MAX thermocouple thermostat
elmaya
compatible with MAX6675 & MAX31655
D1 Gpio 5 = relay
D3 Gpio 0 = botton -- toggle automatic/manual mode, hold down for at least 10 seconds "WiFiConfig"
D4 Gpio 2 = Led "Buildin" flashing = not connected/connecting, Off = connected/OK, On = WiFiConfig.
D5 Gpio14 = Do "max6675"
D6 Gpio12 = Cs "max6675"
D7 Gpio13 = Clk "max6675"
WiFiConfig:
hold botton down for at least 10 seconds. "D2 -- Gpio0 to ground"
the Led turns on.
connect to WiFi AP name "MAX_Thermostat".
Open 192.168.4.1 in your browser.
click on configure WiFi.
select your WiFi network by clicking on the one that corresponds in the list of WiFi networks.
enter your WiFi password.
enter your Supla server.
enter your Email.
enter Supla device name "the name you want the module to have in your Supla server"
enter Step +/- "value for steps +/- for the thermostat temperature setting" allowed from 0.1 to 50.0
enter Hysteresis "allowed from 0.1 to 50.0"
to separate the decimals point is used, do not use the comma.
hit Save.
After a few seconds the module restarts with the established configuration.
Supla cloud seting:
channel 0 "power switch" = automatic/manual mode
channel 1 "power switch" = manual on/off "shows the state of the relay"
channel 2 "temperature" = shows the temperature read by max6675
channel 3 "temperature" = shows the temperature set for the thermostat
channel 4 "power switch" = increases or decreases the temperature set for the thermostat
in automatic mode "channel 0 on":
if the max6675 temperature falls below the "temperature set for the thermostat - hysteresis" the relay is activated.
if the max6675 temperature exceeds the temperature set for the thermostat the relay is deactivated.
when toggle from automatic to manual mode "channel 0" the relay is always deactivated, this allows setting schedules in the Supla cloud.
in manual mode "channel 0 off":
manual on/off "channel 1" controls the relay regardless of temperatures.
#define supla_lib_config_h_  // silences debug messages
#include "LittleFS.h"
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <ESP8266TrueRandom.h>
#include <WiFiClientSecure.h>
#include <Ticker.h>
#include <SuplaDevice.h>
#include <supla/control/virtual_relay.h>
#include <supla/sensor/MAXThermocouple.h>
#define STORAGE_OFFSET 512
#include <supla/storage/eeprom.h>
Supla::Eeprom eeprom(STORAGE_OFFSET);
Supla::ESPWifi wifi("SSID", "PASS");  //------ Do not change----wifimanager takes care------
extern "C"
#include "user_interface.h"
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
//#define RX  3  //High at boot
//#define TX  1  //must not be pulled low during power on/reset
int wificonfig_pin = 0;  //D3 --  0
int LED_PIN = 2;         //D4 --  2
int relay_pin = 5;       //D1 --  5
int pin_CLK = 13;        //D7 -- 13
int pin_CS = 12;         //D6 -- 12
int pin_DO = 14;         //D5 -- 14
int button_pin = 0;      //D3 --  0
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000;               // ---------------------- config delay 10 seconds ---------------------------
char Supla_server[81]=("svr?.supla.org");
char Email[81]=("your@email");
char Supla_name[51]=("Thermostat");
char term_temp[5]=("0.5");
char term_hist[5]=("1.0");
char Supla_status[51]=("No server address");
char Router_SSID[32];
char Router_Pass[64];
bool initialConfig = false;
bool starting = true;
int s;
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16];
static const char logo[] PROGMEM = "<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>";
double ThermostatTemperature = 20.0;
bool doSaveTermSetTemp = false;
float Term_Temp = 0.5;
float Term_Hist = 1.0;
bool tikOn = true;
bool statusLedOn = LOW;
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
