MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
#include "LittleFS.h" // LittleFS is declared
#include <SuplaDevice.h>
#include <supla/io.h>
#include <supla/sensor/DS18B20.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <ESP8266TrueRandom.h>
#include <WiFiClientSecure.h>
#include <Button3.h>
Supla::ESPWifi wifi("", "");
extern "C"
#include "user_interface.h"
char Supla_server[81]=("Set server address");
char Email[81]=("set email address");
char Supla_name[51]=("Supla_LC4");
char Supla_status[51];
bool initialConfig = false;
bool state10 = true;
bool starting = true;
uint8_t an;
int s;
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16]; // UUIDs in binary form are 16 bytes long
static const char logo[] PROGMEM = "<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>";
byte relay_1_on[] = {0xA0, 0x01, 0x01, 0xA2};
byte relay_1_off[] = {0xA0, 0x01, 0x00, 0xA1};
byte relay_2_on[] = {0xA0, 0x02, 0x01, 0xA3};
byte relay_2_off[] = {0xA0, 0x02, 0x00, 0xA2};
byte relay_3_on[] = {0xA0, 0x03, 0x01, 0xA4};
byte relay_3_off[] = {0xA0, 0x03, 0x00, 0xA3};
byte relay_4_on[] = {0xA0, 0x04, 0x01, 0xA5};
byte relay_4_off[] = {0xA0, 0x04, 0x00, 0xA4};
unsigned long rele_milis = 0;
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
WiFiManager wifiManager;
#define BUTTON_PIN 0
Button3 buttonA = Button3(BUTTON_PIN);
class LC_4x : public Supla::Io {
public:
void customDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
if ((pin == 100)){
if (val == 1){
Serial.write(relay_1_on, sizeof(relay_1_on));
delay(20);
}else{
Serial.write(relay_1_off, sizeof(relay_1_off));
delay(20);
if (state10 == false){
EEPROM.write(pin, val);
EEPROM.commit();
}return;}
if ((pin == 101)){
if (val == 1){
Serial.write(relay_2_on, sizeof(relay_2_on));
delay(20);
}else{
Serial.write(relay_2_off, sizeof(relay_2_off));
delay(20);
EEPROM.commit();
}return;}
if ((pin == 102)){
if (val == 1){
Serial.write(relay_3_on, sizeof(relay_3_on));
delay(20);
}else{
Serial.write(relay_3_off, sizeof(relay_3_off));
delay(20);
EEPROM.commit();
}return;}
if ((pin == 103)){
if (val == 1){
Serial.write(relay_4_on, sizeof(relay_4_on));
delay(20);
}else{
Serial.write(relay_4_off, sizeof(relay_4_off));
delay(20);
EEPROM.commit();
}return;}
if (pin <= 99) {
return ::digitalWrite(pin,val);
int customDigitalRead(int channelNumber, uint8_t pin) {
if ((pin >= 100)&& (pin <= 103)){
return EEPROM.read(pin);
if (pin <= 99){
return ::digitalRead(pin);
}LC_4x;
void saveConfigCallback () {
shouldSaveConfig = true;
delay(2000);Serial.println("WIFI DISCONNECT");delay(20);
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81,"required");
WiFiManagerParameter custom_Email("email", "Email", Email, 81,"required");
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
WiFiManagerParameter custom_html_id21("<div><h4> - Supla State - ");
WiFiManagerParameter custom_html_id22( Supla_status);
WiFiManagerParameter custom_html_id23( "</h4></div>");
wifiManager.setBreakAfterConfig(true);
wifiManager.addParameter(&custom_Email);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_html_id21);
wifiManager.addParameter(&custom_html_id22);
wifiManager.addParameter(&custom_html_id23);
wifiManager.setCustomHeadElement(logo);
wifiManager.setMinimumSignalQuality(8);
//wifiManager.setShowStaticFields(true); // force show static ip fields
//wifiManager.setShowDnsFields(true); // force show dns field always
wifiManager.setConfigPortalTimeout(300);
if (!wifiManager.startConfigPortal("Supla_LC4")) {delay(20);Serial.println("WIFI GOT IP");delay(20);} else {delay(20);Serial.println("WIFI GOT IP");delay(20);}
strcpy(Email, custom_Email.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
if(strcmp(Supla_server, "get_new_guid_and_authkey") == 0){
EEPROM.write(300, 0);
EEPROM.commit();
delay(100);
ESP.reset();
WiFi.softAPdisconnect(true); // close AP
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
if (s != status){
s = status;
if (s != 10){
strcpy(Supla_status, msg);
void guid_authkey(void) {
if (EEPROM.read(300) != 60){
int eep_gui = 301;
ESP8266TrueRandom.uuid(uuidNumber);
String uuidString = "";
for (int i = 0; i < 16; i++) {
int topDigit = uuidNumber[i] >> 4;
int bottomDigit = uuidNumber[i] & 0x0f;
uuidString += "0123456789abcdef"[topDigit];
uuidString += "0123456789abcdef"[bottomDigit];
int length_uuid = uuidString.length();
for (int i = 0; i < length_uuid; ++i) {
EEPROM.put(eep_gui + i, uuidString[i]);
int eep_aut = 341;
String uuidString2 = "";
uuidString2 += "0123456789abcdef"[topDigit];
uuidString2 += "0123456789abcdef"[bottomDigit];
int length_uuid2 = uuidString2.length();
for (int i = 0; i < length_uuid2; ++i) {
EEPROM.put(eep_aut + i, uuidString2[i]);
EEPROM.write(300, 60);
EEPROM.commit();
delay(0);
read_guid();
