Mega brak łączenia z Internetem
patrykelek
Hej,
mam problem z łączeniem z mega przez enc28j60
serial wyrzuca coś takiego
(ocalIP: 0.0.0.0
subnetMask: 0.0.0.0
gatewayIP: 0.0.0.0
dnsServerIP: 0.0.0.0
SuplaDevice initialized
Not connected
Register in progress
Not connected
kabel sprawny , połączenia przewodów są ok
Proszę o waszą pomoc
poniżej kod
#include <SPI.h>
#include <UIPEthernet.h>
#include <SuplaDevice.h>
#include <OneWire.h>
int redLed = 43;
int smokeA0 = A5;
// Setup a oneWire instance
OneWire oneWire(42); // 24 - Pin number
// Pass oneWire reference to Dallas Temperature
DeviceAddress piwnica = { 0x28, 0xFF, 0x8A, 0x4D, 0x40, 0x18, 0x2, 0x54};
DeviceAddress korytarz = { 0x28, 0xFF, 0x13, 0x9C, 0x2, 0x17, 0x4, 0x25 };
// DS18B20 Sensor read implementation
    double t = -275;
    if ( sensors.getDeviceCount() > 0 )
         sensors.requestTemperatures();
         switch(channelNumber)
            case 0:
                    t = sensors.getTempC(piwnica);
                    break;
            case 1:
                    t = sensors.getTempC(korytarz);
                    break;
    return t;
void setup() {
  Serial.begin(9600);
  // Init DS18B20 library
  sensors.begin();
  // Set temperature callback
 pinMode (45, INPUT_PULLUP); //ustawiamy Pin 16 (D0) na przycisk
  pinMode(44,OUTPUT);
   pinMode(redLed, OUTPUT);
  pinMode(smokeA0, INPUT);
  // Replace the falowing GUID
  char GUID[SUPLA_GUID_SIZE] = {0x85,0x6B,0x6D,0x58,0x1D,0x72,0x40,0xBF,0x88,0x7D,0x7A,0x39,0xFF,0x13,0xAC,0xC3};
  // Ethernet MAC address
  uint8_t mac[6] = {0x98, 0x79, 0x9D, 0xF2, 0x89, 0x25};
   // CHANNEL0 - Thermometer DS18B20
   // CHANNEL1 - Thermometer DS18B20
  // CHANNEL2 - RELAY
  SuplaDevice.addRelay(47, true);           // 44 - Pin number where the relay is connected
                                      // Call SuplaDevice.addRelay(44, true) with an extra "true" parameter
                                      // to enable "port value inversion"
                                      // where HIGH == LOW, and LOW == HIGH
  // CHANNEL3 - RELAY
  SuplaDevice.addRelay(48, true);           // 45 - Pin number where the relay is connected
    // CHANNEL4 - RELAY
  SuplaDevice.addRelay(49, true);    // 47 - Pin number where the 2nd relay is connected
  // CHANNEL5 - Opening sensor (Normal Open)
  SuplaDevice.addSensorNO(45); // A0 - Pin number where the sensor is connected
                               // Call SuplaDevice.addSensorNO(A0, true) with an extra "true" parameter
                               // to enable the internal pull-up resistor
                    "svr1.supla.org",  // SUPLA server address
                    xxxx,                 // Location ID
                    "xxxx");               // Location Password
void loop() {
  SuplaDevice.iterate();
if(digitalRead(45)==LOW){
  digitalWrite(44,HIGH);
else {
  digitalWrite(44,LOW);
 int analogSensor = analogRead(smokeA0);
  //Serial.println(analogSensor);
  if (analogSensor > 400)
    digitalWrite(redLed, HIGH);
  else
    digitalWrite(redLed, LOW);
  delay(100);
Pobierz bibliotekę z brancha develop https://github.com/SUPLA/arduino/tree/develop
Ale nie polecam tego układu do sieci. W readme jest opisane kilka problemów