WiFiManager wifiManager;
Ticker ticker;
Supla::Control::VirtualRelay *relay_0 = nullptr;
Supla::Control::Relay *relay_1 = nullptr;
Supla::Sensor::MAXThermocouple *MaxTemp = nullptr;
class TermostatTemp : public Supla::Sensor::Thermometer {
 public:
  TermostatTemp() {}
  void onInit() {
    channel.setNewValue(getValue() );
  double getValue() {
    // returns the variable "ThermostatTemperature"
     return ThermostatTemperature;
  void iterateAlways() {
      if (lastReadTime + 5000 < millis()) {
        lastReadTime = millis();
      // check state every 5 seconds
        if(relay_0->isOn()){
          double actualTemp = MaxTemp->getValue();
          if(((relay_1->isOn()) && ( actualTemp >= (ThermostatTemperature))) || ( actualTemp < -100.0)) {
            relay_1->turnOff();
          } else if ((!relay_1->isOn()) && ( actualTemp <= ThermostatTemperature - Term_Hist)){
            relay_1->turnOn();
};TermostatTemp *TerTemp = nullptr;
class TermostatSet : public Supla::Control::Relay {
 public:
  TermostatSet() : Relay(-1, true, 32), state(false) {}
  void onInit(){
   // do nothing here
  void turnOn(_supla_int_t duration) {
   //  increase "ThermostatTemperature" by Term_Temp
    ThermostatTemperature += Term_Temp;
    state = false;
    channel.setNewValue(state);
    doSaveTermSetTemp = true;
  void turnOff(_supla_int_t duration) {
   //  decrease "ThermostatTemperature" by Term_Temp
    ThermostatTemperature -= Term_Temp;
    state = false;
  bool isOn() {
    return state;
 protected:
  bool state;
};TermostatSet *TerSet = nullptr;
void saveConfigCallback () {
  shouldSaveConfig = true;
   ticker.detach();
   digitalWrite(LED_PIN, statusLedOn);
   WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81,"required");
   WiFiManagerParameter custom_Email("email", "Email", Email, 81,"required");
   WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
   WiFiManagerParameter custom_term_temp("step", "Step +/-", term_temp, 5,"required");
   WiFiManagerParameter custom_term_hist("histerisis", "Histerisis", term_hist, 5,"required");
   WiFiManagerParameter custom_html_id21("<div><h4> - Supla State -   ");
   WiFiManagerParameter custom_html_id22(Supla_status);
   WiFiManagerParameter custom_html_id23("</h4></div>");
   wifiManager.setBreakAfterConfig(true);
   wifiManager.addParameter(&custom_Email);
   wifiManager.addParameter(&custom_Supla_name);
   wifiManager.addParameter(&custom_term_temp);
   wifiManager.addParameter(&custom_term_hist);
   wifiManager.addParameter(&custom_html_id21);
   wifiManager.addParameter(&custom_html_id22);
   wifiManager.addParameter(&custom_html_id23);
   wifiManager.setCustomHeadElement(logo);
   wifiManager.setMinimumSignalQuality(8);
   //wifiManager.setShowStaticFields(true); // force show static ip fields
   //wifiManager.setShowDnsFields(true);    // force show dns field always
   wifiManager.setConfigPortalTimeout(300);
   if (!wifiManager.startConfigPortal("MAX_Thermostat")) { Serial.println("Not connected to WiFi but continuing anyway.");} else { Serial.println("connected...yeey :)");}
    strcpy(Email, custom_Email.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    strcpy(term_temp, custom_term_temp.getValue());
    strcpy(term_hist, custom_term_hist.getValue());
    wifiManager.getWiFiSSID().toCharArray(Router_SSID, 33);
    wifiManager.getWiFiPass().toCharArray(Router_Pass, 65);
    if(strcmp(Supla_server, "get_new_guid_and_authkey") == 0){
      Serial.println("new guid & authkey.");
      EEPROM.write(300, 0);
      EEPROM.commit();
      delay(100);
      ESP.reset();
    WiFi.softAPdisconnect(true);   //  close AP
void status_func(int status, const char *msg) {    //    ------------------------ Status --------------------------
