Świeża instalacja Cloud (QNAP) - problem z logowanie
slavo_s2k
Wczoraj postawiłem na nowo Supla Cloud na QNAP, dodałem urządzenia i zacząłem konfigurować konta. Dzisiaj chciałem kontynuować i niestety przy logowaniu mam błąd:
Restart kontenera ani restart całego QNAP nie rozwiązują problemu,
Log z Cloud:
Clients to disable: 0
supla:clean:passed-io-client-registration-dates
Client registration expiration date - cleared: 0
I/O Device registration expiration date - cleared: 0
supla:clean:disable-demo-client-apps
Z Db:
2021-04-11T07:42:52.597242Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2021-04-11T07:42:52.597254Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.3
2021-04-11T07:42:52.597265Z 0 [Note] InnoDB: Using Linux native AIO
2021-04-11T07:42:52.598108Z 0 [Note] InnoDB: Number of pools: 1
2021-04-11T07:42:52.598312Z 0 [Note] InnoDB: Using CPU crc32 instructions
2021-04-11T07:42:52.665460Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2021-04-11T07:42:52.695511Z 0 [Note] InnoDB: Completed initialization of buffer pool
2021-04-11T07:42:52.699811Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2021-04-11T07:42:52.888518Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2021-04-11T07:42:53.731395Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2021-04-11T07:42:53.880805Z 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2021-04-11T07:42:54.263782Z 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2021-04-11T07:42:54.265991Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active.
2021-04-11T07:42:54.266054Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
2021-04-11T07:42:54.266722Z 0 [Note] InnoDB: Waiting for purge to start
2021-04-11T07:42:54.316861Z 0 [Note] InnoDB: Waiting for purge to start
2021-04-11T07:42:54.367016Z 0 [Note] InnoDB: Waiting for purge to start
2021-04-11T07:42:54.417538Z 0 [Note] InnoDB: 5.7.20 started; log sequence number 18451798
2021-04-11T07:42:54.417997Z 0 [Note] Plugin 'FEDERATED' is disabled.
2021-04-11T07:42:54.418024Z 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
2021-04-11T07:42:55.092025Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them.
2021-04-11T07:42:55.134162Z 0 [Warning] CA certificate ca.pem is self signed.
2021-04-11T07:42:55.169930Z 0 [Note] Server hostname (bind-address): '*'; port: 3306
2021-04-11T07:42:55.170431Z 0 [Note] IPv6 is available.
2021-04-11T07:42:55.170524Z 0 [Note]   - '::' resolves to '::';
2021-04-11T07:42:55.170629Z 0 [Note] Server socket created on IP: '::'.
2021-04-11T07:42:55.832473Z 0 [Warning] 'user' entry 'root@localhost' ignored in --skip-name-resolve mode.
2021-04-11T07:42:55.832551Z 0 [Warning] 'user' entry 'mysql.session@localhost' ignored in --skip-name-resolve mode.
2021-04-11T07:42:55.832575Z 0 [Warning] 'user' entry 'mysql.sys@localhost' ignored in --skip-name-resolve mode.
2021-04-11T07:42:55.898308Z 0 [Warning] 'db' entry 'performance_schema mysql.session@localhost' ignored in --skip-name-resolve mode.
2021-04-11T07:42:55.898375Z 0 [Warning] 'db' entry 'sys mysql.sys@localhost' ignored in --skip-name-resolve mode.
2021-04-11T07:42:55.898809Z 0 [Warning] 'proxies_priv' entry '@ root@localhost' ignored in --skip-name-resolve mode.
2021-04-11T07:42:56.431103Z 0 [Note] InnoDB: Buffer pool(s) load completed at 210411  7:42:56
2021-04-11T07:42:56.568115Z 0 [Warning] 'tables_priv' entry 'user mysql.session@localhost' ignored in --skip-name-resolve mode.
2021-04-11T07:42:56.568186Z 0 [Warning] 'tables_priv' entry 'sys_config mysql.sys@localhost' ignored in --skip-name-resolve mode.
2021-04-11T07:42:57.620868Z 0 [Note] Event Scheduler: Loaded 0 events
2021-04-11T07:42:57.621679Z 0 [Note] mysqld: ready for connections.
Version: '5.7.20'  socket: '/var/run/mysqld/mysqld.sock'  port: 3306  MySQL Community Server (GPL)
2021-04-11T07:42:57.621712Z 0 [Note] Executing 'SELECT * FROM INFORMATION_SCHEMA.TABLES;' to get a list of tables using the deprecated partition engine. You may use the startup option '--disable-partition-engine-check' to skip this check.
