Has thanked: 291 times
Cześć,
posiadaczy głowic termostatycznych Zigbee chętnych do udziału w testach proszę o ponowne wrzucenie tutaj danych:
producent::model,
ewentualnie log że skanera.
Tylko nie demontujcie tych z grzejników bo zimno na dworze :D
mariomar
To może na początek Avatto TRV06 https://www.zigbee2mqtt.io/devices/AVATTO_TRV06.html
_TZE284_o3x45p96::TS0601
LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
Smart Radioator Thermostat
ME 167
Using 'COM13' as serial port.
Showing logs:
[22:15:51][ 47258][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[22:15:51][ 47260][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[22:15:52][ 47780][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x2f05)
[22:15:52][ 47781][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x80
[22:15:52][ 47781][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0x2f05), ieee_addr (0xa4):(0xc1):(0x38):(0x88):(0x1):(0x3c):(0xc1):(0xa1)
[22:15:52][ 47782][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x2f05), ieee_addr (0xa4):(0xc1):(0x38):(0x88):(0x1):(0x3c):(0xc1):(0xa1)
[22:15:52][ 47828][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
[22:15:52][ 47828][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0x2f05
[22:15:52][ 47901][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[22:15:52][ 47901][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x2f05), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0
[22:15:52][ 47902][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[22:15:52][ 48030][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[22:15:52][ 48113][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[22:15:52][ 48113][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2f05) src endpoint(1) to dst endpoint(1) cluster(0x0)
[22:15:52][ 48114][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[22:15:52][ 48115][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[22:15:52][ 48530][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
[22:15:52][ 48531][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[22:15:53][ 48678][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[22:15:53][ 48679][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2f05) src endpoint(1) to dst endpoint(1) cluster(0x0)
[22:15:53][ 48679][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[22:15:53][ 48680][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "_TZE200_9xfjixap"
[22:15:53][ 49031][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
[22:15:53][ 49032][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[22:15:53][ 49117][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[22:15:53][ 49118][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2f05) src endpoint(1) to dst endpoint(1) cluster(0x0)
[22:15:53][ 49118][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[22:15:53][ 49119][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[22:15:53][ 49240][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[22:15:53][ 49286][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0xf54f) is open for 180 seconds
[22:15:53][ 49532][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
[22:15:53][ 49533][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[22:15:54][ 49650][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[22:15:54][ 49651][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2f05) src endpoint(1) to dst endpoint(1) cluster(0x0)
[22:15:54][ 49651][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(67)
[22:15:54][ 49652][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "67"
[22:15:54][ 50033][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
[22:15:54][ 50034][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[22:15:54][ 50214][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[22:15:54][ 50215][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2f05) src endpoint(1) to dst endpoint(1) cluster(0x0)
[22:15:54][ 50216][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[22:15:54][ 50216][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "TS0601"
[22:15:54][ 50534][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
[22:15:54][ 50535][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[22:15:55][ 50777][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[22:15:55][ 50777][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2f05) src endpoint(1) to dst endpoint(1) cluster(0x0)
[22:15:55][ 50778][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[22:15:55][ 50779][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "3"
[22:15:55][ 51035][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
[22:15:55][ 51036][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
[22:15:55][ 51090][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[22:15:55][ 51091][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2f05) src endpoint(1) to dst endpoint(1) cluster(0x0)
[22:15:55][ 51091][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[22:15:55][ 51092][I][ZigbeeGateway.cpp:355] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[22:15:55][ 51260][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:55][ 51260][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:55][ 51261][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[22:15:55][ 51261][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:55][ 51262][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xaf
[22:15:55][ 51262][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[22:15:55][ 51263][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[22:15:55][ 51263][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:55][ 51263][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[22:15:55][ 51264][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x2
[22:15:55][ 51385][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:55][ 51385][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:55][ 51386][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[22:15:55][ 51386][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:55][ 51387][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb0
[22:15:55][ 51387][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x3
[22:15:55][ 51388][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[22:15:55][ 51388][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:55][ 51389][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[22:15:55][ 51389][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[22:15:55][ 51507][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:55][ 51508][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:55][ 51508][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[22:15:55][ 51509][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:55][ 51509][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb1
[22:15:55][ 51509][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x4
[22:15:55][ 51510][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[22:15:55][ 51510][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:55][ 51511][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[22:15:55][ 51511][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[22:15:55][ 51512][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[22:15:55][ 51512][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:55][ 51512][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x32