  if (s != status){
    s = status;
      if (s != 10){
        strcpy(Supla_status, msg);
void guid_authkey(void) {
  if (EEPROM.read(300) != 60){
    int eep_gui = 301;
    ESP8266TrueRandom.uuid(uuidNumber);
    String uuidString = "";
    for (int i = 0; i < 16; i++) {
      int topDigit = uuidNumber[i] >> 4;
      int bottomDigit = uuidNumber[i] & 0x0f;
      uuidString += "0123456789abcdef"[topDigit];
      uuidString += "0123456789abcdef"[bottomDigit];
    int length_uuid = uuidString.length();
    for (int i = 0; i < length_uuid; ++i) {
      EEPROM.put(eep_gui + i, uuidString[i]);
    int eep_aut = 341;
    String uuidString2 = "";
      uuidString2 += "0123456789abcdef"[topDigit];
      uuidString2 += "0123456789abcdef"[bottomDigit];
    int length_uuid2 = uuidString2.length();
    for (int i = 0; i < length_uuid2; ++i) {
      EEPROM.put(eep_aut + i, uuidString2[i]);
    EEPROM.write(300, 60);
    EEPROM.commit();
    delay(0);
  read_guid();
  read_authkey();
  //Serial.print("GUID : ");Serial.println(read_guid());
  //Serial.print("AUTHKEY : ");Serial.println(read_authkey());
String read_guid(void) {
  String read_eeprom = "";
  int i, ii = 0;
  int eep_star = 301;
  int end_guid = eep_star + SUPLA_GUID_SIZE;
  String temp_read = "0x";
  for (i = eep_star; i < end_guid + 16;  i = i + 1) {
    temp_read += char(EEPROM.read(i));
    read_eeprom += char(EEPROM.read(i));
    if ( (i % 2) == 0) {
      char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      GUID[ii] = strtoul( _guid, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
String read_authkey(void) {
  int i, ii = 0;
  int eep_star = 341;
  int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
  for (i = eep_star; i < end_authkey + 16;  i = i + 1) {
      char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
void tick(){
  int state = digitalRead(LED_PIN);
  digitalWrite(LED_PIN, !state);
void setup() {
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY, 1);
  delay(10);
  pinMode(wificonfig_pin, INPUT_PULLUP);
  pinMode(LED_PIN,OUTPUT);
  ticker.attach(0.5, tick);
  EEPROM.begin(1024);
  if (EEPROM.read(300) != 60){initialConfig = true;}
  guid_authkey();
  if (WiFi.SSID()==""){ initialConfig = true;}
  if (LittleFS.begin()) {  // ------------------------- wificonfig read -----------------
    if (LittleFS.exists("/config.json")) {
       File configFile = LittleFS.open("/config.json", "r");
      if (configFile) {
        DynamicJsonDocument json(1024);
        DeserializationError deserializeError = deserializeJson(json, buf.get());
        serializeJsonPretty(json, Serial);
        if (!deserializeError) {Serial.println("\nparsed json");
          if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
          if (json.containsKey("Email")) strcpy(Email, json["Email"]);
          if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
          if (json.containsKey("term_temp")) {
            strcpy(term_temp, json["term_temp"]);
            Term_Temp = (String(term_temp).toFloat());
            if (Term_Temp < 0.1){ Term_Temp = 0.1;}
            else if (Term_Temp > 50.0){ Term_Temp = 50.0;}
            strcpy(term_hist, json["term_hist"]);
            Term_Hist = (String(term_hist).toFloat());
            if (Term_Hist < 0.1){ Term_Hist = 0.1;}
            else if (Term_Hist > 50.0){ Term_Hist = 50.0;}
          if (json.containsKey("Router_SSID")) strcpy(Router_SSID, json["Router_SSID"]);
          if (json.containsKey("Router_Pass")) strcpy(Router_Pass, json["Router_Pass"]);
        } else {
        configFile.close();
   } else {
    Serial.println("failed to mount FS");
  Serial.print("Term_Temp: ");Serial.println(Term_Temp);
