Maybe I really wanted to finish quickly and disconnected before loading the software ...
No problem - I'll wait until Monday for a soft window.
Maybe right away (if that's not a problem) then do it the same soft for 1.3 displays - let others also use heating / cooling.
Heating / cooling selection in the configuration menu: GREAT IDEA !!
thermostat with Oled display
jaros12
Hi, @elmaya can you share the code for this latest version with the heating / cooling switch?
Maybe you have some solution for Nodemcu V3 - according to documentation and my tests, Gpio9 cannot be used as a sensor, after connecting to ground it resets. Maybe there is some other option than changing the tile, e.g. replacing Gpio? For testing, I removed the sensor input from the program and the thermostat works OK. I wanted to release Gpio13, but after reprogramming the DS sensor input to RX or TX it doesn't detect it ...
Regards
Regards
elmaya
I personally use nodemcu and Gpio9 works perfectly as a sensor (DOUT mode).jaros12 wrote: Sun Feb 23, 2020 11:44 am Hi, @elmaya can you share the code for this latest version with the heating / cooling switch?
Regards
Please check your connection.
Arduino source code:
#include <FS.h> // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h> // -------- https://github.com/SUPLA/arduino/tree/v1.6.1 -------
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <ESPEFC.h> // modification of ESP8266HTTPUpdateServer that includes erases flash and wifi credentials
#include <OneWire.h>
extern "C"
#include "user_interface.h"
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
//#include "SSD1306Wire.h" //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306
//SSD1306Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 0.96 Oled ---
#include "SH1106Wire.h" //----- 1.3 Oled ---
SH1106Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 1.3 Oled ---
#define ONE_WIRE_BUS 13 //D7 --------------------oneWire Dallas Temperature --------requires 4k7 resistance
int relay_1 = 15; //D8 ------------------- thermometer Auto/Man Led ----- active high
int relay_2 = 12; //D6 ------------------- relay output ----- active high
int relay_3 = 120; // --------------------- thermostat temperature setting +/- 0.5º no Gpio -----
int relay_4 = 122; // --------------------- no Gpio -----
int button_1 = 14; //D5 ------------------- automatic / manual thermostat change ---- WiFi config 10 seconds --------
int button_2 = 16; //D0 ------------------- manual on / off ----requires 10k pullup resistance due to lack of internal
int button_3 = 5; //D1 ------------------- thermostat temperature setting - 0.5º----
int button_4 = 4; //D2 ------------------- thermostat temperature setting + 0.5º----
#define sensor_pin 9 // --------------------Window sensor ------
#define BTN_COUNT 4
OneWire oneWire(ONE_WIRE_BUS);
DeviceAddress tempDeviceAddress;
int resolution = 11;
bool pr_wifi = true;
bool start = true;
bool eep = LOW;
int epr = 0;
int s;
int Term_Temp ;
int Term_Hist ;
int Term_Tipo ;
double tr = -275;
double trs ;
unsigned long wifi_checkDelay = 20000;
unsigned long wifimilis;
unsigned long eep_milis;
unsigned long tr_milis;
unsigned long ds_milis;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // config delay 10 seconds ---------- opóźnienie konfiguracji 10 sekund
bool tikOn = false;
WiFiClient client;
ESP8266WebServer httpServer(81);
ESPEFC httpUpdater;
WiFiManager wifiManager;
const char* host = "su";
const char* update_path = "/update";
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
char up_host[21];
char update_username[21];
char update_password[21];
char term_temp[5];
char term_hist[5];
