Hello guys! In first I want to give you my congratulats for your work, the software is really stable and simple to use. I want to ask some informations: I would like to handle the lights via a step relay with a simple switch. At the same time I have idea to use your software to command that relay, also need to detect the state of it. and change the state via the app. It will be perfect to open an electric lock of the door. One thing, is it possible to change the original pictogram of the door with mine one? One for relay closes and another for relay open?Supla for Arduino change pictogram
AnatoliyRome
Hi!
Hello guys! In first I want to give you my congratulats for your work, the software is really stable and simple to use. I want to ask some informations: I would like to handle the lights via a step relay with a simple switch. At the same time I have idea to use your software to command that relay, also need to detect the state of it. and change the state via the app. It will be perfect to open an electric lock of the door. One thing, is it possible to change the original pictogram of the door with mine one? One for relay closes and another for relay open?-
AnatoliyRome
possible add gpio to change the relay state such feed 5volt?
- Been thanked: 59 times
For Arduino you can operate the relay in non standard way by adding your own support of digitalRead/Write
void setDigitalReadFuncImpl(_impl_arduino_digitalRead impl_arduino_digitalRead);
void setDigitalWriteFuncImpl(_impl_arduino_digitalWrite impl_arduino_digitalWrite);
or just set "bistable" parameter to "true"
bool addRelay(int relayPin1, int relayPin2, bool hiIsLo, bool bistable, _supla_int_t functions);
AnatoliyRome
Sorry, I can not. For example, chanel 0, pin 44. to convert to the state of HIGH, how should the code look like?
AnatoliyRome
Change the status of the switch programmatically. and then I can myself.
Add a pin for on off Thank you