  Serial.print("Term_Hist: ");Serial.println(Term_Hist);
   wifi_station_set_hostname(Supla_name);
   WiFi.mode(WIFI_STA);
   EEPROM.get(381, ThermostatTemperature);
   if((ThermostatTemperature > 1000.0) || isnan(ThermostatTemperature)){
    EEPROM.put(381, ThermostatTemperature);
    EEPROM.commit();
    Serial.println("ThermostatTemperature reset to 20.0ºC");
     relay_0 =  new Supla::Control::VirtualRelay(32);
     relay_0->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
     relay_0->setDefaultStateRestore();
     relay_0->disableChannelState();
     relay_1 =  new Supla::Control::Relay(relay_pin, true);
     relay_1->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
     relay_1->setDefaultStateOff();
     relay_1->disableChannelState();
     MaxTemp = new Supla::Sensor::MAXThermocouple(pin_CLK, pin_CS, pin_DO);
     TerTemp = new TermostatTemp();
     TerSet = new TermostatSet();
     TerSet->getChannel()->setDefault(SUPLA_CHANNELFNC_POWERSWITCH);
     TerSet->disableChannelState();
     auto button_1 = new Supla::Control::Button(button_pin, true, true);
     button_1->addAction(Supla::TOGGLE, relay_0, Supla::ON_PRESS);
     button_1->setSwNoiseFilterDelay(50);
     relay_0->addAction(Supla::TURN_OFF, relay_1, Supla::ON_TURN_OFF);
    SuplaDevice.setName(Supla_name);
    wifi.setSsid(Router_SSID);
    wifi.setPassword(Router_Pass);
    SuplaDevice.setStatusFuncImpl(&status_func);
    wifi.enableSSL(false);
    SuplaDevice.begin(GUID,Supla_server,Email,AUTHKEY);
void loop() {
  if (initialConfig == true){ondemandwifiCallback();}
  int C_W_read = digitalRead(wificonfig_pin);{
   if (C_W_read != last_C_W_state) {  time_last_C_W_change = millis();}
    if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
        ondemandwifiCallback () ;} } }
     last_C_W_state = C_W_read;
    if (starting){
      httpUpdater.setup(&httpServer, "/update", "admin", "pass");
      httpServer.begin();
      starting = false;
      Serial.print("get MAXThermocouple temperature: ");
      Serial.println(MaxTemp->getValue());
     httpServer.handleClient();
  if (shouldSaveConfig) {
    json["Email"] = Email;
    json["Supla_name"] = Supla_name;
    json["term_temp"] = term_temp;
    json["term_hist"] = term_hist;
    json["Router_SSID"] = Router_SSID;
    json["Router_Pass"] = Router_Pass;
    File configFile = LittleFS.open("/config.json", "w");
    if (!configFile) {
    Serial.println("failed to open config file for writing");
    serializeJson(json, configFile);
    configFile.close();
    delay(5000);
    ESP.restart();
  SuplaDevice.iterate();
   delay(25);
   if(doSaveTermSetTemp){
    EEPROM.commit();
  if ((s == STATUS_REGISTERED_AND_READY)&&(tikOn)){
      ticker.detach();
      digitalWrite(LED_PIN, !statusLedOn);
      tikOn = false;
  }else if ((s != STATUS_REGISTERED_AND_READY) && (!tikOn)){
      tikOn = true;
Thermostat_MAXThermocouple_DOUT_16Mbit.rar
kotogi
It works beautifully, the ability to change the increment of addition, subtraction is great - world championship
But you know we'll never let go - or maybe OLED?
It's nice that the relay in the D1 Gpio 5 is able to create a sandwich from cheap components.
Bravo :D
Now I can see how much you have changed since the introduction of the OLED thermostat software- https://en-forum.supla.org/viewtopic.php?f=10&t=5320
Pytam tylko jak muszę.
kotogi
As I needed an oled high temperature thermometer I linked this topic to https://en-forum.supla.org/viewtopic.php?f=10&t=5569
It worked without any major problems (my biggest individual problem is the provider, or rather the speed of the internet), unfortunately there are some lags.
As always, many thanks to elmaya for pioneering solutions that push the project forward.