char termtipo[5];
byte mac[6];
bool initialConfig = false;
bool dimm = false;
bool window = false;
unsigned long dimm_milis ;
int timeout = 180; // seconds to run the wifi config
int customFieldLength = 40;
WiFiManagerParameter custom_field; // global param ( for non blocking w params )
const uint8_t logo32_glcd_bmp[] PROGMEM = //logo supla 32
0x00,0x00,0x00,0x00,0xC0,0x1F,0x00,0x00,0xE0,0x7F,0x00,0x00,
0xF0,0x70,0x00,0x00,0x30,0xE0,0x00,0x00,0x38,0xC0,0x00,0x00,
0x18,0xC0,0x01,0x00,0x18,0xC0,0x01,0x00,0x38,0xC0,0x00,0x00,
0x38,0xE0,0x01,0x00,0x70,0xF0,0x07,0x00,0xE0,0x7F,0x0E,0x00,
0xC0,0x3F,0x38,0x00,0x00,0x1F,0xE0,0x0F,0x00,0x18,0xC0,0x1F,
0x00,0x18,0xC0,0x30,0x00,0x18,0xC0,0x30,0x00,0x30,0xC0,0x30,
0x00,0x30,0x80,0x1F,0x00,0x30,0xC0,0x0F,0x00,0x20,0x60,0x00,
0x00,0x60,0x20,0x00,0x00,0x60,0x30,0x00,0x00,0x40,0x18,0x00,
0x00,0xC0,0x0D,0x00,0x00,0xC0,0x07,0x00,0x00,0x60,0x04,0x00,
0x00,0x20,0x0C,0x00,0x00,0x20,0x0C,0x00,0x00,0x60,0x06,0x00,
0x00,0xC0,0x03,0x00,0x00,0x00,0x00,0x00
const uint8_t logo16_wifi_bmp[] PROGMEM = //logo wifi 16
0x00,0x00,0x00,0x00,0xE0,0x07,0x38,0x1C,0xC4,0x23,0x72,0x4E,
0x08,0x10,0xE4,0x27,0x10,0x0C,0x90,0x09,0x40,0x02,0x60,0x06,
0x40,0x02,0x80,0x01,0x00,0x00,0x00,0x00
const uint8_t logo16_supla_bmp[] PROGMEM = //logo supla 16
0x30,0x00,0x7C,0x00,0xC4,0x00,0x86,0x00,0x84,0x00,0xDC,0x03,
0x78,0x36,0x60,0x78,0x40,0x48,0x40,0x38,0x40,0x04,0x80,0x06,
0x80,0x03,0x40,0x02,0xC0,0x03,0x00,0x01
const uint8_t logo16_Win_open[] PROGMEM = //open window 16
0xFE,0x7F,0xFE,0x7F,0x06,0x60,0x06,0x60,0x06,0x60,0x06,0x60,
0x06,0x60,0x06,0x60,0x06,0x60,0x06,0x60,0x06,0x60,0x06,0x60,
0x06,0x60,0x06,0x60,0xFE,0x7F,0xFE,0x7F
const uint8_t logo16_Win_close[] PROGMEM = //close window 16
0xFE,0x7F,0xFE,0x7F,0x86,0x61,0x86,0x61,0x86,0x61,0xFE,0x7F,
0xFE,0x7F,0x86,0x61,0x86,0x61,0x86,0x61,0x86,0x61,0x86,0x61,
0x86,0x61,0x86,0x61,0xFE,0x7F,0xFE,0x7F
const uint8_t logo16_cool[] PROGMEM = //logo cool 16
0x80,0x01,0x80,0x01,0xE0,0x07,0xD8,0x1B,0x9E,0x79,0xDC,0x3B,
0x7E,0x7E,0x64,0x26,0x66,0x66,0x7E,0x7E,0xDC,0x3B,0x9E,0x79,
0xD8,0x1B,0xE0,0x07,0x80,0x01,0x80,0x01
const uint8_t logo16_hot[] PROGMEM = //logo hot 16
0x80,0x01,0x80,0x01,0x0C,0x30,0x8C,0x31,0xE0,0x07,0x30,0x0C,
0x10,0x08,0x1B,0xD8,0x1B,0xD8,0x10,0x08,0x30,0x0C,0xE0,0x07,
0x8C,0x31,0x0C,0x30,0x80,0x01,0x80,0x01
const uint8_t logo_Power_off[] PROGMEM = //Power off
0xe0, 0xff, 0xff, 0xff, 0x03, 0x38, 0xfc, 0xff, 0xff, 0x0f, 0x0c, 0xf0,
0xff, 0xff, 0x3f, 0x06, 0xe0, 0xff, 0xff, 0x3f, 0x02, 0xc0, 0xcf, 0x43,
0x78, 0x03, 0xc0, 0x33, 0x43, 0x78, 0x01, 0xc0, 0x7b, 0x7b, 0xff, 0x01,
0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0x7b,
0x7b, 0xff, 0x03, 0xc0, 0x33, 0x7b, 0xff, 0x02, 0xc0, 0xcf, 0x7b, 0x7f,
0x06, 0xe0, 0xff, 0xff, 0x7f, 0x0c, 0xf0, 0xff, 0xff, 0x3f, 0x18, 0xfc,
0xff, 0xff, 0x1f, 0xf0, 0xff, 0xff, 0xff, 0x07,
const uint8_t logo_Power_on[] PROGMEM = //Power on
0xe0, 0xff, 0xff, 0xff, 0x07, 0x38, 0x00, 0x00, 0x30, 0x0c, 0x0c, 0x00,
0x00, 0x18, 0x18, 0x06, 0x00, 0x00, 0x0c, 0x30, 0x02, 0x0e, 0x00, 0x06,
0x60, 0x03, 0x9f, 0x19, 0x02, 0x40, 0x81, 0xb1, 0x1b, 0x03, 0xc0, 0x81,
0xa0, 0x1a, 0x01, 0x80, 0x81, 0xa0, 0x1e, 0x01, 0x80, 0x81, 0xb1, 0x1c,
0x01, 0xc0, 0x03, 0x9b, 0x18, 0x03, 0x40, 0x02, 0x8e, 0x18, 0x02, 0x60,
0x06, 0x00, 0x00, 0x06, 0x20, 0x0c, 0x00, 0x00, 0x0c, 0x38, 0x38, 0x00,
0x00, 0x18, 0x0c, 0xe0, 0xff, 0xff, 0xff, 0x07,
void saveConfigCallback () { //callback notifying us of the need to save config
shouldSaveConfig = true;
display.clear();
display.setContrast(100, 241, 64);
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setFont(ArialMT_Plain_10);
display.drawString(64, 16, "wifi config connect");
