Potwierdzam - ten człowiek - elmaya jest NIESAMOWITY.mechatronikaPL wrote: Tue Jul 14, 2020 7:03 am elamya You are amazing ! Been working great since yesterdayThank You very much !!!
thermostat with Oled display
Michal81
MICHAŁ DOM
WitamWALDIYO wrote: Mon Dec 16, 2019 2:09 pm Wszystko pięknie. Fajnie by było by od tego układu wyrzucić przekaźnik ( stacja np. w pokoju ) a moduł wykonawczy z wemosem i przekaźnikiem przy piecu. Wtedy będzie git![]()
czy rozwijałeś ten pomysł aby przekaźniki na kolejnym wemosem zainstalować w innym pomieszczeniu ??
szukam wsparcia przy realizacji sterowania ogrzewaniem
gigilio
Hi Elmaya,
I have question - i want to connect buzzer instead relay.
It wants an alarm to go off if the temperature is too low or too high.
Is it possible on your thermostat ?
Prawdopodobienstwo jest zerowe że wygrasz miliona jak nie wyślesz kuponu totolotka...
MICHAŁ DOM
michael wrote: Wed Oct 16, 2019 10:17 am My visualization of this thermostat,
Cover after the old Sonoff Touch (which doesn't work anyway)
Original glass will be replaced with engraving laminate. It promises to be beautiful
hello did you manage to design the thermostat ????
michael
- Has thanked: 3 times
- Been thanked: 3 times
I'm going to make a working thermostat as well but in other way (glass front panel) but I stucked on projecting pcbIt is true that I abandoned construction, otherwise I had solved it at home, but it was close to implementation![]()
How is Your project? Is working properly? I'm curious
Hi @elmaya
Great respect for the soft
I've got question about setting the temperature. Now it is working like seting + and - so if I want to lower the temperature for night by 1,5 grads I need to make timetable that is lowering 3x 0,5 grad. If something go bad and one order will not go through the net then the next day the tempertature will be lower/higher by 0,5C.
Is it possible to change the soft to make just order setting certain value for thermostat? For example 21 grades? Similar like it is with dimmable LED, it is possible to set % of light so I guess Supla supports states with value. Or am I tottaly wrong?
[email protected]
Hello
Elmaya, will it work on the ds 18b20 in this thermostat ?.
Sorry i don't know english ds18b20 parasitically.
https://en-forum.supla.org/viewtopic.php?f=10&t=5320[email protected] wrote: Sat Nov 21, 2020 8:41 pm Hello
[email protected]
I only have two wires for the sensor, I want to power with two wires parasitically if this soft will do the trick