2021-04-11T07:42:57.621721Z 0 [Note] Beginning of list of non-natively partitioned tables
2021-04-11T07:43:00.028685Z 0 [Note] End of list of non-natively partitioned tables
z Server-a w kółko leci
ipher: AES128-SHA, ClientSD: 25
INFO[1618130044.368388] Connection accepted: 172.21.16.25:20602 ClientSD: 26 Secure: 1
INFO[1618130044.469751] Cipher: AES128-SHA, ClientSD: 26
INFO[1618130046.750579] Connection accepted: 172.21.16.25:21434 ClientSD: 24 Secure: 1
INFO[1618130046.854126] Cipher: AES128-SHA, ClientSD: 24
INFO[1618130049.109251] Connection accepted: 172.21.16.25:34068 ClientSD: 26 Secure: 1
INFO[1618130049.258860] Cipher: AES128-SHA, ClientSD: 26
INFO[1618130051.214921] Connection accepted: 172.21.16.25:8218 ClientSD: 22 Secure: 1
INFO[1618130051.356786] Cipher: AES128-SHA, ClientSD: 22
INFO[1618130051.660514] Connection accepted: 172.21.16.25:38474 ClientSD: 25 Secure: 1
INFO[1618130051.784109] Cipher: AES128-SHA, ClientSD: 25
INFO[1618130053.487934] Connection accepted: 172.21.16.25:17804 ClientSD: 26 Secure: 1
INFO[1618130053.587163] Cipher: AES128-SHA, ClientSD: 26
INFO[1618130054.8190] Connection accepted: 172.21.16.25:34206 ClientSD: 24 Secure: 1
INFO[1618130054.116049] Cipher: AES128-SHA, ClientSD: 24
INFO[1618130055.768940] Connection accepted: 172.21.16.25:32211 ClientSD: 25 Secure: 1
INFO[1618130055.897608] Cipher: AES128-SHA, ClientSD: 25
INFO[1618130056.259526] Connection accepted: 172.21.16.25:10863 ClientSD: 26 Secure: 1
INFO[1618130056.368105] Cipher: AES128-SHA, ClientSD: 26
INFO[1618130058.48411] Connection accepted: 172.21.16.25:38106 ClientSD: 24 Secure: 1
INFO[1618130058.159405] Cipher: AES128-SHA, ClientSD: 24
INFO[1618130058.504113] Connection accepted: 172.21.16.25:32693 ClientSD: 25 Secure: 1
INFO[1618130058.606236] Cipher: AES128-SHA, ClientSD: 25
INFO[1618130060.343053] Connection accepted: 172.21.16.25:42468 ClientSD: 26 Secure: 1
INFO[1618130060.463151] Cipher: AES128-SHA, ClientSD: 26
INFO[1618130062.636230] Connection accepted: 172.21.16.25:42775 ClientSD: 24 Secure: 1
INFO[1618130062.737617] Cipher: AES128-SHA, ClientSD: 24
INFO[1618130064.884625] Connection accepted: 172.21.16.25:34888 ClientSD: 26 Secure: 1
INFO[1618130065.15569] Cipher: AES128-SHA, ClientSD: 26
INFO[1618130066.951039] Connection accepted: 172.21.16.25:42654 ClientSD: 22 Secure: 1
INFO[1618130067.95086] Cipher: AES128-SHA, ClientSD: 22
INFO[1618130067.179933] Connection accepted: 172.21.16.25:5953 ClientSD: 25 Secure: 1
INFO[1618130067.277750] Cipher: AES128-SHA, ClientSD: 25
Jakieś pomysły co dalej? Klient się łączy i mogę sterować tym co zdążyłem dodać, ale nic więcej nie mogę zrobić :(
slavo_s2k
Dobra, jakoś się udało, finalnie podniosłem z wersji 2.3.25 do 2.3.27 i ruszyło, w każdym razie nie wiem co było powodem problemów :(
slavo_s2k
Niestety dziś znów to samo, wczoraj po południu wszystko działało normalnie , dokonfigurowałem do końca , teraz patrzę rano i znowu to samo, te same błędy, sama aplikacja kliencka na telefonach działa poprawnie , tylko nie mogę się zalogować przez WWW.
Zniknęła ikona linku
przy Cloudzie
Nie wiem na ile to istotne, okno logowanie się otwiera, ale nie działa samo logowanie.
Logi