display.drawString(64, 28, "to wifi hotspot");
display.setFont(ArialMT_Plain_16);
display.drawString(64, 44, "Supla_Termostat");
display.display();
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
WiFiManagerParameter custom_up_host("up_host", "xxxx (DHCP name)", up_host, 21,"required");
WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
WiFiManagerParameter custom_term_temp("Termostat", "Temp x 10", term_temp, 5,"required");
WiFiManagerParameter custom_term_hist("Histerisis", "Histerisis x 10", term_hist, 5,"required");
const char* custom_radio_str = "<br><div style='text-align:center; width:100%; padding:0;'><label for='customfieldid'>Thermostat Type</label><input type='radio' name='customfieldid' value='0' checked> Heating<input type='radio' name='customfieldid' value='1'> Cooling</div>";
new (&custom_field) WiFiManagerParameter(custom_radio_str); // custom html input
wifiManager.setBreakAfterConfig(true);
wifiManager.setSaveParamsCallback(saveParamCallback);
wifiManager.addParameter(&custom_Location_id);
wifiManager.addParameter(&custom_Location_Pass);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_up_host);
wifiManager.addParameter(&custom_update_username);
wifiManager.addParameter(&custom_update_password);
wifiManager.addParameter(&custom_term_temp);
wifiManager.addParameter(&custom_term_hist);
wifiManager.addParameter(&custom_field);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality(8);
wifiManager.setConfigPortalTimeout(timeout);
//wifiManager.setShowStaticFields(true); // force show static ip fields
//wifiManager.setShowDnsFields(true); // force show dns field always
if (!wifiManager.startConfigPortal("Supla_Termostat")) {
Serial.println("Not connected to WiFi but continuing anyway.");
} else {
Serial.println("connected...yeey :)"); //if you get here you have connected to the WiFi
strcpy(Location_id, custom_Location_id.getValue());
strcpy(Location_Pass, custom_Location_Pass.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
strcpy(up_host, custom_up_host.getValue());
strcpy(update_username, custom_update_username.getValue());
strcpy(update_password, custom_update_password.getValue());
strcpy(term_temp, custom_term_temp.getValue());
strcpy(term_hist, custom_term_hist.getValue());
WiFi.softAPdisconnect(true); // close AP
String getParam(String name){
String value;
if(wifiManager.server->hasArg(name)) {
value = wifiManager.server->arg(name);
if (value == "1"){ Term_Tipo = 1;} else { Term_Tipo = 0;}
return value;
void saveParamCallback(){
Serial.println("[CALLBACK] saveParamCallback fired");
Serial.println("PARAM customfieldid = " + getParam("customfieldid"));
itoa(Term_Tipo ,termtipo ,10) ;
typedef struct { //------------------------------------------- BTN ----------------------------------------------------
int pin;
int relay_pin;
int channel;
char last_val;
int ms;
unsigned long last_time;
bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
void TH_Overlay() {
display.clear();
if (tr > -100){
display.setFont(ArialMT_Plain_24);
display.drawString(64, 20, String(tr, 2) + "ºC");
if (tr < -100){
display.drawString(64, 20, "ERROR");
if (window == true){
display.drawString(64, 48, "HALTED " + String(trs, 1) + "ºC");
}else{
if ((btn[0].mem) == 1){
display.drawString(64, 48, "Auto Set " + String(trs, 1) + "ºC");
if ((btn[0].mem) == 0){
display.drawString(64, 48, "Manual mode");
if (pr_wifi == false){
display.drawXbm(1, 0, 16, 16, logo16_wifi_bmp);// -------------------------------------------------- oled wifi ok --------
if (s == 17){
display.drawXbm(24, 0, 16, 16, logo16_supla_bmp);// ------------------------------------------------ oled supla ok --------