Thanks a lot
elmaya
added Oled and push buttons for Temp +/-
#include <EEPROM.h>
#include <Ticker.h>
//#include "SSD1306Wire.h" //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306
//SSD1306Wire  display(0x3c, 4, 2);  // D2-SDA  D4-SCL ----- 0.96 Oled ---
#include "SH1106Wire.h" //----- 1.3 Oled ---
SH1106Wire display(0x3c, 4, 2);  // D2-SDA  D4-SCL ----- 1.3 Oled ---
extern "C"
//#define D1  5
//#define D2  4
//#define D5 14
//#define D6 12
//#define D7 13
int buttonA_pin = 0;     //D3 --  0
int buttonB_pin = 15;    //D8 -- 15
int buttonC_pin = 16;    //D0 -- 16
long C_W_delay = 10000;               // ---------------------- config delay 5 seconds ---------------------------
char Supla_server[81] = ("svr?.supla.org");
char Email[81] = ("your@email");
char Supla_name[51] = ("Thermostat");
char term_temp[5] = ("0.5");
char term_hist[5] = ("1.0");
char Supla_status[51] = ("No server address");
int s;
double ThermostatTemperature = 20.5;
double actualTemp = -127.0;
int TempDisp_mtbs = 500;                //Temperature display interval 1/2 second
unsigned long TempDisp_lasttime;
bool WiFiConected = false;
bool tikOn = true;
Ticker ticker;
const uint8_t logo32_glcd_bmp[] PROGMEM =  //logo supla 32
  0x00, 0x00, 0x00, 0x00, 0xC0, 0x1F, 0x00, 0x00, 0xE0, 0x7F, 0x00, 0x00,
  0xF0, 0x70, 0x00, 0x00, 0x30, 0xE0, 0x00, 0x00, 0x38, 0xC0, 0x00, 0x00,
  0x18, 0xC0, 0x01, 0x00, 0x18, 0xC0, 0x01, 0x00, 0x38, 0xC0, 0x00, 0x00,
  0x38, 0xE0, 0x01, 0x00, 0x70, 0xF0, 0x07, 0x00, 0xE0, 0x7F, 0x0E, 0x00,
  0xC0, 0x3F, 0x38, 0x00, 0x00, 0x1F, 0xE0, 0x0F, 0x00, 0x18, 0xC0, 0x1F,
  0x00, 0x18, 0xC0, 0x30, 0x00, 0x18, 0xC0, 0x30, 0x00, 0x30, 0xC0, 0x30,
  0x00, 0x30, 0x80, 0x1F, 0x00, 0x30, 0xC0, 0x0F, 0x00, 0x20, 0x60, 0x00,
  0x00, 0x60, 0x20, 0x00, 0x00, 0x60, 0x30, 0x00, 0x00, 0x40, 0x18, 0x00,
  0x00, 0xC0, 0x0D, 0x00, 0x00, 0xC0, 0x07, 0x00, 0x00, 0x60, 0x04, 0x00,
  0x00, 0x20, 0x0C, 0x00, 0x00, 0x20, 0x0C, 0x00, 0x00, 0x60, 0x06, 0x00,
  0x00, 0xC0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00
const uint8_t logo16_wifi_bmp[] PROGMEM =  //logo wifi 16
  0x00, 0x00, 0x00, 0x00, 0xE0, 0x07, 0x38, 0x1C, 0xC4, 0x23, 0x72, 0x4E,
  0x08, 0x10, 0xE4, 0x27, 0x10, 0x0C, 0x90, 0x09, 0x40, 0x02, 0x60, 0x06,
  0x40, 0x02, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00
const uint8_t logo16_supla_bmp[] PROGMEM =  //logo supla 16
  0x30, 0x00, 0x7C, 0x00, 0xC4, 0x00, 0x86, 0x00, 0x84, 0x00, 0xDC, 0x03,
  0x78, 0x36, 0x60, 0x78, 0x40, 0x48, 0x40, 0x38, 0x40, 0x04, 0x80, 0x06,
  0x80, 0x03, 0x40, 0x02, 0xC0, 0x03, 0x00, 0x01
const uint8_t logo_Power_off[] PROGMEM =  //Power off
  0xe0, 0xff, 0xff, 0xff, 0x03, 0x38, 0xfc, 0xff, 0xff, 0x0f, 0x0c, 0xf0,
  0xff, 0xff, 0x3f, 0x06, 0xe0, 0xff, 0xff, 0x3f, 0x02, 0xc0, 0xcf, 0x43,
  0x78, 0x03, 0xc0, 0x33, 0x43, 0x78, 0x01, 0xc0, 0x7b, 0x7b, 0xff, 0x01,
  0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0x7b,
  0x7b, 0xff, 0x03, 0xc0, 0x33, 0x7b, 0xff, 0x02, 0xc0, 0xcf, 0x7b, 0x7f,
  0x06, 0xe0, 0xff, 0xff, 0x7f, 0x0c, 0xf0, 0xff, 0xff, 0x3f, 0x18, 0xfc,