[22:15:55][ 51537][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[22:15:56][ 51629][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[22:15:56][ 51630][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x2f05) src endpoint(1) to dst endpoint(1) cluster(0x0)
[22:15:56][ 51630][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[22:15:56][ 51633][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:56][ 51634][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:56][ 51634][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[22:15:56][ 51634][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:56][ 51635][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb2
[22:15:56][ 51635][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x5
[22:15:56][ 51636][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[22:15:56][ 51636][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:56][ 51637][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[22:15:56][ 51637][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[22:15:56][ 51638][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[22:15:56][ 51638][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:56][ 51639][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xbe
[22:15:56][ 51754][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:56][ 51754][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:56][ 51755][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[22:15:56][ 51755][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:56][ 51755][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb3
[22:15:56][ 51756][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x7
[22:15:56][ 51756][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[22:15:56][ 51757][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:56][ 51757][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[22:15:56][ 51758][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[22:15:56][ 51876][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:56][ 51877][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:56][ 51877][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 31
[22:15:56][ 51878][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:56][ 51878][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb4
[22:15:56][ 51878][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1c
[22:15:56][ 51879][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x0
[22:15:56][ 51879][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:56][ 51880][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x19
[22:15:56][ 51880][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
[22:15:56][ 51881][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x6
[22:15:56][ 51881][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:56][ 51882][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[22:15:56][ 51882][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xa] = 0xd2
[22:15:56][ 51882][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xb] = 0x8
[22:15:56][ 51883][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xc] = 0x0
[22:15:56][ 51883][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xd] = 0x0
[22:15:56][ 51884][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xe] = 0xa0
[22:15:56][ 51884][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xf] = 0xc
[22:15:56][ 51885][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x10] = 0x0
[22:15:56][ 51885][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x11] = 0x0
[22:15:56][ 51886][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x12] = 0xd2
[22:15:56][ 51886][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x13] = 0xe
[22:15:56][ 51886][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x14] = 0x0
[22:15:56][ 51887][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x15] = 0x0
[22:15:56][ 51887][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x16] = 0xa0
[22:15:56][ 51888][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x17] = 0x12
[22:15:56][ 51888][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x18] = 0x0
[22:15:56][ 51889][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x19] = 0x0
[22:15:56][ 51889][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1a] = 0xd2
[22:15:56][ 51890][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1b] = 0x16
[22:15:56][ 51890][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1c] = 0x0
[22:15:56][ 51891][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1d] = 0x0
[22:15:56][ 51891][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1e] = 0xa0
[22:15:56][ 51999][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:56][ 52000][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:56][ 52000][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 31
[22:15:56][ 52001][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:56][ 52001][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb5
[22:15:56][ 52002][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1d
[22:15:56][ 52002][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x0
[22:15:56][ 52002][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:56][ 52003][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x19
[22:15:56][ 52003][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x2
[22:15:56][ 52004][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x6
[22:15:56][ 52004][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:56][ 52005][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[22:15:56][ 52005][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xa] = 0xd2
[22:15:56][ 52005][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xb] = 0x8
[22:15:56][ 52006][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xc] = 0x0
[22:15:56][ 52006][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xd] = 0x0
[22:15:56][ 52007][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xe] = 0xa0
[22:15:56][ 52007][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xf] = 0xc
[22:15:56][ 52008][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x10] = 0x0
[22:15:56][ 52008][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x11] = 0x0
[22:15:56][ 52009][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x12] = 0xd2
[22:15:56][ 52009][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x13] = 0xe
[22:15:56][ 52010][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x14] = 0x0
[22:15:56][ 52010][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x15] = 0x0
[22:15:56][ 52010][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x16] = 0xa0
[22:15:56][ 52011][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x17] = 0x12
[22:15:56][ 52011][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x18] = 0x0
[22:15:56][ 52012][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x19] = 0x0
[22:15:56][ 52012][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1a] = 0xd2
[22:15:56][ 52013][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1b] = 0x16
[22:15:56][ 52013][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1c] = 0x0
[22:15:56][ 52014][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1d] = 0x0
[22:15:56][ 52014][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1e] = 0xa0
[22:15:56][ 52037][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 12037