}else{
display.setTextAlignment(TEXT_ALIGN_LEFT);
display.drawString(18, 0, "E" + String(s));
if (window == false){
display.drawXbm(48, 0, 16, 16, logo16_Win_close);// -------------------------------------------------- window close --------
}else{
display.drawXbm(48, 0, 16, 16, logo16_Win_open);// -------------------------------------------------- window open --------
if ((btn[1].mem) == 0){
display.drawXbm(86, 0, 40, 16, logo_Power_off);// ------------------------------------------------- Relay off --------
if ((btn[1].mem) == 1){
display.drawXbm(86, 0, 40, 16, logo_Power_on);// -------------------------------------------------- Relay on ---------
if (Term_Tipo == 0){
display.drawXbm(66, 0, 16, 16, logo16_hot);// -------------------------------------------------- heating ---------
}else{
display.drawXbm(66, 0, 16, 16, logo16_cool);// -------------------------------------------------- cooling ---------
display.display();
yield();
double t = -275;
switch(channelNumber)
case 3:
yield();
t = sensors.getTempCByIndex(0);
if (t < -55){t = -275;}
break;
case 4:
double trd = (Term_Temp) ;
trd = (trd / 10) ;
t = (trd);
break;
return t;
void itrate_Term() {
if ( digitalRead(btn[1].relay_pin-1) == 1){
(btn[1].mem) = 0 ;
Serial.println("Window open");
SuplaDevice.relayOff(1);
return ;
if (tr<-99){
(btn[1].mem) = 0 ;
Serial.println(" Relay off temp to low");
return ;
double trt = (Term_Temp + Term_Hist) ;
trt = (trt / 10);
Serial.print("tr ");
Serial.println(tr);
if (tr >= trt) {
if ( digitalRead(btn[1].relay_pin-1) == 1) {
(btn[1].mem) = 0 ;
Serial.println(" Relay off ");
double trs = (Term_Temp - Term_Hist) ;
trs = (trs / 10) ;
if(tr <= trs) {
if ( digitalRead(btn[1].relay_pin-1) == 0) {
(btn[1].mem) = 1 ;
Serial.println(" Relay on ");
SuplaDevice.relayOn(1, 0);
}else{
double trt = (Term_Temp - Term_Hist) ;
trt = (trt / 10);
Serial.println(tr);
if (tr <= trt) {
(btn[1].mem) = 0 ;
double trs = (Term_Temp + Term_Hist) ;
trs = (trs / 10) ;
if(tr >= trs) {
(btn[1].mem) = 1 ;
void iterate_btn() {
char v;
unsigned long now = millis();
for(int a=0;a<4;a++)
if (btn[a].pin > 0) {
v = digitalRead(btn[a].pin-1);
if (v != btn[a].last_val && now - btn[a].last_time ) {
btn[a].last_val = v;
btn[a].last_time = now;
delay(75);
if (v==0)
if (dimm == true){
dimm_milis = millis() + 15000 ;
display.setContrast(100, 230, 60);
dimm = false;
TH_Overlay();
return;
}else{
if ((btn[a].channel)== 2){
Serial.print("Temp - ");
Term_Temp = Term_Temp - 5 ;
Serial.println(Term_Temp);
tr_milis = millis() + 5000 ;
trs = (Term_Temp) ;
trs = (trs / 10) ;
SuplaDevice.channelDoubleValueChanged(4,trs);
TH_Overlay();
return;
if ((btn[a].channel)== 3){
Serial.print("Temp + ");
Term_Temp = Term_Temp + 5 ;
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
return;
if ( (btn[a].mem) == 1 ) {
SuplaDevice.relayOff(btn[a].channel);
Serial.print("BTN Switsh off relay ");
Serial.println(btn[a].relay_pin-1);
btn[a].mem = 0;
return;
} else {
SuplaDevice.relayOn(btn[a].channel, 0);
Serial.print("BTN Switsh on relay ");
btn[a].mem = 1;
return;
void supla_btn_init() {
for(int a=0;a<BTN_COUNT;a++)
pinMode(btn[a].pin-1, INPUT_PULLUP);
btn[a].last_val = digitalRead(btn[a].pin-1);
btn[a].last_time = millis();
pinMode(btn[a].relay_pin-1,OUTPUT);
int supla_DigitalRead(int channelNumber, uint8_t pin) {
if (channelNumber == 5){
return !window;
}else{
return btn[channelNumber].mem;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
btn[channelNumber].mem =val;
case 0:
if ( (btn[channelNumber].mem) == 0 ) {
Serial.print("Manual Mode ");
digitalWrite(btn[channelNumber].relay_pin-1, LOW);
