serwer supla na linux
helius
Restart robilem jutro sie pobawie jak sie nie uda to raspberry zamowie.
Młody zaczynam przygodę z Suplą
helius
Docker version 19.03.11, build dd360c7
helius
teraz mam coś nowego
helius@helius-ESPRIMO:~$ ./supla-docker/supla.sh restart
Stopping SUPLA containers
ERROR: Couldn't connect to Docker daemon - you might need to run `docker-machine start default`.
Starting SUPLA containers
Goral64
Has thanked: 2 times
Jak masz skonfigurowane .env ?
lesny8
Has thanked: 10 times
Been thanked: 9 times
Wcięło mi po drodze instalację docker-compose :roll: chyba że zainstalowałeś sam, jeśli nie to
sudo pip3 install docker-compose
Po instalacji sprawdzając wersję
docker-compose -v
powinieneś dostać odpowidź
docker-compose version 1.27.4, build unknown
Potwierdź jeszcze, czy Twój użytkownik jest w grupie docker
sudo groupmems -g docker -l
SOP 2023 :heavy_check_mark:
SOP 2024 :heavy_check_mark:
🧩: 🔑cz->b ⛴️+ila
helius
The directory '/home/helius/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/helius/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting docker-compose
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (110kB)
100% |████████████████████████████████| 112kB 663kB/s
Requirement already satisfied: PyYAML<6,>=3.10 in /usr/lib/python3/dist-packages (from docker-compose)
Collecting docopt<1,>=0.6.1 (from docker-compose)
Downloading https://files.pythonhosted.org/packages ... 6.2.tar.gz
Collecting jsonschema<4,>=2.5.1 (from docker-compose)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (56kB)
100% |████████████████████████████████| 61kB 1.0MB/s
Collecting cached-property<2,>=1.2.0 (from docker-compose)
Collecting python-dotenv<1,>=0.13.0 (from docker-compose)
Collecting requests<3,>=2.20.0 (from docker-compose)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (61kB)
100% |████████████████████████████████| 61kB 989kB/s
Collecting texttable<2,>=0.9.0 (from docker-compose)
Collecting docker[ssh]<5,>=4.3.1 (from docker-compose)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (146kB)
100% |████████████████████████████████| 153kB 823kB/s
Collecting dockerpty<1,>=0.4.1 (from docker-compose)
Downloading https://files.pythonhosted.org/packages ... 4.1.tar.gz
Collecting distro<2,>=1.5.0 (from docker-compose)
Collecting websocket-client<1,>=0.32.0 (from docker-compose)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (200kB)
100% |████████████████████████████████| 204kB 821kB/s
Collecting attrs>=17.4.0 (from jsonschema<4,>=2.5.1->docker-compose)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (49kB)
100% |████████████████████████████████| 51kB 1.5MB/s
Collecting importlib-metadata; python_version < "3.8" (from jsonschema<4,>=2.5.1->docker-compose)
Collecting pyrsistent>=0.14.0 (from jsonschema<4,>=2.5.1->docker-compose)
Downloading https://files.pythonhosted.org/packages ... 7.3.tar.gz (106kB)
100% |████████████████████████████████| 112kB 734kB/s
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from jsonschema<4,>=2.5.1->docker-compose)
Requirement already satisfied: six>=1.11.0 in /usr/lib/python3/dist-packages (from jsonschema<4,>=2.5.1->docker-compose)
Requirement already satisfied: idna<3,>=2.5 in /usr/lib/python3/dist-packages (from requests<3,>=2.20.0->docker-compose)
Requirement already satisfied: chardet<4,>=3.0.2 in /usr/lib/python3/dist-packages (from requests<3,>=2.20.0->docker-compose)
Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests<3,>=2.20.0->docker-compose)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/lib/python3/dist-packages (from requests<3,>=2.20.0->docker-compose)
Collecting paramiko>=2.4.2; extra == "ssh" (from docker[ssh]<5,>=4.3.1->docker-compose)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (206kB)
100% |████████████████████████████████| 215kB 534kB/s
Collecting zipp>=0.5 (from importlib-metadata; python_version < "3.8"->jsonschema<4,>=2.5.1->docker-compose)
Requirement already satisfied: pynacl>=1.0.1 in /usr/lib/python3/dist-packages (from paramiko>=2.4.2; extra == "ssh"->docker[ssh]<5,>=4.3.1->docker-compose)
Collecting cryptography>=2.5 (from paramiko>=2.4.2; extra == "ssh"->docker[ssh]<5,>=4.3.1->docker-compose)
Downloading https://files.pythonhosted.org/packages ... 2.1.tar.gz (540kB)
100% |████████████████████████████████| 542kB 491kB/s
Collecting bcrypt>=3.1.3 (from paramiko>=2.4.2; extra == "ssh"->docker[ssh]<5,>=4.3.1->docker-compose)
Downloading https://files.pythonhosted.org/packages ... 2.0.tar.gz (42kB)
100% |████████████████████████████████| 51kB 786kB/s
Collecting cffi!=1.11.3,>=1.8 (from cryptography>=2.5->paramiko>=2.4.2; extra == "ssh"->docker[ssh]<5,>=4.3.1->docker-compose)
Downloading https://files.pythonhosted.org/packages ... 1_i686.whl (378kB)
100% |████████████████████████████████| 378kB 627kB/s
Collecting pycparser (from cffi!=1.11.3,>=1.8->cryptography>=2.5->paramiko>=2.4.2; extra == "ssh"->docker[ssh]<5,>=4.3.1->docker-compose)
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (112kB)
100% |████████████████████████████████| 112kB 649kB/s
Installing collected packages: docopt, attrs, zipp, importlib-metadata, pyrsistent, jsonschema, cached-property, python-dotenv, requests, texttable, websocket-client, pycparser, cffi, cryptography, bcrypt, paramiko, docker, dockerpty, distro, docker-compose
Running setup.py install for docopt ... done
Running setup.py install for pyrsistent ... done
Found existing installation: requests 2.18.4
