serwer supla na linux
ocean
.env file
# Where the SUPLA Cloud will be accessible? Put domain or IP address here with port.
CLOUD_DOMAIN=192.168.1.99
# Initial user account details; delete these settings after the first launch
[email protected]
FIRST_USER_PASSWORD=conchocon
# Google ReCaptcha settings
RECAPTCHA_ENABLED=false
RECAPTCHA_PUBLIC_KEY=
RECAPTCHA_PRIVATE_KEY=
# Mailer settings (SMTP)
MAILER_HOST=10.0.75.1
MAILER_PORT=465
MAILER_USER=
MAILER_PASSWORD=
MAILER_ENCRYPTION=ssl
MAILER_FROM=
# If you want to be notified about some server errors, set this
[email protected]
# Where to store SUPLA Cloud's data
VOLUME_DATA=./var
# On which ports the SUPLA Cloud should listen (only if standalone mode)
PORT_HTTP=80
PORT_HTTPS=443
REQUIRE_REGULATIONS_ACCEPTANCE=false
REQUIRE_COOKIE_POLICY_ACCEPTANCE=false
BRUTE_FORCE_AUTH_PREVENTION_ENABLED=true
ACCOUNTS_REGISTRATION_ENABLED=true
# These options protect your application
DB_PASSWORD=52WRbOTcdQeH2vAXffhXcfBCktmjEJa3
SECRET=G0Nmu9lwBuWfoLpiHxMwZr9YdxwpVBqW
COMPOSE_PROJECT_NAME=supla
COMPOSE_PATH_SEPARATOR=:
COMPOSE_FILE=docker-compose.yml:docker-compose.yml
i can ping server, network ok.
lesny8
Has thanked: 10 times
Been thanked: 9 times
Correct these lines in .env and restart dockers
# FIRST_USER_EMAIL=[email protected]
# FIRST_USER_PASSWORD=conchocon
ACCOUNTS_REGISTRATION_ENABLED=false
COMPOSE_FILE=docker-compose.yml:docker-compose.standalone.yml
SOP 2023 :heavy_check_mark:
SOP 2024 :heavy_check_mark:
🧩: 🔑cz->b ⛴️+ila
ocean
yeah. it work. thanks verry much
it run on TV box Tx3 mini Ram 2G, 16GB eMMC flash and price 20$
that great
lesny8
:+1::clap:
🧩: 🔑cz->b ⛴️+ila
Mariusz
Dzień dobry - Wszystkim
Dawno temu zrobiłem Suple na RPi3B+ ale padła karta.
Robię ponownie jak w pierwszym linku do postawienia lokalnego serwera.
Utknąłem na tym
sudo pip3 install docker-compose - zgłasza błąd
pi@SUPLA:~ $ sudo pip3 install docker-compose
error: externally-managed-environment
no i klapa, doradźcie co i jak - RBPi BookWorm Lite nagrany z PiImagera v2.0.7
Mariusz
Mariusz wrote: Fri Jun 05, 2026 5:29 pm Dzień dobry - Wszystkim
Utknąłem na tym
Mariusz
To jest jakiś problem związany z python (i pip3). Kiedyś w innych rzeczach mi taki błąd wyskakiwał i zawsze szukałem w Google rozwiązań i pomagało;) ewentualnie wrzuć do ChatGPT
lesny8
Mariusz wrote: Fri Jun 05, 2026 5:29 pm ...
docker-compose nie jest już do niczego potrzebny, bo teraz jest instalowany jako plugin dockera.
pip3 do instalacji samej Supli też jest niepotrzebny, więc nie trać na to czasu :)
Zrób tak:
Po nagraniu obrazu imagerem, jak zalogujesz się przez terminal to zrób update i upgrade a potem reboot, tak żeby na start mieć pakiety up to date i aktualny kernel.
sudo apt update
sudo apt upgrade -y
sudo reboot
zainstaluj git, pobierz skrypt dla dockera i uruchom
sudo apt install git
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
po instalacji dodaj swojego użytkownika do grupy docker i przeładuj sesje
sudo usermod -aG docker $USER
su $USER -
a później możesz już kontynuować od pkt.2 według oficjalnej dokumentacji
https://github.com/SUPLA/supla-docker#installation
🧩: 🔑cz->b ⛴️+ila
Mariusz
Dzięki za wskazówki - ale nie ważne jak zacznę, z jakiego image/wersji czy tutoriala zawsze kończę na tym:
Wszystkie wcześniejsze kroki przechodzą bez błędów.
~ $ ./supla-docker/supla.sh start
Starting SUPLA containers
[+] up 1/3
⠧ Image supla/supla-server:latest Pulling 8.7s
⠧ Image mariadb:12.2.2 Pulling 8.7s
! Image supla/supla-cloud:latest Interrupted 8.7s
no matching manifest for linux/arm/v7 in the manifest list entries
nie ma znaczenia co wpiszę
jeżeli to jest to mam błąd jak powyżej
jak to dopiszę to pyta o katalog .....arm32v7
COMPOSE_FILE=docker-compose.yml:docker-compose.standalone.yml:docker-compose.arm32v7.yml
Plik "docker-compose.yml" mam pusty tak samo jak "docker-compose.arm32v7.yml"
pzdr
Mariusz
korekta
Plik "docker-compose.yml" mam tylko źle patrzyłem
A nie masz za starej maliny? Rok temu była informacja że z końcem 2025 niektóre wersje maliny przestaną być wspierane
Mariusz
Tak jak napisałem mam "BookWorm " na wersji Triksi nic nie che działac
Czyli z opisu dockera
" Raspberry Pi OS 32-bit (armhf) Deprecation
Docker Engine v28 will be the last major version to support Raspberry Pi OS 32-bit (armhf)."
to mam taką
"OS requirements
To install Docker Engine, you need one of the following OS versions:
32-bit Raspberry Pi OS Bookworm 12 (stable)"
To może spytam inaczej na jakiej działasz - mi to jest obojętne.
pzdr