eep_milis = millis() + 2000 ;
Serial.println(" Relay off Manual Mode");
}else {
Serial.print("Auto Mode ");
digitalWrite(btn[channelNumber].relay_pin-1, HIGH);
TH_Overlay();
break;
case 1:
Serial.print("Switsh off relay ");
Serial.println(btn[channelNumber].relay_pin-1);
}else {
Serial.print("Switsh on relay ");
TH_Overlay();
break;
case 2:
}else {
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
break;
return;
void Eeprom_save() { //----------EEPROM write ---------------------- EEprom
if (start){
return;
if ( (btn[0].mem) == 0 ) {
for(int e=0;e<2;e++) {
if ( btn[e].ms > 0 ) {
continue;
} else {
eep = (btn[e].mem); // --- read relay state
if (eep != EEPROM.read(e)){ // --- compare relay state with memorized state
EEPROM.write(e,eep); // --- if different write memory
Serial.print("EEPROM.");
Serial.print(e);
Serial.print(" write.");
Serial.print((eep));
Serial.print(" channel ");
Serial.println((btn[e].channel));
EEPROM.commit();
if ( (btn[0].mem) == 1 ) {
eep = (btn[0].mem); // --- read relay state
if (eep != EEPROM.read(0)){ // --- compare relay state with memorized state
EEPROM.write(0,eep); // --- if different write memory
Serial.print(0);
Serial.println((btn[0].channel));
EEPROM.commit();
void Eepron_read() { //----------EEPROM read ---------------------- EEprom
if ( btn[epr].ms > 0 ) {
return;
} else {
eep = EEPROM.read(epr); // ---read relay state
Serial.print(epr);
Serial.print(" read.");
Serial.println((btn[epr].channel));
if (eep == HIGH){ // --- if 1 send relay on
(btn[epr].mem) = 1 ;
SuplaDevice.relayOn(epr, 0); // --- only one channel on each pass
if (eep == 1) {
bool stat = digitalRead(btn[1].relay_pin-1);
if (stat) SuplaDevice.relayOn(1, 0);
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
s=status; // -- to check if we are registered and ready before restore from memory
void setup() { //------------------------------------------------ Setup ----------------------------------------------
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin(115200);
pinMode(sensor_pin, INPUT_PULLUP);
delay(200);
EEPROM.begin(512);
sensors.begin();
sensors.getAddress(tempDeviceAddress, 0);
sensors.setResolution(tempDeviceAddress, resolution);
sensors.setWaitForConversion(false);
sensors.requestTemperatures();
display.init();
display.flipScreenVertically();
display.clear();
display.drawString(33, 40, "SUPLA");
display.drawXbm(0, 16, 32, 32,logo32_glcd_bmp );
display.display();
delay(2000);
if (WiFi.SSID()==""){
initialConfig = true;
Serial.println("mounting FS...");
WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.macAddress(mac);
char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
SuplaDevice.addRelay(101, false);
SuplaDevice.addRelay(102, false);
SuplaDevice.addRelay(103, false);
SuplaDevice.addSensorNO(150);
memset(btn, 0, sizeof(btn));
btn[0].pin =button_1 +1; // pin gpio buton +1
btn[0].relay_pin =relay_1 +1; // pin gpio Relay +1
btn[0].channel =0; // channel
btn[0].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[0].mem =0;
btn[1].pin =button_2 +1; // pin gpio buton +1
btn[1].relay_pin =relay_2 +1; // pin gpio Relay +1
btn[1].channel =1; // channel
btn[1].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[1].mem =0;
btn[2].pin =button_3 +1; // pin gpio buton +1
btn[2].relay_pin =relay_3 +1; // pin gpio Relay +1
btn[2].channel =2; // channel
btn[2].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[2].mem =0;
btn[3].pin =button_4 +1; // pin gpio buton +1
btn[3].relay_pin =relay_4 +1; // pin gpio Relay +1
btn[3].channel =3; // channel
btn[3].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[3].mem =0;
supla_btn_init();
display.clear();
