version: '3'
services:
supla-cloud:
container_name: ${COMPOSE_PROJECT_NAME}-cloud
restart: unless-stopped
image: supla/supla-cloud
env_file:
- .env.default
- .env
volumes:
- ./ssl/cloud:/etc/apache2/ssl:z
- ${VOLUME_DATA}/cloud-local:/var/www/cloud/var/local
- ${VOLUME_DATA}/cloud-logs:/var/www/cloud/var/logs
- supla-server-socket:/supla-server:z
links:
- supla-db
depends_on:
- supla-db
supla-db:
container_name: ${COMPOSE_PROJECT_NAME}-db
image: i386/mariadb:5.5
env_file:
- .env.default
- .env
environment:
MYSQL_ROOT_PASSWORD: ${DB_PASSWORD}
MYSQL_DATABASE: supla
MYSQL_USER: supla
MYSQL_PASSWORD: ${DB_PASSWORD}
volumes:
- ${VOLUME_DATA}/mysql:/var/lib/mysql:z
supla-server:
container_name: ${COMPOSE_PROJECT_NAME}-server
image: supla/supla-server
env_file:
- .env.default
- .env
volumes:
- ./ssl/server:/etc/supla-server/ssl:z
- supla-server-socket:/var/run/supla:z
ports:
- "2016:2016"
- "2015:2015"
links:
- supla-db
depends_on:
- supla-cloud
volumes:
supla-server-socket: {}
lokalny serwer supla
skywalker
plik docker-compose::
version: '3'
services:
supla-cloud:
env_file:
- .env.default
- .env
volumes:
links:
- supla-db
depends_on:
- supla-db
supla-db:
env_file:
- .env.default
- .env
environment:
MYSQL_USER: supla
volumes:
supla-server:
env_file:
- .env.default
- .env
volumes:
ports:
- "2016:2016"
- "2015:2015"
links:
- supla-db
depends_on:
- supla-cloud
volumes:
version: '3'
services:
supla-cloud:
env_file:
- .env.default
- .env
volumes:
links:
- supla-db
depends_on:
- supla-db
supla-db:
env_file:
- .env.default
- .env
environment:
MYSQL_USER: supla
volumes:
supla-server:
env_file:
- .env.default
- .env
volumes:
ports:
- "2016:2016"
- "2015:2015"
links:
- supla-db
depends_on:
- supla-cloud
volumes:
skywalker
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.10/http/client.py", line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1037, in _send_output
self.send(msg)
File "/usr/lib/python3.10/http/client.py", line 975, in send
self.connect()
File "/usr/local/lib/python3.10/dist-packages/docker/transport/unixconn.py", line 30, in connect
sock.connect(self.unix_socket)
PermissionError: [Errno 13] Permission denied
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.10/dist-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 532, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/lib/python3/dist-packages/six.py", line 718, in reraise
raise value.with_traceback(tb)
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: ('Connection aborted.', PermissionError(13, 'Permission denied'))
File "/usr/local/lib/python3.10/dist-packages/docker/api/client.py", line 214, in _retrieve_server_version
return self.version(api_version=False)["ApiVersion"]
File "/usr/local/lib/python3.10/dist-packages/docker/api/daemon.py", line 181, in version
return self._result(self._get(url), json=True)
File "/usr/local/lib/python3.10/dist-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/docker/api/client.py", line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File "/usr/local/lib/python3.10/dist-packages/requests/sessions.py", line 600, in get
return self.request("GET", url, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.10/dist-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/requests/adapters.py", line 547, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', PermissionError(13, 'Permission denied'))
File "/usr/local/bin/docker-compose", line 8, in <module>
sys.exit(main())
File "/usr/local/lib/python3.10/dist-packages/compose/cli/main.py", line 81, in main
command_func()
File "/usr/local/lib/python3.10/dist-packages/compose/cli/main.py", line 200, in perform_command
project = project_from_options('.', options)
File "/usr/local/lib/python3.10/dist-packages/compose/cli/command.py", line 60, in project_from_options
return get_project(
File "/usr/local/lib/python3.10/dist-packages/compose/cli/command.py", line 152, in get_project
client = get_client(
File "/usr/local/lib/python3.10/dist-packages/compose/cli/docker_client.py", line 41, in get_client
client = docker_client(
File "/usr/local/lib/python3.10/dist-packages/compose/cli/docker_client.py", line 170, in docker_client
client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/docker/api/client.py", line 197, in __init__
self._version = self._retrieve_server_version()
File "/usr/local/lib/python3.10/dist-packages/docker/api/client.py", line 221, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', PermissionError(13, 'Permission denied'))
self.send(msg)
self.connect()
self.send(msg)
self.connect()
sys.exit(main())
command_func()
return get_project(
skywalker
przepraszam wyslalem bez sudo.... teraz logi:
buntu@ubuntu:~/supla-docker$ sudo docker-compose logs --tail=20
Attaching to supla-server, supla-cloud, supla-db
supla-cloud | exec /usr/local/bin/docker-php-entrypoint: exec format error
supla-server | exec /usr/bin/server-entrypoint: exec format error
supla-db | exec /usr/local/bin/docker-entrypoint.sh: exec format error
skywalker
udalo mi sie "zlapac" cos takiego, widac ze jest chyba problem z adresem ip ....