Not uninstalling requests at /usr/lib/python3/dist-packages, outside environment /usr
Found existing installation: cryptography 2.1.4
Not uninstalling cryptography at /usr/lib/python3/dist-packages, outside environment /usr
Running setup.py install for cryptography ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-gdmmvjt3/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-yzqbwnk9-record/install-record.txt --single-version-externally-managed --compile:
/usr/lib/python3.6/distutils/dist.py:261: UserWarning: Unknown distribution option: 'long_description_content_type'
warnings.warn(msg)
running install
running build
running build_py
creating build
creating build/lib.linux-i686-3.6
creating build/lib.linux-i686-3.6/cryptography
copying src/cryptography/fernet.py -> build/lib.linux-i686-3.6/cryptography
copying src/cryptography/exceptions.py -> build/lib.linux-i686-3.6/cryptography
copying src/cryptography/__about__.py -> build/lib.linux-i686-3.6/cryptography
copying src/cryptography/__init__.py -> build/lib.linux-i686-3.6/cryptography
copying src/cryptography/utils.py -> build/lib.linux-i686-3.6/cryptography
creating build/lib.linux-i686-3.6/cryptography/hazmat
copying src/cryptography/hazmat/_der.py -> build/lib.linux-i686-3.6/cryptography/hazmat
copying src/cryptography/hazmat/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat
copying src/cryptography/hazmat/_oid.py -> build/lib.linux-i686-3.6/cryptography/hazmat
creating build/lib.linux-i686-3.6/cryptography/x509
copying src/cryptography/x509/base.py -> build/lib.linux-i686-3.6/cryptography/x509
copying src/cryptography/x509/general_name.py -> build/lib.linux-i686-3.6/cryptography/x509
copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-i686-3.6/cryptography/x509
copying src/cryptography/x509/ocsp.py -> build/lib.linux-i686-3.6/cryptography/x509
copying src/cryptography/x509/__init__.py -> build/lib.linux-i686-3.6/cryptography/x509
copying src/cryptography/x509/oid.py -> build/lib.linux-i686-3.6/cryptography/x509
copying src/cryptography/x509/extensions.py -> build/lib.linux-i686-3.6/cryptography/x509
copying src/cryptography/x509/name.py -> build/lib.linux-i686-3.6/cryptography/x509
creating build/lib.linux-i686-3.6/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends
creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
creating build/lib.linux-i686-3.6/cryptography/hazmat/bindings
copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/bindings
creating build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ocsp.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
creating build/lib.linux-i686-3.6/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-i686-3.6/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-i686-3.6/cryptography/hazmat/bindings/openssl
running egg_info
writing src/cryptography.egg-info/PKG-INFO
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing requirements to src/cryptography.egg-info/requires.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'docs/_build'
warning: no previously-included files found matching 'vectors'
warning: no previously-included files matching '*' found under directory 'vectors'
warning: no previously-included files found matching '.travis.yml'
warning: no previously-included files found matching '.travis'
warning: no previously-included files matching '*' found under directory '.travis'
warning: no previously-included files matching '*' found under directory '.github'
warning: no previously-included files found matching 'release.py'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files found matching 'dev-requirements.txt'
warning: no previously-included files found matching 'rtd-requirements.txt'
warning: no previously-included files found matching 'tox.ini'
warning: no previously-included files matching '*' found under directory '.zuul.d'
warning: no previously-included files matching '*' found under directory '.zuul.playbooks'
writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
running build_ext
generating cffi module 'build/temp.linux-i686-3.6/_padding.c'
creating build/temp.linux-i686-3.6
generating cffi module 'build/temp.linux-i686-3.6/_openssl.c'
building '_openssl' extension
creating build/temp.linux-i686-3.6/build
creating build/temp.linux-i686-3.6/build/temp.linux-i686-3.6
i686-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.6m -c build/temp.linux-i686-3.6/_openssl.c -o build/temp.linux-i686-3.6/build/temp.linux-i686-3.6/_openssl.o -Wconversion -Wno-error=sign-conversion
build/temp.linux-i686-3.6/_openssl.c:575:10: fatal error: openssl/opensslv.h: Nie ma takiego pliku ani katalogu
#include <openssl/opensslv.h>
compilation terminated.
error: command 'i686-linux-gnu-gcc' failed with exit status 1
Can't rollback cryptography, nothing uninstalled.
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-gdmmvjt3/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-yzqbwnk9-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-gdmmvjt3/cryptography/
lesny8
doinstaluj jeszcze
sudo apt install -y libffi-dev libssl-dev
i powtórz
🧩: 🔑cz->b ⛴️+ila
helius
ciagle coś nowego wywala
helius@helius-ESPRIMO:~$ ./supla-docker/supla.sh start
./supla-docker/supla.sh: linia 37: docker-compose: nie znaleziono polecenia
to ta linia docker-compose up --build -d && \
helius
uaaa może na innym linux-e trzeba to postawić
lesny8
Musisz zainstalować poprawnie docer-compose i dopiero uruchomić skrypt supli.
Systemu nie musisz zmieniać. Ja na Ubuntu postawiłem bez problemu.
🧩: 🔑cz->b ⛴️+ila