display.drawString(64, 0, "mounting FS...");
display.display();
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
DynamicJsonBuffer jsonBuffer;
json.printTo(Serial); //print config data to serial on startup
if (json.success()) {
Serial.println("\nparsed json");
strcpy(Location_id, json["Location_id"]);
strcpy(Location_Pass, json["Location_Pass"]);
strcpy(Supla_name, json["Supla_name"]);
strcpy(up_host, json["up_host"]);
strcpy(update_username, json["update_username"]);
strcpy(update_password, json["update_password"]);
strcpy(term_temp, json["term_temp"]);
Term_Temp = (String(term_temp).toInt());
strcpy(term_hist, json["term_hist"]);
Term_Hist = (String(term_hist).toInt());
strcpy(termtipo, json["termtipo"]);
Term_Tipo = (String(termtipo).toInt());
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
wifi_station_set_hostname(up_host); //nazwa w sieci lokalnej @cino111
host = (up_host);
SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead);
SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);
SuplaDevice.setStatusFuncImpl(&status_func);
SuplaDevice.setName(Supla_name);
int LocationID = atoi(Location_id);
mac, // Ethernet MAC address
Supla_server, // SUPLA server address
LocationID, // Location ID
Location_Pass); // Location Password
dimm_milis = millis() + 15000;
void loop() {
if (start == true){
// read_initial_relay_state
for(int i=0;i<2;i++){
if ( (btn[i].ms) > 0 ) {
digitalWrite(btn[i].relay_pin-1, LOW);
continue;
} else {
eep = EEPROM.read(i);
if (eep >= 2 ){
EEPROM.write(i,0);
Serial.println("epp correct");
EEPROM.commit();
Serial.print("Recover.");
Serial.print(i);
Serial.println((btn[i].channel));
btn[i].mem =eep;
Serial.print((btn[i].relay_pin) -1);
Serial.print(" set ");
Serial.println(eep);
start = false;
if (initialConfig == true){
EEPROM.write(i, 0);
EEPROM.commit();
Serial.println("initial config triger");
ondemandwifiCallback () ;
if (shouldSaveConfig == true) {
Serial.println("saving config");
json["Location_id"] = Location_id;
json["Location_Pass"] = Location_Pass;
json["Supla_name"] = Supla_name;
json["up_host"] = up_host;
json["update_username"] = update_username;
json["update_password"] = update_password;
json["term_temp"] = term_temp;
json["term_hist"] = term_hist;
json["termtipo"] = termtipo;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {Serial.println("failed to open config file for writing");}
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
display.clear();
display.drawString(64, 0, "config saved");
display.display();
delay(5000);
ESP.restart();
if (millis() > ds_milis){ // ------------------------------Termp update -----------------------------
window = digitalRead(sensor_pin);
ds_milis = millis() + 5000 ;
if (WiFi.status() != WL_CONNECTED) {
if (millis() > wifimilis) {
WiFi.begin();
pr_wifi = true;
tikOn = false;
Serial.println("CONNECTING WIFI");
wifimilis = (millis() + wifi_checkDelay) ;
if (millis() > eep_milis){
Eeprom_save() ; // ------------------------------Eepron save callback -----------------------------
eep_milis = millis() + 5000 ;
yield();
if (millis() > dimm_milis){
if (dimm == false){
display.setContrast(50, 50, 30);
display.display();
dimm = true ;
if (s != 17) if (tikOn == true)tikOn = false;
switch (s) { // ------------------------------------------------ Status ------------------------------------
case 17:
if (epr<2){
Eepron_read() ;
epr = epr+1;
if (tikOn == false)tikOn = true;
break;
case 10:
epr = 0 ;
break;
int C_W_read = digitalRead(btn[0].pin-1);{
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
Serial.println("Triger sate changed");
C_W_state = C_W_read;
if (C_W_state == LOW) {
last_C_W_state = C_W_read;