  0xff, 0xff, 0x1f, 0xf0, 0xff, 0xff, 0xff, 0x07,
const uint8_t logo_Power_on[] PROGMEM =  //Power on
  0xe0, 0xff, 0xff, 0xff, 0x07, 0x38, 0x00, 0x00, 0x30, 0x0c, 0x0c, 0x00,
  0x00, 0x18, 0x18, 0x06, 0x00, 0x00, 0x0c, 0x30, 0x02, 0x0e, 0x00, 0x06,
  0x60, 0x03, 0x9f, 0x19, 0x02, 0x40, 0x81, 0xb1, 0x1b, 0x03, 0xc0, 0x81,
  0xa0, 0x1a, 0x01, 0x80, 0x81, 0xa0, 0x1e, 0x01, 0x80, 0x81, 0xb1, 0x1c,
  0x01, 0xc0, 0x03, 0x9b, 0x18, 0x03, 0x40, 0x02, 0x8e, 0x18, 0x02, 0x60,
  0x06, 0x00, 0x00, 0x06, 0x20, 0x0c, 0x00, 0x00, 0x0c, 0x38, 0x38, 0x00,
  0x00, 0x18, 0x0c, 0xe0, 0xff, 0xff, 0xff, 0x07,
  public:
    TermostatTemp() {}
    void onInit() {
      // retrieve value from eeprom to variable "ThermostatTemperature"
    double getValue() {
      if ( millis() - lastReadTime > 2500) {
        if (relay_0->isOn()) {
          if (((relay_1->isOn()) && ( actualTemp >= (ThermostatTemperature))) || ( actualTemp < -100.0)) {
            relay_1->turnOff();
          } else if ((!relay_1->isOn()) && ( actualTemp <= ThermostatTemperature - Term_Hist)) {
            relay_1->turnOn();
}; TermostatTemp *TerTemp = nullptr;
  public:
    TermostatSet() : Relay(-1, true, 32) {}
    void onInit() {
      // do nothing here
      channel.setNewValue(false);
    bool isOn() {
      return false;
}; TermostatSet *TerSet = nullptr;
  display.clear();
  display.setContrast(100, 241, 64);
  display.setTextAlignment(TEXT_ALIGN_CENTER);
  display.setFont(ArialMT_Plain_10);
  display.drawString(64, 16, "wifi config connect");
  display.drawString(64, 28, "to wifi hotspot");
  display.setFont(ArialMT_Plain_16);
  display.drawString(64, 44, "MAX_Thermostat");
  display.display();
  wifi.setSsid("");
  wifi.setPassword("");
  wifiManager.setConfigPortalBlocking(true);
  wifiManager.setCleanConnect(true);
  std::vector<const char *> menu = {"wifi", "wifinoscan", "sep", "update", "sep", "info", "restart"};
  wifiManager.setMenu(menu);
  wifiManager.setTitle("&#66&#121&#46&#46&#69&#108&#77&#97&#121&#97");
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81, "required");
  WiFiManagerParameter custom_Email("email", "Email", Email, 81, "required");
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51, "required");
  WiFiManagerParameter custom_term_temp("step", "Step +/-", term_temp, 5, "required");
  WiFiManagerParameter custom_term_hist("histerisis", "Histerisis", term_hist, 5, "required");
  } else {
  if (strcmp(Supla_server, "get_new_guid_and_authkey") == 0) {
    EEPROM.commit();
    delay(100);
    ESP.reset();
    if (!configFile) {
    configFile.close();
    delay(5000);
    ESP.restart();
  if (initialConfig == true) {
    delay(5000);
    ESP.restart();
  if (s != status) {
    s = status;
    if (s != 10) {
void TH_Overlay() {
  display.clear();
  if (actualTemp > -100) {
    display.setFont(ArialMT_Plain_24);
    display.drawString(64, 20, String(actualTemp, 2) + "ºC");
  } else {
    display.drawString(64, 20, "-----");
    display.drawString(64, 48, "Auto Set " + String(ThermostatTemperature, 1) + "ºC");
  } else {
    display.drawString(64, 48, "Manual mode");