[22:15:56][ 52118][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 12037, endpoints count 1
[22:15:56][ 52118][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[22:15:56][ 52124][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:56][ 52125][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:56][ 52125][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 31
[22:15:56][ 52126][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:56][ 52126][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb6
[22:15:56][ 52127][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1e
[22:15:56][ 52127][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x0
[22:15:56][ 52127][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:56][ 52128][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x19
[22:15:56][ 52128][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x3
[22:15:56][ 52129][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x6
[22:15:56][ 52129][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:56][ 52130][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[22:15:56][ 52130][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xa] = 0xd2
[22:15:56][ 52131][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xb] = 0x8
[22:15:56][ 52131][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xc] = 0x0
[22:15:56][ 52131][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xd] = 0x0
[22:15:56][ 52132][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xe] = 0xa0
[22:15:56][ 52132][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xf] = 0xc
[22:15:56][ 52133][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x10] = 0x0
[22:15:56][ 52133][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x11] = 0x0
[22:15:56][ 52134][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x12] = 0xd2
[22:15:56][ 52134][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x13] = 0xe
[22:15:56][ 52135][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x14] = 0x0
[22:15:56][ 52135][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x15] = 0x0
[22:15:56][ 52135][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x16] = 0xa0
[22:15:56][ 52136][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x17] = 0x12
[22:15:56][ 52136][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x18] = 0x0
[22:15:56][ 52137][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x19] = 0x0
[22:15:56][ 52137][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1a] = 0xd2
[22:15:56][ 52138][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1b] = 0x16
[22:15:56][ 52138][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1c] = 0x0
[22:15:56][ 52139][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1d] = 0x0
[22:15:56][ 52139][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1e] = 0xa0
[22:15:56][ 52248][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 12037, endpoint # 1
[22:15:56][ 52249][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 2
[22:15:56][ 52249][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 4
[22:15:56][ 52250][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 5
[22:15:56][ 52250][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 61184
[22:15:56][ 52251][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 0
[22:15:56][ 52251][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[22:15:56][ 52252][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 2, id 10
[22:15:56][ 52264][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:56][ 52264][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:56][ 52265][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 31
[22:15:56][ 52265][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:56][ 52266][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb7
[22:15:56][ 52266][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1f
[22:15:56][ 52266][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x0
[22:15:56][ 52267][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:56][ 52267][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x19
[22:15:56][ 52268][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x4
[22:15:56][ 52268][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x6
[22:15:56][ 52269][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:56][ 52269][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[22:15:56][ 52269][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xa] = 0xd2
[22:15:56][ 52270][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xb] = 0x8
[22:15:56][ 52270][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xc] = 0x0
[22:15:56][ 52271][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xd] = 0x0
[22:15:56][ 52271][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xe] = 0xa0
[22:15:56][ 52272][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xf] = 0xc
[22:15:56][ 52272][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x10] = 0x0
[22:15:56][ 52273][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x11] = 0x0
[22:15:56][ 52273][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x12] = 0xd2
[22:15:56][ 52274][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x13] = 0xe
[22:15:56][ 52274][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x14] = 0x0
[22:15:56][ 52274][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x15] = 0x0
[22:15:56][ 52275][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x16] = 0xa0
[22:15:56][ 52275][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x17] = 0x12
[22:15:56][ 52276][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x18] = 0x0
[22:15:56][ 52276][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x19] = 0x0
[22:15:56][ 52277][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1a] = 0xd2
[22:15:56][ 52277][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1b] = 0x16
[22:15:56][ 52278][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1c] = 0x0
[22:15:56][ 52278][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1d] = 0x0
[22:15:56][ 52279][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1e] = 0xa0
[22:15:56][ 52387][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[22:15:56][ 52388][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x2f05), src_endpoint(1) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84
[22:15:56][ 52389][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[22:15:56][ 52402][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[22:15:57][ 52403][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x2f05), src_endpoint(1) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
[22:15:57][ 52403][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[22:15:57][ 52417][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[22:15:57][ 52417][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x2f05), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0xc) with status 0x84
[22:15:57][ 52418][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[22:15:57][ 52432][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[22:15:57][ 52432][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x2f05), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[22:15:57][ 52433][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[22:15:57][ 52447][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[22:15:57][ 52447][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[22:15:57][ 52448][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[22:15:57][ 52448][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[22:15:57][ 52449][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 9 size: 2
