thermostat with Oled display
elmaya
to compile this you have to use the Supla library v1.6.1
https://github.com/SUPLA/arduino
Has thanked: 3 times
Been thanked: 3 times
elmaya wrote: Sun Nov 29, 2020 2:59 am to compile this you have to use the Supla library v1.6.1
damn it :evil: ... 2 hours of my life is gone ... ;) Now I wrote it down to remember.
thanks bro
YoMan wrote: Sun Nov 29, 2020 5:45 pm
thanks bro
BTW:
if (dimm == true) {
    display.setContrast(35, 50, 10)
what means second and third value? 1st is brightness - it's clear but two others I couldn't find the right explanation (or haven't looking enought for it). I was trying to change the values but nothing visible has changed in working.
elmaya
thanks bro
yes, it's a bit confusing with the two Supla libraries.
if "#define SUPLADEVICE_CPP" is among the first lines of the code it is the "Supla v1.6.1 library "
otherwise it will be "Supla Dev library"
elmaya wrote: Sun Nov 29, 2020 5:59 pm
thanks bro
OK. I'll try to remember ... ;)
I'm on the beginnig of may adventure with arduino/esp8266/supla/automatization/smart home/things , etc ..... so sometimes I have more questions than anybody is able or has time to give answers ;)
so thank You twice in the name of all beginners for You spending Your valuable time on that forum <thumb up> :)
P.S.
for others as well of course but it is the thread that concerns Your project
@elmaya
I wanted to play more with Your soft and bought 1,3 OLED SH1106. I've just downloaded the source from github and I've got that flicker symptom. There was a compiled version https://en-forum.supla.org/viewtopic.php?p=49382#p49382 with fixed bug but is it fixed in non-compiled version? Or is it my mistake with compilation?
elmaya
YoMan wrote: Fri Dec 04, 2020 9:15 pm @elmaya
this is the latest version with the libraries:
supla_Termostst_oled_sensor_icomo_H_C.rar
elmaya wrote: Sat Dec 05, 2020 9:06 am
Thanks a lot.
BTW: I do not need window sensor at the moment (maybe in future) so I've changed some lines. Would You like to check if it will not cause any problems in future?
added "//":
//   if (window == false){
//                display.drawXbm(48, 0, 16, 16, logo16_Win_close);// -------------------------------------------------- window close  --------
//           }else{
//                display.drawXbm(48, 0, 16, 16, logo16_Win_open);// -------------------------------------------------- window open --------
changed "window == true" to "window == false":
void itrate_Term() {
      if ( digitalRead(btn[1].relay_pin-1) == 1){
          (btn[1].mem) = 0 ;
          Serial.println("Window open");
          CustomSupla.relayOff(1);
and
         display.setFont(ArialMT_Plain_16);
         display.setTextAlignment(TEXT_ALIGN_CENTER);
         display.drawString(64, 48, "HALTED " + String(trs, 1) + "ºC");
eradek
My implementation of Elmaya's thermostat.
radzik_r
Been thanked: 2 times
eradek wrote: Sun Mar 07, 2021 5:15 pm My implementation of Elmaya's thermostat.
fajnie wygląda