ubuntu@ubuntu:~/supla-docker$ sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
b6872e6ac290 supla/supla-server "/usr/bin/server-ent…" 27 minutes ago Restarting (1) 59 seconds ago supla-server
e7b360f6ade8 supla/supla-cloud "docker-php-entrypoi…" 28 minutes ago Up Less than a second 0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp supla-cloud
79bc2f6573c1 i386/mariadb:5.5 "docker-entrypoint.s…" 28 minutes ago Restarting (1) 12 seconds ago supla-db
djack2017
- Been thanked: 1 time
zrób:
./supla stop
docker rm -f b6872e6ac290
docker rm -f e7b360f6ade8
docker rm -f 79bc2f6573c1
Zmień nieznacznie docker-compose.yml:
Plik .env (zmiany w trzech liniach):
następnie ./supla start
i dołącz co wyświetla polecenie
docker ps
./supla stop
version: '3'
services:
supla-cloud:
ports:
- "80:80"
- "443:443"
env_file:
- .env.default
- .env
volumes:
links:
- supla-db
depends_on:
- supla-db
supla-db:
env_file:
- .env.default
- .env
environment:
MYSQL_USER: supla
volumes:
supla-server:
env_file:
- .env.default
- .env
volumes:
ports:
- "2016:2016"
- "2015:2015"
links:
- supla-db
depends_on:
- supla-cloud
volumes:
# Where the SUPLA Cloud will be accessible? Put domain or IP address here with port.
CLOUD_DOMAIN=192.168.1.160
# Initial user account details; delete these settings after the first launch
# [email protected]
# FIRST_USER_PASSWORD=test
# Google ReCaptcha settings
RECAPTCHA_ENABLED=false
RECAPTCHA_PUBLIC_KEY=
RECAPTCHA_PRIVATE_KEY=
# Mailer settings (SMTP)
MAILER_HOST=10.0.75.1
MAILER_PORT=465
MAILER_USER=
MAILER_PASSWORD=
MAILER_ENCRYPTION=ssl
MAILER_FROM=
# If you want to be notified about some server errors, set this
ADMIN_EMAIL=
# Where to store SUPLA Cloud's data
VOLUME_DATA=./var
# On which ports the SUPLA Cloud should listen (only if standalone mode)
#PORT_HTTP=80
#PORT_HTTPS=443
REQUIRE_REGULATIONS_ACCEPTANCE=false
REQUIRE_COOKIE_POLICY_ACCEPTANCE=false
BRUTE_FORCE_AUTH_PREVENTION_ENABLED=true
ACCOUNTS_REGISTRATION_ENABLED=false
# MQTT Broker settings (you have to run the broker yourself)
MQTT_BROKER_ENABLED=false
MQTT_BROKER_HOST=
MQTT_BROKER_PORT=8883
MQTT_BROKER_TLS=true
MQTT_BROKER_USERNAME=
MQTT_BROKER_PASSWORD=
MQTT_BROKER_CLIENT_ID=
# These options protect your application
DB_PASSWORD=QE4YQHs7KE6YMdZd0OyddQz8qrgTJOJa
SECRET=eE17OTo4knfpC3x7bnXv7iSP1JUSoEhv
COMPOSE_PROJECT_NAME=supla
COMPOSE_PATH_SEPARATOR=:
COMPOSE_FILE=docker-compose.yml
docker ps
skywalker
po zmianach docker ps wyswietla podobnie:
4e957dcf897d supla/supla-server "/usr/bin/server-ent…" 56 seconds ago Restarting (1) 11 seconds ago supla-server
d0046a3cf27e supla/supla-cloud "docker-php-entrypoi…" About a minute ago Restarting (1) 3 seconds ago supla-cloud
7a5c7832c455 i386/mariadb:5.5 "docker-entrypoint.s…" About a minute ago Restarting (1) 12 seconds ago supla-db
skywalker
problem rozwiązany pomogły następujące zmiany w pliku .env:
services:
supla-cloud:
image: supla/supla-cloud:arm32v7
supla-db:
image: image: mariadb:10.6.4-focal
supla-server:
image: supla/supla-server:arm32v7
Ps. rozwiązanie problemu podejrzałem tutaj viewtopic.php?t=3218&start=50
dzieki fracz
services:
supla-cloud:
supla-db:
supla-server:
dzieki fracz
klimasstudio
A powiedz czy problem z instalacją docker compose moja podpowiedź z instalacją portainera rozwiązała Twój problem ?
Więc chodź OSUPLUJE Ci dom
lukaszek
Jak rozumiem wpierw trzeba zainstalować debiana a następnie jak w instrukcji ?