[22:15:57][ 52449][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[22:15:57][ 52449][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[22:15:57][ 52450][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x2f05, 0x2f05, 0x0, 0x0
[22:15:57][ 52450][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[22:15:57][ 52464][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[22:15:57][ 52464][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x2f05), src_endpoint(1) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[22:15:57][ 52465][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[22:15:57][ 52480][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:57][ 52481][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:57][ 52481][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 31
[22:15:57][ 52482][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:57][ 52482][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb8
[22:15:57][ 52483][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x20
[22:15:57][ 52483][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x0
[22:15:57][ 52484][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:57][ 52484][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x19
[22:15:57][ 52484][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x5
[22:15:57][ 52485][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x6
[22:15:57][ 52485][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:57][ 52486][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[22:15:57][ 52486][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xa] = 0xd2
[22:15:57][ 52487][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xb] = 0x8
[22:15:57][ 52487][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xc] = 0x0
[22:15:57][ 52487][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xd] = 0x0
[22:15:57][ 52488][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xe] = 0xa0
[22:15:57][ 52488][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xf] = 0xc
[22:15:57][ 52489][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x10] = 0x0
[22:15:57][ 52489][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x11] = 0x0
[22:15:57][ 52490][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x12] = 0xd2
[22:15:57][ 52490][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x13] = 0xe
[22:15:57][ 52491][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x14] = 0x0
[22:15:57][ 52491][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x15] = 0x0
[22:15:57][ 52491][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x16] = 0xa0
[22:15:57][ 52492][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x17] = 0x12
[22:15:57][ 52492][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x18] = 0x0
[22:15:57][ 52493][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x19] = 0x0
[22:15:57][ 52493][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1a] = 0xd2
[22:15:57][ 52494][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1b] = 0x16
[22:15:57][ 52494][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1c] = 0x0
[22:15:57][ 52495][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1d] = 0x0
[22:15:57][ 52495][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1e] = 0xa0
[22:15:57][ 52604][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:57][ 52604][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:57][ 52605][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 31
[22:15:57][ 52605][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:57][ 52606][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb9
[22:15:57][ 52606][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x21
[22:15:57][ 52607][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x0
[22:15:57][ 52607][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:57][ 52607][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x19
[22:15:57][ 52608][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x6
[22:15:57][ 52608][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x6
[22:15:57][ 52609][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:57][ 52609][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[22:15:57][ 52610][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xa] = 0xd2
[22:15:57][ 52610][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xb] = 0x8
[22:15:57][ 52611][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xc] = 0x0
[22:15:57][ 52611][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xd] = 0x0
[22:15:57][ 52612][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xe] = 0xa0
[22:15:57][ 52612][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xf] = 0xc
[22:15:57][ 52612][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x10] = 0x0
[22:15:57][ 52613][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x11] = 0x0
[22:15:57][ 52613][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x12] = 0xd2
[22:15:57][ 52614][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x13] = 0xe
[22:15:57][ 52614][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x14] = 0x0
[22:15:57][ 52615][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x15] = 0x0
[22:15:57][ 52615][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x16] = 0xa0
[22:15:57][ 52616][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x17] = 0x12
[22:15:57][ 52616][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x18] = 0x0
[22:15:57][ 52616][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x19] = 0x0
[22:15:57][ 52617][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1a] = 0xd2
[22:15:57][ 52617][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1b] = 0x16
[22:15:57][ 52618][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1c] = 0x0
[22:15:57][ 52618][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1d] = 0x0
[22:15:57][ 52619][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1e] = 0xa0
[22:15:57][ 52726][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:57][ 52727][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:57][ 52727][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 31
[22:15:57][ 52728][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:57][ 52728][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xba
[22:15:57][ 52729][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x22
[22:15:57][ 52729][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x0
[22:15:57][ 52730][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:57][ 52730][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x19
[22:15:57][ 52731][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x7
[22:15:57][ 52731][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x6
[22:15:57][ 52731][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:57][ 52732][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[22:15:57][ 52732][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xa] = 0xd2
[22:15:57][ 52733][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xb] = 0x8
[22:15:57][ 52733][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xc] = 0x0
[22:15:57][ 52734][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xd] = 0x0
