:62: warning: control reaches end of non-void function [-Wreturn-type]
virtual Node *Insert(const size_t index) { return nullptr; }
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::MapImp::Insert(size_t)’:
../src/yaml/yaml.cpp:239:62: warning: control reaches end of non-void function [-Wreturn-type]
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::ScalarImp::PushFront()’:
../src/yaml/yaml.cpp:278:47: warning: control reaches end of non-void function [-Wreturn-type]
virtual Node *PushFront() { return nullptr; }
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::MapImp::PushFront()’:
../src/yaml/yaml.cpp:241:47: warning: control reaches end of non-void function [-Wreturn-type]
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::ScalarImp::PushBack()’:
../src/yaml/yaml.cpp:280:46: warning: control reaches end of non-void function [-Wreturn-type]
virtual Node *PushBack() { return nullptr; }
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::MapImp::PushBack()’:
../src/yaml/yaml.cpp:243:46: warning: control reaches end of non-void function [-Wreturn-type]
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::ScalarImp::GetNode(size_t)’:
../src/yaml/yaml.cpp:272:63: warning: control reaches end of non-void function [-Wreturn-type]
virtual Node *GetNode(const size_t index) { return nullptr; }
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::MapImp::GetNode(size_t)’:
../src/yaml/yaml.cpp:227:63: warning: control reaches end of non-void function [-Wreturn-type]
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::SequenceImp::GetNode(size_t)’:
../src/yaml/yaml.cpp:143:3: warning: control reaches end of non-void function [-Wreturn-type]
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::ScalarImp::GetNode(const string&)’:
../src/yaml/yaml.cpp:274:67: warning: control reaches end of non-void function [-Wreturn-type]
virtual Node *GetNode(const std::string &key) { return nullptr; }
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::MapImp::GetNode(const string&)’:
../src/yaml/yaml.cpp:237:3: warning: control reaches end of non-void function [-Wreturn-type]
../src/yaml/yaml.cpp: In member function ‘virtual Yaml::Node* Yaml::SequenceImp::GetNode(const string&)’:
../src/yaml/yaml.cpp:145:67: warning: control reaches end of non-void function [-Wreturn-type]
../src/yaml/yaml.cpp:1995:1: warning: control reaches end of non-void function [-Wreturn-type]
../src/yaml/yaml.cpp:1982:1: warning: control reaches end of non-void function [-Wreturn-type]
src/yaml/subdir.mk:18: polecenia dla obiektu 'src/yaml/yaml.o' nie powiodły się
make: *** [src/yaml/yaml.o] Błąd 1