read_authkey();
String read_guid(void) {
String read_eeprom = "";
int i, ii = 0;
int eep_star = 301;
int end_guid = eep_star + SUPLA_GUID_SIZE;
String temp_read = "0x";
for (i = eep_star; i < end_guid + 16; i = i + 1) {
temp_read += char(EEPROM.read(i));
read_eeprom += char(EEPROM.read(i));
if ( (i % 2) == 0) {
char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
GUID[ii] = strtoul( _guid, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
String read_authkey(void) {
int i, ii = 0;
int eep_star = 341;
int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
for (i = eep_star; i < end_authkey + 16; i = i + 1) {
char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
void setup() {
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin(115200);
delay(0);
EEPROM.begin(1024);
if (EEPROM.read(300) != 60){initialConfig = true;}
guid_authkey();
delay(20);Serial.println("0,CLOSED");delay(20);
if (WiFi.SSID()==""){ initialConfig = true;}
buttonA.setClickHandler(click);
buttonA.setLongClickHandler(longClick);
buttonA.setDoubleClickHandler(doubleClick);
buttonA.setTripleClickHandler(tripleClick);
buttonA.setQuatleClickHandler(quatleClick);
if (LittleFS.begin()) { // ------------------------- wificonfig read -----------------
if (LittleFS.exists("/config.json")) {
File configFile = LittleFS.open("/config.json", "r");
if (configFile) {
DynamicJsonDocument json(1024);
DeserializationError deserializeError = deserializeJson(json, buf.get());
if (!deserializeError) {Serial.println("\nparsed json");
if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
if (json.containsKey("Email")) strcpy(Email, json["Email"]);
if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
} else {
configFile.close();
wifi_station_set_hostname(Supla_name);
WiFi.mode(WIFI_STA);
SuplaDevice.addRelay(100, false);
SuplaDevice.addRelay(101, false);
SuplaDevice.addRelay(102, false);
SuplaDevice.addRelay(103, false);
new Supla::Sensor::DS18B20(2);
SuplaDevice.setName(Supla_name);
SuplaDevice.setStatusFuncImpl(&status_func);
wifi.enableSSL(false);
SuplaDevice.begin(GUID,Supla_server,Email,AUTHKEY);
void loop() {
if (initialConfig == true){ondemandwifiCallback();}
if (rele_milis < millis()){
if (EEPROM.read(100) != 0){delay(20);Serial.write(relay_1_on, sizeof(relay_1_on));delay(20);}else{delay(20);Serial.write(relay_1_off, sizeof(relay_1_off));delay(20);}
if (EEPROM.read(101) != 0){delay(20);Serial.write(relay_2_on, sizeof(relay_2_on));delay(20);}else{delay(20);Serial.write(relay_2_off, sizeof(relay_2_off));delay(20);}
if (EEPROM.read(102) != 0){delay(20);Serial.write(relay_3_on, sizeof(relay_3_on));delay(20);}else{delay(20);Serial.write(relay_3_off, sizeof(relay_3_off));delay(20);}
if (EEPROM.read(103) != 0){delay(20);Serial.write(relay_4_on, sizeof(relay_4_on));delay(20);}else{delay(20);Serial.write(relay_4_off, sizeof(relay_4_off));delay(20);}
if (s == 17) {Serial.println("0,CONNECT");delay(20);}else{;Serial.println("0,CLOSED");delay(20); }
rele_milis = millis() +5000;
if (shouldSaveConfig) {
json["Email"] = Email;
json["Supla_name"] = Supla_name;
File configFile = LittleFS.open("/config.json", "w");
if (!configFile) {
serializeJson(json, configFile);
configFile.close();
delay(5000);
ESP.restart();
buttonA.loop();
SuplaDevice.iterate();
delay(50);
if (starting){
httpUpdater.setup(&httpServer, "/update", "admin", "pass");
httpServer.begin();
starting = false;
httpServer.handleClient();
if (Serial.available())
String S_data = Serial.readString();
if (S_data.indexOf("RESTORE") >0) {initialConfig = true;Serial.flush();}
switch (s) {
case 17:
if (state10 == true){
for (int i = 0; i < 4; i++) {
if (EEPROM.read(i +100) >= 1){
SuplaDevice.relayOn(i, 0);
delay(20);
state10 = false;
break;
case 10:
state10 = true;
break;
void click(Button3& btn) {
Serial.println("single click");
if (EEPROM.read(100) >= 1){SuplaDevice.relayOff(0);}else{SuplaDevice.relayOn(0, 0);}
void doubleClick(Button3& btn) {
Serial.println("double click");
if (EEPROM.read(101) >= 1){SuplaDevice.relayOff(1);}else{SuplaDevice.relayOn(1, 0);}
void tripleClick(Button3& btn) {
Serial.println("triple click");
if (EEPROM.read(102) >= 1){SuplaDevice.relayOff(2);}else{SuplaDevice.relayOn(2, 0);}
void quatleClick(Button3& btn) {
Serial.println("quatle click");
if (EEPROM.read(103) >= 1){SuplaDevice.relayOff(3);}else{SuplaDevice.relayOn(3, 0);}
void longClick(Button3& btn) {
Serial.println("long click");
if ((EEPROM.read(100) >= 1) || (EEPROM.read(101) >= 1) || (EEPROM.read(102) >= 1) || (EEPROM.read(103) >= 1)){
SuplaDevice.relayOff(0); SuplaDevice.relayOff(1); SuplaDevice.relayOff(2); SuplaDevice.relayOff(3);
}else{
SuplaDevice.relayOn(0, 0);SuplaDevice.relayOn(1, 0);SuplaDevice.relayOn(2, 0);SuplaDevice.relayOn(3, 0);