[22:15:57][ 52734][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xe] = 0xa0
[22:15:57][ 52735][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0xf] = 0xc
[22:15:57][ 52735][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x10] = 0x0
[22:15:57][ 52735][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x11] = 0x0
[22:15:57][ 52736][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x12] = 0xd2
[22:15:57][ 52736][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x13] = 0xe
[22:15:57][ 52737][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x14] = 0x0
[22:15:57][ 52737][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x15] = 0x0
[22:15:57][ 52738][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x16] = 0xa0
[22:15:57][ 52738][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x17] = 0x12
[22:15:57][ 52739][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x18] = 0x0
[22:15:57][ 52739][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x19] = 0x0
[22:15:57][ 52740][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1a] = 0xd2
[22:15:57][ 52740][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1b] = 0x16
[22:15:57][ 52740][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1c] = 0x0
[22:15:57][ 52741][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1d] = 0x0
[22:15:57][ 52741][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1e] = 0xa0
[22:15:57][ 52848][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:57][ 52849][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:57][ 52849][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[22:15:57][ 52850][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:57][ 52850][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xbb
[22:15:57][ 52851][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x23
[22:15:57][ 52851][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x5
[22:15:57][ 52852][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:57][ 52852][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[22:15:57][ 52852][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[22:15:57][ 52971][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:57][ 52972][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:57][ 52972][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[22:15:57][ 52973][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:57][ 52973][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xbc
[22:15:57][ 52973][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x24
[22:15:57][ 52974][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[22:15:57][ 52974][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:57][ 52975][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[22:15:57][ 52975][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[22:15:57][ 53094][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:57][ 53095][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:57][ 53095][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[22:15:57][ 53096][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:57][ 53096][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xbd
[22:15:57][ 53097][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x27
[22:15:57][ 53097][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x1
[22:15:57][ 53097][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:57][ 53098][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[22:15:57][ 53098][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[22:15:57][ 53217][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:57][ 53218][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x2f05
[22:15:57][ 53218][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[22:15:57][ 53219][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:57][ 53219][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xbe
[22:15:57][ 53220][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2f
[22:15:57][ 53220][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[22:15:57][ 53220][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[22:15:57][ 53221][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[22:15:57][ 53221][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[22:15:57][ 53222][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[22:15:57][ 53222][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[22:15:57][ 53223][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[22:15:57][ 53340][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:57][ 53340][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 36 from address 0x2f05
[22:15:57][ 53341][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 2
[22:15:57][ 53341][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0xbf
[22:15:57][ 53342][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x0
[22:15:58][ 54326][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[22:15:58][ 54326][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 17 from address 0x2f05
[22:15:58][ 54327][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 3
[22:15:58][ 54327][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[22:15:58][ 54328][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x70
[22:15:58][ 54328][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x41
[22:16:00][ 56163][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[22:16:00][ 56164][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[22:16:00][ 56164][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[22:16:00][ 56165][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[22:16:00][ 56165][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 2 size: 2
[22:16:00][ 56165][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[22:16:00][ 56166][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[22:16:00][ 56166][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x2f05, 0x2f05, 0x0, 0x0
[22:16:00][ 56166][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[22:16:04]
Serial port closed!
Been thanked: 31 times
vajera wrote: Tue Feb 18, 2025 5:35 pm Cześć,
producent::model,
Nawet nie wiesz, jak na to czekałem. Głupio mi było pytać wcześniej, bo widziałem ile rzeczy teraz robisz z tą bramką. Na bieżąco obserwuję też zmiany w kodzie i jestem pod wrażeniem :)
W każdym razie pierwsza głowica. Przedstawia się jako: TS0601 _TZE200_cpmgn2cf (logi ze skanera /ver. 1.3./ w załączniku)
Kiedyś już się nią bawiliśmy (na samym początku). Tak wygląda:
ale wiem, że kilka innych, mimo że wyglądają inaczej, to przedstawia się tak samo.
Później dodam kolejną głowicę.
lukasz06
Has thanked: 46 times
Been thanked: 21 times
Tak się przymierzam do tej, rozumiem, że jeśli jest tu to się nadaje?
https://www.zigbee2mqtt.io/devices/TRV801Z.html
I kolejna. Ta z kolei przedstawia się jako: TS0601 _TZE284_o3x45p96
Tak wygląda:
https://pl.aliexpress.com/item/1005006439482487.html
Logi w załączniku. Nie chciała dużo gadać. Dopiero, jak zacząłem nią kręcić, to wypluła te wszystkie "Payload" ;)
lukasz06 wrote: Tue Feb 18, 2025 11:21 pm Tak się przymierzam do tej, rozumiem, że jeśli jest tu to się nadaje?
No risk no fun ;)
walanar1
Proszę o dodanie głowicy termostatycznej
https://www.rtx24.pl/glowica-termostat- ... -1144.html
walanar1 wrote: Wed Feb 19, 2025 11:47 am Proszę o dodanie głowicy termostatycznej
Pierwszy post.
walanar1
Producent RTX
model ZRT2