  if (WiFiConected) {
    display.drawXbm(1, 0, 16, 16, logo16_wifi_bmp);// -------------------------------------------------- oled wifi ok  --------
  if (s == STATUS_REGISTERED_AND_READY) {
    display.drawXbm(24, 0, 16, 16, logo16_supla_bmp);// ------------------------------------------------ oled supla ok --------
  } else if (s != 10) {
    display.drawString(48, 0, "E " + String(s));
  if (relay_1->isOn()) {
    display.drawXbm(86, 0, 40, 16, logo_Power_on);// -------------------------------------------------- Relay on  ---------
  } else {
    display.drawXbm(86, 0, 40, 16, logo_Power_off);// ------------------------------------------------- Relay off  --------
  display.display();
  //yield();
  TempDisp_lasttime = millis();
  if (EEPROM.read(300) != 60) {
    int eep_gui = 301;
    int eep_aut = 341;
    EEPROM.commit();
    delay(0);
  read_guid();
  read_authkey();
  int i, ii = 0;
  int eep_star = 301;
      temp_read = "0x";
      ii++;
  return read_eeprom;
  int i, ii = 0;
  int eep_star = 341;
      temp_read = "0x";
      ii++;
  return read_eeprom;
void tick() {
  //int state = digitalRead(LED_PIN);
  //digitalWrite(LED_PIN, !state);
void setup() {
  display.init();
  display.flipScreenVertically();
  display.clear();
  display.drawString(33, 40, "SUPLA");
  display.drawXbm(0, 16, 32, 32, logo32_glcd_bmp );
  display.display();
  delay(100);
  EEPROM.begin(1024);
  guid_authkey();
  if (WiFi.SSID() == "") {
      if (configFile) {
            if (Term_Temp < 0.1) {
              Term_Temp = 0.1;
            else if (Term_Temp > 50.0) {
              Term_Temp = 50.0;
            if (Term_Hist < 0.1) {
              Term_Hist = 0.1;
            else if (Term_Hist > 50.0) {
              Term_Hist = 50.0;
        } else {
        configFile.close();
  } else {
  Serial.print("Term_Temp: "); Serial.println(Term_Temp);
  Serial.print("Term_Hist: "); Serial.println(Term_Hist);
  if ((ThermostatTemperature > 1000.0) || isnan(ThermostatTemperature)) {
    EEPROM.commit();
  auto button_1 = new Supla::Control::Button(buttonA_pin, true, true);
  auto button_2 = new Supla::Control::Button(buttonB_pin, false, false);
  auto button_3 = new Supla::Control::Button(buttonC_pin, false, false);
  button_2->addAction(Supla::TURN_ON, TerSet, Supla::ON_PRESS);
  button_3->addAction(Supla::TURN_OFF, TerSet, Supla::ON_PRESS);
  SuplaDevice.begin(GUID, Supla_server, Email, AUTHKEY);
void loop() {
  int C_W_read = digitalRead(buttonA_pin); {
  delay(20);
  if (doSaveTermSetTemp) {
    EEPROM.commit();
  if ((millis() -  TempDisp_lasttime) > TempDisp_mtbs)  {    //-------------TempDisp_lasttime--------------------
    WiFiConected = (WiFi.status() == WL_CONNECTED);
    TH_Overlay();
Thermostat_MAXThermocouple_OLED_DOUT_16Mbit_V3.rar
kotogi
Thank you very much for this project. The design meets all of my concerns regarding the thermostat on a thermocouple with a display.
It's great that you can freely change the step +/- and that you can set the hysteresis.
It works stably and quickly, just great.
THANKS
