To czekam jak kiedyś to rozpracujeszvajera wrote: Sun Nov 16, 2025 11:00 amJest to na 100% możliwe. Ciekawy pomysł - nie wpadłbym na toKuba.DeX wrote: Sun Nov 16, 2025 7:17 amSprawdzałeś czy jest możliwość zmiany "temperatur komfortu" przez bramkę? To te ikonki z ogniem i sniegiem. Myślę o wykorzystaniu tego jako termostatu do pieca z sygnalizacją załączenia (tak jak obecnie w Euroster 2006TX, zapala siejak grzeje)
Kuba.DeX
- Has thanked: 291 times
- Been thanked: 161 times
Tu nie ma nic do rozpracowywania - nawet w tej chwili możesz to samemu ustawić:
tu masz numery i typy atrybutów:
m.deviceAddCustomCluster("customSonoffSnzb02d", {
attributes: {
comfortTemperatureMax: {ID: 0x0003, type: Zcl.DataType.INT16},
comfortTemperatureMin: {ID: 0x0004, type: Zcl.DataType.INT16},
comfortHumidityMin: {ID: 0x0005, type: Zcl.DataType.UINT16},
comfortHumidityMax: {ID: 0x0006, type: Zcl.DataType.UINT16},
temperatureUnits: {ID: 0x0007, type: Zcl.DataType.UINT16},
: {ID: 0x2003, type: Zcl.DataType.INT16},
humidityCalibration: {ID: 0x2004, type: Zcl.DataType.INT16},
m.numeric<"customSonoffSnzb02d", SonoffSnzb02d>({
cluster: "customSonoffSnzb02d",
attribute: "comfortTemperatureMin",
description:
"Minimum temperature that is considered comfortable. The device will display ❄️ when the temperature is lower than this value. Note: wake up the device by pressing the button on the back before changing this value.",
valueMin: -10,
valueMax: 60,
scale: 100,
valueStep: 0.1,
unit: "°C",
attribute: "comfortTemperatureMax",
description:
"Maximum temperature that is considered comfortable. The device will display 🔥 when the temperature is higher than this value. Note: wake up the device by pressing the button on the back before changing this value.",
valueMin: -10,
valueMax: 60,
scale: 100,
valueStep: 0.1,
unit: "°C",
attribute: "comfortHumidityMin",
description:
"Minimum relative humidity that is considered comfortable. The device will display â€ď¸Ź when the humidity is lower than this value. Note: wake up the device by pressing the button on the back before changing this value.",
valueMin: 5,
valueMax: 95,
scale: 100,
valueStep: 0.1,
unit: "%",
attribute: "comfortHumidityMax",
description:
"Maximum relative humidity that is considered comfortable. The device will display đź’§ when the humidity is higher than this value. Note: wake up the device by pressing the button on the back before changing this value.",
valueMin: 5,
valueMax: 95,
scale: 100,
valueStep: 0.1,
unit: "%",
m.enumLookup<"customSonoffSnzb02d", SonoffSnzb02d>({
lookup: {celsius: 0, fahrenheit: 1},
attribute: "temperatureUnits",
description:
"The unit of the temperature displayed on the device screen. Note: wake up the device by pressing the button on the back before changing this value.",
attribute: "temperatureCalibration",
description: "Offset to add/subtract to the reported temperature",
valueMin: -50,
valueMax: 50,
scale: 100,
valueStep: 0.1,
unit: "°C",
attribute: "humidityCalibration",
description: "Offset to add/subtract to the reported relative humidity",
valueMin: -50,
valueMax: 50,
scale: 100,
valueStep: 0.1,
unit: "%",
Bramka ma local actions - łącznie z warunkowaniem, więc wszystko możesz ustawić na urządzeniu, np.:trochę upośledzony termostat, bo zmienić można tylko przez reakcje tak naprawdę a nie z urządzenia jak w przypadku tego z a), ale jako informacja w sumie starczy
gdy temperatura termometru spadnie < 19°C, to włącz przekaźnik od pieca.
Cała ta operacja będzie realizowana lokalnie w obrębie bramki.