iterate_btn();
delay(50);
SuplaDevice.iterate();
if (pr_wifi == true){
Serial.println("");
Serial.println("CONNECTED");
Serial.print("local IP: ");
Serial.print("subnetMask: ");
Serial.print("gatewayIP: ");
long rssi = WiFi.RSSI();
Serial.print("Signal Strength (RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
pr_wifi = false;
MDNS.begin(host);
httpUpdater.setup(&httpServer, update_path, update_username, update_password);
httpServer.begin();
MDNS.addService("http", "tcp", 81);
Serial.printf("HTTPUpdateServer ready! Open http://%s.local:81%s in your browser and login with username '%s' and password '%s'\n", host, update_path, update_username, update_password);
delay(100);
httpServer.handleClient();
MDNS.update();
if (millis() > tr_milis){ // ------------------------------Termostat callback -----------------------------
yield();
tr = sensors.getTempCByIndex(0);
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
if ((btn[0].mem) == true) itrate_Term();
if ((String(term_temp).toInt()) != Term_Temp){
display.invertDisplay();// ------------------- oled imvert ---------------------------------------------------
Serial.println(term_temp);
Serial.println("save Temp_Term");
itoa(Term_Temp ,term_temp ,10) ;
json["termtipo"] = Term_Tipo;
configFile.close();
delay(100);
display.normalDisplay();//---------------------- oled normal ---------------------------------------------------
// Supla.org ethernet layer
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
SuplaDeviceCallbacks cb;
cb.get_temperature = &get_temperature;
cb.get_rgbw_value = NULL;
cb.set_rgbw_value = NULL;
return cb;
}You do not have the required permissions to view the files attached to this post.
jaros12
elmaya wrote: Sun Feb 23, 2020 12:55 pm
I personally use nodemcu and Gpio9 works perfectly as a sensor (DOUT mode).![]()
Thanks for the code. I have a Lolin (new Nodemcu V3) board, maybe this model doesn't work with Gpio9. The connection seems OK, after removing the sensor from the code, the other functions work. I checked on 2 tiles, I uploaded via both Arduino and FlashTool, the result the same tile resets. I connected a 4k7 pullup to Gpio9, maybe a bad value? I will still test ...
elmaya
jaros12 wrote: Sun Feb 23, 2020 2:23 pmelmaya wrote: Sun Feb 23, 2020 12:55 pm
Please check your connection.in arduino ide select generic Esp8266 and Flash Mode DOUT.
It works 100% right now I have one in front of me.
the resistance value does not matter (you don't really need it, the internal one is activated).
The important thing is Flash Mode DOUT.
jaros12
@elmaya, thanks.
I chose in Arduino - Nodemcu, changed to ESP8266 and checked.
Michal81
Hi.
I noticed one problem in the driver's work. By using it to work with the furnace pump - the hysteresis should work only down from the set temperature.
With hysteresis 2 degrees - currently the state changes at: switching on at +2 degrees and switching off at -2 from the set temperature.
Can you do it so that the state changes only at -2 degrees from the set temperature, down from the set temperature?
And as I wrote when changing heating / cooling.
Example:
Set temperature: 35, hysteria 2.
On at 35, off at 33.
Example:
elmaya
and you can't just set the hysteresis to 1?Michal81 wrote: Sun Feb 23, 2020 7:41 pm Hi.
Example:
Michal81
That's right - the effect will be the same, but I'm pushing it with the generally accepted configuration of such furnace controllers - there ALWAYS hysteresis works only below the set temperature. Of course, this is not a big problem, but if it is a matter of changing e.g. two lines of code, I think it would be worth thinking about.
