thermostat with Oled display
kotogi
Great. Thank you very much. You are wonderful. Everything works correctly. You are my guru. I also use Termopar ESP8266 y MAX6675 .
Pytam tylko jak muszę.
kotogi
elmaya
In many applications, there is no need to increase the temperature by 0.5 degrees (smokehouses, stoves, saunas, etc.). Can you modify the program in such a way that the setting can be changed by 1 step or even by two with one click?
Thus, the display shows the set temperature without tenths of a degree.
Thanks whether it works or not.
greetings
greetings
elmaya
the code is getting a bit old.kotogi wrote: Tue May 04, 2021 3:57 pm elmaya
greetings
I am considering updating the code to the current Supla library.
but I have to find time to do it.
I am considering adding the possibility of defining the steps of +/- thermostat temperature to WiFiConfig, from "0.1ºc" to "10ºc"
MAX6675 and MAX31655 probably only in the version without Oled due to lack of Gpio to connect.kotogi wrote: Sat Apr 24, 2021 8:26 pm Great. Thank you very much. You are wonderful. Everything works correctly. You are my guru. I also use Termopar ESP8266 y MAX6675 .![]()
kotogi
I wanted to write that I use your software from the Termopar ESP8266 y MAX6675 https://es-forum.supla.org/viewtopic.php?f=70&t=5950kotogi wrote: Sat Apr 24, 2021 8:26 pm Great. Thank you very much. You are wonderful. Everything works correctly. You are my guru. I also use Termopar ESP8266 y MAX6675 .![]()
"I am considering adding the possibility of defining the steps of +/- thermostat temperature to WiFiConfig, from "0.1ºc" to "10ºc""
SUPER
- Has thanked: 134 times
@elmaya, please consider that support for "thermostat" channel type should be introduced within few months (hopefully). So personally I'd rather hold with rewriting thermostat applications before that.
elmaya
I am aware that someday there will be a thermostat channel.klew wrote: Wed May 05, 2021 9:15 am @elmaya, please consider that support for "thermostat" channel type should be introduced within few months (hopefully). So personally I'd rather hold with rewriting thermostat applications before that.
but there will be at least a thermocoupler version "probably without Oled" as a workaround to avoid having to use Supla scripts as a thermostat.
I expect that someday will happen within few months.elmaya wrote: Wed May 05, 2021 10:57 am I am aware that someday there will be a thermostat channel.![]()
elmaya
the "someday" was meant to be a joke.
