A small improvement to smoothen the movement of the servo.
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
#include <FS.h> // ---- esp board manager 2.5.2 --- iwip Variant V2 higher Bandwidth
#include <SPI.h>
#include <SuplaDevice.h> //------- https://github.com/SUPLA/arduino/tree/develop
#include <Servo.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <ESP8266TrueRandom.h>
Supla::ESPWifi wifi("", ""); //------ Do not change----wifimanager takes care------
extern "C"
#include "user_interface.h"
#define PUYA_SUPPORT 1 //PUYASUPPORT
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16]; // UUIDs in binary form are 16 bytes long
Servo myservo; // create servo object to control a servo
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
WiFiManager wifiManager;
int wificonfig_pin = 0; // D3
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // config delay 10 seconds
char Supla_server[81];
char Email[81];
char Supla_name[51];
char Supla_status[51];;
bool initialConfig = false;
int s = 0;
bool starting = true;
unsigned char _red = 0;
unsigned char _green = 255;
unsigned char _blue = 0;
unsigned char _color_brightness = 0;
unsigned char _brightness = 0;
unsigned char _bright = 0;
void saveConfigCallback () {
shouldSaveConfig = true;
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81,"required");
WiFiManagerParameter custom_Email("email", "Email", Email, 81,"required");
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
WiFiManagerParameter custom_Supla_status("status", "Supla Last State", Supla_status, 51,"readonly");
wifiManager.setBreakAfterConfig(true);
wifiManager.addParameter(&custom_Email);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_Supla_status);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality(8);
//wifiManager.setShowStaticFields(true); // force show static ip fields
//wifiManager.setShowDnsFields(true); // force show dns field always
wifiManager.setConfigPortalTimeout(180);
if (!wifiManager.startConfigPortal("Servo")) { Serial.println("Not connected to WiFi but continuing anyway.");} else { Serial.println("connected...yeey :)");}
strcpy(Email, custom_Email.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
if(strcmp(Supla_server, "get_new_guid_and_authkey") == 0){
Serial.println("new guid & authkey.");
EEPROM.write(300, 0);
EEPROM.commit();
ESP.reset();
WiFi.softAPdisconnect(true); // close AP
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
if (s != status){
s = status;
if (s != 10){
strcpy(Supla_status, msg);
void guid_authkey(void) {
if (EEPROM.read(300) != 60){
int eep_gui = 301;
ESP8266TrueRandom.uuid(uuidNumber);
String uuidString = "";
for (int i = 0; i < 16; i++) {
int topDigit = uuidNumber[i] >> 4;
int bottomDigit = uuidNumber[i] & 0x0f;
uuidString += "0123456789abcdef"[topDigit];
uuidString += "0123456789abcdef"[bottomDigit];
int length_uuid = uuidString.length();
for (int i = 0; i < length_uuid; ++i) {
EEPROM.put(eep_gui + i, uuidString[i]);
int eep_aut = 321;
String uuidString2 = "";
uuidString2 += "0123456789abcdef"[topDigit];
uuidString2 += "0123456789abcdef"[bottomDigit];
int length_uuid2 = uuidString2.length();
for (int i = 0; i < length_uuid2; ++i) {
EEPROM.put(eep_aut + i, uuidString2[i]);
EEPROM.write(300, 60);
EEPROM.commit();
read_guid();
read_authkey();
Serial.print("GUID : ");Serial.println(read_guid());
Serial.print("AUTHKEY : ");Serial.println(read_authkey());
String read_guid(void) {
String read_eeprom = "";
int i, ii = 0;
int eep_star = 301;
int end_guid = eep_star + SUPLA_GUID_SIZE;
String temp_read = "0x";
for (i = eep_star; i < end_guid + 16; i = i + 1) {
temp_read += char(EEPROM.read(i));
read_eeprom += char(EEPROM.read(i));
if ( (i % 2) == 0) {
char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
GUID[ii] = strtoul( _guid, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
String read_authkey(void) {
int i, ii = 0;
int eep_star = 321;
int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
for (i = eep_star; i < end_authkey + 16; i = i + 1) {
char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
void supla_timer() {
if (_brightness > _bright){
_bright = _bright + 1;
set_rgbw();
}else if (_brightness < _bright){
_bright = _bright - 1;
set_rgbw();
void get_rgbw_value(int channelNumber, unsigned char *red, unsigned char *green, unsigned char *blue, unsigned char *color_brightness, unsigned char *brightness) {
*brightness = _brightness;
*color_brightness= _color_brightness;
*red = _red;
*green = _green;
*blue = _blue;
void set_rgbw() {
int pos = map(_bright, 0, 100, 0,180);
Serial.print("Pos: "); Serial.println(pos);
myservo.write(pos); // tell servo to go to position in variable 'pos'
void set_rgbw_value(int channelNumber, unsigned char red, unsigned char green, unsigned char blue, unsigned char color_brightness, unsigned char brightness) {
_brightness = brightness;
_color_brightness= color_brightness;
_red = red;
_green = green;
_blue = blue;
//set_rgbw();
void setup() {
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin(115200);
Serial.println();
pinMode(wificonfig_pin, INPUT_PULLUP);
EEPROM.begin(1024);
myservo.attach(2); // attaches the servo on GIO2 to the servo object
if (EEPROM.read(300) != 60){initialConfig = true;}
guid_authkey();
if (WiFi.SSID()==""){ initialConfig = true;}
if (SPIFFS.begin()) { // ------------------------- wificonfig read -----------------
Serial.println("mounted file system");
if (SPIFFS.exists("/servo.json")) {
Serial.println("reading config file");
File configFile = SPIFFS.open("/servo.json", "r");
if (configFile) {
Serial.println("opened config file");
DynamicJsonBuffer jsonBuffer;
json.printTo(Serial); //print config data to serial on startup
if (json.success()) {Serial.println("\nparsed json");
strcpy(Email, json["Email"]);
strcpy(Supla_name, json["Supla_name"]);
} else {
Serial.println("failed to load json config");
configFile.close();
} else {
Serial.println("failed to mount FS");
wifi_station_set_hostname(Supla_name);
set_rgbw();
// Set RGBW callbacks
SuplaDevice.setRGBWCallbacks(&get_rgbw_value, &set_rgbw_value);
SuplaDevice.addDimmer();
SuplaDevice.setName(Supla_name);
SuplaDevice.setStatusFuncImpl(&status_func);
SuplaDevice.setTimerFuncImpl(&supla_timer);
SuplaDevice.begin(GUID,Supla_server,Email,AUTHKEY);
void loop() {
if (initialConfig == true){ondemandwifiCallback();}
int C_W_read = digitalRead(wificonfig_pin);{
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
C_W_state = C_W_read;
if (C_W_state == LOW) {
ondemandwifiCallback () ;
last_C_W_state = C_W_read;
if (shouldSaveConfig == true) { // ------------------------ wificonfig save --------------
Serial.println("saving config");
json["Email"] = Email;
json["Supla_name"] = Supla_name;
File configFile = SPIFFS.open("/servo.json", "w");
if (!configFile) {Serial.println("failed to open config file for writing"); }
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
WiFi.mode(WIFI_STA);
delay(5000);
ESP.restart();
SuplaDevice.iterate();
delay(75);
if (starting){
httpUpdater.setup(&httpServer, "/update", "admin", "pass");
httpServer.begin();
starting = false;
httpServer.handleClient();