Or, for example, make an option in configuration:
- hysteresis measured below the set temperature.
- hysteresis measured above the set temperature.
- hysteresis measured below and above the set temperature.
elmaya
I am aware that it is usually done that way.Michal81 wrote: Sun Feb 23, 2020 8:01 pm That's right - the effect will be the same, but I'm pushing it with the generally accepted configuration of such furnace controllers - there ALWAYS hysteresis works only below the set temperature. Of course, this is not a big problem, but if it is a matter of changing e.g. two lines of code, I think it would be worth thinking about.
however I prefer to set the temperature I want to have (average temperature) and not the maximum temperature.
The code with the 2 edited lines:
#include <EEPROM.h>
extern "C"
//#define D1 5
//#define D2 4
//#define D5 14
//#define D6 12
//#define D7 13
#define BTN_COUNT 4
bool start = true;
bool eep = LOW;
int epr = 0;
int s;
int Term_Temp ;
int Term_Hist ;
int Term_Tipo ;
double tr = -275;
double trs ;
bool tikOn = false;
WiFiClient client;
ESPEFC httpUpdater;
char up_host[21];
char term_temp[5];
char term_hist[5];
char termtipo[5];
byte mac[6];
bool dimm = false;
display.clear();
display.display();
} else {
String value;
return value;
int pin;
int relay_pin;
int channel;
char last_val;
int ms;
bool mem;
} _btn_t;
void TH_Overlay() {
display.clear();
if (tr > -100){
if (tr < -100){
}else{
if (s == 17){
}else{
}else{
}else{
display.display();
yield();
double t = -275;
case 3:
yield();
break;
case 4:
trd = (trd / 10) ;
t = (trd);
break;
return t;
(btn[1].mem) = 0 ;
return ;
if (tr<-99){
(btn[1].mem) = 0 ;
return ;
double trt = (Term_Temp) ;
trt = (trt / 10);
Serial.println(tr);
if (tr >= trt) {
(btn[1].mem) = 0 ;
trs = (trs / 10) ;
if(tr <= trs) {
(btn[1].mem) = 1 ;
}else{
trt = (trt / 10);
Serial.println(tr);
if (tr <= trt) {
(btn[1].mem) = 0 ;
trs = (trs / 10) ;
if(tr >= trs) {
(btn[1].mem) = 1 ;
char v;
delay(75);
if (v==0)
if (dimm == true){
dimm = false;
TH_Overlay();
return;
}else{
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
return;
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
return;
btn[a].mem = 0;
return;
} else {
btn[a].mem = 1;
return;
return !window;
}else{
case 0:
}else {
TH_Overlay();
break;
case 1:
}else {
TH_Overlay();
break;
case 2:
}else {
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
break;
return;
if (start){
return;
continue;
} else {
Serial.print(e);
EEPROM.commit();
Serial.print(0);
EEPROM.commit();
return;
} else {
Serial.print(epr);
if (eep == 1) {
delay(200);
EEPROM.begin(512);
sensors.begin();
display.init();
display.clear();
display.display();
delay(2000);
btn[0].mem =0;
btn[1].mem =0;
btn[2].mem =0;
btn[3].mem =0;
supla_btn_init();
display.clear();
display.display();
if (configFile) {
} else {
} else {
host = (up_host);
void loop() {
if (start == true){
continue;
} else {
if (eep >= 2 ){
EEPROM.write(i,0);
EEPROM.commit();
Serial.print(i);
btn[i].mem =eep;
start = false;
EEPROM.write(i, 0);
EEPROM.commit();
configFile.close();
display.clear();
display.display();
delay(5000);
ESP.restart();
WiFi.begin();
pr_wifi = true;
tikOn = false;
yield();
if (dimm == false){
display.display();
dimm = true ;
case 17:
if (epr<2){
Eepron_read() ;
epr = epr+1;
break;
case 10:
epr = 0 ;
break;
iterate_btn();
delay(50);
Serial.println("");
Serial.print(rssi);
pr_wifi = false;
MDNS.begin(host);
httpServer.begin();
delay(100);
MDNS.update();
yield();
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
configFile.close();
delay(100);
if ( size > 0 ) {
return -1;
client.stop();
return cb;
