Of course yesbulek68 wrote: Mon Feb 10, 2020 7:53 pm In your project you used 4 modules with 4 relays.
I know that in cloud I can run 2,4,8,16 channels.
I asked if I would physically connect 2 modules with 4 relays then this construction would still work.
Supla 16 X relay -- esp8266 + mcp23017
elmaya
bulek68
meliwal wrote: Fri Feb 07, 2020 10:05 am interesting,I did everything you posted, and it works the first time, can you add buttons at least 8 to activate relays (not touch buttons thisway allow me to use rf receiver to swith relays) and ds18b20 sensor to this projects? thanks a lot
The GPIO have not been used yet.
I think that many people will be missing up to 8xDS and DHT22 / BME280.
Is this possible?
elmaya
who knows?
maybe one day you wake up in the morning and Esp8266 takes you coffee to bed.
maybe i add 1 ds18b20
bulek68
Looking at what you can force these ESP devices to do, I would not be surprised that one day it will happen.elmaya wrote: Mon Feb 10, 2020 11:19 pm who knows?
maybe one day you wake up in the morning and Esp8266 takes you coffee to bed.![]()
elmaya
changed in third SensorNO D7 for Ds18B20 in D7
bulek68
Me again.
Could you suggest how to secure sensor inputs for long cables (about 30m).
EDIT:
Maybe this- EVERLIGHT EL817 will be ok?
EDIT:
elmaya
maybe this https://es.aliexpress.com/item/33017803 ... lsrc=aw.ds in 24v out 3,3vbulek68 wrote: Tue Feb 11, 2020 10:47 pm Me again.![]()
EDIT:
or you can use DirectLink.
bulek68
I noticed a certain pattern.
When the relays are turned on and the module loses power and returns again then the relays are turned off and the application indicates their switching on.
elmaya
try with thisbulek68 wrote: Mon Mar 23, 2020 10:33 pm I noticed a certain pattern.