Kuba.DeX
No, ale chodzi o to, że jak użytkownik by chciał zmienić temperaturę to już nie kliknie przycisku na urządzeniu i będzie miałvajera wrote: Sun Nov 16, 2025 4:57 pmBramka ma local actions - łącznie z warunkowaniem, więc wszystko możesz ustawić na urządzeniu, np.:Kuba.DeX wrote: Sun Nov 16, 2025 4:02 pm trochę upośledzony termostat, bo zmienić można tylko przez reakcje tak naprawdę a nie z urządzenia jak w przypadku tego z a), ale jako informacja w sumie starczy
Dzieki za atrybuty, pogrzebie sobie
Możesz obok termometru umieścić bateryjny przycisk Zigbee i poprzypisywać mu różne funkcje - też na bazie lokalnych reakcjiKuba.DeX wrote: Sun Nov 16, 2025 5:09 pm No, ale chodzi o to, że jak użytkownik by chciał zmienić temperaturę to już nie kliknie przycisku na urządzeniu i będzie miał![]()
Have funDzieki za atrybuty, pogrzebie sobie
Kuba.DeX
Ale lokalnymi akcjami nie zmienisz chyba atrybutów (?) tak, żeby ikonka odpowiadała nowym nastawom ani temperatury-warunku zadanej w innej akcjivajera wrote: Sun Nov 16, 2025 5:25 pmMożesz obok termometru umieścić bateryjny przycisk Zigbee i poprzypisywać mu różne funkcje - też na bazie lokalnych reakcjiKuba.DeX wrote: Sun Nov 16, 2025 5:09 pm No, ale chodzi o to, że jak użytkownik by chciał zmienić temperaturę to już nie kliknie przycisku na urządzeniu i będzie miał![]()
- Has thanked: 135 times
Jeśli macie tam jakiś panel, który jest lub udaje termostat, to można go w cloud ustawić jako termostat nadrzędny i wtedy nastawy są ustawiane na podrzędny.
Tak to działa w Auratonie
Tak się właśnie zastanawiałem, czy można by to wykorzystać - to jest w sumie to, o co pytał @zzrr.klew wrote: Sun Nov 16, 2025 7:37 pm Jeśli macie tam jakiś panel, który jest lub udaje termostat, to można go w cloud ustawić jako termostat nadrzędny i wtedy nastawy są ustawiane na podrzędny.
Będzie działać normalnie. U mnie doskonale spisuje się jako termostat nadrzędny ten od Auratona https://manuals.auraton.pl/manuals/heat-monitor-supla/ - działa (przynajmniej na razie) tylko w obrębie bramki (boxa). Ale w Z2S w zasadzie byłoby to samo.
Do tego można wykorzystać nawet ten ścienny, którego zdjęcia pokazywałeś. W ostateczności będzie "tykał" przekaźnikami...
Przy próbie ustawienia termostatu nadrzędnego dostaje komunikat błędu - "oba urządzenia muszą być w tej samej lokalizacji" - jest jakiś powód takiego ograniczenia (są w tym samym urządzeniu)?klew wrote: Sun Nov 16, 2025 7:37 pm Jeśli macie tam jakiś panel, który jest lub udaje termostat, to można go w cloud ustawić jako termostat nadrzędny i wtedy nastawy są ustawiane na podrzędny.
Termostat nadrzędny i tak w apce "zjada" podrzędne (można je podejrzeć wchodząc w termostat nadrzędny).vajera wrote: Sun Nov 16, 2025 9:26 pmPrzy próbie ustawienia termostatu nadrzędnego dostaje komunikat błędu - "oba urządzenia muszą być w tej samej lokalizacji" - jest jakiś powód takiego ograniczenia (są w tym samym urządzeniu)?klew wrote: Sun Nov 16, 2025 7:37 pm Jeśli macie tam jakiś panel, który jest lub udaje termostat, to można go w cloud ustawić jako termostat nadrzędny i wtedy nastawy są ustawiane na podrzędny.
Także inne lokalizacje i tak by tutaj nic nie wnosiły
